[Swift-commit] r4947 - in branches/release-0.93/tests: . bugs groups language/working language-behaviour/mappers providers/local-pbs/fusion providers/local-pbs-coasters providers/local-pbs-coasters/fusion providers/local-pbs-coasters/pads
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Aug 5 00:14:57 CDT 2011
Author: hategan
Date: 2011-08-05 00:14:57 -0500 (Fri, 05 Aug 2011)
New Revision: 4947
Added:
   branches/release-0.93/tests/bugs/
   branches/release-0.93/tests/bugs/481-array-hang.swift
   branches/release-0.93/tests/language/working/015-mapper-literal.in
   branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.check.sh
   branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.setup.sh
   branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.swift
   branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.timeout
   branches/release-0.93/tests/providers/local-pbs-coasters/fusion/data.txt
   branches/release-0.93/tests/providers/local-pbs-coasters/fusion/sites.template.xml
   branches/release-0.93/tests/providers/local-pbs-coasters/fusion/tc.template.data
   branches/release-0.93/tests/providers/local-pbs-coasters/pads/
   branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.check.sh
   branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.setup.sh
   branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.swift
   branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.timeout
   branches/release-0.93/tests/providers/local-pbs-coasters/pads/data.txt
   branches/release-0.93/tests/providers/local-pbs-coasters/pads/sites.template.xml
   branches/release-0.93/tests/providers/local-pbs-coasters/pads/tc.template.data
Removed:
   branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh
   branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh
   branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift
   branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0001.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0002.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0003.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0004.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0005.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0006.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0007.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0008.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0009.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0010.out.expected
   branches/release-0.93/tests/providers/local-pbs-coasters/data.txt
   branches/release-0.93/tests/providers/local-pbs-coasters/sites.template.xml
   branches/release-0.93/tests/providers/local-pbs-coasters/tc.template.data
Modified:
   branches/release-0.93/tests/groups/group-all-local.sh
   branches/release-0.93/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh
   branches/release-0.93/tests/language/working/015-mapper-literal.swift
   branches/release-0.93/tests/providers/local-pbs/fusion/001-catsn.check.sh
   branches/release-0.93/tests/providers/local-pbs/fusion/001-catsn.setup.sh
   branches/release-0.93/tests/suite.sh
Log:
backported test fixes from trunk
Property changes on: branches/release-0.93/tests
___________________________________________________________________
Added: svn:mergeinfo
   + /trunk/tests:4762-4946
Deleted: branches/release-0.93/tests/bugs/481-array-hang.swift
--- trunk/tests/bugs/481-array-hang.swift	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/bugs/481-array-hang.swift	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,4 +0,0 @@
-int[] a = [1, 2, 3];
-// hangs waiting for a[4]
-trace(a[4]);
\ No newline at end of file
Copied: branches/release-0.93/tests/bugs/481-array-hang.swift (from rev 4946, trunk/tests/bugs/481-array-hang.swift)
--- branches/release-0.93/tests/bugs/481-array-hang.swift	                        (rev 0)
@@ -0,0 +1,4 @@
+int[] a = [1, 2, 3];
+// hangs waiting for a[4]
+trace(a[4]);
Modified: branches/release-0.93/tests/groups/group-all-local.sh
--- branches/release-0.93/tests/groups/group-all-local.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/groups/group-all-local.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -20,6 +20,7 @@
             $TESTDIR/language-behaviour/procedures \
             $TESTDIR/language-behaviour/strings \
 	    $TESTDIR/language-behaviour/variables \
+	    $TESTDIR/bugs \
 	    $TESTDIR/documentation/tutorial \
 	    # $TESTDIR/cdm/ps/pinned
 	    # $TESTDIR/site/intrepid
