[Swift-commit] r5017 - branches/release-0.93/docs/quickstart
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Aug 29 09:40:16 CDT 2011
Author: davidk
Date: 2011-08-29 09:40:16 -0500 (Mon, 29 Aug 2011)
New Revision: 5017
Modified:
   branches/release-0.93/docs/quickstart/quickstart.txt
Log:
Updates to quickstart guide
Modified: branches/release-0.93/docs/quickstart/quickstart.txt
--- branches/release-0.93/docs/quickstart/quickstart.txt	2011-08-29 04:27:45 UTC (rev 5016)
+++ branches/release-0.93/docs/quickstart/quickstart.txt	2011-08-29 14:40:16 UTC (rev 5017)
@@ -8,38 +8,29 @@
 and run the basic examples for Swift. If you are using a pre-installed
 version of Swift, you can skip directly to the configuration section.
+Stable Releases vs. Development Releases
+Stable releases of Swift have undergone more extensive testing than development releases.
+In general, they are more stable, have fewer bugs, and have been tested on a variety of
+systems.
+The development version of Swift is aimed at developers and testers. The development
+code has the highest chance of containing buggy and untested code. If you need stability
+please use the latest stable release.
 Downloading a Swift Distribution
-There are three main ways of getting the Swift implementation: stable
-releases, nightly builds, and the source code repository.
+There are two main ways of getting the Swift implementation: binary
+releases and the source repository.
-Stable Releases
+Binary Releases
-Stable releases can be obtained from the Swift download page: Swift
-Downloads Page. Once you downloaded the package, please move to the
-install section.
+For the majority of users, downloading and installing binary releases is recommended.
+Since Swift is written in Java, the binary packages will run on all supported platforms with
+Java Runtime Environment 1.5 or greater. Binary releases can be obtained from the
+http://www.ci.uchicago.edu/swift/downloads/index.php[Swift downloads page].
-Nightly Builds
-Swift builds and tests are being run every day. The Swift downloads page
-contains links to the latest build and test page. The nightly builds
-reflect a development version of the Swift code and should not be used in
-production mode. After downloading a nightly build package, please
-continue to the install section.
-Source Repository
-Details about accessing the Swift source repository together with build
-instructions are available on the Swift downloads page. Once
-built, the dist/swift-svn directory will contain a self-contained
-build which can be used in place or moved to a different location. You
-should then proceed to the configuration section.
-Installing a Swift Binary Package
-Simply unpack the downloaded package (swift-<version>.tar.gz) into a
+Once downloaded, simply unpack the downloaded package (swift-<version>.tar.gz) into a
 directory of your choice:
@@ -48,91 +39,63 @@
 This will create a swift-<version> directory containing the build.
+Source Repository
+The source code for Swift is available to developers who have an interest in contributing
+new features. To build Swift from source code, you will need http://ant.apache.org/[Apache Ant]
+and http://www.oracle.com/technetwork/java/javase/downloads/index.html[Java JDK]. Once
+built, the dist/swift-svn directory will contain your build.
-Configuring Swift
-This section describes configuration steps that need to be taken in
-order to get Swift running. Since all command line tools provided with
-Swift can be found in the |bin/| directory of the Swift distribution, it
-may be a good idea to add this directory to your |PATH| environment
-variable:
+To download and build Swift 0.93, follow these instructions:
-export PATH=/path/to/swift/bin:$PATH
+$ mkdir swift-0.93
+$ cd swift-0.93
+$ svn co https://cogkit.svn.sourceforge.net/svnroot/cogkit/branches/4.1.9/src/cog
+$ cd cog/modules
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/branches/release-0.93 swift
+$ cd swift
+$ ant redist
-Grid Security
-For local execution of jobs, no grid security configuration is necessary.
+Setting your PATH
+Once Swift is installed, it is useful to add the swift binary to your PATH
+environment variable. To do this, first determine where the Swift bin
+directory is located. If you installed Swift from a binary release, it will
+be in the swift-0.93/bin directory where you installed it. If you followed
+the instructions above for installing Swift from a source repository, it
+will be located in swift-0.93/cog/modules/swift/dist/swift-svn/bin.
-However, when submitting jobs to a remote machine using Globus Toolkit
-services, Swift makes use of the Grid Security Infrastructure (GSI)
-at http://www.globus.org/toolkit/docs/4.0/security/key-index.html for
-authentication and authorization. The requirements for this are detailed
-in the following sections. Note that GSI is not required to be
-configured for local execution (which will usually be the case when
-first starting with Swift).
+Add the following line to the bottom of ~/.bashrc:
-User Certificate
-GSI requires a certificate/private key pair for authentication to Globus
-Toolkit services. The certificate and private key should be placed into
-the ~/.globus/usercert.pem and ~/.globus/userkey.pem files, respectively.
+export PATH=$PATH:/full/path/to/swift
-Certificate Authorities Root Certificates
-The Swift client libraries are generally required to authenticate the
-services to which they connect. This process requires the presence on
-the Swift submit site of the root certificates used to sign the host
-certificates of services used. These root certificates need to be
-installed in either (or both) the ~/.globus/certificates and
-/etc/grid-security/certificates directories. A package with the root
-certificates of the certificate authorities used in the
-http://www.teragrid.org[TeraGrid] can be found
-http://security.teragrid.org/TG-CAs.html[here].
-Swift Properties
-A Swift properties file (named swift.properties) can be used to
-customize certain configuration aspects of Swift. A shared version of
-this file, etc/swift.properties in the installation directory can be
-used to provide installation-wide defaults. A per-user properties file,
-~/.swift/swift.properties can be used for user specific settings.
-Swift first loads the shared configuration file and, if present, the
-user configuration file. Any properties not explicitly set in the user
-configuration file will be inherited from the shared configuration file.
-Properties are specified in the following format:
+When you login, test this out by typing the command
-name=value
+$ which swift
-For details about the various properties Swift accepts, please take a
-look at the http://www.ci.uchicago.edu/swift/guides/userguide.php#properties[Swift Properties Section]
-in the http://www.ci.uchicago.edu/swift/guides/userguide.php[Swift User Guide].
+This should point you to the path of the Swift binary.
 Running Swift Examples
 The Swift examples can be found in the examples directory in the Swift
 distribution. The examples are written in the SwiftScript language, and
-have |.swift| as a file extension.
+have .swift as a file extension.
-The Grid Security Infrastructure, which Swift uses, works with limited
-time certificates called proxies. These proxies can be generated from
-your user certificate and private key using one of grid-proxy-init or
-cog-proxy-init (the latter being a Java Swing interface to the former).
 Execution of a Swift workflow is done using the swift command, which
 takes the Swift workflow file name as an argument:
-cd examples/swift
-swift first.swift
+cd examples/tutorial
+swift hello.swift
-The
-http://www.ci.uchicago.edu/swift/guides/userguide.php#swiftcommand[Swift Command Options Section]
-in the http://www.ci.uchicago.edu/swift/guides/userguide.php[Swift User Guide] contains details
-about the various options of swift.
+When you run this application, it should create a file called hello.txt.
+If this file gets created, you have successfully ran your first
+Swift script!
+More documentation on how to run Swift can be found at
+http://www.ci.uchicago.edu/swift/docs/index.php,
