[Swift-commit] r3614 - in trunk: etc libexec tests/cdm-ps
Wed Sep 8 13:57:55 CDT 2010
Author: wozniak
Date: 2010-09-08 13:57:54 -0500 (Wed, 08 Sep 2010)
New Revision: 3614
Modified:
   trunk/etc/swift.properties
   trunk/libexec/vdl-int-staging.k
   trunk/tests/cdm-ps/swift.properties
Log:
Add provider.staging.pin.swiftfiles property
Modified: trunk/etc/swift.properties
--- trunk/etc/swift.properties	2010-09-08 18:56:26 UTC (rev 3613)
+++ trunk/etc/swift.properties	2010-09-08 18:57:54 UTC (rev 3614)
@@ -4,10 +4,10 @@
 # The host name of the submit machine is used by GRAM as a callback
 # address to report the status of submitted jobs. In general, Swift
-# can automatically detect the host name of the local machine.
+# can automatically detect the host name of the local machine.
 # However, if the machine host name is improperly configured or if
 # it does not represent a valid DNS entry, certain services (such as
-# GRAM) will not be able to send job status notifications back to
+# GRAM) will not be able to send job status notifications back to
 # the client. The value of this property can be an IP address.
 # Format:
@@ -20,7 +20,7 @@
 # A TCP port range can be specified to restrict the ports on which GRAM
 # callback services are started. This is likely needed if your submit
-# host is behind a firewall, in which case the firewall should be
+# host is behind a firewall, in which case the firewall should be
 # configured to allow incoming connections on ports in the range.
 # Format:
@@ -33,10 +33,10 @@
 # false	- means an error will be immediately reported and cause the
 # 		workflow to abort. At this time remote jobs that are already
 #		running will not be canceled
-# true	- means that Swift will try to do as much work as possible and
+# true	- means that Swift will try to do as much work as possible and
 #		report all errors encountered at the end. However, "errors"
 #		here only applies to job execution errors. Certain errors
-#		that are related to the Swift implementation (should such
+#		that are related to the Swift implementation (should such
 #		errors occur) will still be reported eagerly.
 # Default: false
@@ -46,7 +46,7 @@
 # What algorithm to use for caching of remote files. LRU (as in what
 # files to purge) is the only implementation right now. One can set
-# a target size (in bytes) for a host by using the swift:storagesize
+# a target size (in bytes) for a host by using the swift:storagesize
 # profile for a host in sites.xml
 # Default: LRU
@@ -56,7 +56,7 @@
 # true       - generate a provenance graph in .dot format (Swift will
 #			 choose a random file name)
-# false      - do not generate a provenance graph
+# false      - do not generate a provenance graph
 # <filename> - generate a provenange graph in the give file name
 # Default: false
@@ -65,7 +65,7 @@
-# graph properties for the provenance graph (.dot specific)
+# graph properties for the provenance graph (.dot specific)
 # Default: splines="compound", rankdir="TB"
@@ -73,25 +73,25 @@
-# node properties for the provenance graph (.dot specific)
+# node properties for the provenance graph (.dot specific)
 # Default: color="seagreen", style="filled"
 pgraph.node.options=color="seagreen", style="filled"
-# true	- clustering of small jobs is enabled. Clustering works in the
+# true	- clustering of small jobs is enabled. Clustering works in the
 #       following way: If a job is clusterable (meaning that it has the
 #       GLOBUS::maxwalltime profile specified in tc.data and its value
 #       is less than the value of the "clustering.min.time" property) it will
-#       be put in a clustering queue. The queue is processed at intervals
+#       be put in a clustering queue. The queue is processed at intervals
 #       specified by the "clustering.queue.delay" property. The processing
 #       of the clustering queue consists of selecting compatible jobs and
 #		grouping them in clusters whose max wall time does not exceed twice
-#       the value of the "clustering.min.time" property. Two or more jobs are
+#       the value of the "clustering.min.time" property. Two or more jobs are
 #       considered compatible if they share the same site and do not have
 #       conflicting profiles (e.g. different values for the same environment
-#       variable).
