[Swift-commit] r4082 - in SwiftApps/SwiftR: . Swift Swift/R Swift/tests
Thu Feb 10 13:15:45 CST 2011
Author: tga
Date: 2011-02-10 13:15:41 -0600 (Thu, 10 Feb 2011)
New Revision: 4082
Added:
   SwiftApps/SwiftR/Swift/R/Bench.R
Modified:
   SwiftApps/SwiftR/IMMEDIATE-TODO
   SwiftApps/SwiftR/Makefile
   SwiftApps/SwiftR/Swift/NAMESPACE
   SwiftApps/SwiftR/Swift/R/TestFramework.R
   SwiftApps/SwiftR/Swift/R/Tests.R
   SwiftApps/SwiftR/Swift/tests/runtests.R
Log:
Added initial benchmark which simply does a configurable sleep.
Added infrastructure to allow easy construction of parameterized performance
tests.
Modified: SwiftApps/SwiftR/IMMEDIATE-TODO
--- SwiftApps/SwiftR/IMMEDIATE-TODO	2011-02-10 17:40:02 UTC (rev 4081)
+++ SwiftApps/SwiftR/IMMEDIATE-TODO	2011-02-10 19:15:41 UTC (rev 4082)
@@ -77,6 +77,10 @@
 - user testing in general (ssh, pbs, sge)
 * SGE testing: ranger, siraf (low priority)
+MID:
+* Cleanup ssh worker processes: add a watchdog that detects when worker.pl has
+    gone away
 LOW: (unless needed by immediate OpenMx app or test)
 - complete sf compat functions (sapply, lapply -> for openMx, based on usage)
Modified: SwiftApps/SwiftR/Makefile
--- SwiftApps/SwiftR/Makefile	2011-02-10 17:40:02 UTC (rev 4081)
+++ SwiftApps/SwiftR/Makefile	2011-02-10 19:15:41 UTC (rev 4082)
@@ -38,7 +38,7 @@
 	R CMD check $(TBALL)
 test: install
-	./Swift/tests/runtests.R
+	Rscript Swift/tests/runtests.R
 clean:
 	rm -rf Swift/inst/swift/*
Modified: SwiftApps/SwiftR/Swift/NAMESPACE
--- SwiftApps/SwiftR/Swift/NAMESPACE	2011-02-10 17:40:02 UTC (rev 4081)
+++ SwiftApps/SwiftR/Swift/NAMESPACE	2011-02-10 19:15:41 UTC (rev 4082)
@@ -11,12 +11,17 @@
 export(swiftRemoveAll)
 export(runAllSwiftTests)
-export(basicSwiftTest)
-exportPattern("^swiftTest")
 export(makeTestGroup)
+export(makeParamTestGroup)
 export(runTestGroup)
 export(runTestSuite)
+export(printTestGroup)
+export(mkTest)
+export(basicSwiftTest)
+exportPattern("^swiftTest")
 exportPattern("^testGroup")
 export(swiftTestSuite)
-export(printTestGroup)
-export(mkTest)
+export(mkPerfTest)
+export(doPerfTest)
Added: SwiftApps/SwiftR/Swift/R/Bench.R
--- SwiftApps/SwiftR/Swift/R/Bench.R	                        (rev 0)
+++ SwiftApps/SwiftR/Swift/R/Bench.R	2011-02-10 19:15:41 UTC (rev 4082)
@@ -0,0 +1,75 @@
+swiftTest_6.1.1 <- function () {
+    swiftTest_6.1(2, 20)
+sleeper <- function(delay,ncalls) {
+  options(swift.initialexpr="initVar3 <- 123; initVar4 <- 100");
+  timed <- function(delay) { Sys.sleep(delay); delay }
+  args=list(delay)
+  arglist = rep(list(args),ncalls)
+  cat("\nTest of swiftapply(delay,arglist)\n")
+  startTime = proc.time()[["elapsed"]]
+  swiftres = swiftapply(timed,arglist)
+  endTime = proc.time()[["elapsed"]]
+  runTime <- endTime - startTime
+  cat("\n\n ===> Ran for ",runTime," seconds.\n\n")
+  cat("Swift result:\n")
+  print(swiftres[[1]])
+  if(identical(delay,swiftres[[1]])) {
+    cat("\n==> sleeper passed\n")
+    return (TRUE)
+  } else {
+    cat("\n==> sleeper FAILED !!!!!\n")
+    return (FALSE)
+id <- function () { return (1) }
+mkPerfTest <- function() {
+    # Have an initial test that will block until
+    # resources are ready
+    warmUpGroup <- makeTestGroup(
