[Swift-commit] r4899 - in wwwdev: . docs docs/_notes
vytas at ci.uchicago.edu vytas at ci.uchicago.edu
Mon Aug 1 09:23:55 CDT 2011
Author: vytas
Date: 2011-08-01 09:23:54 -0500 (Mon, 01 Aug 2011)
New Revision: 4899
Added:
   wwwdev/docs/
   wwwdev/docs/_notes/
   wwwdev/docs/_notes/dwsync.xml
   wwwdev/docs/index copy.php
   wwwdev/docs/index.php
   wwwdev/docs/license.php
   wwwdev/docs/tracking_policy.php
   wwwdev/docs/usage_data.php
Log:
new look & feel
Added: wwwdev/docs/_notes/dwsync.xml
--- wwwdev/docs/_notes/dwsync.xml	                        (rev 0)
+++ wwwdev/docs/_notes/dwsync.xml	2011-08-01 14:23:54 UTC (rev 4899)
@@ -0,0 +1,7 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<dwsync>
+<file name="index.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394711849" remote="16279613743" />
+<file name="license.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394121885" remote="11984604671" />
+<file name="tracking_policy.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394121885" remote="11984604674" />
+<file name="usage_data.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394121885" remote="11984604677" />
+</dwsync>
\ No newline at end of file
Added: wwwdev/docs/index copy.php
--- wwwdev/docs/index copy.php	                        (rev 0)
+++ wwwdev/docs/index copy.php	2011-08-01 14:23:54 UTC (rev 4899)
@@ -0,0 +1,149 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
+<title>Swift - A system for rapid and reliable specification, execution, and management of large scale workflows</title>
+<link href="../css/960_12_col.css" rel="stylesheet" type="text/css" />
+<link href="../css/reset.css" rel="stylesheet" type="text/css" />
+<link href="../css/style3.css" rel="stylesheet" type="text/css" />
+<script type="text/javascript" src="http://use.typekit.com/dbf2lqy.js"></script>
+<script type="text/javascript">try{Typekit.load();}catch(e){}</script>
+</head>
+<body>
+<div class="container_12">
+	<!-- header -->
+	<?php require('../inc/header2.php') ?>
+	<!-- end header -->
+<div class="grid_12 page-header">
+	<h1>Documentation</h1>
+</div>
+<div class="clear"></div>
+<!-- end .grid_12 -->
+ <div class="grid_9">
+	<h3>Swift Quickstart Guide</h3>
+<ul>
+	<li>Swift Quickstart Guide [<a href="../guides/quickstartguide.php">html</a>]</li>
+</ul>
+<p>
+	Use the Quickstart Guide to help you install and configure swift and run a
+	simple 'Hello World' example.
+</p>
+<h3>Swift Tutorials</h3>
+<ul>
+	<li><strong>latest (0.92)</strong>
+        [<a href="../guides/tutorial.php">html</a>] [<a href="../guides/tutorial.pdf">pdf</a>]
+        </li>
+	<li><strong>trunk</strong>
+        [<a href="../guides/trunk/tutorial/tutorial.html">html</a>] [<a href="../guides/trunk/tutorial/tutorial.pdf">pdf</a>]
+        </li>
+</ul>
+<ul>
+	<li><strong>Swift Tutorial (on your own machine)</strong> [<a href="../guides/tutorial.php">html</a>] [<a href="../guides/tutorial.pdf" onClick="javascript: pageTracker._trackPageview('/swift/guides/tutorial.php');">pdf</a>]</li>
+</ul>
+<p>
+	This Swift tutorial carries on where the Quickstart Guide leaves off,
+	introducing you to Swift environment and the SwiftScript language in more
+	depth.
+</p>
+<ul>
+	<li><strong>Swift Tutorial (on a UC machine)</strong> [<a href="http://www.ci.uchicago.edu/osgedu/schools/swiftlab/">html</a>] </li>
+</ul>
+<p>
+	This tutorial (part of the Open Science Grid teaching lab) introduces
+	you to the Swift environment and the SwiftScript language in more
+	depth using a provided training account where installation of the
+	software has already been performed.
+</p>
+<h3>Swift User Guide</h3>
+<ul>
+<p>
+	The User Guide provides more detailed reference documentation and background
+	information on swift. It is assumed that the reader is already familiar with
+	the material in the Quickstart and Tutorial documents.
