[Swift-commit] r4954 - branches/release-0.93/tests/local
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Aug 5 18:42:46 CDT 2011
Author: hategan
Date: 2011-08-05 18:42:45 -0500 (Fri, 05 Aug 2011)
New Revision: 4954
Modified:
   branches/release-0.93/tests/local/filesysmapper.check.sh
   branches/release-0.93/tests/local/range.check.sh
Log:
oops, that should be TEST_LOG
Modified: branches/release-0.93/tests/local/filesysmapper.check.sh
--- branches/release-0.93/tests/local/filesysmapper.check.sh	2011-08-05 23:33:01 UTC (rev 4953)
+++ branches/release-0.93/tests/local/filesysmapper.check.sh	2011-08-05 23:42:45 UTC (rev 4954)
@@ -2,8 +2,8 @@
 set -x
-ls $OUTPUT || exit 1
-COUNT=$( grep -c "file: [abc].dat" < $OUTPUT )
+ls $TEST_LOG || exit 1
+COUNT=$( grep -c "file: [abc].dat" < $TEST_LOG )
 (( $COUNT == 3 )) || exit 1
 exit 0
Modified: branches/release-0.93/tests/local/range.check.sh
--- branches/release-0.93/tests/local/range.check.sh	2011-08-05 23:33:01 UTC (rev 4953)
+++ branches/release-0.93/tests/local/range.check.sh	2011-08-05 23:42:45 UTC (rev 4954)
@@ -2,9 +2,9 @@
 set -x
-COUNT=$( grep -c "num:" $OUTPUT )
+COUNT=$( grep -c "num:" $TEST_LOG )
 (( $COUNT == 11 )) || exit 1
 exit 0
