[Swift-commit] r3606 - SwiftApps/SwiftR
Tue Sep 7 11:59:21 CDT 2010
Author: wilde
Date: 2010-09-07 11:59:21 -0500 (Tue, 07 Sep 2010)
New Revision: 3606
Added:
   SwiftApps/SwiftR/README
Modified:
   SwiftApps/SwiftR/TODO
Log:
Update notes.
Added: SwiftApps/SwiftR/README
--- SwiftApps/SwiftR/README	                        (rev 0)
+++ SwiftApps/SwiftR/README	2010-09-07 16:59:21 UTC (rev 3606)
@@ -0,0 +1,132 @@
+TIPS AND REMINDERS FOR THE FORGETFUL DEVELOPER :)
+* NOTES on where everything lives:
+Am testing on PADS
+   ~/SwiftR is my "project" main working dir
+R is under ~/R and ~/R/pads (compiled for PADS; the ~/R/bin/R
+executable gets a library error on pads)
+To build R:
+  http://cran.r-project.org/src/base/R-2/R-2.11.1.tar.gz (or desired release)
+  tar zxf *gz
+  cd ddd
+  ./configure --prefix=/home/wilde/R/R-2.11.0
+  make
+  make install
+Need to put the right R in the PATH for building and testing.
+Using R 2.11 as of 2010.0903
+OpenMx source tree checked out under: ~/SwiftR/OpenMx
+Repo is: https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/SwiftR
+R packages are installed under: ~/RPackages
+(These are the release-independent packages?
+FIXME: how does this relate to packages under the current R relesae?
+bri$ pwd
+/home/wilde/R/R-2.11.0
+bri$ cd library/
+bri$ pwd
+/home/wilde/R/R-2.11.0/library
+bri$ ls
+KernSmooth/  OpenMx/  base/   cluster/    foreign/    grid/     mgcv/  rpart/    stats/     tcltk/
+MASS/        R.css    boot/   codetools/  grDevices/  lattice/  nlme/  spatial/  stats4/    tools/
+Matrix/      Swift/   class/  datasets/   graphics/   methods/  nnet/  splines/  survival/  utils/
+bri$
+* Note: dont yet know if we do or do not need separate compiles between
+communicado, bridled, pads. teraport, and other systems on the CI
+net. Hopefully not; if we do, weill need to create a tree to R
+releases each with a separate subtree for user-installed packages)
+Seems that we do, at least for PADS, we get this error:
+login1$ ~/R/bin/R
+/home/wilde/R/lib64/R/bin/exec/R:
+  error while loading shared libraries: libreadline.so.4:
+    cannot open shared object file: No such file or directory
+login1$
+-- Swift package *source* (tbd) is under:
+   ~/SwiftR/Swift (the "Swift" package)
+-- Swift package is installed under: ????????
+* Setup
+Get latest R in path for installs etc.
+   PATH=/home/wilde/R/R-2.11.0/bin:$PATH
+* Fetch, Build, Install OpenMx
+* Make Swift Package
+FIXME: document R CMD BUILD and R CMD INSTALL here
+  cd ~/SwiftR/Swift?
+* How to build swift package into a source archive:
+  R CMD build Swift
+* package can also be fetched from svn abd built/installed from source I think?  Isnt this how OpenMx itself works?
+* How to build swift package right into source code
+* How to test the package
+  R CMD check Swift
+* Install Swift Package
+  R CMD INSTALL Swift # Puts package under current R release:
+  $ R CMD INSTALL Swift | tee INSTALL.out
+#--- Example:
+login1$ R CMD INSTALL Swift
+* installing to library '/home/wilde/R/R-2.11.0/library'
+* installing *source* package 'Swift' ...
+...etc
+  R CMD INSTALL -l ~/RLibrary Swift # Puts package under user lib; then need to add this to R search path?
