[Swift-commit] r3610 - SwiftApps/SwiftR/Swift/exec
Tue Sep 7 20:01:21 CDT 2010
Author: wilde
Date: 2010-09-07 20:01:21 -0500 (Tue, 07 Sep 2010)
New Revision: 3610
Added:
   SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
   SwiftApps/SwiftR/Swift/exec/passive-coaster-swift
Modified:
   SwiftApps/SwiftR/Swift/exec/RunSwiftScript.sh
   SwiftApps/SwiftR/Swift/exec/swiftapply.swift
Log:
Initial versions of scripts for passive coasters and persisten R eval processes.
Added: SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
--- SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh	                        (rev 0)
+++ SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh	2010-09-08 01:01:21 UTC (rev 3610)
@@ -0,0 +1,80 @@
+#! /bin/bash
+# Arguments: inputBatchSaveFile outputBatchSaveFile
+# Find our bin dir (to use for running utility scripts)
+SWIFTRBIN=$(cd $(dirname $0); pwd)
+# This script expects to be called (typically from Swift worker.pl)
+# with the following env vars set:
+#  SWIFT_WORKER_PID - process ID of the worker.pl that launched this script
+#  SWIFT_JOB_SLOT   - slot ID of the worker job that launched this script (0..maxWorkers-1)
+# Ensure that the dir for this slot exists.
+BASEDIR=/tmp/SwiftR/fifos
+WORKERDIR=$BASEDIR/worker.$SWIFT_WORKER_PID
+SLOTDIR=$WORKERDIR/${SWIFT_JOB_SLOT}
+mkdir -p $WORKERDIR
+# Try to make slotdir.
+# If the mkdir succeeds, this is the first request to the slot,
+# so we create a new R server and send the current request to it;
+# else we send the current request to an existing R server.
+RPIDS=
+TRAPS="EXIT 1 2 3 15"
+function onexit { # FIXME: move this logic into worker.pl, or try to use R timeout option if it works on fifos - need to test.
+  trap - $TRAPS
+  echo "Terminating R processes $RPIDS"
+  if [ "_$RPIDS" != _ ]; then
+    kill $RPIDS >& /dev/null
+  fi
+# trap onexit $TRAPS
+function idletimer {
+  cd $1
+  while true; do
+    touch idle
+    sleep 60
+    if [ ! -f lastwrite -o \( idle -nt lastwrite \) ]; then
+      # FIXME: should work, but does not: echo quit x x >toR.fifo # fifo problem?
+      RPID=$(cat R.pid)
+      echo killing idle R process $RPID
+      kill $RPID
+      exit 0
+    fi
+  done
+mkdir $SLOTDIR >& /dev/null
+if [ $? = 0 ]; then
+  mkfifo $SLOTDIR/toR.fifo
+  mkfifo $SLOTDIR/fromR.fifo
+  $SWIFTRBIN/SwiftRServer.sh $SLOTDIR >& $SLOTDIR/R.log &   # launch R server
+  idletimer $SLOTDIR </dev/null >/dev/null 2>&1 & # R saves pid in R.pid for idletimer to kill it
+  echo "$0: INFO: Launched $SWIFTRBIN/SwiftServer.sh $SLOTDIR Rscript"
+else
+  # wait to make sure fifo exists
+  # fromR fifo is created last, so wait for that one
+  if [ ! -p $SLOTDIR/fromR.fifo ]; then
+    sleep 5  # FIXME: try a few times, or wait longer?
+      echo "$0: ERROR: FIFO $SLOTDIR/fromR.fifo did not appear within 5 seconds.\n"
+      exit 1
+    fi
+  fi
+fi
+# Ready to talk to the server: send request and read response
+echo run $(pwd)/$1 $(pwd)/$2 > $SLOTDIR/toR.fifo
+touch $SLOTDIR/lastwrite
+head -3 < $SLOTDIR/fromR.fifo # FIXME: Trim this down to 1 line for each call (or same # lines for each, in particular, for "quit")
Modified: SwiftApps/SwiftR/Swift/exec/RunSwiftScript.sh
--- SwiftApps/SwiftR/Swift/exec/RunSwiftScript.sh	2010-09-07 19:36:39 UTC (rev 3609)
+++ SwiftApps/SwiftR/Swift/exec/RunSwiftScript.sh	2010-09-08 01:01:21 UTC (rev 3610)
