[Swift-commit] r5388 - wwwdev/case_studies
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Thu Dec 8 23:12:07 CST 2011
Author: wilde
Date: 2011-12-08 23:12:07 -0600 (Thu, 08 Dec 2011)
New Revision: 5388
Modified:
   wwwdev/case_studies/Glass-Structure.php
Log:
Edit Glass case study text; replace image; remove fig references
Modified: wwwdev/case_studies/Glass-Structure.php
--- wwwdev/case_studies/Glass-Structure.php	2011-12-09 01:36:03 UTC (rev 5387)
+++ wwwdev/case_studies/Glass-Structure.php	2011-12-09 05:12:07 UTC (rev 5388)
@@ -24,15 +24,20 @@
  <div class="grid_9">
 	<h3>Glass Structure Modeling</h3>
 	<p>
-This project models of aspects of glass structure at a theoretical chemistry level, by Glen Hocky and David Reichmann, Columbia University Department of Chemistry.
+This project models of aspects of glass structure at a theoretical chemistry level, by Glen Hocky and
+<a href="http://www.columbia.edu/cu/chemistry/groups/reichman/">David Reichmann, Columbia University Department of Chemistry.</a>
 </p>
-	<img src="images/glass2.jpg" style="padding:0px 0px 15px 20px;" />
+	<!-- <img src="images/glass2.jpg" style="padding:0px 0px 15px 20px;" /> -->
+	<img src="http://www.columbia.edu/cu/chemistry/groups/reichman/images/glass1.png" height="30%" style="padding:0px 0px 15px 20px;" />
 	<p><b>Approach.</b>
-Recent studies of the glass transition in model systems have focused on calculating from theory or simulation what is known as the “mosaic length”. This project  evaluated a new “cavity method” for measuring this length scale.  Correlation functions are calculated at the interior of cavities of varying sizes and averaged over many independent simulations to determine a thermodynamic length. Using Swift on the Uchicago Beagle supercomputer and the Open Science Grid, Hocky investigated whether this thermodynamic length causes variations among seemingly identical systems. ~1M Beagle CPU hours were used, and many hundreds of thousand of hours of computing were performed using Swift on the Open Science Grid.
+Recent studies of the glass transition in model systems have focused on calculating from theory or simulation what is known as the “mosaic length”. This project  evaluated a new “cavity method” for measuring this length scale.  Correlation functions are calculated at the interior of cavities of varying sizes and averaged over many independent simulations to determine a thermodynamic length. Using Swift on the UChicago Beagle supercomputer and the Open Science Grid, Hocky investigated whether this thermodynamic length causes variations among seemingly identical systems. Close to one million Beagle CPU hours were used, and many hundreds of thousand of hours of computing were performed on the Open Science Grid.
 	<p><b>Results.</b>
-Three simple models of glassy behavior were studied. All appear the same (top, abc) but only two of which have particles relaxing at the same rate for the same temperature (top, d). This would imply that the glass structure does not dictate the dynamics. A new computational technique was used to extract a length scale on which the liquid is ordered in an otherwise undetectable way.  Results (bottom) showed that using this length we can distinguish the two systems which have the same dynamics as separate from the third which has faster dynamics than the other two.
-A manuscript is in preparation for Physical Review Letters.
+Three simple models of glassy behavior were studied. All appeared the same, but only two of the models have particles relaxing at the same rate for the same temperature. This would imply that the glass structure does not dictate the dynamics. A new computational technique was used to extract a length scale on which the liquid is ordered in an otherwise undetectable way.  Results showed that using this length we can distinguish the two systems which have the same dynamics as separate from the third which has faster dynamics than the other two.
+A manuscript describing the study and findings is in preparation.
 </p>
 	<p> </p>
 	</div>
