[Swift-commit] r4932 - in SwiftApps/GOSwift: bin pykoa/tools
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Tue Aug 2 16:35:31 CDT 2011
Author: jonmon
Date: 2011-08-02 16:35:30 -0500 (Tue, 02 Aug 2011)
New Revision: 4932
Added:
   SwiftApps/GOSwift/bin/koa-goswift-run
   SwiftApps/GOSwift/pykoa/tools/koa_goswift_run.py
Removed:
   SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o rename koa_goswift to koa_goswift_run
o cleaned up the getting of the credentials business
o Fixed issues with writing information to the log. Wrong error code was being written to the log
o remove proxy file when execution is finished
Deleted: SwiftApps/GOSwift/bin/koa-goswift
--- SwiftApps/GOSwift/bin/koa-goswift	2011-08-02 16:28:12 UTC (rev 4931)
+++ SwiftApps/GOSwift/bin/koa-goswift	2011-08-02 21:35:30 UTC (rev 4932)
@@ -1,15 +0,0 @@
-#!/bin/sh
-if [ -z "$KOA_HOME" ]; then
-   echo "Error: KOA_HOME must be set"
-   exit 1
-fi
-if [ -s "$KOA_USER" ]; then
-   echo "Error: KOA_USER must be set"
-   exit 1
-fi
-export KOA_API_11=TRUE
-exec $KOA_HOME/pykoa/tools/koa_goswift.py "$@"
Copied: SwiftApps/GOSwift/bin/koa-goswift-run (from rev 4924, SwiftApps/GOSwift/bin/koa-goswift)
--- SwiftApps/GOSwift/bin/koa-goswift-run	                        (rev 0)
+++ SwiftApps/GOSwift/bin/koa-goswift-run	2011-08-02 21:35:30 UTC (rev 4932)
@@ -0,0 +1,15 @@
+#!/bin/sh
+if [ -z "$KOA_HOME" ]; then
+   echo "Error: KOA_HOME must be set"
+   exit 1
+fi
+if [ -s "$KOA_USER" ]; then
+   echo "Error: KOA_USER must be set"
+   exit 1
+fi
+export KOA_API_11=TRUE
+exec $KOA_HOME/pykoa/tools/koa_goswift_run.py "$@"
Deleted: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-08-02 16:28:12 UTC (rev 4931)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-08-02 21:35:30 UTC (rev 4932)
@@ -1,478 +0,0 @@
-#!/usr/bin/python
-import os
-import re
-import sys
-import subprocess
-import commands
-import datetime
-import stat
-from sqlalchemy.sql import text
-import pykoa
-import pykoa.tools
-from pykoa.process_observer import ProcessObserver
-from pykoa.signal_util import BlockInterrupt, enable_sigint
-from pykoa.tools import url_parse, myproxy
-from pykoa.tools import koa_transfer
-from pykoa.tools.koa_ep_activate import check_explicit_activate
-from pykoa.consumers import guc_util
-from pykoa.constants import get_scheme
-from pykoa.data import endpoint_dao
-from pykoa.data import creds_dao
-from pykoa.koaexception import ToolsException, cli_exception_handler
-class SwiftObserver(ProcessObserver):
-    def __init__(self):
-        self.lines = []
-    def stdout_event(self, line):
-        sys.stdout.write(line)
-        self.lines.append(line)
-        return
-    def stderr_event(self, line):
-        sys.stderr.write(line)
-        return
-def setup_opts(argv):
-    # Set up help message
-    help_screen = """ \
-goswift [options] <credentials> < \"goswift.package\"
-Executes Swift under Globus Online. The <sites> must be logical sites. This will not work for physical sites.
-Add site using endpoint-add and configure site using endpoint-modify.