@@ -1,9 +1,10 @@
 rundir=$1
 site=$2
 script=$3
-# runR=$4
+workerhosts=$4
-cp $script $runR $rundir
+cp $script $SWIFTRBIN/passive-coaster-swift $rundir
 # FIXME: rework this script to transfer all shells and rscripts
 # needed, and to copy in the R prelude for the R server processes (to
@@ -15,13 +16,19 @@
 # use /bin/sh and count on users PATH?
 # then add ENV::PATH as an option, e.g., from options(swift.remotepath and swift.remotepath.sitename)
+app=/bin/bash
 cat >tc <<END
-$site	Rscript	Rscript	null	null	ENV::R_TESTS="";ENV::PATH="$PATH"
-# $site	RunR	$runR	null	null	ENV::R_TESTS="";ENV::PATH="$PATH"
+$site	bash	$app    	null	null
+#$site	bash	$app    	null	null	ENV::R_TESTS=""
+#$site	bash	/bin/bash	null	null	ENV::R_TESTS="";ENV::PATH="$PATH"
+#$site	Rscript	Rscript	        null	null	ENV::R_TESTS="";ENV::PATH="$PATH"
+# $site	RunR	$runR	        null	null	ENV::R_TESTS="";ENV::PATH="$PATH"
 END
 cat >sites.xml <<END
 <config>
   <pool handle="local">
     <execution provider="local" url="none" />
     <profile namespace="karajan" key="initialScore">10000</profile>
@@ -29,6 +36,17 @@
     <filesystem provider="local"/>
     <workdirectory>$(pwd)</workdirectory>
   </pool>
+  <pool handle="passive">
+    <execution provider="coaster" url="none" jobmanager="local:local"/>
+    <profile namespace="globus" key="workerManager">passive</profile>
+    <profile namespace="globus" key="workersPerNode">8</profile>
+    <profile key="jobThrottle" namespace="karajan">.07</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <filesystem provider="local" url="none" />
+    <workdirectory>/home/wilde/swiftwork</workdirectory>
+  </pool>
   <pool handle="pbs">
     <profile namespace="globus" key="maxwalltime">00:00:10</profile>
     <profile namespace="globus" key="maxtime">1800</profile>
@@ -39,11 +57,18 @@
   </pool>
 </config>
 END
-cat >RunR.R <<END  # Note: \$ escapes in "here document" below
+cat >RunR.sh <<ENDX  # Note: \$ escapes and nested "<<" in "here document" below
+echo PRINTENV:
+printenv
+echo ENV:
+env
+cat >serverscript.R <<END
 # User initialization statements (if specified):
 $(cat initialize.R 2>/dev/null)
 # End of user initialization statements
@@ -53,14 +78,25 @@
 load(argv[1]);
 result=list()
-for(c in 1:length(rcall\$arglistbatch)) {
+for(c in 1:length(rcall\\\$arglistbatch)) {
     # FIXME: run this under try/catch and save error status in results object (need to make it a list: rval + error status)
-    result[[c]] = do.call( rcall\$func, rcall\$arglistbatch[[c]] )
+    result[[c]] = do.call( rcall\\\$func, rcall\\\$arglistbatch[[c]] )
 save(result,file=argv[2])
 END
+Rscript serverscript.R \$*
+ENDX
+if [ _$site = _passive ]; then
+    swiftcmd=./passive-coaster-swift
+    # workhosts passed in as argument
+else
+    swiftcmd=swift
+    workerhosts=""
+fi
 script=$(basename $script)
-swift -tc.file tc -sites.file sites.xml $script
+$swiftcmd "$workerhosts" -tc.file tc -sites.file sites.xml $script
Added: SwiftApps/SwiftR/Swift/exec/passive-coaster-swift
--- SwiftApps/SwiftR/Swift/exec/passive-coaster-swift	                        (rev 0)
+++ SwiftApps/SwiftR/Swift/exec/passive-coaster-swift	2010-09-08 01:01:21 UTC (rev 3610)
@@ -0,0 +1,70 @@
+#! /bin/bash
+COMPUTEHOSTS=$1
+#  COMPUTEHOSTS='crush thwomp stomp crank steamroller grind churn trounce thrash vanquish'
+#  COMPUTEHOSTS='communicado'
+shift
+function wait-and-start-workers
+  # Look for:
+  # Passive queue processor initialized. Callback URI is http://140.221.8.62:55379
+  for try in $(seq 1 20); do
+    uriline=$(grep "Passive queue processor initialized. Callback URI is" $out 2> /dev/null)
+    if [ "_$uriline" = _ ]; then
+      sleep 1
+    else
+      break;
+    fi
+  done
+  CONTACT=$(echo $uriline | sed -e 's/^.*http:/http:/')
+  echo Coaster contact: $CONTACT
+  LOGDIR=$(pwd)/swiftworkerlogs # full path. FIXME: Generate this with remote-side paths if not shared dir env?