+#       variable).
 # false	- clustering of small jobs is disabled.
 # Default: false
@@ -123,7 +123,7 @@
 # true  - use Kickstart. If a job is scheduled on a site that does not have
 #       Kickstart installed, that job will fail.
 # maybe - Use Kickstart if installed (i.e. the entry is present in the sites
-#       file)
+#       file)
 # Default: maybe
@@ -164,9 +164,9 @@
 # throttle only limits the number of concurrent tasks (jobs) that are being
 # sent to sites, not the total number of concurrent jobs that can be run.
 # The submission stage in GRAM is one of the most CPU expensive stages (due
-# mostly to the mutual authentication and delegation). Having too many
+# mostly to the mutual authentication and delegation). Having too many
 # concurrent submissions can overload either or both the submit host CPU
-# and the remote host/head node causing degraded performance.
+# and the remote host/head node causing degraded performance.
 # Default: 4
@@ -176,7 +176,7 @@
 # Limits the number of concurrent submissions for any of the sites Swift will
-# try to send jobs to. In other words it guarantees that no more than the
+# try to send jobs to. In other words it guarantees that no more than the
 # value of this throttle jobs sent to any site will be concurrently in a state
 # of being submitted.
@@ -192,7 +192,7 @@
 # is assigned a score (initially 1), which can increase or decrease based
 # on whether the site yields successful or faulty job runs. The score for a
 # site can take values in the (0.1, 100) interval. The number of allowed jobs
-# is calculated using the following formula:
+# is calculated using the following formula:
 # 	2 + score*throttle.score.job.factor
 # This means a site will always be allowed at least two concurrent jobs and
 # at most 2 + 100*throttle.score.job.factor. With a default of 4 this means
@@ -220,11 +220,11 @@
 # Limits the total number of concurrent file operations that can happen at any
 # given time. File operations (like transfers) require an exclusive connection
 # to a site. These connections can be expensive to establish. A large number
-# of concurrent file operations may cause Swift to attempt to establish many
+# of concurrent file operations may cause Swift to attempt to establish many
 # such expensive connections to various sites. Limiting the number of concurrent
 # file operations causes Swift to use a small number of cached connections and
-# achieve better overall performance.
+# achieve better overall performance.
 # Default: 8
@@ -240,7 +240,7 @@
 sitedir.keep=false
-# number of time a job will be retried if it fails (giving a maximum of
+# number of time a job will be retried if it fails (giving a maximum of
 # 1 + execution.retries attempts at execution)
@@ -256,7 +256,7 @@
 replication.enabled=false
 # If replication is enabled, this value specifies the minimum time, in seconds,
-# a job needs to be queued in a batch queue in order to be considered for
+# a job needs to be queued in a batch queue in order to be considered for
 # replication
@@ -271,7 +271,7 @@
 # The IP address of the submit machine is used by GRAM as a callback
-# can automatically detect the IP address of the local machine.
+# can automatically detect the IP address of the local machine.
 # However, if the machine has more than one network interface, Swift
 # will pick the first one, which may not be the right choice. It is
 # recommended that this property is set properly before attempting to
@@ -312,7 +312,7 @@
 # Limits the number of concurrent iterations that each foreach statement
-# can have at one time. This conserves memory for swift programs that
+# can have at one time. This conserves memory for swift programs that
 # have large numbers of iterations (which would otherwise all be executed
 # in parallel).
@@ -327,11 +327,11 @@
 provenance.log=false
-# Controls whether file staging is done by swift or by the execution
+# Controls whether file staging is done by swift or by the execution
 # provider. If set to false, the standard swift staging mechanism is
-# used. If set to true, swift does not stage files. Instead, the
+# used. If set to true, swift does not stage files. Instead, the
 # execution provider is instructed to stage files in and out.
 # Provider staging is experimental.
 # When enabled, and when coasters are used as an execution provider,
@@ -339,14 +339,15 @@
 # using the swift:stagingMethod site profile in sites.xml. The
 # following is a list of accepted mechanisms:
-# * file:  Staging is done from a filesystem accessible to the
-#          coaster service (typically running on the head node)
+# * file:  Staging is done from a filesystem accessible to the
+#          coaster service (typically running on the head node)
 # * proxy: Staging is done from a filesystem accessible to the
 #          client machine that swift is running on, and is proxied
 #          through the coaster service
 # * sfs:   (short for "shared filesystem") Staging is done by
 #          copying files to and from a filesystem accessible
-#          by the compute node (such as an NFS or GPFS mount).