-Type 'man goswift' for details. \
-    # parse out options
-    parser = pykoa.tools.get_option_parser(help_screen)
-    parser.add_option("--dry-run", dest="do_not_execute",
-                      default=False, action="store_true",
-                      help="Output the Swift command line that will execute the workflow and the configuration files")
-    parser.add_option("--watch", dest="watch_swift_stdoutput",
-                      help="Run Swift as an immediate command. Watch the output that Swift produces")
-    parser.add_option("--trunk", dest="trunk",
-                      help="Run the development trunk version of Swift")
-    parser.add_option("--stable", dest="stable",
-                      default=True, action="store_true",
-                      help="Run the most stable release version")
-    parser.add_option("-d", dest="deadline",
-                      default="30m",
-                      help="Set the time limit for this workflow.  " + \
-                           "Default: 30m (30 minutes)")
-    parser.add_option("-g", dest="gsi_activation",
-                      help="Use gsi-ssh delegated credential")
-    myproxy.add_myproxy_options(parser)
-    (options, args) = pykoa.tools.parse_args(parser, argv)
-    if options.gsi_activation and not os.getenv("X509_USER_PROXY"):
-        raise ToolsException("ENO_GSI_SSH")
-    return (parser, options, args)
-def parse_stdin():
-    lines = []
-    index = 0
-    lines = sys.stdin.readlines()
-    tc         = extract_tc( lines )
-    sites_file = extract_sites( lines )
-    config     = extract_config( lines )
-    script     = extract_script( lines )
-    return ( tc, sites_file, config, script )
-def extract_tc( lines ):
-    begin_tc = False
-    tc       = ""
-    for line in lines:
-        line=line.rstrip()
-        if line == "# begin tc":
-            begin_tc = True
-        elif line == "# end tc":
-            begin_tc = False
-            break
-        elif begin_tc:
-            tc += line + "\n"
-    return tc
-def extract_sites( lines ):
-    begin_sites = False
-    sites       = ""
-        if line == "# begin sites":
-            begin_sites = True
-        elif line == "# end sites":
-            break
-        elif begin_sites:
-            sites += line + "\n"
-    return sites
-def extract_config( lines ):
-    begin_config = False
-    config       = ""
-        if line == "# begin config":
-            begin_config = True
-        elif line == "# end config":
-            break
-        elif begin_config:
-            config += line + "\n"
-    return config
-def extract_script( lines ):
-    begin_script = False
-    script       = ""
-        if line == "# begin script":
-            begin_script = True
-        elif line == "# end script":
-            break
-        elif begin_script:
-            script += line + "\n"
-    return script
-def get_creds(args, conn, user_id, options):
-    # A logical endpoint (no dots) can be a scp like path, if it has a :
-    # This for loop is wrong.  If I am understanding this correctly, this should only parsethe last site I pass the script.
-    # A current issue is that the site must also be accompanied by a path, which is not necessary for Swift execution.
-    # Unless I leave it and use the path given as the work directory on the site in the sites.xml file?
-    for arg in args:
-        if re.match("^[^.]+:", arg):
-            url = url_parse.SCPUrl(arg, allow_empty_path=True)
-            url.update_relative_path()
-        else:
-            url = url_parse.TransferURL(arg)
-    src_url = None
-    src_cred = None
-    default_myproxy = None
-    ep = None
-    if not url.scheme:
-        # See if it's a logical endpoint
-        ep = endpoint_dao.get_logical_by_name(conn, user_id, url.name)
-        if not ep:
-            ep = endpoint_dao.get_public_by_name(conn, url.name)
-    if ep:
-	default_myproxy = ep.myproxy_server
-	# Get first physical ep, if exists
-	phys = endpoint_dao.get_physicals_for_logical(conn, ep.id)
-	if not phys:
-	    raise ToolsException("No physical server exists for '%s'" % (
-		url.name))
-	phys = phys[0]
-	scheme = get_scheme(phys.xfer_service_id)
-	src_url = "%s://%s:%d%s" % (scheme, phys.hostname, phys.port, url.path)
-	src_subject = phys.x509_dn
-	# See if LTA endpoint is connected
-	if phys.is_lta and phys.alive == 0:
-	    raise ToolsException("The requested Globus Connect endpoint is not currently connected to Globus Online")
-	# Get creds
-	row = creds_dao.get_cred_for_logical(conn, user_id, ep.id)
-	if row and row.exp_time > datetime.datetime.utcnow():
-	    src_cred = row.sec_info
-    if not src_url:
-        # Not a logical endpoint
-	if "." not in url.name:
-	    raise ToolsException("EEXIST_ENDPOINT", url.name)
-            url.scheme = "gsiftp"
-        if not url.port:
-            url.port = "2811"
-        src_url = url.full_name + url.path
-        src_subject = ""
-        src_cred = None
-    # Get creds
-    if options.gsi_activation:
-	if ep:
-	    check_explicit_activate([ep])
-        cred_file = os.environ["X509_USER_PROXY"]
-        src_cred = open(cred_file).read()
-    elif options.myproxy_host or ((not src_cred) and default_myproxy):
-        if not options.myproxy_host:
-            options.myproxy_host = default_myproxy
-	if ep:
-	    check_explicit_activate([ep], options.myproxy_host)
-        cred_file = myproxy.contact_myproxy_server(options.myproxy_host,
-                                                   options.myproxy_user, options.myproxy_dn,
-                                                   lifetime=options.myproxy_lifetime)
-        if not cred_file:
-            return 1
-        try:
-            if ep:
-                # Save to the database
-                ep_cache = {"foo": ep.id}
-                koa_transfer.do_activate(conn, cred_file, ep_cache, user_id,
-                                         quiet=True)
-        finally:
-            os.remove(cred_file)
-    if not src_cred:
-        raise ToolsException("A credential is needed.  Try -g or -m.")