Copied: branches/release-0.93/tests/language/working/015-mapper-literal.in (from rev 4946, trunk/tests/language/working/015-mapper-literal.in)
Modified: branches/release-0.93/tests/language/working/015-mapper-literal.swift
--- branches/release-0.93/tests/language/working/015-mapper-literal.swift	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/language/working/015-mapper-literal.swift	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,2 +1,2 @@
 type myfile;
-myfile v<"literalfilename.txt">;
+myfile v<"015-mapper-literal.in">;
Modified: branches/release-0.93/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh
--- branches/release-0.93/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,6 +1,6 @@
 #!/bin/bash
 set -x
-cat $OUTPUT | grep "file: 07511-fixed-array-mapper-input.first.in" || exit 1
-cat $OUTPUT | grep "file: 07511-fixed-array-mapper-input.second.in" || exit 1
-cat $OUTPUT | grep "file: 07511-fixed-array-mapper-input.third.in" || exit 1
+cat $TEST_LOG | grep "file: 07511-fixed-array-mapper-input.first.in" || exit 1
+cat $TEST_LOG | grep "file: 07511-fixed-array-mapper-input.second.in" || exit 1
+cat $TEST_LOG | grep "file: 07511-fixed-array-mapper-input.third.in" || exit 1
 exit 0
Modified: branches/release-0.93/tests/providers/local-pbs/fusion/001-catsn.check.sh
--- branches/release-0.93/tests/providers/local-pbs/fusion/001-catsn.check.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs/fusion/001-catsn.check.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,9 +1,9 @@
 #!/bin/bash
-# Pseudo-code for now
+set -x
-# for f in *.out.expected
-# do
-#   assert *.out exists
-#   assert *.out.expected == *.out
-# done
+LINES=$( ls catsn*.out | wc -l )
+[[ ${?} == 0 ]] || exit 1
+[[ ${LINES} == 10 ]] || exit 1
+exit 0
Modified: branches/release-0.93/tests/providers/local-pbs/fusion/001-catsn.setup.sh
--- branches/release-0.93/tests/providers/local-pbs/fusion/001-catsn.setup.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs/fusion/001-catsn.setup.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,4 +1,4 @@
 #!/bin/bash
 cp -v $GROUP/data.txt . || exit 1
-cp -v $GROUP/*expected . || exit 1
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh
--- branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,12 +0,0 @@
-#!/bin/bash
-set -x
-for count in `seq --format "%04.f" 1 1 10`
-do
-	[ -f catsn.$count.out ] || exit 1
-	CONTENTS1=$( cat catsn.$count.out.expected )
-	CONTENTS2=$( cat catsn.$count.out )
-	[[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
-done
-exit 0
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh
--- branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,4 +0,0 @@
-#!/bin/bash
-cp -v $GROUP/data.txt . || exit 1
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift
--- branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,15 +0,0 @@
-type file;
-app (file o) cat (file i)
-  cat @i stdout=@o;
-string t = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
-string char[] = @strsplit(t, "");
-file out[]<simple_mapper; location=".", prefix="catsn.",suffix=".out">;
-foreach j in [1:@toint(@arg("n","10"))] {
-  file data<"data.txt">;
-  out[j] = cat(data);
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout
--- branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,2 +0,0 @@
-7200
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0001.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0001.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0001.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0002.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0002.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0002.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0003.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0003.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0003.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0004.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0004.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0004.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0005.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0005.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0005.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0006.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0006.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0006.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0007.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0007.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0007.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0008.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0008.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0008.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0009.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0009.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0009.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0010.out.expected
--- branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0010.out.expected	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/catsn.0010.out.expected	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/data.txt
--- branches/release-0.93/tests/providers/local-pbs-coasters/data.txt	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/data.txt	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.check.sh (from rev 4946, trunk/tests/providers/local-pbs-coasters/fusion/001-catsn.check.sh)
--- branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.check.sh	                        (rev 0)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.check.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+for count in `seq --format "%04.f" 1 1 10`
+do
+	[ -f catsn.$count.out ] || exit 1
+	CONTENTS1=$( cat catsn.$count.out.expected )
+	CONTENTS2=$( cat catsn.$count.out )
+	[[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
+done
+exit 0
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.setup.sh (from rev 4946, trunk/tests/providers/local-pbs-coasters/fusion/001-catsn.setup.sh)
--- branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.setup.sh	                        (rev 0)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.setup.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -0,0 +1,4 @@
+#!/bin/bash
+cp -v $GROUP/data.txt . || exit 1
+cp -v $GROUP/*expected . || exit 1
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.swift (from rev 4946, trunk/tests/providers/local-pbs-coasters/fusion/001-catsn.swift)
--- branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.swift	                        (rev 0)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.swift	2011-08-05 05:14:57 UTC (rev 4947)
@@ -0,0 +1,15 @@
+type file;
+app (file o) cat (file i)
+  cat @i stdout=@o;
+string t = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
+string char[] = @strsplit(t, "");
+file out[]<simple_mapper; location=".", prefix="catsn.",suffix=".out">;
+foreach j in [1:@toint(@arg("n","10"))] {
+  file data<"data.txt">;
+  out[j] = cat(data);
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.timeout (from rev 4946, trunk/tests/providers/local-pbs-coasters/fusion/001-catsn.timeout)
--- branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.timeout	                        (rev 0)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/fusion/001-catsn.timeout	2011-08-05 05:14:57 UTC (rev 4947)
@@ -0,0 +1,2 @@
+7200
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/fusion/data.txt (from rev 4946, trunk/tests/providers/local-pbs-coasters/fusion/data.txt)
--- branches/release-0.93/tests/providers/local-pbs-coasters/fusion/data.txt	                        (rev 0)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/fusion/data.txt	2011-08-05 05:14:57 UTC (rev 4947)
@@ -0,0 +1 @@
+Hello world
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/fusion/sites.template.xml (from rev 4946, trunk/tests/providers/local-pbs-coasters/fusion/sites.template.xml)
--- branches/release-0.93/tests/providers/local-pbs-coasters/fusion/sites.template.xml	                        (rev 0)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/fusion/sites.template.xml	2011-08-05 05:14:57 UTC (rev 4947)
@@ -0,0 +1,17 @@
+<config>
+<pool handle="local-pbs-coasters">
+  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
+  <filesystem provider="local" url="none" />
+  <profile namespace="globus" key="maxWallTime">1</profile>
+  <profile namespace="globus" key="maxTime">7200</profile>
+  <profile key="jobsPerNode" namespace="globus">1</profile>
+  <profile key="slots" namespace="globus">1</profile>
+  <profile key="nodeGranularity" namespace="globus">1</profile>
+  <profile key="maxNodes" namespace="globus">1</profile>
+  <profile key="queue" namespace="globus">_QUEUE_</profile>
+  <profile key="jobThrottle" namespace="karajan">5.99</profile>
+  <profile key="initialScore" namespace="karajan">10000</profile>
+  <profile namespace="globus" key="project">_PROJECT_</profile>
+  <workdirectory>_WORK_</workdirectory>
+</pool>
+</config>
