[Swift-commit] r3618 - trunk/tests/cdm/ps/pinned
Wed Sep 8 14:55:10 CDT 2010
Author: wozniak
Date: 2010-09-08 14:55:10 -0500 (Wed, 08 Sep 2010)
New Revision: 3618
Added:
   trunk/tests/cdm/ps/pinned/201-direct-output.check.sh
   trunk/tests/cdm/ps/pinned/201-direct-output.clean.sh
   trunk/tests/cdm/ps/pinned/201-direct-output.setup.sh
   trunk/tests/cdm/ps/pinned/201-direct-output.swift
   trunk/tests/cdm/ps/pinned/202-direct-io.check.sh
   trunk/tests/cdm/ps/pinned/202-direct-io.clean.sh
   trunk/tests/cdm/ps/pinned/202-direct-io.setup.sh
   trunk/tests/cdm/ps/pinned/202-direct-io.swift
   trunk/tests/cdm/ps/pinned/README.txt
   trunk/tests/cdm/ps/pinned/fs.template.data
   trunk/tests/cdm/ps/pinned/merge.sh
   trunk/tests/cdm/ps/pinned/sites.template.xml
   trunk/tests/cdm/ps/pinned/swift.properties
   trunk/tests/cdm/ps/pinned/tc.template.data
   trunk/tests/cdm/ps/pinned/title.txt
Log:
Copy pinned tests from cdm/ps
Copied: trunk/tests/cdm/ps/pinned/201-direct-output.check.sh (from rev 3616, trunk/tests/cdm/ps/201-direct-output.check.sh)
--- trunk/tests/cdm/ps/pinned/201-direct-output.check.sh	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/201-direct-output.check.sh	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,8 @@
+#!/bin/sh
+set -x
+grep $( uname -m ) 201-input.txt  || exit 1
+grep $( uname -m ) 201/201-output.txt || exit 1
+exit 0
Copied: trunk/tests/cdm/ps/pinned/201-direct-output.clean.sh (from rev 3616, trunk/tests/cdm/ps/201-direct-output.clean.sh)
--- trunk/tests/cdm/ps/pinned/201-direct-output.clean.sh	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/201-direct-output.clean.sh	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 201-input.txt 201 || exit 1
+exit 0
Copied: trunk/tests/cdm/ps/pinned/201-direct-output.setup.sh (from rev 3616, trunk/tests/cdm/ps/201-direct-output.setup.sh)
--- trunk/tests/cdm/ps/pinned/201-direct-output.setup.sh	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/201-direct-output.setup.sh	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,10 @@
+#!/bin/sh
+set -x
+  uname -a
+  date
+} > 201-input.txt
+exit 0
Copied: trunk/tests/cdm/ps/pinned/201-direct-output.swift (from rev 3616, trunk/tests/cdm/ps/201-direct-output.swift)
--- trunk/tests/cdm/ps/pinned/201-direct-output.swift	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/201-direct-output.swift	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,14 @@
+type file;
+app (file o) copy (file i)
+  cp @i @o;
+file f1<"201-input.txt">;
+// Will be transformed by CDM to 201/output.txt:
+file f2<"201-output.txt">;
+f2 = copy(f1);
Copied: trunk/tests/cdm/ps/pinned/202-direct-io.check.sh (from rev 3616, trunk/tests/cdm/ps/202-direct-io.check.sh)
--- trunk/tests/cdm/ps/pinned/202-direct-io.check.sh	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/202-direct-io.check.sh	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,11 @@
+#!/bin/sh
+set -x
+grep $( uname -m ) 202/202-input-1.txt || exit 1
+grep $( hostname ) 202/202-input-1.txt || exit 1
+grep $( uname -m ) 202/202-output.txt  || exit 1
+grep $( hostname ) 202/202-output.txt || exit 1
+exit 0
Copied: trunk/tests/cdm/ps/pinned/202-direct-io.clean.sh (from rev 3616, trunk/tests/cdm/ps/202-direct-io.clean.sh)
--- trunk/tests/cdm/ps/pinned/202-direct-io.clean.sh	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/202-direct-io.clean.sh	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 202 || exit 1
+exit 0
Copied: trunk/tests/cdm/ps/pinned/202-direct-io.setup.sh (from rev 3616, trunk/tests/cdm/ps/202-direct-io.setup.sh)
--- trunk/tests/cdm/ps/pinned/202-direct-io.setup.sh	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/202-direct-io.setup.sh	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,17 @@
+#!/bin/sh
+set -x
+mkdir -v 202
+  uname -a
+  date
+} > 202/202-input-1.txt
+  hostname
+  pwd
+} > 202/202-input-2.txt
+exit 0
Copied: trunk/tests/cdm/ps/pinned/202-direct-io.swift (from rev 3616, trunk/tests/cdm/ps/202-direct-io.swift)
--- trunk/tests/cdm/ps/pinned/202-direct-io.swift	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/202-direct-io.swift	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,16 @@
+type file;
+app (file o) merge (file i, file j)
