[Swift-commit] r4985 - branches/release-0.93/docs/siteguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Thu Aug 11 13:22:57 CDT 2011
Author: davidk
Date: 2011-08-11 13:22:57 -0500 (Thu, 11 Aug 2011)
New Revision: 4985
Added:
   branches/release-0.93/docs/siteguide/intrepid
Modified:
   branches/release-0.93/docs/siteguide/siteguide.txt
Log:
Start of intrepid entry in siteguide
Added: branches/release-0.93/docs/siteguide/intrepid
--- branches/release-0.93/docs/siteguide/intrepid	                        (rev 0)
+++ branches/release-0.93/docs/siteguide/intrepid	2011-08-11 18:22:57 UTC (rev 4985)
@@ -0,0 +1,168 @@
+Intrepid
+Requesting Access
+If you do not already have an account on Intrepid, you can request
+one at https://accounts.alcf.anl.gov/accounts/request.php. More information about
+this process and requesting allocations for your project can be found at
+http://www.alcf.anl.gov/support/gettingstarted/index.php.
+SSH Keys
+Accessing the Intrepid via SSH can be done with any SSH software package.
+Before logging in, you will need to generate an SSH public key and send it to
+support at alcf.anl.gov for verification and installation.
+Cryptocard
+This security token uses one-time passwords for controlled access to the BG/P login systems.
+Connecting to a login node
+When you gain access to Intrepid, you should receive a cryptocard and a temporary PIN.
+You must have a working cryptocard, know your PIN, and have your SSH key in place before
+you may login.
+You can connect to Intrepid with the following command:
+ssh yourusername at intrepid.alcf.anl.gov
+You will be presented with a password prompt. The first part of your password is your PIN. Enter you PIN,
+press the Cryptocard button, and then enter the password your crypocard generates. If this is the first
+time you are logging in, you will be prompted to change your PIN.
+Downloading and building Swift
+The most recent versions of Swift can be found at
+http://www.ci.uchicago.edu/swift/downloads/index.php. Follow the instructions
+provided on that site to download and build Swift.
+Adding Swift to your PATH
+Once you have installed Swift, add the Swift binary to your PATH so you can
+easily run it from any directory.
+In your home directory, edit the file ".bashrc".
+If you have installed Swift via a source repository, add the following line
+at the bottom of .bashrc.
+export PATH=$PATH:$HOME/cog/modules/swift/dist/swift-svn/bin
+If you have installed Swift via a binary package, add this line:
+export PATH=$PATH:$HOME/swift-<version>/bin
+Replace <version> with the actual name of the swift directory in the example above.
+What You Need To Know Before Running Swift
+Before you can create a Swift configuration file, there are some things
+you will need to know.
+Swift Work Directory
+The Swift work directory is a directory which Swift uses for processing work.
+This directory needs to be writable. Common options for this are:
+/home/username/swiftwork
+/home/username/work
+/tmp
+Which project(s) are you a member of?
+Intrepid requires that you are a member of a project. You can determine this by
+running the following command:
+$ projects
+HTCScienceApps
+If you are not a member of a project, you must first request access
+to a project. More information on this process can be found at
+https://wiki.alcf.anl.gov/index.php/Discretionary_Allocations
+Determine your Queue
+Intrepid has several different queues you can submit jobs to depending on
+the type of work you will be doing. The command "qstat -q" will print
+the most up to date list of this information.
+.Intrepid Queues
+[options="header"]
+|User Queue|Queue|Nodes|Time (hours)|User Maxrun|Project maxrun
+|prod-devel|prod-devel|64-512|0-1|5|20
+|prod|prod-short|512-4096|0-6|5|20
+|prod|prod-long|512-4096|6-12|5|20
+|prod|prod-capability|4097-32768|0-12|2|20
+|prod|prod-24k|16385-24576|0-12|2|20
+|prod|prod-bigrun|32769-40960|0-12|2|20
+|prod|backfill|512-8192|0-6|5|10
+Generating Configuration Files
+Now that you know what queue to use, your project, and your work directory, it is time to
+set up Swift. Swift uses a configuration file called sites.xml to determine how it should run.
+There are two methods you can use for creating this file. You can manually edit
+the configuration file, or generate it with a utility called gensites.
+Manually Editing sites.xml
+Below is the template that is used by Swift's test suite for running on Intrepid.
+TODO: Update the rest below here
+include::../../tests/providers/local-pbs/pads/sites.template.xml[]
+The values to note here are the ones that are listed between underscores. In the example above, they are _QUEUE_, and _WORK_. Queue is the PADS queue to use and WORK is the swift work directory. These are placeholder values you will need to modify to fit your needs. Copy and paste this template, replace the values, and call it sites.xml.
+Manually Editing tc.data
+Below is the tc.data file used by Swift's test suite for running on PADS.
+include::../../tests/providers/local-pbs/pads/tc.template.data[]
+Copy these commands and save it as tc.data.
+Catsn.swift
+The swift script we will run is called catsn.swift. It simply cats a file and saves the result. This is a nice simple test to ensure jobs are running correctly. Create a file called data.txt which contains some simple input - a "hello world" will do the trick.
+include::../../examples/misc/catsn.swift[]
+Running Swift
+Now that everything is in place, run Swift with the following command:
+swift -sites.file sites.xml -tc.file tc.data catsn.swift -n=10
+You should see several new files being created, called catsn.0001.out, catsn.0002.out, etc. Each of these
+files should contain the contents of what you placed into data.txt. If this happens, your job has run
+successfully on PADS!
+More Help
+The best place for additional help is the Swift user mailing list. You can subscribe to this list at
+https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user. When submitting information, please send your sites.xml file, your tc.data, and any Swift log files that were created during your attempt.
Modified: branches/release-0.93/docs/siteguide/siteguide.txt
--- branches/release-0.93/docs/siteguide/siteguide.txt	2011-08-11 17:32:43 UTC (rev 4984)
+++ branches/release-0.93/docs/siteguide/siteguide.txt	2011-08-11 18:22:57 UTC (rev 4985)
@@ -11,3 +11,5 @@
 include::beagle[]
 include::futuregrid[]
+include::intrepid[]
