[Swift-commit] r3673 - trunk/tests
Fri Oct 8 14:15:02 CDT 2010
Author: wozniak
Date: 2010-10-08 14:15:02 -0500 (Fri, 08 Oct 2010)
New Revision: 3673
Modified:
   trunk/tests/nightly.sh
Log:
Minor changes + suppressing cdm/ps/pinned for now
Modified: trunk/tests/nightly.sh
--- trunk/tests/nightly.sh	2010-10-08 17:00:17 UTC (rev 3672)
+++ trunk/tests/nightly.sh	2010-10-08 19:15:02 UTC (rev 3673)
@@ -2,14 +2,10 @@
 # USAGE NOTES:
-# Run this script from a working directory in which you
-# are willing to check out the whole Swift source and
-# generate many small test files.
+# The script will (optionally) checkout Swift, run several tests in a
+# subdirectory called run-DATE, and generate useful HTML output and
+# tests.log
-# The script will checkout Swift, run several tests
-# in a subdirectory called run-DATE, and generate
-# useful HTML output and tests.log
 # Run nightly.sh -h for quick help
 # When something goes wrong, find and check tests.log or use -v
 # Code is checked out into TOPDIR
@@ -83,6 +79,7 @@
 RUN_ANT=1
 CLEAN=1
 SKIP_TESTS=0
+NUMBER_OF_TESTS=1000000 # Run all tests by default
 BUILD_PACKAGE=1
 GRID_TESTS=1
 SKIP_CHECKOUT=0
@@ -653,7 +650,7 @@
   STOP=$( date +%s )
   # If the test was killed, monitor() may have work to do
-  rm killed_test && sleep 5
+  rm killed_test > /dev/null 2>&1 && sleep 5
   verbose "Killing monitor..."
   /bin/kill -TERM $MONITOR_PID
@@ -907,8 +904,10 @@
             $TESTDIR/language/should-not-work \
             $TESTDIR/cdm \
             $TESTDIR/cdm/ps \
-            $TESTDIR/cdm/ps/pinned )
+            $TESTDIR/cdm/star )
+#             $TESTDIR/cdm/ps/pinned \ # Currently broken
 GROUPCOUNT=1
 for G in ${GROUPLIST[@]}; do
   export GROUP=$G