+  merge @i @j @o;
+// Will be transformed by CDM to 202/input-[12].txt
+file f1<"202-input-1.txt">;
+file f2<"202-input-2.txt">;
+// Will be transformed by CDM to 202/output.txt:
+file f3<"202-output.txt">;
+f3 = merge(f1, f2);
Copied: trunk/tests/cdm/ps/pinned/README.txt (from rev 3616, trunk/tests/cdm/ps/README.txt)
--- trunk/tests/cdm/ps/pinned/README.txt	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/README.txt	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,5 @@
+000 series : noop tests
+200 series : DIRECT tests
+300 series : BROADCAST test
Copied: trunk/tests/cdm/ps/pinned/fs.template.data (from rev 3616, trunk/tests/cdm/ps/fs.template.data)
--- trunk/tests/cdm/ps/pinned/fs.template.data	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/fs.template.data	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,4 @@
+rule .*201-output.txt  DIRECT _PWD_/201
+rule .*202-input.*.txt DIRECT _PWD_/202
+rule .*202-output.txt  DIRECT _PWD_/202
Copied: trunk/tests/cdm/ps/pinned/merge.sh (from rev 3616, trunk/tests/cdm/ps/merge.sh)
--- trunk/tests/cdm/ps/pinned/merge.sh	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/merge.sh	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,7 @@
+#!/bin/sh
+F1=$1
+F2=$2
+F3=$3
+cat $F1 $F2 > $F3
Copied: trunk/tests/cdm/ps/pinned/sites.template.xml (from rev 3616, trunk/tests/cdm/ps/sites.template.xml)
--- trunk/tests/cdm/ps/pinned/sites.template.xml	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/sites.template.xml	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,24 @@
+<config>
+  <pool handle="localhost" sysinfo="INTEL32::LINUX">
+    <gridftp url="local://localhost" />
+    <execution provider="local" url="none" />
+    <workdirectory>_WORK_</workdirectory>
+    <profile namespace="swift" key="stagingMethod">file</profile>
+  </pool>
+  <pool handle="coasterslocal">
+    <filesystem provider="local" />
+    <execution provider="coaster" jobmanager="local:local"/>
+    <profile namespace="globus"   key="internalHostname">_HOST_</profile>
+    <profile namespace="karajan"  key="jobthrottle">2.55</profile>
+    <profile namespace="karajan"  key="initialScore">10000</profile>
+    <profile namespace="globus"   key="workersPerNode">4</profile>
+    <profile namespace="globus"   key="slots">8</profile>
+    <profile namespace="globus"   key="maxTime">1000</profile>
+    <profile namespace="globus"   key="nodeGranularity">1</profile>
+    <profile namespace="globus"   key="maxNodes">4</profile>
+  </pool>
+</config>
Copied: trunk/tests/cdm/ps/pinned/swift.properties (from rev 3616, trunk/tests/cdm/ps/swift.properties)
--- trunk/tests/cdm/ps/pinned/swift.properties	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/swift.properties	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,353 @@
+sites.file=${swift.home}/etc/sites.xml
+tc.file=${swift.home}/etc/tc.data
+# The host name of the submit machine is used by GRAM as a callback
+# address to report the status of submitted jobs. In general, Swift
+# can automatically detect the host name of the local machine.
+# However, if the machine host name is improperly configured or if
+# it does not represent a valid DNS entry, certain services (such as
+# GRAM) will not be able to send job status notifications back to
+# the client. The value of this property can be an IP address.
+# Format:
+#    hostname=string
+#hostname=localhost
+# A TCP port range can be specified to restrict the ports on which GRAM
+# callback services are started. This is likely needed if your submit
+# host is behind a firewall, in which case the firewall should be
+# configured to allow incoming connections on ports in the range.
+# Format:
+#     tcp.port.range=start,end
+#tcp.port.range=50000,50100
+# false	- means an error will be immediately reported and cause the
+# 		workflow to abort. At this time remote jobs that are already
+#		running will not be canceled
+# true	- means that Swift will try to do as much work as possible and
+#		report all errors encountered at the end. However, "errors"
+#		here only applies to job execution errors. Certain errors
+#		that are related to the Swift implementation (should such
+#		errors occur) will still be reported eagerly.
