[Swift-commit] r4945 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Thu Aug 4 16:30:54 CDT 2011
Author: jonmon
Date: 2011-08-04 16:30:54 -0500 (Thu, 04 Aug 2011)
New Revision: 4945
Modified:
   SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py
Log:
o Changed the 'ps -u $USER -f' to 'ps -u $USER -H -f'
o Added get the Swift pid from the swift.info file
o Getting list of processes to kill is broken.  Don't parse the lines from the 'ps' output correctly.
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py	2011-08-04 20:02:30 UTC (rev 4944)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py	2011-08-04 21:30:54 UTC (rev 4945)
@@ -20,22 +20,34 @@
                       default=False, action="store_true",
                       help="Stop/resume a run my the run id")
-    (options, args) pykoa.tools.parse_args(parser, argv)
+    (options, args) = pykoa.tools.parse_args(parser, argv)
     return (parser, options, args)
 def stop(run_id):
     user = os.environ["USER"]
-    (status, output) = commands.getstatusoutput("ps -u "+user+" -f")
+    (status, output) = commands.getstatusoutput("ps -u "+user+" -H -f")
     if status != 0:
         sys.stderr.write("Failed to get a list of running processes\n")
         return 1
-    ppid = ??
+    ppid = -1
+    with open(os.environ["HOME"]+"/Swift/run."+run_id+"/swift.info") as swift_info:
+        for line in swift_info.readlines():
+            line_parsed = line.split(":")
+            if line_parsed[0] == "Swift pid":
+                ppid = int(line_parsed[1].strip())
+                break
+    if ppid == -1:
+        sys.stderr.write("Could not find the Swift pid from the swift.info file\n")
+        return 1
     processes = [ppid]
-    lines = []
-    for line in ouput.split("\n"):
-        parsed_line = line.split(" ")
+    # BROKEN: Doesn't parse the 'ps' output correctly. Fix the 'parsed_line' split delimiter
+    for line in output.split("\n"):
+        parsed_line = line.split()
         if ppid == parsed_line[2]:
             processes.append(parsed_line[1])
             ppid = int(parsed_line[1])
