[Swift-commit] r5029 - in trunk/tests/mpi: . fusion/long fusion/short
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Aug 30 13:28:40 CDT 2011
Author: wozniak
Date: 2011-08-30 13:28:40 -0500 (Tue, 30 Aug 2011)
New Revision: 5029
Added:
   trunk/tests/mpi/fusion/
   trunk/tests/mpi/fusion/long/sites.template.xml
   trunk/tests/mpi/fusion/long/tc.template.data
   trunk/tests/mpi/fusion/short/100-mci.timeout
   trunk/tests/mpi/fusion/short/sites.template.xml
   trunk/tests/mpi/fusion/short/tc.template.data
Removed:
Log:
Copy Beagle test for Fusion
Deleted: trunk/tests/mpi/fusion/long/sites.template.xml
--- trunk/tests/mpi/beagle/long/sites.template.xml	2011-08-30 02:36:19 UTC (rev 5025)
+++ trunk/tests/mpi/fusion/long/sites.template.xml	2011-08-30 18:28:40 UTC (rev 5029)
@@ -1,31 +0,0 @@
-<config>
-<import file="sys.xml"/>
-<set name="pwd"><sys:getenv name="PWD"/></set>
-<set name="wdir" value="{pwd}/work"/>
-<echo message="setting workDirectory to: {wdir}"/>
-<pool handle="crow">
-  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
-  <filesystem provider="local" url="none" />
-  <profile namespace="globus" key="maxWallTime">1</profile>
-  <profile namespace="globus" key="maxTime">7200</profile>
-  <profile namespace="globus" key="providerAttributes">
-    pbs.aprun;pbs.mpp;depth=6
-  </profile>
-  <profile key="jobsPerNode" namespace="globus">1</profile>
-  <profile key="slots" namespace="globus">1</profile>
-  <profile key="nodeGranularity" namespace="globus">10</profile>
-  <profile key="maxNodes" namespace="globus">20</profile>
-  <profile key="workerLoggingLevel" namespace="globus">DEBUG</profile>
-  <profile key="workerLoggingDirectory" namespace="globus">{wdir}</profile>
-  <profile key="jobThrottle" namespace="karajan">5.99</profile>
-  <profile key="initialScore" namespace="karajan">10000</profile>
-  <workdirectory>{wdir}</workdirectory>
-</pool>
-</config>
-<!-- RESERVATIONS:
-Add something like this to your providerAttributes:
-pbs.resources=advres=modFTDock.47 -->
Copied: trunk/tests/mpi/fusion/long/sites.template.xml (from rev 5027, trunk/tests/mpi/beagle/long/sites.template.xml)
--- trunk/tests/mpi/fusion/long/sites.template.xml	                        (rev 0)
@@ -0,0 +1,31 @@
+<config>
+<import file="sys.xml"/>
+<set name="pwd"><sys:getenv name="PWD"/></set>
+<set name="wdir" value="{pwd}/work"/>
+<echo message="setting workDirectory to: {wdir}"/>
+<pool handle="beagle">
+  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
+  <filesystem provider="local" url="none" />
+  <profile namespace="globus" key="maxWallTime">1</profile>
+  <profile namespace="globus" key="maxTime">7200</profile>
+  <profile namespace="globus" key="providerAttributes">
+    pbs.aprun;pbs.mpp;depth=1
+  </profile>
+  <profile key="jobsPerNode" namespace="globus">1</profile>
+  <profile key="slots" namespace="globus">1</profile>
+  <profile key="nodeGranularity" namespace="globus">10</profile>
+  <profile key="maxNodes" namespace="globus">20</profile>
+  <profile key="workerLoggingLevel" namespace="globus">DEBUG</profile>
+  <profile key="workerLoggingDirectory" namespace="globus">{wdir}</profile>
+  <profile key="jobThrottle" namespace="karajan">5.99</profile>
+  <profile key="initialScore" namespace="karajan">10000</profile>
+  <workdirectory>{wdir}</workdirectory>
+</pool>
+</config>
+<!-- RESERVATIONS:
+Add something like this to your providerAttributes:
+pbs.resources=advres=modFTDock.47 -->
Deleted: trunk/tests/mpi/fusion/long/tc.template.data
--- trunk/tests/mpi/beagle/long/tc.template.data	2011-08-30 02:36:19 UTC (rev 5025)
+++ trunk/tests/mpi/fusion/long/tc.template.data	2011-08-30 18:28:40 UTC (rev 5029)
@@ -1,23 +0,0 @@
-#This is the transformation catalog.