+# Default: false
+lazy.errors=false
+# What algorithm to use for caching of remote files. LRU (as in what
+# files to purge) is the only implementation right now. One can set
+# a target size (in bytes) for a host by using the swift:storagesize
+# profile for a host in sites.xml
+# Default: LRU
+caching.algorithm=LRU
+# true       - generate a provenance graph in .dot format (Swift will
+#			 choose a random file name)
+# false      - do not generate a provenance graph
+# <filename> - generate a provenange graph in the give file name
+# Default: false
+pgraph=false
+# graph properties for the provenance graph (.dot specific)
+# Default: splines="compound", rankdir="TB"
+pgraph.graph.options=splines="compound", rankdir="TB"
+# node properties for the provenance graph (.dot specific)
+# Default: color="seagreen", style="filled"
+pgraph.node.options=color="seagreen", style="filled"
+# true	- clustering of small jobs is enabled. Clustering works in the
+#       following way: If a job is clusterable (meaning that it has the
+#       GLOBUS::maxwalltime profile specified in tc.data and its value
+#       is less than the value of the "clustering.min.time" property) it will
+#       be put in a clustering queue. The queue is processed at intervals
+#       specified by the "clustering.queue.delay" property. The processing
+#       of the clustering queue consists of selecting compatible jobs and
+#		grouping them in clusters whose max wall time does not exceed twice
+#       the value of the "clustering.min.time" property. Two or more jobs are
+#       considered compatible if they share the same site and do not have
+#       conflicting profiles (e.g. different values for the same environment
+#       variable).
+# false	- clustering of small jobs is disabled.
+# Default: false
+clustering.enabled=false
+# <seconds>	- the intervals at which the clustering queue is processed
+# Default: 4
+clustering.queue.delay=4
+# <seconds>	- the threshold time for clustering
+# Default: 60
+clustering.min.time=60
+# Kickstart is a useful tool that can be used to gather various information
+# about a remote process. Before it can be used it must be installed on the
+# remote site and the corresponding entry be set in the sites file.
+# This option allows controlling of how Swift uses Kickstart. The following
+# values are possible:
+# false - do not use Kickstart
+# true  - use Kickstart. If a job is scheduled on a site that does not have
+#       Kickstart installed, that job will fail.
+# maybe - Use Kickstart if installed (i.e. the entry is present in the sites
+#       file)
+# Default: maybe
+kickstart.enabled=maybe
+# Indicates when Kickstart records should be fetched from the remote site:
+# true	- always transfer Kickstart records if Kickstart was used (see
+#		kickstart.enabled)
+# false	- only transfer Kickstart records if the job fails
+# Default: false
+kickstart.always.transfer=false
+# Indicates when wrapper logs should be fetched from the remote site:
+# true	- always transfer wrapper logs
+# false	- only transfer wrapper logs if the job fails
+# Default: false
+wrapperlog.always.transfer=false
+#                          Throttling options                             #
+# For the throttling parameters, valid values are either a positive integer
+# or "off" (without the quotes).
+# Limits the number of concurrent submissions for a workflow instance. This
+# throttle only limits the number of concurrent tasks (jobs) that are being
+# sent to sites, not the total number of concurrent jobs that can be run.
+# The submission stage in GRAM is one of the most CPU expensive stages (due
+# mostly to the mutual authentication and delegation). Having too many
+# concurrent submissions can overload either or both the submit host CPU
+# and the remote host/head node causing degraded performance.
+# Default: 4
+throttle.submit=4
+#throttle.submit=off
+# Limits the number of concurrent submissions for any of the sites Swift will
+# try to send jobs to. In other words it guarantees that no more than the
+# value of this throttle jobs sent to any site will be concurrently in a state
+# of being submitted.
+# Default: 2
+throttle.host.submit=2
+#throttle.host.submit=off
+# The Swift scheduler has the ability to limit the number of concurrent jobs
+# allowed on a site based on the performance history of that site. Each site
+# is assigned a score (initially 1), which can increase or decrease based
+# on whether the site yields successful or faulty job runs. The score for a
+# site can take values in the (0.1, 100) interval. The number of allowed jobs
+# is calculated using the following formula:
+# 	2 + score*throttle.score.job.factor
+# This means a site will always be allowed at least two concurrent jobs and
+# at most 2 + 100*throttle.score.job.factor. With a default of 4 this means
+# at least 2 jobs and at most 402.
+# Default: 4
+throttle.score.job.factor=0.2
+#throttle.score.job.factor=off
+# Limits the total number of concurrent file transfers that can happen at any
+# given time. File transfers consume bandwidth. Too many concurrent transfers
+# can cause the network to be overloaded preventing various other signalling
+# traffic from flowing properly.
+# Default: 4
+throttle.transfers=4
+#throttle.transfers=off
+# Limits the total number of concurrent file operations that can happen at any
+# given time. File operations (like transfers) require an exclusive connection
+# to a site. These connections can be expensive to establish. A large number
+# of concurrent file operations may cause Swift to attempt to establish many
+# such expensive connections to various sites. Limiting the number of concurrent
+# file operations causes Swift to use a small number of cached connections and
+# achieve better overall performance.
