[Swift-commit] r4982 - trunk/tests/providers/ssh
achavez at ci.uchicago.edu achavez at ci.uchicago.edu
Thu Aug 11 11:39:03 CDT 2011
Author: achavez
Date: 2011-08-11 11:39:03 -0500 (Thu, 11 Aug 2011)
New Revision: 4982
Modified:
   trunk/tests/providers/ssh/README
Log:
Placed a Warning, if a configuration file is used, user.provider.staging must be set to false if coasters is not needed.
Modified: trunk/tests/providers/ssh/README
--- trunk/tests/providers/ssh/README	2011-08-10 23:34:15 UTC (rev 4981)
+++ trunk/tests/providers/ssh/README	2011-08-11 16:39:03 UTC (rev 4982)
@@ -1,2 +1,5 @@
 May need to edit sites.template.xml file if work directory contained in $WORK differs on local and remote machines
 Requires auth.defaults to be set up correctly in ~/.ssh
+If the default configuration is overrided, and coasters is not required, the line in the configuration file:
+user.provider.staging
+must be set to false, otherwise the script will fail