+        name="Wait for server to start",
+        tests=list(mkTest(id)))
+    perfTestGroup1 <- makeParamTestGroup(
+        name="1 - basic performance test",
+        f=sleeper,
+        allargs=list(
+            list(1, 10),
+            list(1, 20),
+            list(1, 50),
+            list(1, 100),
+            list(2, 10),
+            list(2, 20),
+            list(2, 50),
+            list(2, 100),
+            list(3, 10),
+            list(3, 20),
+            list(3, 50),
+            list(3, 100),
+            list(4, 10),
+            list(4, 20),
+            list(4, 50),
+            list(4, 100)))
+    swiftTestSuite <- list(
+            setup=function () { initSwiftTestOptions();
+                               swiftInit() }, # swiftInit controlled via options
+            tests=list(warmUpGroup, perfTestGroup1),
+            teardown=function () { swiftShutdown() })
+    return (swiftTestSuite)
+doPerfTest <- function () {
+    runTestSuite(mkPerfTest())
Modified: SwiftApps/SwiftR/Swift/R/TestFramework.R
--- SwiftApps/SwiftR/Swift/R/TestFramework.R	2011-02-10 17:40:02 UTC (rev 4081)
+++ SwiftApps/SwiftR/Swift/R/TestFramework.R	2011-02-10 19:15:41 UTC (rev 4082)
@@ -3,23 +3,53 @@
 mkTest <- function (f) {
     test = list()
-    test$name = substitute(f)
+    test$name = deparse(substitute(f))
     test$fun = f
     test$passed = NULL
+    test$time <- NULL
     return (test)
-makeTestGroup <- function (name, tlist, init=NULL) {
+makeTestGroup <- function (name, tests, setup=NULL, teardown=NULL) {
     group = list()
-    group$init = init
-    group$tests = tlist
+    group$name <- name
+    group$setup = setup
+    group$tests = tests
+    group$teardown = teardown
     return (group)
+makeParamTestGroup <- function (name, f, allargs,
+                setup=NULL, teardown=NULL) {
+    buildClosure <- function (f, args) {
+        force(f)
+        force(args)
+        return (function () { do.call(f, args) })
+    fname = deparse(substitute(f))
+    tests = list()
+    for (args in allargs) {
+        test = list()
+        args <- as.list(args)
+        test$name = paste(fname, substring(deparse(args), 5) , sep="")
+        test$fun <- buildClosure(f, args)
+        test$args <- args # Store for later analysis
+        test$passed <- NULL
+        test$time <- NULL
+        tests[[length(tests) + 1]] <- test
+    return (makeTestGroup(name, tests, setup, teardown))
 runTestGroup <- function (group) {
     cat("\n*** Starting test group ", group$name, "***\n")
-    if (!is.null(group$init))
-        group$init()
+    if (!is.null(group$setup))
+        group$setup()
     for (i in 1:length(group$tests)) {
         test <- group$tests[[i]]
         cat("\n== Starting test ", test$name, " ==\n")
@@ -30,6 +60,8 @@
         group$tests[[i]]$time <- runTime
+    if (!is.null(group$teardown))
+        group$teardown()
     return (group)
@@ -49,7 +81,7 @@
         if (is.null(time))
         else
-            sprintf("%.2f", time)
+            sprintf("%.2fs", time)
     for (test in group$tests) {
         cat(paste(test$name, ": ", resFmt(test$passed),
@@ -60,7 +92,8 @@
 runTestSuite <- function (suite) {