-    return (src_url, src_cred, src_subject)
-def execute_swift(user_id, options, src_url, src_cred, src_subject, work_directory, run_id):
-    if src_subject:
-        os.environ["GLOBUS_FTP_CLIENT_TEST_SUBJECT"] = src_subject
-    if src_cred:
-        proxyfile = guc_util.sec_text_to_proxy_file(user_id, src_cred)
-        os.environ["X509_USER_CERT"] = proxyfile
-        os.environ["X509_USER_KEY"] = proxyfile
-        os.environ["X509_USER_PROXY"] = proxyfile
-    # Not sure this will work all the time, but this is what the internet said i could do.
-    # Need to check for errors, maybe should use the commands module for this part so I can get the status and output at the same time
-    cmd = "curl http://169.254.169.254/2009-04-04/meta-data/public-ipv4"
-    (status, host ) = commands.getstatusoutput( cmd )
-    if status != 0:
-        sys.stderr.write( "Could not determine hostname\n" )
-        return status
-    # There has to be an easier way to get the last line of a string
-    # Maybe limit the curl output from above
-    lines = []
-    for line in host.split("\n"):
-        lines.append(line)
-    host = lines[len(lines)-1]
-    os.environ["GLOBUS_HOSTNAME"] = host
-    os.environ["GLOBUS_TCP_PORT_RANGE"] = "50000,51000"
-    os.environ["GLOBUS_SOURCE_PORT_RANGE"] = "50000,51000"
-    # Execute the script
-    cmd = ""
-    if options.trunk:
-        cmd = os.path.join(os.environ["HOME"], "Swift_lib/trunk", "swift")             # trunk release
-    elif options.stable:
-        cmd = os.path.join(os.environ["HOME"], "Swift_lib/0.92", "swift")              # stable 0.92.1 release
-    os.chdir(work_directory)
-    status = -1
-    pid = -1
-    if options.watch_swift_stdoutput:
-        try:
-            with BlockInterrupt():
-                execute = cmd + " -runid "+str(run_id)+" -sites.file sites.xml -tc.file tc -config cf script.swift"
-                pykoa.debug( "running %s in watch mode" % (execute))
-                with open(work_directory+"/run.sh", "w") as run_sh:
-                    run_sh.write( "#!/bin/bash\n" )
-                    run_sh.write( "[ -f /opt/osg/setup.sh ] && source /opt/osg/setup.sh\n")
-                    run_sh.write( execute + "\n" )
-                    run_sh.write( "\n" )
-                    run_sh.write( "echo \"\nExit Code: $?\" >> swift.info\n" )
-                    run_sh.write( "exit $?" )
-                os.chmod(work_directory+"/run.sh", stat.S_IRUSR | stat.S_IXUSR )
-                p = subprocess.Popen("exec "+work_directory+"/run.sh",
-                                     close_fds=True, shell=True,
-                                     preexec_fn=enable_sigint,
-                                     cwd=os.getcwd(),
-                                     stdout=subprocess.PIPE,
-                                     stderr=subprocess.PIPE)
-                pid = p.pid
-                with open("swift.info", "w") as swift_info:
-                    swift_info.write("StartTime: "+str(datetime.datetime.utcnow())+"\n")
-                    swift_info.write("Swift pid: "+str(pid)+"\n")
-                    swift_info.write("Run id:    "+str(run_id)+"\n")
-                    swift_info.write("\n")
-                    swift_info.write("Command Line:\n     "+execute+"\n")
-                c = SwiftObserver()
-                status = c.run(p)
-        finally:
-            if src_cred:
-                os.remove( proxyfile )
-        with open("swift.out", "w") as swift_out:
-            for line in c.lines:
-                swift_out.write(line)
-        sys.stdout.write( "Swift exit status: " + str(status) + "\n" )
-    else:
-        swift_out = open("swift.out", "w")
-        pykoa.debug( "running %s in background mode" % (execute))
-            run_sh.write( "echo \"\nExit Code: $? >> swift.info\"\n" )
-                             cwd=os.getcwd(),
-                             stderr=subprocess.STDOUT,
-                             stdout=swift_out)
-        pid = p.pid
-        swift_out.close()
-    return status
-def create_work_directory():
-    # check to see is the swift directory has been created
-    home = os.getenv( "HOME" )
-    swift_dir = home + "/Swift"