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/fusion/tc.template.data (from rev 4946, trunk/tests/providers/local-pbs-coasters/fusion/tc.template.data)
--- branches/release-0.93/tests/providers/local-pbs-coasters/fusion/tc.template.data	                        (rev 0)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/fusion/tc.template.data	2011-08-05 05:14:57 UTC (rev 4947)
@@ -0,0 +1,8 @@
+local-pbs-coasters 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
+local-pbs-coasters 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+local-pbs-coasters 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
+local-pbs-coasters 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
+local-pbs-coasters 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
+local-pbs-coasters 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
+local-pbs-coasters	wc		/usr/bin/wc	INSTALLED	INTEL32::LINUX	null
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.check.sh
--- trunk/tests/providers/local-pbs-coasters/pads/001-catsn.check.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.check.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,12 +0,0 @@
-#!/bin/bash
-set -x
-do
-done
-exit 0
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.check.sh (from rev 4946, trunk/tests/providers/local-pbs-coasters/pads/001-catsn.check.sh)
--- branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.check.sh	                        (rev 0)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+do
+done
+exit 0
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.setup.sh
--- trunk/tests/providers/local-pbs-coasters/pads/001-catsn.setup.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.setup.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,4 +0,0 @@
-#!/bin/bash
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.setup.sh (from rev 4946, trunk/tests/providers/local-pbs-coasters/pads/001-catsn.setup.sh)
--- branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.setup.sh	                        (rev 0)
@@ -0,0 +1,4 @@
+#!/bin/bash
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.swift
--- trunk/tests/providers/local-pbs-coasters/pads/001-catsn.swift	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.swift	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,15 +0,0 @@
-type file;
-  cat @i stdout=@o;
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.swift (from rev 4946, trunk/tests/providers/local-pbs-coasters/pads/001-catsn.swift)
--- branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.swift	                        (rev 0)
@@ -0,0 +1,15 @@
+type file;
+  cat @i stdout=@o;
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.timeout
--- trunk/tests/providers/local-pbs-coasters/pads/001-catsn.timeout	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.timeout	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,2 +0,0 @@
-7200
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.timeout (from rev 4946, trunk/tests/providers/local-pbs-coasters/pads/001-catsn.timeout)
--- branches/release-0.93/tests/providers/local-pbs-coasters/pads/001-catsn.timeout	                        (rev 0)
@@ -0,0 +1,2 @@
+7200
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/pads/data.txt
--- trunk/tests/providers/local-pbs-coasters/pads/data.txt	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/pads/data.txt	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1 +0,0 @@
-Hello world
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/pads/data.txt (from rev 4946, trunk/tests/providers/local-pbs-coasters/pads/data.txt)
--- branches/release-0.93/tests/providers/local-pbs-coasters/pads/data.txt	                        (rev 0)
@@ -0,0 +1 @@
+Hello world
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/pads/sites.template.xml
--- trunk/tests/providers/local-pbs-coasters/pads/sites.template.xml	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/pads/sites.template.xml	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,17 +0,0 @@
-<config>
-<pool handle="local-pbs-coasters">
-  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
-  <filesystem provider="local" url="none" />
-  <profile namespace="globus" key="maxWallTime">1</profile>
-  <profile namespace="globus" key="maxTime">7200</profile>
-  <profile key="jobsPerNode" namespace="globus">1</profile>
-  <profile key="slots" namespace="globus">1</profile>
-  <profile key="nodeGranularity" namespace="globus">1</profile>
-  <profile key="maxNodes" namespace="globus">1</profile>
-  <profile key="queue" namespace="globus">_QUEUE_</profile>