-#It comes pre-configured with a number of simple transformations with
-#paths that are likely to work on a linux box. However, on some systems,
-#the paths to these executables will be different (for example, sometimes
-#some of these programs are found in /usr/bin rather than in /bin)
-#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
-#there must be no trailing whitespace at the end of each line.
-# sitename  transformation  path   INSTALLED  platform  profiles
-localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
-localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
-localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
-localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
-localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
-localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
-localhost 	cp 		/bin/cp	        INSTALLED	INTEL32::LINUX	null
-# hydra-tests-2
-crow 	mpi_cp 		_DIR_/mpi-cp    INSTALLED	INTEL32::LINUX	globus::hostCount=2
-crow 	mpi_sleep 	_DIR_/mpi-sleep    INSTALLED	INTEL32::LINUX	globus::hostCount=2
Copied: trunk/tests/mpi/fusion/long/tc.template.data (from rev 5027, trunk/tests/mpi/beagle/long/tc.template.data)
--- trunk/tests/mpi/fusion/long/tc.template.data	                        (rev 0)
@@ -0,0 +1,23 @@
+#This is the transformation catalog.
+#It comes pre-configured with a number of simple transformations with
+#paths that are likely to work on a linux box. However, on some systems,
+#the paths to these executables will be different (for example, sometimes
+#some of these programs are found in /usr/bin rather than in /bin)
+#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
+#there must be no trailing whitespace at the end of each line.
+# sitename  transformation  path   INSTALLED  platform  profiles
+localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
+localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
+localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
+localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
+localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
+localhost 	cp 		/bin/cp	        INSTALLED	INTEL32::LINUX	null
+# hydra-tests-2
+beagle 	mpi_cp 		_DIR_/mpi-cp       INSTALLED	INTEL32::LINUX	globus::hostCount=2
+beagle 	mpi_sleep 	_DIR_/mpi-sleep    INSTALLED	INTEL32::LINUX	globus::hostCount=2
Copied: trunk/tests/mpi/fusion/short/100-mci.timeout (from rev 5026, trunk/tests/mpi/beagle/short/100-mci.timeout)
--- trunk/tests/mpi/fusion/short/100-mci.timeout	                        (rev 0)
+++ trunk/tests/mpi/fusion/short/100-mci.timeout	2011-08-30 18:28:40 UTC (rev 5029)
@@ -0,0 +1 @@
+1000
Deleted: trunk/tests/mpi/fusion/short/sites.template.xml
--- trunk/tests/mpi/beagle/short/sites.template.xml	2011-08-30 02:36:19 UTC (rev 5025)
+++ trunk/tests/mpi/fusion/short/sites.template.xml	2011-08-30 18:28:40 UTC (rev 5029)
@@ -1,31 +0,0 @@
-<config>
-  </profile>
-  <profile key="nodeGranularity" namespace="globus">2</profile>
-  <profile key="maxNodes" namespace="globus">4</profile>
-</pool>
-</config>
-<!-- RESERVATIONS:
Copied: trunk/tests/mpi/fusion/short/sites.template.xml (from rev 5026, trunk/tests/mpi/beagle/short/sites.template.xml)
--- trunk/tests/mpi/fusion/short/sites.template.xml	                        (rev 0)
@@ -0,0 +1,31 @@
+<config>
+    pbs.aprun;pbs.mpp;depth=6
+  </profile>
+  <profile key="nodeGranularity" namespace="globus">2</profile>
+  <profile key="maxNodes" namespace="globus">4</profile>
+</pool>
+</config>
+<!-- RESERVATIONS:
Deleted: trunk/tests/mpi/fusion/short/tc.template.data
--- trunk/tests/mpi/beagle/short/tc.template.data	2011-08-30 02:36:19 UTC (rev 5025)
+++ trunk/tests/mpi/fusion/short/tc.template.data	2011-08-30 18:28:40 UTC (rev 5029)
@@ -1,22 +0,0 @@
-# hydra-tests-2
Copied: trunk/tests/mpi/fusion/short/tc.template.data (from rev 5026, trunk/tests/mpi/beagle/short/tc.template.data)
--- trunk/tests/mpi/fusion/short/tc.template.data	                        (rev 0)
@@ -0,0 +1,22 @@
+# hydra-tests-2