     suite$setup()
     resSuite <- lapply(suite$tests, runTestGroup)
+    suite$teardown()
     lapply(resSuite, printTestGroup)
-    suite$teardown()
-    return (NULL)
+    return (resSuite)
Modified: SwiftApps/SwiftR/Swift/R/Tests.R
--- SwiftApps/SwiftR/Swift/R/Tests.R	2011-02-10 17:40:02 UTC (rev 4081)
+++ SwiftApps/SwiftR/Swift/R/Tests.R	2011-02-10 19:15:41 UTC (rev 4082)
@@ -590,40 +590,7 @@
-swiftTest_6.1.1 <- function () {
-    swiftTest_6.1(2, 20)
-swiftTest_6.1 <- function(delay,ncalls) {
-  options(swift.initialexpr="initVar3 <- 123; initVar4 <- 100");
-  timed <- function(delay) { Sys.sleep(delay); delay }
-  args=list(delay)
-  arglist = rep(list(args),ncalls)
-  cat("\nTest of swiftapply(delay,arglist)\n")
-  startTime = proc.time()[["elapsed"]]
-  swiftres = swiftapply(timed,arglist)
-  endTime = proc.time()[["elapsed"]]
-  runTime <- endTime - startTime
-  cat("\n\n ===> Total elapsed unit test time = ",runTime," seconds.\n\n")
-  cat("Swift result:\n")
-  print(swiftres[[1]])
-  if(identical(delay,swiftres[[1]])) {
-    cat("\n==> test 6.1 passed\n")
-    return (TRUE)
-  } else {
-    cat("\n==> test 6.1 FAILED !!!!!\n")
-    return (FALSE)
 runAllSwiftTests <- function() {
@@ -649,50 +616,47 @@
-testGroup1.1 <- list( init=NULL,
+testGroup1.1 <- makeTestGroup(
     name="1.1 Sanity Check",
     tests = list(mkTest(swiftTest_1.1)))
-testGroup1.2 <- list( init=NULL,
+testGroup1.2 <- makeTestGroup(
     name="1.2 Basic Test - Adding data sets",
     tests = list(mkTest(swiftTest_1.2.1),
         mkTest(swiftTest_1.2.2), mkTest(swiftTest_1.2.3),
         mkTest(swiftTest_1.2.4)))
-testGroup1.3 <- list( init=NULL,
+testGroup1.3 <- makeTestGroup(
     name="1.3 - Export functionality",
     tests = list(mkTest(swiftTest_1.3.1),
         mkTest(swiftTest_1.3.2), mkTest(swiftTest_1.3.3),
         mkTest(swiftTest_1.3.4),  mkTest(swiftTest_1.3.5)) )
-testGroup2 <- list( init=NULL,
+testGroup2 <- makeTestGroup(
     name="2 - test matrix passing",
     tests = list(mkTest(swiftTest_2.1),
         mkTest(swiftTest_2.2)) )
-testGroup3 <- list( init=NULL,
+testGroup3 <- makeTestGroup(
     name="3 - test list element and name passing",
     tests = list(mkTest(swiftTest_3.1),
         mkTest(swiftTest_3.2)))
-testGroup4 <- list( init=NULL,
+testGroup4 <- makeTestGroup(
     name="4 - test remote R service initialization string",
     tests = list(mkTest(swiftTest_4.1),
         mkTest(swiftTest_4.2)))
-testGroup5 <- list( init=NULL,
+testGroup5 <- makeTestGroup(
     name="5 - remote R service error ",
     tests = list(mkTest(swiftTest_5.1)))
-testGroup6 <- list( init=NULL,
-    name="6 - performance tests",
-    tests = list(mkTest(swiftTest_6.1.1)))
         tests=list(testGroup1.1, testGroup2, testGroup1.2, testGroup1.3, testGroup3, testGroup4,
-            testGroup5, testGroup6),
+            testGroup5),
Modified: SwiftApps/SwiftR/Swift/tests/runtests.R
--- SwiftApps/SwiftR/Swift/tests/runtests.R	2011-02-10 17:40:02 UTC (rev 4081)
+++ SwiftApps/SwiftR/Swift/tests/runtests.R	2011-02-10 19:15:41 UTC (rev 4082)
@@ -1,4 +1,4 @@
-#!/bin/env Rscript
+#!/usr/bin/env Rscript
 library(Swift)
 #TODO: take command line options to setup options