-    if not os.access( swift_dir, os.F_OK ):
-        os.mkdir( swift_dir )
-    # default is run.0, if there are other directories then adjust the run directory count
-    run_directory = "run.0"
-    last_run = 0
-    directories = os.listdir( swift_dir )
-    # This might cause a performance problem(to even begin to start Swift)
-    # Need to figure out how maybe purge these run directories
-    # For now I can manually purge
-    runs = []
-    for direc in directories:
-        ( name, sep, run_num ) = direc.partition( "." )
-        try:
-            runs.append( int( run_num) )
-        except ValueError:
-            pykoa.debug( "Directory "+direc+" is not a run directory" )
-    runs.sort()
-    # if the directories list is not empty, create the name of the run directory
-    if runs:
-        last_run = runs[ len(runs)-1 ] + 1
-        run_directory = "run."+str(last_run)
-    work_directory = swift_dir+"/"+run_directory
-    return (work_directory, last_run)
-# Do not know what this syntax is but pops up in other pykoa_* files, so I kept it
- at cli_exception_handler
-def main( argv=sys.argv[1:] ):
-    (parser, options, args) = setup_opts(argv)
-    # If I did not specify at least one site, print help message
-    if len(args) != 1:
-        parser.print_help()
-        return 1
-    # Not sure what these lines do yet, just copied from koa-ly.py
-    guc_util.init_guc_env()
-    conn     = pykoa.connect()
-    user_row = pykoa.tools.cli_get_user( conn )
-    user_id  = user_row.id
-    # get the swift input package
-    ( tc, sites, config, script ) = parse_stdin()
-    (work_directory, run_id) = create_work_directory()
-    # get a space seperated String of the sites to execute on
-    execution_sites=" ".join( map ( str, args ) )
-    sys.stdout.write( "\nExecuting Swift with " + execution_sites + " credentials\n" )
-    sys.stdout.write( "Execution directory: " + work_directory + "\n" )
-    # If I do not execute the script, just print out all important information
-    # useful to verify that the inputs to the Swift command line have been parsed correctly
-    if options.do_not_execute:
-        sys.stdout.write( "\nTC file: \n" + tc + "\n" )
-        sys.stdout.write( "SITES file: \n" + sites + "\n" )
-        sys.stdout.write( "CONFIG file: \n" + config + "\n" )
-        sys.stdout.write( "SWIFTSCRIPT file: \n" + script + "\n" )
-        sys.stdout.write( "swift -sites.file sites.xml -tc.file tc -config cf script.swift\n\n" )
-        return 0
-    # Set up for the acutal execution
-    try:
-        os.mkdir( work_directory )
-        pykoa.debug( "Created work_directory: " + work_directory )
-    except os.error:
-        sys.stderr.write( work_directory + " already exists, clean up " + os.getenv("HOME") + "/Swift" )
-        pykoa.debug( work_directory + " already exists" )
-        return 1
-    with open( work_directory+"/tc", "w" ) as tc_file:
-        tc_file.write( tc )
-    with open( work_directory+"/sites.xml", "w" ) as sites_file:
-        sites_file.write( sites )
-    with open( work_directory+"/cf", "w" ) as config_file:
-        config_file.write( config )
-    with open( work_directory+"/script.swift", "w" ) as script_file:
-        script_file.write( script )
-    (src_url, src_cred, src_subject ) = get_creds(args, conn, user_id, options)
-    ret = execute_swift(user_id, options, src_url, src_cred, src_subject, work_directory, run_id)
-    return ret
-if __name__ == "__main__":
-    rc = main()
-    sys.exit(rc)
Copied: SwiftApps/GOSwift/pykoa/tools/koa_goswift_run.py (from rev 4931, SwiftApps/GOSwift/pykoa/tools/koa_goswift.py)
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift_run.py	                        (rev 0)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift_run.py	2011-08-02 21:35:30 UTC (rev 4932)
@@ -0,0 +1,432 @@
+#!/usr/bin/python
+import os
+import re
+import sys
+import subprocess
+import commands
+import datetime
+import stat
+from sqlalchemy.sql import text
+import pykoa
+import pykoa.tools
+from pykoa.process_observer import ProcessObserver
+from pykoa.signal_util import BlockInterrupt, enable_sigint
+from pykoa.tools import url_parse, myproxy
+from pykoa.tools import koa_transfer
