[Swift-commit] r3647 - in trunk: libexec src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan/lib/swiftscript tests/functions
Mon Sep 27 12:56:09 CDT 2010
Author: wozniak
Date: 2010-09-27 12:56:09 -0500 (Mon, 27 Sep 2010)
New Revision: 3647
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
   trunk/tests/functions/200-sprintf.swift
   trunk/tests/functions/README.txt
Modified:
   trunk/libexec/vdl-lib.xml
   trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
Log:
New @sprintf() and test
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml	2010-09-27 16:32:09 UTC (rev 3646)
+++ trunk/libexec/vdl-lib.xml	2010-09-27 17:56:09 UTC (rev 3647)
@@ -15,6 +15,7 @@
 	<export name="tofloat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="format"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="pad"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+	<export name="sprintf"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Sprintf"/></export>
 	<export name="tostring"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="assert"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Assert"/></export>
 	<export name="trace"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2010-09-27 16:32:09 UTC (rev 3646)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2010-09-27 17:56:09 UTC (rev 3647)
@@ -224,6 +224,12 @@
 		strcat.addOutputArg(strcatOut1);
 		functionsMap.put(strcat.getName(), strcat);
+		ProcedureSignature sprintf = new ProcedureSignature("sprintf");
+        sprintf.setAnyNumOfInputArgs();
+        FormalArgumentSignature sprintfOut1 = new FormalArgumentSignature("string");
+        sprintf.addOutputArg(sprintfOut1);
+        functionsMap.put(sprintf.getName(), sprintf);
 		ProcedureSignature strcut = new ProcedureSignature("strcut");
 		FormalArgumentSignature strcutIn1 = new FormalArgumentSignature("string");
 		strcut.addInputArg(strcutIn1);
Added: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java	2010-09-27 17:56:09 UTC (rev 3647)
@@ -0,0 +1,245 @@
+package org.griphyn.vdl.karajan.lib.swiftscript;
+import org.apache.log4j.Logger;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.workflow.ExecutionException;
+import org.griphyn.vdl.karajan.lib.SwiftArg;
+import org.griphyn.vdl.karajan.lib.VDLFunction;
+import org.griphyn.vdl.mapping.ArrayDataNode;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.mapping.RootDataNode;
+import org.griphyn.vdl.type.Types;
+    Formatted string generation. <br>
+    Example: sprintf("\t%s\n", "hello"); <br>
+    Differences from trace():
+    1) respects \t, \n and \\;
+    2) allows for typechecked format specifiers;
+    3) allows for consumption of variables without display (%k)
+    Format specifiers: <br>
+      %%: % sign. <br>
+      %M: Filename output: waits for close
+      %p: Not typechecked, output as in trace(). <br>
+      %f: Typechecked float output. <br>
+      %i: Typechecked int output. <br>
+      %s: Typechecked string output. <br>
+      %k: Variable sKipped, no output. <br>
+      %q: Array output
+public class Sprintf extends VDLFunction {
+    private static final Logger logger =
+        Logger.getLogger(Sprintf.class);
+    static {
+        setArguments(Sprintf.class, new Arg[] { Arg.VARGS });
+    @Override
+    protected Object function(VariableStack stack)
+    throws ExecutionException {
+        DSHandle[] args = SwiftArg.VARGS.asDSHandleArray(stack);
+        for (int i = 0; i < args.length; i++) {
+            DSHandle handle = args[i];
+            VDLFunction.waitFor(stack, handle);
+        String msg = format(args);
+        logger.debug("generated: " + msg);
+        DSHandle result = new RootDataNode(Types.STRING);
+        result.setValue(msg);
+        return result;
+    private String format(DSHandle[] args)
+        if (! (args[0].getType() == Types.STRING))
+            throw new ExecutionException
+            ("First argument to sprintf() must be a string!");
+        String spec = args[0].toString();
+        DSHandle[] vars = copyArray(args, 1, args.length-1);
+        StringBuilder output = new StringBuilder();
+        format(spec, vars, output);
+        return output.toString();
+    public static DSHandle[] copyArray(DSHandle[] src,
+                                int offset, int length)
+        DSHandle[] result = new DSHandle[length];
+        for (int i = 0; i < length; i++)
+            result[i] = src[i+offset];
+        return result;
+       This method can be targeted as a helper function
+       (by @sprintf(), etc.)
