[Swift-commit] r5010 - trunk/tests/mpi/crow/long
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Thu Aug 25 14:52:00 CDT 2011
Author: wozniak
Date: 2011-08-25 14:52:00 -0500 (Thu, 25 Aug 2011)
New Revision: 5010
Added:
   trunk/tests/mpi/crow/long/mpi-sleep.c
Log:
Copy in this script from JETS.  TODO: modify it to create output
Added: trunk/tests/mpi/crow/long/mpi-sleep.c
--- trunk/tests/mpi/crow/long/mpi-sleep.c	                        (rev 0)
+++ trunk/tests/mpi/crow/long/mpi-sleep.c	2011-08-25 19:52:00 UTC (rev 5010)
@@ -0,0 +1,179 @@
+ * Simple Hydra test
+ * No I/O
+ * usage: mpi-sleep <duration>
+#include <assert.h>
+#include <stdbool.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sys/stat.h>
+#include <unistd.h>
+#include <mpi.h>
+#include "./profile.h"
+// There is a Makefile option to turn on debugging
+#ifdef ENABLE_DEBUG
+#define DEBUG(...) __VA_ARGS__
+#define debug(...)                              \
+  { printf("%i: ", mpi_rank); printf(__VA_ARGS__); }
+#else
+#define DEBUG(...)
+#define debug(...)
+#endif
+#define max(a, b) (((a) > (b)) ? (a) : (b))
+#define min(a, b) (((a) < (b)) ? (a) : (b))
+void print_help(void);
+void startup(void);
+void crash(char* msg);
+void check(void* value, char* msg);
+int mpi_size, mpi_rank;
+const int INPUT_MAX = 10;
+int input_count = 0;
+const int OUTPUT_MAX = 10;
+int output_count = 0;
+bool write_header = false;
+int main(int argc, char* argv[])
+  profile_init(100);
+  int duration = -1;
+  char* inputs[INPUT_MAX];
+  char* outputs[OUTPUT_MAX];
+  int opt = -1;
+  while ((opt = getopt(argc, argv, "i:o:v")) != -1)
+    switch (opt)
+      case 'i':
+        if (input_count >= INPUT_MAX)
+          crash("too many inputs!");
+        inputs[input_count++] = strdup(optarg);
+        break;
+      case 'o':
+        if (output_count >= OUTPUT_MAX)
+          crash("too many outputs!");
+        outputs[output_count++] = optarg;
+        debug("output: %s\n", optarg);
+        break;
+      case 'v':
+        write_header = true;
+        break;
+  MPI_Init(&argc, &argv);
+  profile_entry(MPI_Wtime(), strdup("job start"));
+  debug("mpi-sleep\n");
+  MPI_Comm_size(MPI_COMM_WORLD, &mpi_size);
+  MPI_Comm_rank(MPI_COMM_WORLD, &mpi_rank);
+  profile_entry(MPI_Wtime(), strdup("rank"));
+  startup();
+  if (optind >= argc)
+    if (mpi_rank == 0)
+      print_help();
+    return EXIT_FAILURE;
+  int count = sscanf(argv[optind], "%d", &duration);
+  if (count != 1)
+    printf("Did not receive integer duration argument!\n");
+  // INTRO BARRIER
+  debug("barrier1\n");
+  profile_entry(MPI_Wtime(), strdup("barrier1 start"));
+  MPI_Barrier(MPI_COMM_WORLD);
+  profile_entry(MPI_Wtime(), strdup("barrier1 done"));
+  debug("sleep %i\n", duration);
+  // SLEEP
+  sleep(duration);
+  // WRITE OUTPUTS
+  if (output_count > 0)
+    profile_entry(MPI_Wtime(), strdup("write start"));
+  for (int i = 0; i < output_count; i++)
+    char tmp[128];
+    sprintf(tmp, "%s-%i", outputs[i], mpi_rank);
+    debug("write to: %s\n", tmp);
+    FILE* file = fopen(tmp, "w");
+    check(file, "could not write to file!");
+    if (write_header)
+      fprintf(file, "rank: %i/%i\n", mpi_rank, mpi_size);
+    fclose(file);
+    profile_entry(MPI_Wtime(), strdup("write done"));
+  // FINAL BARRIER
+  debug("barrier2\n");
+  profile_entry(MPI_Wtime(), strdup("barrier2 start"));
+  profile_entry(MPI_Wtime(), strdup("barrier2 done"));
+  debug("job done\n");
+  MPI_Finalize();
+  profile_write(mpi_rank, stdout);
+  profile_finalize();
+  return EXIT_SUCCESS;
+void startup()
+  char* pwd;
+  FILE* file;
+  char filename[1024];
+  // DEBUG(system("/bin/hostname"));
+  debug("size: %i\n", mpi_size);
+  debug("rank: %i\n", mpi_rank);
+  DEBUG(pwd = getenv("PWD"));
+  debug("PWD: %s\n", pwd);
+  DEBUG(fflush(NULL));
+  // DEBUG(sprintf(filename, "mpi-sleep-%i.out", mpi_rank));
+  // DEBUG(file = fopen(filename, "w"));
+  // DEBUG(fprintf(file, "OK\n"));
+  // DEBUG(fclose(file));
+void print_help()
+  printf("usage: <duration>\n");
+  printf("mpi-sleep: %s\n", msg);
+  exit(1);
+  if (!value)
+    crash(msg);
