[Swift-commit] r4993 - in trunk/tests/mpi: . local
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Aug 23 14:52:37 CDT 2011
Author: wozniak
Date: 2011-08-23 14:52:37 -0500 (Tue, 23 Aug 2011)
New Revision: 4993
Added:
   trunk/tests/mpi/local/100-input.txt
   trunk/tests/mpi/local/100-mci.check.sh
   trunk/tests/mpi/local/100-mci.clean.sh
   trunk/tests/mpi/local/100-mci.setup.sh
   trunk/tests/mpi/local/100-mci.swift
   trunk/tests/mpi/local/100-mpi-cp.c
   trunk/tests/mpi/local/README.txt
   trunk/tests/mpi/local/sites.template.xml
   trunk/tests/mpi/local/tc.template.data
   trunk/tests/mpi/local/title.txt
Removed:
   trunk/tests/mpi/100-input.txt
   trunk/tests/mpi/100-mci.check.sh
   trunk/tests/mpi/100-mci.clean.sh
   trunk/tests/mpi/100-mci.setup.sh
   trunk/tests/mpi/100-mci.swift
   trunk/tests/mpi/100-mpi-cp.c
   trunk/tests/mpi/README.txt
   trunk/tests/mpi/sites.template.xml
   trunk/tests/mpi/tc.template.data
   trunk/tests/mpi/title.txt
Log:
Put local MPI test in tests/mpi/local
Deleted: trunk/tests/mpi/100-input.txt
--- trunk/tests/mpi/100-input.txt	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/100-input.txt	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1 +0,0 @@
-hello
Deleted: trunk/tests/mpi/100-mci.check.sh
--- trunk/tests/mpi/100-mci.check.sh	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/100-mci.check.sh	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,12 +0,0 @@
-#!/bin/bash
-set -x
-[ -f 100-output.txt ] || exit 1
-CONTENTS1=$( cat 100-input.txt )
-CONTENTS2=$( cat 100-output.txt )
-[[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
-exit 0
Deleted: trunk/tests/mpi/100-mci.clean.sh
--- trunk/tests/mpi/100-mci.clean.sh	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/100-mci.clean.sh	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,8 +0,0 @@
-#!/bin/bash
-set -x
-rm -v 100-input.txt  || exit 1
-rm -v 100-output.txt || exit 1
-exit 0
Deleted: trunk/tests/mpi/100-mci.setup.sh
--- trunk/tests/mpi/100-mci.setup.sh	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/100-mci.setup.sh	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,11 +0,0 @@
-#!/bin/bash
-set -x
-which mpicc || exit 1
-mpicc -std=gnu99 $GROUP/100-mpi-cp.c -o $GROUP/mpi-cp || exit 1
-cp -v $GROUP/100-input.txt . || exit 1
-exit 0
Deleted: trunk/tests/mpi/100-mci.swift
--- trunk/tests/mpi/100-mci.swift	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/100-mci.swift	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,12 +0,0 @@
-type file;
-app (file o) copy(file i)
-  mpi_cp @i @o;
-file input<"100-input.txt">;
-file output<"100-output.txt">;
-output = copy(input);
Deleted: trunk/tests/mpi/100-mpi-cp.c
--- trunk/tests/mpi/100-mpi-cp.c	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/100-mpi-cp.c	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,155 +0,0 @@
- * Simple Hydra test
- * usage: mpi-cp <input> <output>
- * Rank 0 reads the input file and sends it to rank 1.
- * Rank 1 recvs the data and writes the output.