+  mkdir -p $LOGDIR
+  workerscript=/home/wilde/swift/lab/worker.pl # FIXME: Try to send this inline or via scp; cp from exec/ dir
+  # CA="X509_CERT_DIR=$CERTDIR X509_CADIR=$CERTDIR"
+  for host in $(echo $COMPUTEHOSTS); do
+    timestamp=$(date "+%Y.%m%d.%H%M%S")
+    random=$(awk "BEGIN {printf \"%0.5d\", $RANDOM}")
+    ID=$timestamp.$random
+    ssh $host WORKER_LOGGING_ENABLED=true $workerscript $CONTACT $ID $LOGDIR &
+    sshpids="$sshpids $!"
+  done
+  echo Started workers from these ssh processes: $sshpids
+  echo $sshpids > $sshpidfile
+  # ps $sshpids
+if ! which swift >& /dev/null; then
+  echo $0: \'swift\' command not found in PATH
+  exit 1
+fi
+out=`mktemp swift.stdouterr.XXXX`
+touch $out
+sshpidfile=${out/stdouterr/workerpids}
+echo swift output is in: $out, pids in $sshpidfile
+TRAPS="EXIT 1 2 3 15"  # Signals and conditions to trap
+function onexit {
+  trap - $TRAPS
+  sshpids=$(cat $sshpidfile)
+  echo "Terminating worker processes $sshpids and starter $starterpid"
+  if [ "_$sshpids$starterpid" != _ ]; then
+    kill $sshpids $starterpid >& /dev/null
+  fi
+trap onexit $TRAPS
+wait-and-start-workers &
+starterpid=$!
+swift $* 2>&1 | tee $out
Property changes on: SwiftApps/SwiftR/Swift/exec/passive-coaster-swift
___________________________________________________________________
Modified: SwiftApps/SwiftR/Swift/exec/swiftapply.swift
--- SwiftApps/SwiftR/Swift/exec/swiftapply.swift	2010-09-07 19:36:39 UTC (rev 3609)
+++ SwiftApps/SwiftR/Swift/exec/swiftapply.swift	2010-09-08 01:01:21 UTC (rev 3610)
@@ -1,10 +1,9 @@
 type file;
 type RData;
-type RScript;
-app (RData result, file stout, file sterr) RunR (RScript rscript, RData rcall)
+app (RData result, file stout, file sterr) RunR (file shellscript, RData rcall)
-  Rscript @rscript @rcall @result stdout=@stout stderr=@sterr;
+  bash @shellscript @rcall @result stdout=@stout stderr=@sterr;
 #  RunR @rcall @result stdout=@stout stderr=@sterr;
@@ -12,8 +11,8 @@
 RData results[] <simple_mapper; prefix="rbatch.", suffix=".Rdata", padding=0>;
 file  stout[]   <simple_mapper; prefix="stdout.", suffix=".txt", padding=0>;
 file  sterr[]   <simple_mapper; prefix="stderr.", suffix=".txt", padding=0>;
-RScript rs      <"RunR.R">;
+file  runRscript <"RunR.sh">;
 foreach c, i in rcalls {
-  (results[i],stout[i], sterr[i]) = RunR(rs,c);
+  (results[i],stout[i], sterr[i]) = RunR(runRscript,c);
