[Swift-commit] r4911 - wwwdev
vytas at ci.uchicago.edu vytas at ci.uchicago.edu
Mon Aug 1 09:34:02 CDT 2011
Author: vytas
Date: 2011-08-01 09:34:01 -0500 (Mon, 01 Aug 2011)
New Revision: 4911
Added:
   wwwdev/shCoreu.js
Log:
new look & feel
Added: wwwdev/shCoreu.js
--- wwwdev/shCoreu.js	                        (rev 0)
+++ wwwdev/shCoreu.js	2011-08-01 14:34:01 UTC (rev 4911)
@@ -0,0 +1,599 @@
+ * Code Syntax Highlighter.
+ * Version 1.3.0
+ * Copyright (C) 2004 Alex Gorbatchev.
+ * http://www.dreamprojections.com/syntaxhighlighter/
+ * This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General
+ * Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option)
+ * any later version.
+ * This library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied
+ * warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more
+ * details.
+ * You should have received a copy of the GNU Lesser General Public License along with this library; if not, write to
+ * the Free Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+// create namespaces
+var dp = {
+	sh :
+		Toolbar : {},
+		Utils	: {},
+		RegexLib: {},
+		Brushes	: {},
+		Strings : {},
+		Version : '1.4.1'
+dp.sh.Strings = {
+	AboutDialog : '<html><head><title>About...</title></head><body class="dp-about"><table cellspacing="0"><tr><td class="copy"><p class="title">dp.SyntaxHighlighter</div><div class="para">Version: {V}</p><p><a href="http://www.dreamprojections.com/syntaxhighlighter/?ref=about" target="_blank">http://www.dreamprojections.com/SyntaxHighlighter</a></p>©2004-2005 Alex Gorbatchev. All right reserved.</td></tr><tr><td class="footer"><input type="button" class="close" value="OK" onClick="window.close()"/></td></tr></table></body></html>'
+dp.SyntaxHighlighter = dp.sh;
+// Toolbar functions
+dp.sh.Toolbar.Commands = {
+	ExpandSource: {
+		label: '+ expand source',
+		check: function(highlighter) { return highlighter.collapse; },
+		func: function(sender, highlighter)
+			sender.parentNode.removeChild(sender);
+			highlighter.div.className = highlighter.div.className.replace('collapsed', '');
+	// opens a new windows and puts the original unformatted source code inside.
+	ViewSource: {
+		label: 'view plain',
+			var code = highlighter.originalCode.replace(/</g, '<');
+			var wnd = window.open('', '_blank', 'width=750, height=400, location=0, resizable=1, menubar=0, scrollbars=1');
+			wnd.document.write('<textarea style="width:99%;height:99%">' + code + '</textarea>');
+			wnd.document.close();
+	// copies the original source code in to the clipboard (IE only)
+	CopyToClipboard: {
+		label: 'copy to clipboard',
+		check: function() { return window.clipboardData != null; },
+			window.clipboardData.setData('text', highlighter.originalCode);
+			alert('The code is in your clipboard now');
+	// creates an invisible iframe, puts the original source code inside and prints it
+	PrintSource: {
+		label: 'print',
+			var iframe = document.createElement('IFRAME');
+			var doc = null;
+			// this hides the iframe
+			iframe.style.cssText = 'position:absolute;width:0px;height:0px;left:-500px;top:-500px;';
+			document.body.appendChild(iframe);
+			doc = iframe.contentWindow.document;
+			dp.sh.Utils.CopyStyles(doc, window.document);
+			doc.write('<div class="' + highlighter.div.className.replace('collapsed', '') + ' printing">' + highlighter.div.innerHTML + '</div>');
+			doc.close();
+			iframe.contentWindow.focus();
+			iframe.contentWindow.print();
+			alert('Printing...');
+			document.body.removeChild(iframe);
+	About: {
+		label: '?',
+		func: function(highlighter)
+			var wnd	= window.open('', '_blank', 'dialog,width=300,height=150,scrollbars=0');
+			var doc	= wnd.document;
+			doc.write(dp.sh.Strings.AboutDialog.replace('{V}', dp.sh.Version));
+			doc.close();
+			wnd.focus();
+// creates a <div /> with all toolbar links
