[Swift-commit] r5475 - branches/release-0.93/docs/userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sun Dec 25 00:09:25 CST 2011
Author: ketan
Date: 2011-12-25 00:09:25 -0600 (Sun, 25 Dec 2011)
New Revision: 5475
Modified:
   branches/release-0.93/docs/userguide/troubleshooting
   branches/release-0.93/docs/userguide/userguide.txt
Log:
troubleshooting
Modified: branches/release-0.93/docs/userguide/troubleshooting
--- branches/release-0.93/docs/userguide/troubleshooting	2011-12-25 02:45:31 UTC (rev 5474)
+++ branches/release-0.93/docs/userguide/troubleshooting	2011-12-25 06:09:25 UTC (rev 5475)
@@ -19,7 +19,7 @@
 $ export PATH=<swift-install-location>/bin:$PATH
-Note: If you are running Swift on a system where it is installed as a module, do module load swift. For instance:
+Note: If you are running Swift on a system where it is installed as a module, do module load swift. For instance, on the Beagle supercomputer, Swift is loaded as follows:
 $ module load swift
Modified: branches/release-0.93/docs/userguide/userguide.txt
--- branches/release-0.93/docs/userguide/userguide.txt	2011-12-25 02:45:31 UTC (rev 5474)
+++ branches/release-0.93/docs/userguide/userguide.txt	2011-12-25 06:09:25 UTC (rev 5475)
@@ -39,3 +39,5 @@
 include::cdm[]
 include::log-processing[]
+include::troubleshooting[]
