[Swift-commit] r3696 - usertools/mpich
Tue Oct 26 15:03:19 CDT 2010
Author: wozniak
Date: 2010-10-26 15:03:18 -0500 (Tue, 26 Oct 2010)
New Revision: 3696
Added:
   usertools/mpich/mpich2-1.3.diff
Log:
MPICH patch for 1.3
Added: usertools/mpich/mpich2-1.3.diff
--- usertools/mpich/mpich2-1.3.diff	                        (rev 0)
+++ usertools/mpich/mpich2-1.3.diff	2010-10-26 20:03:18 UTC (rev 3696)
@@ -0,0 +1,99 @@
+Index: src/pm/hydra/tools/bootstrap/external/external_init.c
+--- src/pm/hydra/tools/bootstrap/external/external_init.c	(revision 7377)
++++ src/pm/hydra/tools/bootstrap/external/external_init.c	(working copy)
+@@ -89,3 +89,8 @@
+     return external_init();
++HYD_status HYDT_bsci_manual_init(void)
++    return external_init();
+Index: src/pm/hydra/tools/bootstrap/external/external_launch.c
+--- src/pm/hydra/tools/bootstrap/external/external_launch.c	(revision 7377)
++++ src/pm/hydra/tools/bootstrap/external/external_launch.c	(working copy)
+@@ -268,6 +268,12 @@
+             HYDU_print_strlist(targs + offset);
++        if (!strcmp(HYDT_bsci_info.bootstrap, "manual")) {
++            printf("HYDRA_MANUAL_LINE: ");
++            HYDU_print_strlist(targs + offset);
++            continue;
+         /* The stdin pointer will be some value for process_id 0; for
+          * everyone else, it's a dummy value. We don't just pass it
+          * NULL, as older versions of ssh seem to freak out when no
+@@ -304,6 +310,13 @@
+         HYDU_ERR_POP(status, "demux returned error registering fd\n");
++    fprintf(stderr, "%c\n", 'A');
++        printf("HYDRA_MANUAL_DONE:\n");
++        fflush(stdout);
+   fn_exit:
+     HYDU_free_strlist(targs);
+     if (path)
+Index: src/pm/hydra/configure.in
+--- src/pm/hydra/configure.in	(revision 7377)
++++ src/pm/hydra/configure.in	(working copy)
+@@ -146,7 +146,7 @@
+ AC_ARG_WITH(hydra-bss, [  --with-hydra-bss=name - Boot-strap Server (ssh,rsh,fork,slurm,ll,lsf,sge,persist)],
+ 		    [ hydra_bss=$withval ],
+-		    [ hydra_bss="ssh,rsh,fork,slurm,ll,lsf,sge,persist" ])
++		    [ hydra_bss="ssh,rsh,fork,slurm,ll,lsf,sge,persist,manual" ])
+ AC_MSG_CHECKING(boot-strap server)
+ AC_MSG_RESULT($hydra_bss)
+ hydra_bss_names="`echo $hydra_bss | sed -e 's/:/ /g' -e 's/,/ /g'`"
+@@ -187,6 +187,10 @@
+ 		hydra_bss_persist=true
+ 		available_bss=`echo $available_bss persist`
++	manual)
++		hydra_bss_manual=true
++		available_bss=`echo $available_bss manual`
+     esac
+@@ -377,7 +381,7 @@
+ 		   have_plpa=yes
+ 		   AC_DEFINE(HAVE_PLPA,1,[Define if plpa is available])
+ 		fi
+ 	hwloc)
+ 		if test "$with_hwloc_prefix" = "embedded" ; then
+ 		   PAC_CONFIG_SUBDIR([tools/bind/hwloc/hwloc],[have_hwloc=yes],[have_hwloc=no])
+@@ -451,7 +455,7 @@
+ 	       AC_DEFINE(HAVE_BLCR,1,[Define if blcr is available])
+ 	       available_ckpointlib=`echo $available_ckpointlib blcr`
+ 	    fi
+     esac
+Index: src/pm/hydra/pm/pmiserv/pmiserv_utils.c
+--- src/pm/hydra/pm/pmiserv/pmiserv_utils.c	(revision 7377)
++++ src/pm/hydra/pm/pmiserv/pmiserv_utils.c	(working copy)
+@@ -90,7 +90,7 @@
+     proxy_args[arg++] = HYDU_strdup("--enable-stdin");
+-    proxy_args[arg++] = HYDU_int_to_str(enable_stdin);
++    proxy_args[arg++] = HYDU_int_to_str(0); // (enable_stdin);
+     proxy_args[arg++] = HYDU_strdup("--proxy-id");
+     proxy_args[arg++] = NULL;