-#include <assert.h>
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <sys/stat.h>
-#include <mpi.h>
-#define max(a, b) (((a) > (b)) ? (a) : (b))
-#define min(a, b) (((a) < (b)) ? (a) : (b))
-void print_help(void);
-void read_input(const char *restrict filename, char** data, int* size);
-void write_output(const char *restrict filename, char* data, int size);
-void startup(void);
-const int chunk = 64*1024;
-int main(int argc, char* argv[])
-  int mpi_size, mpi_rank;
-  MPI_Init(&argc, &argv);
-  MPI_Comm_size(MPI_COMM_WORLD, &mpi_size);
-  MPI_Comm_rank(MPI_COMM_WORLD, &mpi_rank);
-  startup();
-  // system("/bin/hostname");
-  // printf("size: %i\n", mpi_size);
-  // printf("rank: %i\n", mpi_rank);
-  char* data;
-  int size;
-  if (argc != 3)
-    print_help();
-    return 1;
-  if (mpi_rank == 0)
-    read_input(argv[1], &data, &size);
-    printf("size: %i\n", size);
-    MPI_Send(&size, 1, MPI_INT,
-             1, 1, MPI_COMM_WORLD);
-    MPI_Send(data, size, MPI_CHAR,
-  else
-    MPI_Status status;
-    MPI_Recv(&size, 1, MPI_INT,
-             0, 1, MPI_COMM_WORLD, &status);
-    data = malloc(size);
-    assert(data);
-    MPI_Recv(data, size, MPI_CHAR,
-    write_output(argv[2], data, size);
-  free(data);
-  MPI_Finalize();
-  return EXIT_SUCCESS;
-void startup()
-  char* pwd = getenv("PWD");
-  printf("PWD: %s\n", pwd);
-  fflush(NULL);
-   Allocates memory for *data
-void read_input(const char* restrict filename, char** data, int* size)
-  char* result;
-  FILE *file;
-  printf("read: %s\n", filename);
-  struct stat filestat;
-  int error = stat(filename, &filestat);
-  assert(error == 0);
-  int s = filestat.st_size;
-  int actual, c;
-  result = malloc(s);
-  file = fopen(filename, "r");
-  assert(file);
-  int count = 0;
-  while (count < s)
-    c = min(chunk, s-count);
-    actual = fread(result+count, 1, c, file);
-    count += actual;
-  fclose(file);
-  *size = s;
-  *data = result;
-void write_output(const char* restrict filename,
-                   char* data, int size)
-  FILE *file;
-  int actual, c;
-  printf("write: %s\n", filename);
-  file = fopen(filename, "w");
-  assert(file);
-  int count = 0;
-  while (count < size)
-    c = min(chunk, size-count);
-    actual = fwrite(data+count, 1, c, file);
-    count += actual;
-  fclose(file);
-void print_help()
-  printf("usage: <input> <output>\n");
Deleted: trunk/tests/mpi/README.txt
--- trunk/tests/mpi/README.txt	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/README.txt	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,6 +0,0 @@
-Test MPICH/Coasters integration
-Be sure the correct MPICH is in your PATH before running suite.sh
-See: http://www.ci.uchicago.edu/wiki/bin/view/SWFT/CoastersMpi
Copied: trunk/tests/mpi/local/100-input.txt (from rev 4991, trunk/tests/mpi/100-input.txt)
--- trunk/tests/mpi/local/100-input.txt	                        (rev 0)
+++ trunk/tests/mpi/local/100-input.txt	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1 @@
+hello
Copied: trunk/tests/mpi/local/100-mci.check.sh (from rev 4991, trunk/tests/mpi/100-mci.check.sh)
--- trunk/tests/mpi/local/100-mci.check.sh	                        (rev 0)
+++ trunk/tests/mpi/local/100-mci.check.sh	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+[ -f 100-output.txt ] || exit 1
+CONTENTS1=$( cat 100-input.txt )
+CONTENTS2=$( cat 100-output.txt )
+[[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
+exit 0
Copied: trunk/tests/mpi/local/100-mci.clean.sh (from rev 4991, trunk/tests/mpi/100-mci.clean.sh)
--- trunk/tests/mpi/local/100-mci.clean.sh	                        (rev 0)
+++ trunk/tests/mpi/local/100-mci.clean.sh	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,8 @@
+#!/bin/bash
+set -x
+rm -v 100-input.txt  || exit 1
+rm -v 100-output.txt || exit 1
+exit 0
Copied: trunk/tests/mpi/local/100-mci.setup.sh (from rev 4991, trunk/tests/mpi/100-mci.setup.sh)
--- trunk/tests/mpi/local/100-mci.setup.sh	                        (rev 0)
+++ trunk/tests/mpi/local/100-mci.setup.sh	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,11 @@
+#!/bin/bash
+set -x
+which mpicc || exit 1
+mpicc -std=gnu99 $GROUP/100-mpi-cp.c -o $GROUP/mpi-cp || exit 1
+cp -v $GROUP/100-input.txt . || exit 1
+exit 0
Copied: trunk/tests/mpi/local/100-mci.swift (from rev 4991, trunk/tests/mpi/100-mci.swift)
--- trunk/tests/mpi/local/100-mci.swift	                        (rev 0)
+++ trunk/tests/mpi/local/100-mci.swift	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,12 @@
+type file;
+app (file o) copy(file i)
+  mpi_cp @i @o;
+file input<"100-input.txt">;
+file output<"100-output.txt">;
+output = copy(input);
Copied: trunk/tests/mpi/local/100-mpi-cp.c (from rev 4991, trunk/tests/mpi/100-mpi-cp.c)
--- trunk/tests/mpi/local/100-mpi-cp.c	                        (rev 0)
+++ trunk/tests/mpi/local/100-mpi-cp.c	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,155 @@
+ * Simple Hydra test
+ * usage: mpi-cp <input> <output>
+ * Rank 0 reads the input file and sends it to rank 1.