+</p>
+          [<a href="../guides/trunk/userguide/userguide.html">html</a>] [<a href="../guides/trunk/userguide/userguide.pdf">pdf</a>]
+        </li>
+          [<a href="../guides/release-0.92/userguide/">multi-page html</a>]
+        </li>
+	<li><strong>historical (0.91)</strong>
+          [<a href="../guides/release-0.91/userguide/">multi-page html</a>]
+        </li>
+</ul>
+<h3>Log Processing tools</h3>
+<ul>
+	<li>Swift log processing tools [<a href="../guides/log-processing.php">html</a>] [<a href="../guides/log-processing.pdf" onClick="javascript: pageTracker._trackPageview('/swift/guides/log-processing.pdf');">pdf</a>]</li>
+</ul>
+<p>
+	The Swift log processing tools can be used to analyse the log files of
+	Swift runs - as a webpage, and in several processed text formats. This
+	document gives some usage information for those tools.
+</p>
+<h3>Elsewhere</h3>
+<p>
+We've taught a hands on Swift tutorial on a number of occasions. This is
+harder to do alone because it relies on a number of brain image processing
+applications which you probably don't have installed.
+[<a href="http://www.ci.uchicago.edu/osgedu/modules/#workflow_swift">html</a>]
+</p>
+<h3>Historical - SwiftScript Language</h3>
+<p>
+	The SwiftScript language reference was a specification for an
+	earlier version of the language, and is probably of little interest to the majority of users.
+	<ul>
+    	<li> SwiftScript Language Reference - latest work in progress [<a href="../guides/historical/languagespec.php">html</a>] [<a href="../guides/languagespec.pdf" onClick="javascript: pageTracker._trackPageview('/swift/guides/historical/languagespec.pdf');">pdf</a>]</li>
+	    <li> SwiftScript Language Reference v 0.6 [<a href="../guides/languagespec-0.6.php">html</a>] [<a href="../guides/historical/languagespec.pdf" onClick="javascript: pageTracker._trackPageview('/swift/guides/languagespec-0.6.pdf');">pdf</a>]</li>
+	</ul>
+</p>
+	<p> </p>
+	</div>
+  <!-- end .grid_9 -->
+  <div class="grid_3">
+  	<h3>Right Header</h3>
+    <p>Right column content.</p>
+    <p> </p>
+  </div>
+  <!-- end .grid_3 -->
+  <div class="clear"></div>
+  </div>
+<!-- end .container_12 -->
+<!-- footer -->
+<?php require('../inc/footer2.php') ?>
+<!-- end footer -->
+var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
+document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
+</script>
+try {
+var pageTracker = _gat._getTracker("UA-106257-5");
+pageTracker._trackPageview();
+} catch(err) {}</script>
+</body>
+</html>
Added: wwwdev/docs/index.php
--- wwwdev/docs/index.php	                        (rev 0)
+++ wwwdev/docs/index.php	2011-08-01 14:23:54 UTC (rev 4899)
@@ -0,0 +1,150 @@
+<head>
+<title>Swift - Documentation</title>
+</head>
+<body>
+	<!-- header -->
+</div>
+<ul>
+</ul>
+<p>
+</p>
+<p> </p>
+<ul>
+        </li>
+        </li>
+</ul>
+<ul>
+</ul>
+<p>
+	depth.
+</p>
+<ul>
+</ul>
+<p>
+</p>
+<p> </p>
+<ul>
+<p>
+</p>
+        </li>
+        </li>
+        </li>
+</ul>
+<p> </p>
+<ul>
+</ul>
+<p>
+	document gives some usage information for those tools.</p>
+<p> </p>
+<h3>Elsewhere</h3>
+<p>
+</p>
+<p> </p>
+<p>
+	<ul>
+	</ul>
+</p>
+	<p> </p>
+	</div>
+  	<?php require('../inc/docs_sidebar.php') ?>
+  </div>
+  </div>
+<!-- footer -->
+</script>
+try {
+</body>
+</html>
Added: wwwdev/docs/license.php
--- wwwdev/docs/license.php	                        (rev 0)
+++ wwwdev/docs/license.php	2011-08-01 14:23:54 UTC (rev 4899)
@@ -0,0 +1,7 @@
+<html>
+<head>
+</head>
+<body>
+License
+</body>
+</html>
Added: wwwdev/docs/tracking_policy.php
--- wwwdev/docs/tracking_policy.php	                        (rev 0)
+++ wwwdev/docs/tracking_policy.php	2011-08-01 14:23:54 UTC (rev 4899)
@@ -0,0 +1,7 @@
+<html>
+<head>
+</head>
+<body>
+Tracking policy
+</body>
+</html>
Added: wwwdev/docs/usage_data.php
--- wwwdev/docs/usage_data.php	                        (rev 0)
+++ wwwdev/docs/usage_data.php	2011-08-01 14:23:54 UTC (rev 4899)
@@ -0,0 +1,7 @@
+<html>
+<head>
+</head>
+<body>
+Usage data
+</body>
+</html>