+# Default: 8
+throttle.file.operations=8
+#throttle.file.operations=off
+# Indicates whether the working directory on the remote site should be
+# left intact even when the workflow completes successfully. This can be
+# used to inspect the site working directory for debugging purposes.
+# Default: false
+sitedir.keep=false
+# number of time a job will be retried if it fails (giving a maximum of
+# 1 + execution.retries attempts at execution)
+execution.retries=2
+# Enables/disables replication. Replication is used to deal with jobs sitting
+# in batch queues for abnormally large amounts of time. If replication is enabled
+# and certain conditions are met, Swift creates and submits replicas of jobs, and
+# allows multiple instances of a job to compete.
+replication.enabled=false
+# If replication is enabled, this value specifies the minimum time, in seconds,
+# a job needs to be queued in a batch queue in order to be considered for
+# replication
+replication.min.queue.time=60
+# The maximum number of replicas that Swift should attempt.
+replication.limit=3
+# WARNING: This option is deprecated. Please use the hostname option.
+# The IP address of the submit machine is used by GRAM as a callback
+# can automatically detect the IP address of the local machine.
+# However, if the machine has more than one network interface, Swift
+# will pick the first one, which may not be the right choice. It is
+# recommended that this property is set properly before attempting to
+# run jobs through GRAM.
+# Format:
+#    ip.address=x.y.z.w
+#ip.address=127.0.0.1
+# Controls how Swift will communicate the result code of running user programs
+# from workers to the submit side. In files mode, a file
+# indicating success or failure will be created on the site shared filesystem.
+# In provider mode, the execution provider job status will
+# be used. Notably, GRAM2 does not return job statuses correctly, and so
+# provider mode will not work with GRAM2. With other
+# providers, it can be used to reduce the amount of filesystem access compared
+# to files mode.
+# status.mode=files
+# Controls how swift will supply parameters to the remote wrapper script.
+# 'args' mode will pass parameters on the command line
+# 'files' mode will pass parameters through an additional input file
+# valid values: args, files
+# Default: files
+# wrapper.parameter.mode=args
+# Determines if Swift remote wrappers will be executed by specifying an
+# absolute path, or a path relative to the job initial working directory
+# valid values: absolute, relative
+# wrapper.invocation.mode=absolute
+# Limits the number of concurrent iterations that each foreach statement
+# can have at one time. This conserves memory for swift programs that
+# have large numbers of iterations (which would otherwise all be executed
+# in parallel).
+# Default: 1024
+foreach.max.threads=16384
+# controls whether the log file will contain provenance information
+# enabling this will increase the size of log files, sometimes
+# significantly.
+provenance.log=false
+# Controls whether file staging is done by swift or by the execution
+# provider. If set to false, the standard swift staging mechanism is
+# used. If set to true, swift does not stage files. Instead, the
+# execution provider is instructed to stage files in and out.
+# Provider staging is experimental.
+# When enabled, and when coasters are used as an execution provider,
+# a staging mechanism can be selected for each site
+# using the swift:stagingMethod site profile in sites.xml. The
+# following is a list of accepted mechanisms:
+# * file:  Staging is done from a filesystem accessible to the
+#          coaster service (typically running on the head node)
+# * proxy: Staging is done from a filesystem accessible to the
+#          client machine that swift is running on, and is proxied
+#          through the coaster service
+# * sfs:   (short for "shared filesystem") Staging is done by
+#          copying files to and from a filesystem accessible
+#          by the compute node (such as an NFS or GPFS mount).
+use.provider.staging=true
+provider.staging.pin.swiftfiles=false
Copied: trunk/tests/cdm/ps/pinned/tc.template.data (from rev 3616, trunk/tests/cdm/ps/tc.template.data)
--- trunk/tests/cdm/ps/pinned/tc.template.data	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/tc.template.data	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1,20 @@
+#This is the transformation catalog.
+#It comes pre-configured with a number of simple transformations with
+#paths that are likely to work on a linux box. However, on some systems,
+#the paths to these executables will be different (for example, sometimes
+#some of these programs are found in /usr/bin rather than in /bin)
+#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
+#there must be no trailing whitespace at the end of each line.
+# sitename  transformation  path   INSTALLED  platform  profiles
+localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
+localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
+localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
+localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
+localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
+coasterslocal 	cp 		/bin/cp         INSTALLED	INTEL32::LINUX	null
+coasterslocal 	merge 		_DIR_/merge.sh      INSTALLED	INTEL32::LINUX	null
Copied: trunk/tests/cdm/ps/pinned/title.txt (from rev 3616, trunk/tests/cdm/ps/title.txt)
--- trunk/tests/cdm/ps/pinned/title.txt	                        (rev 0)
+++ trunk/tests/cdm/ps/pinned/title.txt	2010-09-08 19:55:10 UTC (rev 3618)
@@ -0,0 +1 @@
+CDM tests with provider staging
