[Swift-commit] r5403 - in wwwdev: docs inc
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Fri Dec 9 15:37:26 CST 2011
Author: davidk
Date: 2011-12-09 15:37:25 -0600 (Fri, 09 Dec 2011)
New Revision: 5403
Modified:
   wwwdev/docs/index.php
   wwwdev/inc/footer2.php
Log:
Navigation footer had wrong link
Adjust docs a bit
Modified: wwwdev/docs/index.php
--- wwwdev/docs/index.php	2011-12-09 20:41:55 UTC (rev 5402)
+++ wwwdev/docs/index.php	2011-12-09 21:37:25 UTC (rev 5403)
@@ -56,22 +56,13 @@
 <p> </p>
-<h3>Swift Siteguide</h3>
-        This document will guide new users to run Swift in a variety of different environments.
-<br><br>
-<ul>
-        <li type="circle" style="margin-left:50px;">Trunk [<a href="../guides/trunk/siteguide/siteguide.html">html</a>] [<a href="../guides/trunk/siteguide/siteguide.pdf">pdf</a>]</li>
-        <li type="circle" style="margin-left:50px;">Latest (0.93) [<a href="../guides/release-0.93/siteguide/siteguide.html">html</a>] [<a href="../guides/release-0.93/siteguide/siteguide.pdf">pdf</a>]</li>
-</ul>
-<p> </p>
 <h3>Swift User Guide</h3>
-	The User Guide provides more detailed reference documentation and background
-	information on swift. It is assumed that the reader is already familiar with
-	the material in the Quickstart and Tutorial documents.
-<br><br>
+        The User Guide provides more detailed reference documentation and background
+        information on swift. It is assumed that the reader is already familiar with
+        the material in the Quickstart and Tutorial documents.
+<br><br>
 <ul>
+        <li type="circle" style="margin-left:50px;">Latest (0.93)
         [<a href="../guides/release-0.93/userguide/userguide.html">html</a>] [<a href="../guides/release-0.93/userguide/userguide.pdf">pdf</a>]
         </li>
@@ -79,11 +70,22 @@
         [<a href="../guides/userguide.php">html</a>] [<a href="../guides/userguide/userguide.pdf">pdf</a>]
         </li>
+        <li type="circle" style="margin-left:50px;">Trunk
           [<a href="../guides/trunk/userguide/userguide.html">html</a>] [<a href="../guides/trunk/userguide/userguide.pdf">pdf</a>]
         </li>
 </ul>
 <p> </p>
+<h3>Swift Siteguide</h3>
+        This document will guide new users to run Swift in a variety of different environments.
+<br><br>
+<ul>
+        <li type="circle" style="margin-left:50px;">Trunk [<a href="../guides/trunk/siteguide/siteguide.html">html</a>] [<a href="../guides/trunk/siteguide/siteguide.pdf">pdf</a>]</li>
+        <li type="circle" style="margin-left:50px;">Latest (0.93) [<a href="../guides/release-0.93/siteguide/siteguide.html">html</a>] [<a href="../guides/release-0.93/siteguide/siteguide.pdf">pdf</a>]</li>
+</ul>
+<p> </p>
 <h3>Search All Documentation</h3>
 <div id="cse" style="width: 100%;">Loading</div>
Modified: wwwdev/inc/footer2.php
--- wwwdev/inc/footer2.php	2011-12-09 20:41:55 UTC (rev 5402)
+++ wwwdev/inc/footer2.php	2011-12-09 21:37:25 UTC (rev 5403)
@@ -1,7 +1,7 @@
 <div id="footer">
     <ul>
 		<li><a href="../downloads/index.php">downloads</a></li>
-		<li><a href="../documentation/index.php">documentation</a></li>
+		<li><a href="../docs/index.php">documentation</a></li>
 		<li><a href="../case_studies/index.php">case studies</a></li>
 		<li><a href="../papers/index.php">papers</a></li>
 		<li><a href="../support/index.php">support</a></li>