+  R CMD INSTALL Swift_0.1.tar.gz  # Installs from a pre-built source archive instead of from Swift/ source dir
+* Run tests Swift package tests manually
+$ cd ~/SwiftR/Swift
+$ R
+> require(Swift)
+> source("tests/TestSwift.R")
+##################  INTERNAL DESIGN LOGIC
+the core R function is switapply()
+Its a bit more general then the lApply/sApply/etc functions:
+For each call it specfies a full set of arguments
+lApply calls swiftapply
+in swiftapply the remote calls are batched
+option processing:
Modified: SwiftApps/SwiftR/TODO
--- SwiftApps/SwiftR/TODO	2010-09-07 16:54:44 UTC (rev 3605)
+++ SwiftApps/SwiftR/TODO	2010-09-07 16:59:21 UTC (rev 3606)
@@ -1,73 +1,138 @@
+*** TO DO LIST:
-*** NOTES on where everything lives:
-Am testing on PADS
-~/SwiftR is my "project" main working dir
+  need persistent coaster service
-R is under ~/R and ~/R/pads (compiled for PADS; the ~/R/bin/R executable gets a library error on pads)
-OpenMx source tree checked out under: ~/SwiftR/OpenMx
+  output issues from swift worker to clean up (see bottom of this file):
+    "Directory no empty" worker.pl line 1001
+    unlink messages
-R packages are installed under: ~/RPackages
+  clean up of R procs on remote side
-(Note: dont yet know if we do or do not need separate compiles between
-communicado, bridles, pads. teraport, and other systems on the CI
-net. Hopefully nit; if we do, weill need to create a tree to R
-releases each with a separate subtree for user-installed packages)
-Seems that we do, at least for PADS, we get this error:
+[] debug version
+    create version of swiftapply etc that runs by saving file, printing
+    message, and waiting for user to do "swiftrun" in a separate
+    window. This will mimic the exec path and enable a developer to debug
+    serially, and under a debugger, on both the client and server side.
+    --> did i do this already?
-login1$ ~/R/bin/R
-/home/wilde/R/lib64/R/bin/exec/R:
-  error while loading shared libraries: libreadline.so.4:
-    cannot open shared object file: No such file or directory
-login1$
+x  check snow/fall code to see if we are missing anything for
+    transparent remote exec
+   (This was list propoerties; fixed now; anything else?)
+x n args
+x batch
+x into svn
+x unique dirs
+  clean up source code formatting: Use OpenMx conventions?
+    (spaces, tabbing?)
-Swift package *source* (tbd) is under:
+For OpenMx 1.0:
-~/SwiftR/Swift (the "Swift" package)
+  coasters for persistent R Servers
+  handle entire apply family
+  determine if we should improve the way we handle options (ask OpenMx team)
-Swift package is installed under:
+  use match.fun ( ??? )
+  ensure (and test) that all expected object attributes are passed and preserved on inputs and outputs (names, dims, etc)
+  capture stdout/err, perhaps with length limits, into R return vars
+  control over Swift properties; set defaults to "no retries":
+    Progress:  Active:7 Failed but can retry:2  ==> should not happen
+  R docs
+x R package (SwiftR)
+  Swift docs
+  pass the func as val ( ??? )
+  pass extra funcs and packages required
+  pass extra vals
+  pass extra files
+  better download and install of Swift (compliant with CRAN regs)
+  args as alists vs args as list( ??? )
+  return good error messages including messages from R eval and from Swift
+  Name pbs jobs mnemonically
+  options for cleaning up and/or retaining intermidiate save/load and stdout/err files
+  tools for displaying what was sent / received in calls (easy to pick apart from retained Rcall and Rret files)
+_ select sites and swift args (throttles etc)
+  Improve tests - see list below
+  runids, output logging
+  select exec sites and swift  params etc
+  make polymorphic to *apply and snow
-*** TO DO LIST:
+For General R usage:
-x n args
-x batch
-x into svn
-x unique dirs
-_ select sites and swift args (throttles etc)
-  R docs
-  R package (SwiftR)
-  Swift docs
+  integration with snowfall/snow?
   async exec
   clean up boot: fix all calls to statistics; update boot package w/ pboot() or swiftboot()
   error handling and null and missing values: ensure res#s correspond to arg#s
   status
   specify swift scripts
+  specify data files to be passed to remote side
+  setup the R envs (???)