+dp.sh.Toolbar.Create = function(highlighter)
+	var div = document.createElement('DIV');
+	div.className = 'tools';
+	for(var name in dp.sh.Toolbar.Commands)
+		var cmd = dp.sh.Toolbar.Commands[name];
+		if(cmd.check != null && !cmd.check(highlighter))
+			continue;
+		div.innerHTML += '<a href="#" onclick="dp.sh.Toolbar.Command(\'' + name + '\',this);return false;">' + cmd.label + '</a>';
+	return div;
+// executes toolbar command by name
+dp.sh.Toolbar.Command = function(name, sender)
+	var n = sender;
+	while(n != null && n.className.indexOf('dp-highlighter') == -1)
+		n = n.parentNode;
+	if(n != null)
+		dp.sh.Toolbar.Commands[name].func(sender, n.highlighter);
+// copies all <link rel="stylesheet" /> from 'target' window to 'dest'
+dp.sh.Utils.CopyStyles = function(destDoc, sourceDoc)
+	var links = sourceDoc.getElementsByTagName('link');
+	for(var i = 0; i < links.length; i++)
+		if(links[i].rel.toLowerCase() == 'stylesheet')
+			destDoc.write('<link type="text/css" rel="stylesheet" href="' + links[i].href + '"></link>');
+// Common reusable regular expressions
+dp.sh.RegexLib = {
+	MultiLineCComments : new RegExp('/\\*[\\s\\S]*?\\*/', 'gm'),
+	SingleLineCComments : new RegExp('//.*$', 'gm'),
+	SingleLinePerlComments : new RegExp('#.*$', 'gm'),
+	DoubleQuotedString : new RegExp('"(?:\\.|(\\\\\\")|[^\\""])*"','g'),
+	SingleQuotedString : new RegExp("'(?:\\.|(\\\\\\')|[^\\''])*'", 'g')
+// Match object
+dp.sh.Match = function(value, index, css)
+	this.value = value;
+	this.index = index;
+	this.length = value.length;
+	this.css = css;
+// Highlighter object
+dp.sh.Highlighter = function()
+	this.noGutter = false;
+	this.addControls = true;
+	this.collapse = false;
+	this.tabsToSpaces = true;
+	this.wrapColumn = 80;
+	this.showColumns = true;
+// static callback for the match sorting
+dp.sh.Highlighter.SortCallback = function(m1, m2)
+	// sort matches by index first
+	if(m1.index < m2.index)
+		return -1;
+	else if(m1.index > m2.index)
+		return 1;
+	else
+		// if index is the same, sort by length
+		if(m1.length < m2.length)
+			return -1;
+		else if(m1.length > m2.length)
+			return 1;
+	return 0;
+dp.sh.Highlighter.prototype.CreateElement = function(name)
+	var result = document.createElement(name);
+	result.highlighter = this;
+	return result;
+// gets a list of all matches for a given regular expression
+dp.sh.Highlighter.prototype.GetMatches = function(regex, css)
+	var index = 0;
+	var match = null;
+	while((match = regex.exec(this.code)) != null)
+		this.matches[this.matches.length] = new dp.sh.Match(match[0], match.index, css);
+dp.sh.Highlighter.prototype.AddBit = function(str, css)
+	if(str == null || str.length == 0)
+		return;
+	var span = this.CreateElement('span');
+	//str = str.replace(/&/g, '&');
+	str = str.replace(/ /g, ' ');
+	str = str.replace(/</g, '<');
+	str = str.replace(/\n/gm, ' <br>');
+	// when adding a piece of code, check to see if it has line breaks in it
+	// and if it does, wrap individual line breaks with span tags
+	if(css != null)
+		var regex = new RegExp('<br>', 'gi');
+		if(regex.test(str))
+			var lines = str.split(' <br>');
+			str = '';
+			for(var i = 0; i < lines.length; i++)
+				span = this.CreateElement('SPAN');
+				span.className = css;
+				span.innerHTML = lines[i];
+				this.div.appendChild(span);
+				// don't add a <BR> for the last line
+				if(i + 1 < lines.length)
+					this.div.appendChild(this.CreateElement('BR'));
+		else
+			span.innerHTML = str;
+	else
+// checks if one match is inside any other match
+dp.sh.Highlighter.prototype.IsInside = function(match)
+	if(match == null || match.length == 0)
+		return false;
+	for(var i = 0; i < this.matches.length; i++)
+		var c = this.matches[i];
+		if(c == null)
+			continue;
+		if((match.index > c.index) && (match.index < c.index + c.length))
+			return true;
+	return false;
