[Swift-commit] r3699 - trunk/docs/guides
Tue Oct 26 17:04:30 CDT 2010
Author: skenny
Date: 2010-10-26 17:04:30 -0500 (Tue, 26 Oct 2010)
New Revision: 3699
Modified:
   trunk/docs/guides/quickstartguide.php
Log:
removed reallyquickstartguide code and link
Modified: trunk/docs/guides/quickstartguide.php
--- trunk/docs/guides/quickstartguide.php	2010-10-26 21:59:31 UTC (rev 3698)
+++ trunk/docs/guides/quickstartguide.php	2010-10-26 22:04:30 UTC (rev 3699)
@@ -187,97 +187,3 @@
 var pageTracker = _gat._getTracker("UA-106257-5");
 pageTracker._trackPageview();
 } catch(err) {}</script></body></html>
- <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
-<html><head><meta http-equiv="Content-Type" content="text/html; charset=UTF-8"><title>Swift Really Quick Start Guide</title><meta name="generator" content="DocBook XSL Stylesheets V1.75.2"><meta name="description" content="This guide is a compressed version of the Swift Quick Start Guide."><link rel="home" href="index.html" title="Swift Really Quick Start Guide"><link href="http://www.ci.uchicago.edu/swift/css/style1col.css" rel="stylesheet" type="text/css"><script type="text/javascript" src="http://www.ci.uchicago.edu/swift/dhtml.js"></script><script type="text/javascript" src="http://www.ci.uchicago.edu/swift/shCoreu.js"></script><script type="text/javascript" src="http://www.ci.uchicago.edu/swift/shBrushVDL2.js"></script></head><body onLoad="initjs();sh();" class="section-3">
-		<!-- entire page container -->
-		<div id="container">
-			<!-- header -->
-			<div id="header">
-				<?php require('/disks/space0/projects/swift/inc/header.php') ?>
-				<?php #require('/ci/www/projects/swift/inc/header.php') ?>
-			</div>
-			<!-- end header -->
-			<!-- nav -->
-			<div id="nav">
-				<?php require('/disks/space0/projects/swift/inc/nav.php') ?>
-				<?php #require('/ci/www/projects/swift/inc/nav.php') ?>
-			</div>
-			<!-- end nav -->
-			<!-- content container -->
-			<div id="content">
-		<div class="article" title="Swift Really Quick Start Guide"><div class="titlepage"><div><div><h2 class="title"><a name="id2725197"></a>Swift Really Quick Start Guide</h2></div><div><h3 class="subtitle"><i>Source control $LastChangedRevision: 2646 $</i></h3></div><div><div class="abstract" title="Abstract"><p class="title"><b>Abstract</b></p><p><b> </b>
-					This guide is a compressed version of the <a class="ulink" href="quickstartguide.php" target="_top">Swift Quick Start
-					Guide</a>.
-				</p></div></div></div><hr></div><div class="toc"><p><b>Table of Contents</b></p><dl><dt><span class="sect1"><a href="#reallyquickstart">1. Swift Really Quick Start Guide</a></span></dt></dl></div><div class="sect1" title="1. Swift Really Quick Start Guide"><div class="titlepage"><div><div><h2 class="title"><a name="reallyquickstart"></a>1. Swift Really Quick Start Guide</h2></div></div></div><div class="itemizedlist"><ul class="itemizedlist" type="disc"><li class="listitem"><p>
-					<a class="ulink" href="http://www.ci.uchicago.edu/swift/downloads/index.php" target="_top">Download</a>
-					Swift.
-				</p></li><li class="listitem"><p>
-					Unpack it and add the <code class="filename">swift-xyz/bin</code> directory to your
-					<code class="envar">PATH</code>.
-					Make sure you have your user certificate, a valid GSI proxy
-					certificate, and the proper CA root certificates in either
-					<code class="filename">~/.globus/certificates</code> or
-					<code class="filename">/etc/grid-security/certificates</code>.
-					Edit <code class="filename">swift-xyz/etc/swift.properties</code>. You
-					should add your numeric IP address there
-					(<span class="property">ip.address</span>=<code class="literal">x.y.z.w</code>).
-					Use the example site catalog and transformation catalog (they
-					are configured for local submission):
-</p><pre class="screen">
-<span class="command"><strong>cd</strong></span> swift-xyz/etc
-<span class="command"><strong>cp</strong></span> sites.xml.example sites.xml
-<span class="command"><strong>cp</strong></span> tc.data.example tc.data
-</pre><p>
-					Use <span class="command"><strong>swift file.dtm</strong></span> to compile and execute
-					<code class="filename">file.dtm</code>.
-					Use <span class="command"><strong>swift -resume file-<runid>.?.rlog
-					file.dtm</strong></span> to resume a failed run.
-				</p></li></ul></div></div></div>
-			</div>
-			<!-- end content container-->
-			<!-- footer -->
-			<div id="footer">
-				<?php require('/disks/space0/projects/swift/inc/footer.php') ?>
-				<?php #require('/ci/www/projects/swift/inc/footer.php') ?>
-			</div>
-			<!-- end footer -->
-		</div>
-		<!-- end entire page container -->
-		<script type="text/javascript">
-var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
-document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
-</script><script type="text/javascript">
-try {
-var pageTracker = _gat._getTracker("UA-106257-5");
-pageTracker._trackPageview();
-} catch(err) {}</script></body></html>