+ * Rank 1 recvs the data and writes the output.
+#include <assert.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sys/stat.h>
+#include <mpi.h>
+#define max(a, b) (((a) > (b)) ? (a) : (b))
+#define min(a, b) (((a) < (b)) ? (a) : (b))
+void print_help(void);
+void read_input(const char *restrict filename, char** data, int* size);
+void write_output(const char *restrict filename, char* data, int size);
+void startup(void);
+const int chunk = 64*1024;
+int main(int argc, char* argv[])
+  int mpi_size, mpi_rank;
+  MPI_Init(&argc, &argv);
+  MPI_Comm_size(MPI_COMM_WORLD, &mpi_size);
+  MPI_Comm_rank(MPI_COMM_WORLD, &mpi_rank);
+  startup();
+  // system("/bin/hostname");
+  // printf("size: %i\n", mpi_size);
+  // printf("rank: %i\n", mpi_rank);
+  char* data;
+  int size;
+  if (argc != 3)
+    print_help();
+    return 1;
+  if (mpi_rank == 0)
+    read_input(argv[1], &data, &size);
+    printf("size: %i\n", size);
+    MPI_Send(&size, 1, MPI_INT,
+             1, 1, MPI_COMM_WORLD);
+    MPI_Send(data, size, MPI_CHAR,
+  else
+    MPI_Status status;
+    MPI_Recv(&size, 1, MPI_INT,
+             0, 1, MPI_COMM_WORLD, &status);
+    data = malloc(size);
+    assert(data);
+    MPI_Recv(data, size, MPI_CHAR,
+    write_output(argv[2], data, size);
+  free(data);
+  MPI_Finalize();
+  return EXIT_SUCCESS;
+void startup()
+  char* pwd = getenv("PWD");
+  printf("PWD: %s\n", pwd);
+  fflush(NULL);
+   Allocates memory for *data
+void read_input(const char* restrict filename, char** data, int* size)
+  char* result;
+  FILE *file;
+  printf("read: %s\n", filename);
+  struct stat filestat;
+  int error = stat(filename, &filestat);
+  assert(error == 0);
+  int s = filestat.st_size;
+  int actual, c;
+  result = malloc(s);
+  file = fopen(filename, "r");
+  assert(file);
+  int count = 0;
+  while (count < s)
+    c = min(chunk, s-count);
+    actual = fread(result+count, 1, c, file);
+    count += actual;
+  fclose(file);
+  *size = s;
+  *data = result;
+void write_output(const char* restrict filename,
+                   char* data, int size)
+  FILE *file;
+  int actual, c;
+  printf("write: %s\n", filename);
+  file = fopen(filename, "w");
+  assert(file);
+  int count = 0;
+  while (count < size)
+    c = min(chunk, size-count);
+    actual = fwrite(data+count, 1, c, file);
+    count += actual;
+  fclose(file);
+void print_help()
+  printf("usage: <input> <output>\n");
Copied: trunk/tests/mpi/local/README.txt (from rev 4991, trunk/tests/mpi/README.txt)
--- trunk/tests/mpi/local/README.txt	                        (rev 0)
+++ trunk/tests/mpi/local/README.txt	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,6 @@
+Test MPICH/Coasters integration
+Be sure the correct MPICH is in your PATH before running suite.sh
+See: http://www.ci.uchicago.edu/wiki/bin/view/SWFT/CoastersMpi
Copied: trunk/tests/mpi/local/sites.template.xml (from rev 4991, trunk/tests/mpi/sites.template.xml)
--- trunk/tests/mpi/local/sites.template.xml	                        (rev 0)
+++ trunk/tests/mpi/local/sites.template.xml	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,24 @@
+<config>
+  <pool handle="localhost" sysinfo="INTEL32::LINUX">
+    <gridftp url="local://localhost" />
+    <execution provider="local" url="none" />
+    <workdirectory>_WORK_</workdirectory>
+    <profile namespace="swift" key="stagingMethod">file</profile>
+  </pool>
+  <pool handle="coasterslocal">
+    <filesystem provider="local" />
+    <execution provider="coaster" jobmanager="local:local"/>
+    <profile namespace="globus"   key="internalHostname">_HOST_</profile>
+    <profile namespace="karajan"  key="jobthrottle">2.55</profile>
+    <profile namespace="karajan"  key="initialScore">10000</profile>
+    <profile namespace="globus"   key="jobsPerNode">4</profile>
+    <profile namespace="globus"   key="slots">8</profile>
+    <profile namespace="globus"   key="maxTime">1000</profile>
+    <profile namespace="globus"   key="nodeGranularity">1</profile>
+    <profile namespace="globus"   key="maxNodes">4</profile>
+  </pool>
+</config>
Copied: trunk/tests/mpi/local/tc.template.data (from rev 4991, trunk/tests/mpi/tc.template.data)
--- trunk/tests/mpi/local/tc.template.data	                        (rev 0)
+++ trunk/tests/mpi/local/tc.template.data	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,22 @@
+#This is the transformation catalog.