+from pykoa.tools.koa_ep_activate import check_explicit_activate
+from pykoa.consumers import guc_util
+from pykoa.constants import get_scheme
+from pykoa.data import endpoint_dao
+from pykoa.data import creds_dao
+from pykoa.koaexception import ToolsException, cli_exception_handler
+class SwiftObserver(ProcessObserver):
+    def __init__(self):
+        self.lines = []
+    def stdout_event(self, line):
+        sys.stdout.write(line)
+        self.lines.append(line)
+        return
+    def stderr_event(self, line):
+        sys.stderr.write(line)
+        return
+def setup_opts(argv):
+    # Set up help message
+    help_screen = """ \
+goswift [options] <credentials> < \"goswift.package\"
+Executes Swift under Globus Online. The <sites> must be logical sites. This will not work for physical sites.
+Add site using endpoint-add and configure site using endpoint-modify.
+Type 'man goswift' for details. \
+    # parse out options
+    parser = pykoa.tools.get_option_parser(help_screen)
+    parser.add_option("--dry-run", dest="do_not_execute",
+                      default=False, action="store_true",
+                      help="Output the Swift command line that will execute the workflow and the configuration files")
+    parser.add_option("--now", dest="watch_swift_stdoutput",
+                      help="Run Swift as an immediate command. Watch the output that Swift produces")
+    parser.add_option("--trunk", dest="trunk",
+                      help="Run the development trunk version of Swift")
+    parser.add_option("--stable", dest="stable",
+                      default=True, action="store_true",
+                      help="Run the most stable release version")
+    parser.add_option("-d", dest="deadline",
+                      default="30m",
+                      help="Set the time limit for this workflow.  " + \
+                           "Default: 30m (30 minutes)")
+    parser.add_option("-g", dest="gsi_activation",
+                      help="Use gsi-ssh delegated credential")
+    myproxy.add_myproxy_options(parser)
+    (options, args) = pykoa.tools.parse_args(parser, argv)
+    if options.gsi_activation and not os.getenv("X509_USER_PROXY"):
+        raise ToolsException("ENO_GSI_SSH")
+    return (parser, options, args)
+def parse_stdin():
+    lines = []
+    index = 0
+    lines = sys.stdin.readlines()
+    tc         = extract_tc( lines )
+    sites_file = extract_sites( lines )
+    config     = extract_config( lines )
+    script     = extract_script( lines )
+    return ( tc, sites_file, config, script )
+def extract_tc( lines ):
+    begin_tc = False
+    tc       = ""
+    for line in lines:
+        line=line.rstrip()
+        if line == "# begin tc":
+            begin_tc = True
+        elif line == "# end tc":
+            begin_tc = False
+            break
+        elif begin_tc:
+            tc += line + "\n"
+    return tc
+def extract_sites( lines ):
+    begin_sites = False
+    sites       = ""
+        if line == "# begin sites":
+            begin_sites = True
+        elif line == "# end sites":
+            break
+        elif begin_sites:
+            sites += line + "\n"
+    return sites
+def extract_config( lines ):
+    begin_config = False
+    config       = ""
+        if line == "# begin config":
+            begin_config = True
+        elif line == "# end config":
+            break
+        elif begin_config:
+            config += line + "\n"
+    return config
+def extract_script( lines ):
+    begin_script = False
+    script       = ""
+        if line == "# begin script":
+            begin_script = True
+        elif line == "# end script":
+            break
+        elif begin_script:
+            script += line + "\n"
+    return script
+def get_creds(args, conn, user_id, options):
+    # get activate credentials for a logical endpoint
+    # endpoint must be logical
+    # if endpoint is not activated(or credential is expired), raise ToolsException
+    src_cred = None
+    ep = endpoint_dao.get_logical_by_name( conn, user_id, args[0] )
+    if not ep:
+        ep = endpoint_dao.get_public_by_name( conn, args[0] )
+    if ep:
+        default_myproxy = ep.myproxy_server