+  specify initial R code to run on remote side: (if !initialized_swift) { initialRCodeHere }
   run async and grab status (track 'runs' in R)
   increm result collect
-  pass the func as val
-  pass extra funcs and packages required
-  pass extra vals
-  pass extra files
   specifiy unique swift scritps ala Dirk's tools
-  setup the R envs (???)
-  coasters for persistent R Servers
-  test suites
   use littleR
-  args as alists vs args as list
-  runids, output logging
-  select exec sites and swift  params etc
-  make polymorphic to *apply and snow
   stream results back to R (so use can inspect as they arrive)
-  (pull them in with a Swift.poll() func)
-  handle discontiguous results
-  return good error messages including messages from R eval and from Swift
-  TUI
-  Name pbs jobs mnemonically
+    (pull them in with a Swift.poll() func)
+  handle discontiguous results (??) and incomplete results (not every element of apply() completes)
+  TUI (in various forms)
+*** TESTS NEEDED
+more tests
+test with better data that makes it easier to cross check the results
+dont require boot() for the test datasets
+but test (p)boot() if available
+add output data comparisons (or other output checks) to all tests
+test across a bigger range of types and R weirnesses like local funcs, namespaces, non local assigns, closures, data types etc.
+test on matrices
+test on big matrixes etc to assure that we have no length issues
+tests to ensure all data object attrs passed in and out OK
+test strategy:
+- can we part data of arbitrary structure back and forth?
+- can we pass functions back and forth?
+- do the remote calls work the same regardless of whether they go to an R server or a pre-call R invocation
+flag to control # of tests and degree
+OUTPUT and SWIFT EXEC ISSUES TO CLEAN UP:
+Issues below was that we created a long-lived process that hung on to open files, preventing jobdir from being removed.
+bri$ ./TestSwiftScript.sh run03
+swift output is in: swift.stdouterr.7124, pids in swift.workerpids.7124
+Swift svn swift-r3591 cog-r2868 (cog modified locally)
+RunID: 20100902-1723-etxm22pg
+Progress:
+Passive queue processor initialized. Callback URI is http://128.135.125.18:50003
+Coaster contact: http://128.135.125.18:50003
+Started workers from these ssh processes: 27297
+logilename: /home/wilde/SwiftR/run03/swiftworkerlogs/worker-2010.0902.172334.09027.log
+Progress:  Active:1
+Can't remove directory /home/wilde/SwiftR/run03/swiftwork/rtest-20100902-1723-etxm22pg-f-runr-f90rr6yj (Directory not empty) at /home/wilde/swift/lab/worker.pl line 1001
+Final status:  Finished successfully:1
+Cleaning up...
+Shutting down service at https://128.135.125.18:50002
+Got channel MetaChannel: 570110481[1922304900: {}] -> null[1922304900: {}]
++ Done
+unlink /home/wilde/SwiftR/run03/swiftwork/rtest-20100902-1723-etxm22pg-f-runr-f90rr6yj/_swiftwrap.staging
+unlink /home/wilde/SwiftR/run03/swiftwork/rtest-20100902-1723-etxm22pg-f-runr-f90rr6yj/outdir/r.0001.out
+rmdir /home/wilde/SwiftR/run03/swiftwork/rtest-20100902-1723-etxm22pg-f-runr-f90rr6yj/outdir
+unlink /home/wilde/SwiftR/run03/swiftwork/rtest-20100902-1723-etxm22pg-f-runr-f90rr6yj/3
+unlink /home/wilde/SwiftR/run03/swiftwork/rtest-20100902-1723-etxm22pg-f-runr-f90rr6yj/stdout.txt
+unlink /home/wilde/SwiftR/run03/swiftwork/rtest-20100902-1723-etxm22pg-f-runr-f90rr6yj/wrapper.log
+unlink /home/wilde/SwiftR/run03/swiftwork/rtest-20100902-1723-etxm22pg-f-runr-f90rr6yj/cb1
+Terminating worker processes 27297 and starter 27126
+bri$
