[Swift-commit] r3634 - in trunk/tests: . language-behaviour
Tue Sep 21 14:00:50 CDT 2010
Author: wozniak
Date: 2010-09-21 14:00:46 -0500 (Tue, 21 Sep 2010)
New Revision: 3634
Added:
   trunk/tests/language-behaviour/00261-function-param-file.clean.sh
   trunk/tests/language-behaviour/00261-function-param-file.setup.sh
   trunk/tests/language-behaviour/00262-function-param-file-many.clean.sh
   trunk/tests/language-behaviour/00262-function-param-file-many.setup.sh
   trunk/tests/language-behaviour/060-duplicate.check.sh
   trunk/tests/language-behaviour/060-duplicate.clean.sh
   trunk/tests/language-behaviour/060-duplicate.setup.sh
   trunk/tests/language-behaviour/061-cattwo.clean.sh
   trunk/tests/language-behaviour/061-cattwo.setup.sh
   trunk/tests/language-behaviour/066-many.check.sh
   trunk/tests/language-behaviour/066-many.clean.sh
   trunk/tests/language-behaviour/066-many.time
   trunk/tests/language-behaviour/tc.template.data
   trunk/tests/language-behaviour/title.txt
Modified:
   trunk/tests/language-behaviour/065-delay.swift
   trunk/tests/language-behaviour/0651-several-delay.swift
   trunk/tests/language-behaviour/066-many.swift
   trunk/tests/nightly.sh
Log:
Test fixes
Added: trunk/tests/language-behaviour/00261-function-param-file.clean.sh
--- trunk/tests/language-behaviour/00261-function-param-file.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/00261-function-param-file.clean.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,5 @@
+#!/bin/bash
+rm -v 00261-function-param-file.in || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/00261-function-param-file.clean.sh
___________________________________________________________________
Added: trunk/tests/language-behaviour/00261-function-param-file.setup.sh
--- trunk/tests/language-behaviour/00261-function-param-file.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/00261-function-param-file.setup.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,5 @@
+#!/bin/bash
+cp -v ${GROUP}/00261-function-param-file.in . || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/00261-function-param-file.setup.sh
Added: trunk/tests/language-behaviour/00262-function-param-file-many.clean.sh
--- trunk/tests/language-behaviour/00262-function-param-file-many.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/00262-function-param-file-many.clean.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,5 @@
+#!/bin/bash
+rm -v 00262-function-param-file-many.in || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/00262-function-param-file-many.clean.sh
Added: trunk/tests/language-behaviour/00262-function-param-file-many.setup.sh
--- trunk/tests/language-behaviour/00262-function-param-file-many.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/00262-function-param-file-many.setup.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,5 @@
+#!/bin/bash
+cp -v ${GROUP}/00262-function-param-file-many.in . || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/00262-function-param-file-many.setup.sh
Added: trunk/tests/language-behaviour/060-duplicate.check.sh
--- trunk/tests/language-behaviour/060-duplicate.check.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/060-duplicate.check.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,5 @@
+#!/bin/bash
+grep 060-duplicate.in 060-duplicate.out || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/060-duplicate.check.sh
Added: trunk/tests/language-behaviour/060-duplicate.clean.sh
--- trunk/tests/language-behaviour/060-duplicate.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/060-duplicate.clean.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,6 @@
+#!/bin/bash
+rm -v 060-duplicate.in  || exit 1
+rm -v 060-duplicate.out || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/060-duplicate.clean.sh
Added: trunk/tests/language-behaviour/060-duplicate.setup.sh
--- trunk/tests/language-behaviour/060-duplicate.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/060-duplicate.setup.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,5 @@
+#!/bin/bash
+cp -v ${GROUP}/060-duplicate.in . || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/060-duplicate.setup.sh
Added: trunk/tests/language-behaviour/061-cattwo.clean.sh
--- trunk/tests/language-behaviour/061-cattwo.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/061-cattwo.clean.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+rm 061-cattwo.[12].in || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/061-cattwo.clean.sh
Added: trunk/tests/language-behaviour/061-cattwo.setup.sh