+        # Get first physical ep, if exists
+        phys = endpoint_dao.get_physicals_for_logical(conn, ep.id)
+        if not phys:
+            raise ToolsException("No physical server exists for '%s'" % (
+                    args[0]))
+        phys = phys[0]
+        scheme = get_scheme(phys.xfer_service_id)
+        src_subject = phys.x509_dn
+        # See if LTA endpoint is connected
+        if phys.is_lta and phys.alive == 0:
+            raise ToolsException("The requested Globus Connect endpoint is not currently connected to Globus Online")
+        # Get creds
+        row = creds_dao.get_cred_for_logical(conn, user_id, ep.id)
+        if row and row.exp_time > datetime.datetime.utcnow():
+            src_cred = row.sec_info
+    if not src_cred:
+        raise ToolsException("A credential is needed.  Activate the endpoint with endpoint-activate")
+    return ( src_cred, src_subject)
+def execute_swift(user_id, options, src_cred, src_subject, work_directory, run_id):
+    if src_subject:
+        os.environ["GLOBUS_FTP_CLIENT_TEST_SUBJECT"] = src_subject
+    if src_cred:
+        proxyfile = guc_util.sec_text_to_proxy_file(user_id, src_cred)
+        os.environ["X509_USER_CERT"] = proxyfile
+        os.environ["X509_USER_KEY"] = proxyfile
+        os.environ["X509_USER_PROXY"] = proxyfile
+    # Not sure this will work all the time, but this is what the internet said i could do.
+    cmd = "curl http://169.254.169.254/2009-04-04/meta-data/public-ipv4"
+    (status, host ) = commands.getstatusoutput( cmd )
+    if status != 0:
+        sys.stderr.write( "Could not determine hostname\n" )
+        return status
+    # There has to be an easier way to get the last line of a string
+    # Maybe limit the curl output from above?
+    lines = []
+    for line in host.split("\n"):
+        lines.append(line)
+    host = lines[len(lines)-1]
+    os.environ["GLOBUS_HOSTNAME"] = host
+    os.environ["GLOBUS_TCP_PORT_RANGE"] = "50000,51000"
+    os.environ["GLOBUS_SOURCE_PORT_RANGE"] = "50000,51000"
+    # Execute the script
+    cmd = ""
+    if options.trunk:
+        cmd = os.path.join(os.environ["HOME"], "Swift_lib/trunk", "swift")             # trunk release
+    elif options.stable:
+        cmd = os.path.join(os.environ["HOME"], "Swift_lib/0.92", "swift")              # stable 0.92.1 release
+    os.chdir(work_directory)
+    status = -1
+    pid = -1
+    if options.watch_swift_stdoutput:
+        try:
+            with BlockInterrupt():
+                execute = cmd + " -runid "+str(run_id)+" -sites.file sites.xml -tc.file tc -config cf script.swift"
+                pykoa.debug( "running %s in watch mode" % (execute))
+                with open(work_directory+"/run.sh", "w") as run_sh:
+                    run_sh.write( "#!/bin/bash\n" )
+                    run_sh.write( "[ -f /opt/osg/setup.sh ] && source /opt/osg/setup.sh\n")
+                    run_sh.write( execute + "\n" )
+                    run_sh.write( "ret=$?\n" )
+                    run_sh.write( "\n" )
+                    run_sh.write( "echo \"\nExit Code: $ret\" >> swift.info\n" )
+                    run_sh.write( "exit $ret" )
+                os.chmod(work_directory+"/run.sh", stat.S_IRUSR | stat.S_IXUSR )
+                p = subprocess.Popen("exec "+work_directory+"/run.sh",
+                                     close_fds=True, shell=True,
+                                     preexec_fn=enable_sigint,
+                                     cwd=os.getcwd(),
+                                     stdout=subprocess.PIPE,
+                                     stderr=subprocess.PIPE)
+                pid = p.pid
+                with open("swift.info", "w") as swift_info:
+                    swift_info.write("StartTime: "+str(datetime.datetime.utcnow())+"\n")
+                    swift_info.write("Swift pid: "+str(pid)+"\n")
+                    swift_info.write("Run id:    "+str(run_id)+"\n")
+                    swift_info.write("\n")
+                    swift_info.write("Command Line:\n     "+execute+"\n")
+                c = SwiftObserver()
+                status = c.run(p)
+        finally:
+            if src_cred:
+                os.remove( proxyfile )