+    public static void format(String spec, DSHandle[] vars,
+                              StringBuilder output)
+        int i = 0;
+        int arg = 0;
+        while (i < spec.length()) {
+            char c = spec.charAt(i);
+            if (c == '%') {
+                char d = spec.charAt(++i);
+                arg = append(d, arg, vars, output);
+            else if (c == '\\') {
+                escape(d, output);
+            else {
+                output.append(c);
+            i++;
+    private static int append(char c, int arg, DSHandle[] vars,
+        if (c == '%') {
+            output.append('%');
+            return arg;
+        if (arg >= vars.length) {
+            ("tracef(): too many specifiers!");
+        if (c == 'M') {
+            append_M(vars[arg], output);
+        else if (c == 'f') {
+            append_f(vars[arg], output);
+        else if (c == 'i') {
+            append_i(vars[arg], output);
+        else if (c == 'p') {
+            output.append(vars[arg].toString());
+        else if (c == 's') {
+            append_s(vars[arg], output);
+        else if (c == 'q') {
+            append_q(vars[arg], output);
+        else if (c == 'k') {
+        else {
+            ("tracef(): Unknown format: %" + c);
+        return arg+1;
+    private static void append_M(DSHandle arg, StringBuilder output)
+        try {
+            synchronized (arg.getRoot()) {
+                String[] names = VDLFunction.filename(arg);
+                if (names.length > 1)
+                    output.append(names);
+                else
+                    output.append(names[0]);
+        catch (Exception e) {
+            ("tracef(%M): Could not lookup: " + arg);
+    private static void append_f(DSHandle arg, StringBuilder output)
+        if (arg.getType() == Types.FLOAT) {
+            output.append(arg).toString();
+        else {
+            ("tracef(): %f requires a float!");
+    private static void append_i(DSHandle arg, StringBuilder output)
+        if (arg.getType() == Types.INT) {
+        else {
+            ("tracef(): %i requires an int!");
+    private static void append_q(DSHandle arg, StringBuilder output)
+        if (arg instanceof ArrayDataNode) {
+            ArrayDataNode node = (ArrayDataNode) arg;
+            output.append("[");
+            try {
+                int size = node.size();
+                for (int i = 0; i < size; i++) {
+                    String entry = ""+i;
+                    DSHandle handle =
+                        node.getField(Path.parse(entry));
+                    output.append(handle);
+                    if (i < size-1)
+                        output.append(",");
+                e.printStackTrace();
+                ("trace(%q): Could not get children of: " + arg);
+            output.append("]");
+        else {
+            ("tracef(): %q requires an array!");
+    private static void append_s(DSHandle arg, StringBuilder output)
+        if (arg.getType() == Types.STRING) {
+        else {
+            ("tracef(): %s requires a string!");
+    private static void escape(char c, StringBuilder output)
+        if (c == '\\') {
+            output.append('\\');
+        else if (c == 'n') {
+            output.append('\n');
+        else if (c == 't') {
+            output.append('\t');
+        else {
+            ("tracef(): unknown backslash escape sequence!");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2010-09-27 16:32:09 UTC (rev 3646)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2010-09-27 17:56:09 UTC (rev 3647)
@@ -6,28 +6,17 @@
-import org.griphyn.vdl.mapping.ArrayDataNode;
-import org.griphyn.vdl.mapping.Path;
-import org.griphyn.vdl.type.Types;
     Formatted trace output. <br>
     Example: tracef("\t%s\n", "hello"); <br>
-    2) allows for typechecked format specifiers;
+       (cf. {@link Sprintf});
     3) allows for consumption of variables without display (%k);
     4) does not impose any formatting (commas, etc.).  <br><br>
-    Format specifiers: <br>
-      %%: % sign. <br>
-      %M: Filename output: waits for close
-      %p: Not typechecked, output as in trace(). <br>
-      %f: Typechecked float output. <br>
-      %i: Typechecked int output. <br>
-      %s: Typechecked string output. <br>
-      %k: Variable sKipped, no output. <br>
-      %q: Array output
 public class Tracef extends VDLFunction {
@@ -47,175 +36,15 @@
-        String msg = format(args);
+        DSHandle[] vars = Sprintf.copyArray(args, 1, args.length-1);