+dp.sh.Highlighter.prototype.ProcessRegexList = function()
+	for(var i = 0; i < this.regexList.length; i++)
+		this.GetMatches(this.regexList[i].regex, this.regexList[i].css);
+dp.sh.Highlighter.prototype.ProcessSmartTabs = function(code)
+	var lines	= code.split('\n');
+	var result	= '';
+	var tabSize	= 4;
+	var tab		= '\t';
+	// This function inserts specified amount of spaces in the string
+	// where a tab is while removing that given tab.
+	function InsertSpaces(line, pos, count)
+		var left	= line.substr(0, pos);
+		var right	= line.substr(pos + 1, line.length);	// pos + 1 will get rid of the tab
+		var spaces	= '';
+		for(var i = 0; i < count; i++)
+			spaces += ' ';
+		return left + spaces + right;
+	// This function process one line for 'smart tabs'
+	function ProcessLine(line, tabSize)
+		if(line.indexOf(tab) == -1)
+			return line;
+		var pos = 0;
+		while((pos = line.indexOf(tab)) != -1)
+			// This is pretty much all there is to the 'smart tabs' logic.
+			// Based on the position within the line and size of a tab,
+			// calculate the amount of spaces we need to insert.
+			var spaces = tabSize - pos % tabSize;
+			line = InsertSpaces(line, pos, spaces);
+		return line;
+	// Go through all the lines and do the 'smart tabs' magic.
+		result += ProcessLine(lines[i], tabSize) + '\n';
+	return result;
+dp.sh.Highlighter.prototype.SwitchToList = function()
+	// thanks to Lachlan Donald from SitePoint.com for this <br/> tag fix.
+	var html = this.div.innerHTML.replace(/<(br)\/?>/gi, '\n');
+	var lines = html.split('\n');
+	for(var i = 0, lineIndex = this.firstLine; i < lines.length - 1; i++, lineIndex++)
+		span.className = "codeline";
+		span.innerHTML = lines[i] + ' <br>';
+		this.ol.appendChild(span);
+	this.div.innerHTML	= '';
+dp.sh.Highlighter.prototype.Highlight = function(code)
+	function Trim(str)
+		return str.replace(/^\s*(.*?)[\s\n]*$/g, '$1');
+	function Chop(str)
+		return str.replace(/\n*$/, '').replace(/^\n*/, '');
+	function Unindent(str)
+		var lines = str.split('\n');
+		var indents = new Array();
+		var regex = new RegExp('^\\s*', 'g');
+		var min = 1000;
+		// go through every line and check for common number of indents
+		for(var i = 0; i < lines.length && min > 0; i++)
+			if(Trim(lines[i]).length == 0)
+				continue;
+			var matches = regex.exec(lines[i]);
+			if(matches != null && matches.length > 0)
+				min = Math.min(matches[0].length, min);
+		// trim minimum common number of white space from the begining of every line
+		if(min > 0)
+				lines[i] = lines[i].substr(min);
+		return lines.join('\n');
+	// This function returns a portions of the string from pos1 to pos2 inclusive
+	function Copy(string, pos1, pos2)
+		return string.substr(pos1, pos2 - pos1);
+	var pos	= 0;
+	this.originalCode = code;
+	this.code = Chop(Unindent(code));
+	this.div = this.CreateElement('DIV');
+	this.ol = this.CreateElement('p');
+	this.matches = new Array();
+	this.div.className = 'dp-highlighter';
+	this.div.highlighter = this;
+	// set the first line
+	this.ol.start = this.firstLine;
+	if(this.CssClass != null)
+		this.ol.className = this.CssClass;
+	if(this.collapse)
+		this.div.className += ' collapsed';
+	if(this.noGutter)
+		this.div.className += ' nogutter';
+	// replace tabs with spaces
+	if(this.tabsToSpaces == true)
+		this.code = this.ProcessSmartTabs(this.code);
+	this.ProcessRegexList();
+	// if no matches found, add entire code as plain text
+	if(this.matches.length == 0)
+		this.AddBit(this.code, null);
+		this.SwitchToList();
+		this.div.appendChild(this.ol);
+		return;
+	// sort the matches
+	this.matches = this.matches.sort(dp.sh.Highlighter.SortCallback);
+	// The following loop checks to see if any of the matches are inside
+	// of other matches. This process would get rid of highligted strings
+	// inside comments, keywords inside strings and so on.