-  <profile key="jobThrottle" namespace="karajan">5.99</profile>
-  <profile key="initialScore" namespace="karajan">10000</profile>
-  <profile namespace="globus" key="project">_PROJECT_</profile>
-  <workdirectory>_WORK_</workdirectory>
-</pool>
-</config>
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/pads/sites.template.xml (from rev 4946, trunk/tests/providers/local-pbs-coasters/pads/sites.template.xml)
--- branches/release-0.93/tests/providers/local-pbs-coasters/pads/sites.template.xml	                        (rev 0)
@@ -0,0 +1,17 @@
+<config>
+</pool>
+</config>
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/pads/tc.template.data
--- trunk/tests/providers/local-pbs-coasters/pads/tc.template.data	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/pads/tc.template.data	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,8 +0,0 @@
-local-pbs-coasters 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
-local-pbs-coasters 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
-local-pbs-coasters 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
-local-pbs-coasters 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
-local-pbs-coasters 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
-local-pbs-coasters 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
-local-pbs-coasters	wc		/usr/bin/wc	INSTALLED	INTEL32::LINUX	null
Copied: branches/release-0.93/tests/providers/local-pbs-coasters/pads/tc.template.data (from rev 4946, trunk/tests/providers/local-pbs-coasters/pads/tc.template.data)
--- branches/release-0.93/tests/providers/local-pbs-coasters/pads/tc.template.data	                        (rev 0)
@@ -0,0 +1,8 @@
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/sites.template.xml
--- branches/release-0.93/tests/providers/local-pbs-coasters/sites.template.xml	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/sites.template.xml	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,17 +0,0 @@
-<config>
-</pool>
-</config>
Deleted: branches/release-0.93/tests/providers/local-pbs-coasters/tc.template.data
--- branches/release-0.93/tests/providers/local-pbs-coasters/tc.template.data	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/providers/local-pbs-coasters/tc.template.data	2011-08-05 05:14:57 UTC (rev 4947)
@@ -1,8 +0,0 @@
Modified: branches/release-0.93/tests/suite.sh
--- branches/release-0.93/tests/suite.sh	2011-08-05 00:18:28 UTC (rev 4946)
+++ branches/release-0.93/tests/suite.sh	2011-08-05 05:14:57 UTC (rev 4947)
@@ -97,7 +97,7 @@
   HTML_COMMENTS=1
 fi
-if [ $COLORIZE ]; then
+if (( $COLORIZE )); then
 	LGREEN="\033[1;32m"
 	YELLOW="\033[1;33m"
 	RED="\033[1;31m"
@@ -411,7 +411,7 @@
   echo "| $G"
   echo "|"
   echo -e "\\----------------------------------------------------${GRAY}"
-  echo
+  echo
   if [ $TEXTREPORT == 1 ]; then
   	  stars
 	  printf "$G\n">>$REPORT
@@ -426,7 +426,7 @@
 	  html "$G"
 	  html_~th
 	  html_~tr
 	 html_tr group
 	 html_td
 	 html "#"
@@ -684,7 +684,7 @@
   rm killed_test > /dev/null 2>&1 && sleep 5
   verbose "killing monitor: $MONITOR_PID..."
   kill $MONITOR_PID
   INDIVIDUAL_TEST_TIME=$(( STOP-START ))
   TOTAL_TIME=$(( INDIVIDUAL_TEST_TIME+TOTAL_TIME ))
   echo -e "${YELLOW}TOOK (seconds): $INDIVIDUAL_TEST_TIME${GRAY}"
@@ -717,6 +717,7 @@
   process_exec $SCRIPT
   RESULT=$( result )
+  test_log
   output_report test "$SYMBOL" "$LASTCMD" $RESULT
   check_bailout
@@ -725,9 +726,9 @@
 stage_files() {
 	GROUP=$1
 	NAME=$2
 	RESULT="None"
 	if [ -f $GROUP/$NAME.in ]; then
 		echo "Copying input: $NAME.in"
 		cp -v $GROUP/$NAME.in . 2>&1 >> $OUTPUT
@@ -749,18 +750,18 @@
 			RESULT="Passed"
 		fi
 	done
 	output_report test "s" "setup" $RESULT
 	check_bailout
 check_outputs() {
 	GROUP=$1
 	NAME=$2
 	RESULT="None"
 	for EXPECTED in $GROUP/$NAME.*.expected; do
 		BNE=`basename $EXPECTED .expected`
 		echo -n "Checking output: $BNE "
@@ -775,15 +776,15 @@
 			RESULT="Passed"
 		fi
 	done
 	if [ "$RESULT" == "None" ]; then
 		html_td width 25
    		html "  "
    		html_~td
 	fi
 	output_report test "√" "check" $RESULT
 	check_bailout
@@ -791,7 +792,7 @@
 swift_test_case() {
   SWIFTSCRIPT=$1
   NAME=${SWIFTSCRIPT%.swift}
   SETUPSCRIPT=$NAME.setup.sh
   CHECKSCRIPT=$NAME.check.sh
   CLEANSCRIPT=$NAME.clean.sh
@@ -804,12 +805,12 @@
   else
     stage_files $GROUP $NAME
   fi
   ARGS=""
   if [ -f $GROUP/$ARGSFILE ]; then
   	ARGS=`cat $GROUP/$ARGSFILE`
   fi
   CDM=
   [ -r fs.data ] && CDM="-cdm.file fs.data"
@@ -848,9 +849,9 @@
 script_test_case() {
   SHELLSCRIPT=$1