--- trunk/tests/language-behaviour/061-cattwo.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/061-cattwo.setup.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+cp ${GROUP}/061-cattwo.[12].in . || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/061-cattwo.setup.sh
Modified: trunk/tests/language-behaviour/065-delay.swift
--- trunk/tests/language-behaviour/065-delay.swift	2010-09-21 18:57:45 UTC (rev 3633)
+++ trunk/tests/language-behaviour/065-delay.swift	2010-09-21 19:00:46 UTC (rev 3634)
@@ -1,9 +1,6 @@
-delay() {
-    app {
-        sleep "90s";
+app delay() {
+  sleep "3";
 delay();
Modified: trunk/tests/language-behaviour/0651-several-delay.swift
--- trunk/tests/language-behaviour/0651-several-delay.swift	2010-09-21 18:57:45 UTC (rev 3633)
+++ trunk/tests/language-behaviour/0651-several-delay.swift	2010-09-21 19:00:46 UTC (rev 3634)
@@ -1,10 +1,8 @@
-delay() {
-    app {
-        sleep "90s";
+app delay(int i) {
+  sleep i;
-foreach i in [1:10] {
-delay();
+foreach i in [1:3] {
+  delay(i);
Added: trunk/tests/language-behaviour/066-many.check.sh
--- trunk/tests/language-behaviour/066-many.check.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/066-many.check.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+[ -f nop ] || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/066-many.check.sh
Added: trunk/tests/language-behaviour/066-many.clean.sh
--- trunk/tests/language-behaviour/066-many.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/066-many.clean.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+rm -v nop || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/066-many.clean.sh
Modified: trunk/tests/language-behaviour/066-many.swift
--- trunk/tests/language-behaviour/066-many.swift	2010-09-21 18:57:45 UTC (rev 3633)
+++ trunk/tests/language-behaviour/066-many.swift	2010-09-21 19:00:46 UTC (rev 3634)
@@ -1,8 +1,7 @@
-p() {
-    app {
-        touch "nop";
+app p()
+  touch "nop";
 foreach i in [1:3000] {
Added: trunk/tests/language-behaviour/066-many.time
--- trunk/tests/language-behaviour/066-many.time	                        (rev 0)
+++ trunk/tests/language-behaviour/066-many.time	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1 @@
+300
Added: trunk/tests/language-behaviour/tc.template.data
--- trunk/tests/language-behaviour/tc.template.data	                        (rev 0)
+++ trunk/tests/language-behaviour/tc.template.data	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1,20 @@
+#This is the transformation catalog.
+#It comes pre-configured with a number of simple transformations with
+#paths that are likely to work on a linux box. However, on some systems,
+#the paths to these executables will be different (for example, sometimes
+#some of these programs are found in /usr/bin rather than in /bin)
+#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
+#there must be no trailing whitespace at the end of each line.
+# sitename  transformation  path   INSTALLED  platform  profiles
+localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
+localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
+localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
+localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
+localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
+localhost 	cp 		/bin/cp         INSTALLED	INTEL32::LINUX	null
+localhost 	sleep 		/bin/sleep      INSTALLED	INTEL32::LINUX	null
+localhost 	touch 		/bin/touch      INSTALLED	INTEL32::LINUX	null
Added: trunk/tests/language-behaviour/title.txt
--- trunk/tests/language-behaviour/title.txt	                        (rev 0)
+++ trunk/tests/language-behaviour/title.txt	2010-09-21 19:00:46 UTC (rev 3634)
@@ -0,0 +1 @@
+Language-behaviour tests
Modified: trunk/tests/nightly.sh
--- trunk/tests/nightly.sh	2010-09-21 18:57:45 UTC (rev 3633)
+++ trunk/tests/nightly.sh	2010-09-21 19:00:46 UTC (rev 3634)
@@ -22,14 +22,16 @@
 # Each *.swift test may be accompanied by a
 # *.setup.sh, *.check.sh, and/or *.clean.sh script
 # These may setup and inspect files in RUNDIR including exec.out
+# The GROUP scripts can read the GROUP variable
 # Tests are GROUPed into directories
 # Each GROUP directory has:
 #      1) a list of *.swift tests (plus *.sh scripts)
 #      2) optionally a tc.template.data
-#      3) optionally a swift.properties
-#      4) optionally a title.txt
-#      5) preferably a README.txt
+#      3) optionally a fs.template.data
+#      4) optionally a swift.properties
+#      5) optionally a title.txt
+#      6) preferably a README.txt
 # OUTPUT is the stdout of the current test
 # stdout.txt retains stdout from the previous test (for *.clean.sh)