+		if(this.IsInside(this.matches[i]))
+			this.matches[i] = null;
+	// Finally, go through the final list of matches and pull the all
+	// together adding everything in between that isn't a match.
+		var match = this.matches[i];
+			continue;
+		this.AddBit(Copy(this.code, pos, match.index), null);
+		this.AddBit(match.value, match.css);
+		pos = match.index + match.length;
+	this.AddBit(this.code.substr(pos), null);
+dp.sh.Highlighter.prototype.GetKeywords = function(str)
+	return '\\b' + str.replace(/ /g, '\\b|\\b') + '\\b';
+// highlightes all elements identified by name and gets source code from specified property
+dp.sh.HighlightAll = function(name, showGutter /* optional */, showControls /* optional */, collapseAll /* optional */, firstLine /* optional */, showColumns /* optional */)
+	function FindValue()
+		var a = arguments;
+		for(var i = 0; i < a.length; i++)
+			if(a[i] == null)
+				continue;
+			if(typeof(a[i]) == 'string' && a[i] != '')
+				return a[i] + '';
+			if(typeof(a[i]) == 'object' && a[i].value != '')
+				return a[i].value + '';
+		return null;
+	function IsOptionSet(value, list)
+		for(var i = 0; i < list.length; i++)
+			if(list[i] == value)
+				return true;
+		return false;
+	function GetOptionValue(name, list, defaultValue)
+		var regex = new RegExp('^' + name + '\\[(\\w+)\\]$', 'gi');
+		var matches = null;
+			if((matches = regex.exec(list[i])) != null)
+				return matches[1];
+		return defaultValue;
+	var els = document.getElementsByTagName("pre");
+	var elements = new Array();
+	for(var i = 0; i < els.length; i++) {
+		elements[i] = els[i];
+	var highlighter = null;
+	var registered = new Object();
+	var propertyName = 'value';
+	// if no code blocks found, leave
+	if(elements == null)
+		return;
+	// register all brushes
+	for(var brush in dp.sh.Brushes)
+		var aliases = dp.sh.Brushes[brush].Aliases;
+		if(aliases == null)
+			continue;
+		for(var i = 0; i < aliases.length; i++)
+			registered[aliases[i]] = brush;
+	for(var i = 0; i < elements.length; i++)
+		var element = elements[i];
+		if (element.className != "programlisting") {
+			continue;
+		var language = 'vdl2';
+		if(registered[language] == null)
+			continue;
+		// instantiate a brush
+		highlighter = new dp.sh.Brushes[registered[language]]();
+		// hide the original element
+		element.style.display = 'none';
+		highlighter.Highlight(element.innerHTML);
+		element.parentNode.replaceChild(highlighter.div, element);
+function sh() {
+	dp.SyntaxHighlighter.HighlightAll('code');
\ No newline at end of file