+        with open("swift.out", "a") as swift_out:
+            for line in c.lines:
+                swift_out.write(line)
+        sys.stdout.write( "Swift exit status: " + str(status) + "\n" )
+    else:
+        swift_out = open("swift.out", "w")
+        pykoa.debug( "running %s in background mode" % (execute))
+            run_sh.write( "rm -f $X509_USER_PROXY\n" )
+                             cwd=os.getcwd(),
+                             stderr=subprocess.STDOUT,
+                             stdout=swift_out)
+        pid = p.pid
+        status = 0
+    return status
+def create_work_directory():
+    # check to see is the swift directory has been created
+    home = os.getenv( "HOME" )
+    swift_dir = home + "/Swift"
+    if not os.access( swift_dir, os.F_OK ):
+        os.mkdir( swift_dir )
+    # default is run.0, if there are other directories then adjust the run directory count
+    run_directory = "run.0"
+    last_run = 0
+    directories = os.listdir( swift_dir )
+    # This might cause a performance problem(to even begin to start Swift)
+    # Need to figure out how maybe purge these run directories
+    # For now I can manually purge
+    runs = []
+    for direc in directories:
+        ( name, sep, run_num ) = direc.partition( "." )
+        try:
+            runs.append( int( run_num) )
+        except ValueError:
+            pykoa.debug( "Directory "+direc+" is not a run directory" )
+    runs.sort()
+    # if the directories list is not empty, create the name of the run directory
+    if runs:
+        last_run = runs[ len(runs)-1 ] + 1
+        run_directory = "run."+str(last_run)
+    work_directory = swift_dir+"/"+run_directory
+    return (work_directory, last_run)
+# Do not know what this syntax is but pops up in other pykoa_* files, so I kept it
+ at cli_exception_handler
+def main( argv=sys.argv[1:] ):
+    (parser, options, args) = setup_opts(argv)
+    # If I did not specify at least one site, print help message
+    if len(args) != 1:
+        parser.print_help()
+        return 1
+    # Not sure what these lines do yet, just copied from koa-ly.py
+    guc_util.init_guc_env()
+    conn     = pykoa.connect()
+    user_row = pykoa.tools.cli_get_user( conn )
+    user_id  = user_row.id
+    # get the swift input package
+    ( tc, sites, config, script ) = parse_stdin()
+    (work_directory, run_id) = create_work_directory()
+    # get a space seperated String of the sites to execute on
+    execution_sites=" ".join( map ( str, args ) )
+    sys.stdout.write( "\nExecuting Swift with " + execution_sites + " credentials\n" )
+    sys.stdout.write( "Execution directory: " + work_directory + "\n" )
+    # If I do not execute the script, just print out all important information
+    # useful to verify that the inputs to the Swift command line have been parsed correctly
+    if options.do_not_execute:
+        sys.stdout.write( "\nTC file: \n" + tc + "\n" )
+        sys.stdout.write( "SITES file: \n" + sites + "\n" )
+        sys.stdout.write( "CONFIG file: \n" + config + "\n" )
+        sys.stdout.write( "SWIFTSCRIPT file: \n" + script + "\n" )
+        sys.stdout.write( "swift -sites.file sites.xml -tc.file tc -config cf script.swift\n\n" )
+        return 0
+    # Set up for the acutal execution
+    try:
+        os.mkdir( work_directory )
+        pykoa.debug( "Created work_directory: " + work_directory )
+    except os.error:
+        sys.stderr.write( work_directory + " already exists, clean up " + os.getenv("HOME") + "/Swift" )
+        pykoa.debug( work_directory + " already exists" )
+        return 1
+    with open( work_directory+"/tc", "w" ) as tc_file:
+        tc_file.write( tc )
+    with open( work_directory+"/sites.xml", "w" ) as sites_file:
+        sites_file.write( sites )
+    with open( work_directory+"/cf", "w" ) as config_file:
+        config_file.write( config )
+    with open( work_directory+"/script.swift", "w" ) as script_file:
+        script_file.write( script )
+    ( src_cred, src_subject ) = get_creds(args, conn, user_id, options)
+    ret = execute_swift(user_id, options, src_cred, src_subject, work_directory, run_id)
+    return ret
+if __name__ == "__main__":
+    rc = main()
+    sys.exit(rc)