+#          by the compute node (such as an NFS or GPFS mount).
-use.provider.staging=false
\ No newline at end of file
+use.provider.staging=false
+provider.staging.pin.swiftfiles=false
Modified: trunk/libexec/vdl-int-staging.k
--- trunk/libexec/vdl-int-staging.k	2010-09-08 18:56:26 UTC (rev 3613)
+++ trunk/libexec/vdl-int-staging.k	2010-09-08 18:57:54 UTC (rev 3614)
@@ -81,7 +81,7 @@
 				jobid := "{tr}-{uid}"
 				log(LOG:DEBUG, "THREAD_ASSOCIATION jobid={jobid} thread={#thread} host={rhost} replicationGroup={replicationGroup}")
 				wrapper := "_swiftwrap.staging"
 				wrapfile := "{ddir}/param-{jobid}"
@@ -91,7 +91,7 @@
 				vdl:setprogress("Stage in")
 				wfdir := "{VDL:SCRIPTNAME}-{VDL:RUNID}"
 				tmpdir := dircat("{wfdir}/jobs/{jobdir}", jobid)
-                                cdmfile := cdm:file()
+				cdmfile := cdm:file()
 				try(
 					sequential(
@@ -119,24 +119,26 @@
 							directory = "{wfdir}-{jobdir}-{jobid}"
 							redirect = false
 							host = rhost
-							vdl:tcprofile(rhost, tr = tr) //this gets various app params from the tc, such as environment, walltime, etc
+							vdl:tcprofile(rhost, tr = tr) //this gets various app params from the tc, such as environment, walltime, etc
 							replicationGroup = replicationGroup
 							replicationChannel = replicationChannel
 							jobid = jobid
 							stagingMethod := vdl:siteProfile(rhost, "swift:stagingMethod", default="proxy")
+							pinOption := configProperty("provider.staging.pin.swiftfiles")
+							pin := if (pinOption == "" then ("pinned:") else (""))
-							stageIn("{stagingMethod}://localhost/{swift.home}/libexec/{wrapper}", wrapper)
+							stageIn("{pin}{stagingMethod}://localhost/{swift.home}/libexec/{wrapper}", wrapper)
-							if( cdmfile != "" then(
-								d := vdl:dirname(cdmfile)
-								f := basename(cdmfile)
-								echo("d: {d} f: {f}")
-								stageIn("{stagingMethod}://localhost/{d}/{f}", cdmfile)
+							if ( cdmfile != "" then(
+								d  := vdl:dirname(cdmfile)
+								file := basename(cdmfile)
+								dir := if ( d == "" then("./") else(str:concat(d,"/")))
+								stageIn("{stagingMethod}://localhost/{dir}{file}", cdmfile)
 								stageIn("{stagingMethod}://localhost/{swift.home}/libexec/cdm.pl", "cdm.pl")
 								stageIn("{stagingMethod}://localhost/{swift.home}/libexec/cdm_lib.sh", "cdm_lib.sh")
 							appStageins(jobid, stagein, ".", stagingMethod)
@@ -193,3 +195,8 @@
+// Local variables:
+// tab-width: 4
+// indent-tabs-mode: 1
+// End:
Modified: trunk/tests/cdm-ps/swift.properties
--- trunk/tests/cdm-ps/swift.properties	2010-09-08 18:56:26 UTC (rev 3613)
+++ trunk/tests/cdm-ps/swift.properties	2010-09-08 18:57:54 UTC (rev 3614)
@@ -350,3 +350,4 @@
 use.provider.staging=true