+#It comes pre-configured with a number of simple transformations with
+#paths that are likely to work on a linux box. However, on some systems,
+#the paths to these executables will be different (for example, sometimes
+#some of these programs are found in /usr/bin rather than in /bin)
+#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
+#there must be no trailing whitespace at the end of each line.
+# sitename  transformation  path   INSTALLED  platform  profiles
+localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
+localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
+localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
+localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
+localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
+localhost 	cp 		/bin/cp	        INSTALLED	INTEL32::LINUX	null
+# hydra-tests-2
+coasterslocal 	mpi_cp 		_DIR_/mpi-cp    INSTALLED	INTEL32::LINUX	globus::hostCount=2
Copied: trunk/tests/mpi/local/title.txt (from rev 4991, trunk/tests/mpi/title.txt)
--- trunk/tests/mpi/local/title.txt	                        (rev 0)
+++ trunk/tests/mpi/local/title.txt	2011-08-23 19:52:37 UTC (rev 4993)
@@ -0,0 +1,2 @@
+MPI Tests
Deleted: trunk/tests/mpi/sites.template.xml
--- trunk/tests/mpi/sites.template.xml	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/sites.template.xml	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,24 +0,0 @@
-<config>
-  <pool handle="localhost" sysinfo="INTEL32::LINUX">
-    <gridftp url="local://localhost" />
-    <execution provider="local" url="none" />
-    <workdirectory>_WORK_</workdirectory>
-    <profile namespace="swift" key="stagingMethod">file</profile>
-  </pool>
-  <pool handle="coasterslocal">
-    <filesystem provider="local" />
-    <execution provider="coaster" jobmanager="local:local"/>
-    <profile namespace="globus"   key="internalHostname">_HOST_</profile>
-    <profile namespace="karajan"  key="jobthrottle">2.55</profile>
-    <profile namespace="karajan"  key="initialScore">10000</profile>
-    <profile namespace="globus"   key="jobsPerNode">4</profile>
-    <profile namespace="globus"   key="slots">8</profile>
-    <profile namespace="globus"   key="maxTime">1000</profile>
-    <profile namespace="globus"   key="nodeGranularity">1</profile>
-    <profile namespace="globus"   key="maxNodes">4</profile>
-  </pool>
-</config>
Deleted: trunk/tests/mpi/tc.template.data
--- trunk/tests/mpi/tc.template.data	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/tc.template.data	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,22 +0,0 @@
-#This is the transformation catalog.
-#It comes pre-configured with a number of simple transformations with
-#paths that are likely to work on a linux box. However, on some systems,
-#the paths to these executables will be different (for example, sometimes
-#some of these programs are found in /usr/bin rather than in /bin)
-#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
-#there must be no trailing whitespace at the end of each line.
-# sitename  transformation  path   INSTALLED  platform  profiles
-localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
-localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
-localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
-localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
-localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
-localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
-localhost 	cp 		/bin/cp	        INSTALLED	INTEL32::LINUX	null
-# hydra-tests-2
-coasterslocal 	mpi_cp 		_DIR_/mpi-cp    INSTALLED	INTEL32::LINUX	globus::hostCount=2
Deleted: trunk/tests/mpi/title.txt
--- trunk/tests/mpi/title.txt	2011-08-23 19:51:45 UTC (rev 4992)
+++ trunk/tests/mpi/title.txt	2011-08-23 19:52:37 UTC (rev 4993)
@@ -1,2 +0,0 @@
-MPI Tests