+        Sprintf.format(spec, vars, output);
+        String msg = output.toString();
         logger.info(msg);
         System.out.print(msg);
         return null;
-    private String format(DSHandle[] args)
-    throws ExecutionException {
-        if (! (args[0].getType() == Types.STRING))
-            throw new ExecutionException
-            ("First argument to tracef() must be a string!");
-        String spec = args[0].toString();
-        StringBuffer output = new StringBuffer();
-        int i = 0;
-        int arg = 1;
-        while (i < spec.length()) {
-            char c = spec.charAt(i);
-            if (c == '%') {
-                char d = spec.charAt(++i);
-                arg = append(d, arg, args, output);
-            else if (c == '\\') {
-                escape(d, output);
-            else {
-                output.append(c);
-            i++;
-        String result = output.toString();
-        return result;
-    private int append(char c, int arg, DSHandle[] args,
-                       StringBuffer output)
-        if (c == '%') {
-            output.append('%');
-            return arg;
-        if (arg >= args.length) {
-            ("tracef(): too many specifiers!");
-        if (c == 'M') {
-            append_M(args[arg], output);
-        else if (c == 'f') {
-            append_f(args[arg], output);
-        else if (c == 'i') {
-            append_i(args[arg], output);
-        else if (c == 'p') {
-            output.append(args[arg].toString());
-        else if (c == 's') {
-            append_s(args[arg], output);
-        else if (c == 'q') {
-            append_q(args[arg], output);
-        else if (c == 'k') {
-        else {
-            ("tracef(): Unknown format: %" + c);
-        return arg+1;
-    private void append_M(DSHandle arg, StringBuffer output)
-        try {
-            synchronized (arg.getRoot()) {
-                String[] names = VDLFunction.filename(arg);
-                if (names.length > 1)
-                    output.append(names);
-                else
-                    output.append(names[0]);
-        catch (Exception e) {
-            ("tracef(%M): Could not lookup: " + arg);
-    private void append_f(DSHandle arg, StringBuffer output)
-        if (arg.getType() == Types.FLOAT) {
-            output.append(arg).toString();
-        else {
-            ("tracef(): %f requires a float!");
-    private void append_i(DSHandle arg, StringBuffer output)
-        if (arg.getType() == Types.INT) {
-        else {
-            ("tracef(): %i requires an int!");
-    private void append_q(DSHandle arg, StringBuffer output)
-        if (arg instanceof ArrayDataNode) {
-            ArrayDataNode node = (ArrayDataNode) arg;
-            output.append("[");
-            try {
-                int size = node.size();
-                for (int i = 0; i < size; i++) {
-                    String entry = ""+i;
-                    DSHandle handle =
-                        node.getField(Path.parse(entry));
-                    output.append(handle);
-                    if (i < size-1)
-                        output.append(",");
-                e.printStackTrace();
-                ("trace(%q): Could not get children of: " + arg);
-            output.append("]");
-        else {
-            ("tracef(): %q requires an array!");
-    private void append_s(DSHandle arg, StringBuffer output)
-        if (arg.getType() == Types.STRING) {
-        else {
-            ("tracef(): %s requires a string!");
-    private void escape(char c, StringBuffer output)
-        if (c == '\\') {
-            output.append('\\');
-        else if (c == 'n') {
-            output.append('\n');
-        else if (c == 't') {
-            output.append('\t');
-        else {
-            ("tracef(): unknown backslash escape sequence!");
Added: trunk/tests/functions/200-sprintf.swift
--- trunk/tests/functions/200-sprintf.swift	                        (rev 0)
+++ trunk/tests/functions/200-sprintf.swift	2010-09-27 17:56:09 UTC (rev 3647)
@@ -0,0 +1,7 @@
+string d = "-";
+string b = "bye";
+string f = @sprintf("hi%s%s", d, b);
+assert(f == "hi-bye");
Added: trunk/tests/functions/README.txt
--- trunk/tests/functions/README.txt	                        (rev 0)
+++ trunk/tests/functions/README.txt	2010-09-27 17:56:09 UTC (rev 3647)
@@ -0,0 +1,6 @@
+Tests for Swift's functions library
+100 series: Fundamentals
+200 series: String processing
+400 series: I/O
