[Swift-commit] r3667 - in trunk/src/org/globus/swift/data: . policy util
Thu Oct 7 16:25:29 CDT 2010
Author: wozniak
Date: 2010-10-07 16:25:29 -0500 (Thu, 07 Oct 2010)
New Revision: 3667
Modified:
   trunk/src/org/globus/swift/data/Director.java
   trunk/src/org/globus/swift/data/Query.java
   trunk/src/org/globus/swift/data/policy/Broadcast.java
   trunk/src/org/globus/swift/data/util/LineReader.java
Log:
Minor refactoring
Modified: trunk/src/org/globus/swift/data/Director.java
--- trunk/src/org/globus/swift/data/Director.java	2010-10-07 20:40:01 UTC (rev 3666)
+++ trunk/src/org/globus/swift/data/Director.java	2010-10-07 21:25:29 UTC (rev 3667)
@@ -7,12 +7,10 @@
 import java.util.Arrays;
 import java.util.HashMap;
 import java.util.HashSet;
-import java.util.Iterator;
 import java.util.LinkedHashMap;
 import java.util.LinkedHashSet;
 import java.util.List;
 import java.util.Map;
-import java.util.Map.Entry;
 import java.util.Set;
 import java.util.regex.Matcher;
 import java.util.regex.Pattern;
@@ -21,7 +19,6 @@
 import org.globus.swift.data.policy.Policy;
 import org.globus.swift.data.policy.Broadcast;
 import org.globus.swift.data.util.LineReader;
-import org.griphyn.vdl.karajan.Loader;
  * Manages CDM policies for files based on pattern matching.
@@ -29,7 +26,8 @@
 public class Director {
-    private static final Logger logger = Logger.getLogger(Director.class);
+    private static final Logger logger =
+        Logger.getLogger(Director.class);
        Has a CDM policy file been provided?
@@ -44,12 +42,14 @@
        Maps from Patterns to Policies for fs.data rules
-    static Map<Pattern,Policy> map = new LinkedHashMap();
+    static Map<Pattern,Policy> map =
+        new LinkedHashMap<Pattern, Policy>();
        Maps from String names to String values for fs.data properties
-    static Map<String,String> properties = new HashMap();
+    static Map<String,String> properties =
+        new HashMap<String, String>();
        Remember the files we have broadcasted.
@@ -82,12 +82,9 @@
         logger.info("CDM file: " + policyFile);
         enabled = true;
         Director.policyFile = policyFile;
-        LineReader lines = new LineReader();
-        List list = lines.read(policyFile);
-        for (Iterator it = list.iterator(); it.hasNext(); ) {
-            String s = (String) it.next();
+        List<String> list = LineReader.read(policyFile);
+        for (String s : list)
             addLine(s);
@@ -168,7 +165,8 @@
        Add a file to the list of files to be broadcasted.
-    public static synchronized void addBroadcast(String srcdir, String srcfile) {
+    public static synchronized void addBroadcast(String srcdir,
+                                                 String srcfile) {
         logger.debug("addBroadcast(): " + srcdir + " " + srcfile);
         String path = srcdir+"/"+srcfile;
         broadcastWork.add(path);
@@ -266,7 +264,6 @@
         try {
             String name = args[0];
             File policyFile = new File(args[1]);
             if (! policyFile.exists()) {
Modified: trunk/src/org/globus/swift/data/Query.java
--- trunk/src/org/globus/swift/data/Query.java	2010-10-07 20:40:01 UTC (rev 3666)
+++ trunk/src/org/globus/swift/data/Query.java	2010-10-07 21:25:29 UTC (rev 3667)
@@ -1,14 +1,9 @@
 package org.globus.swift.data;
-import java.io.BufferedReader;
-import java.io.File;
-import java.io.FileReader;
 import org.apache.log4j.Logger;
 import org.globus.cog.karajan.arguments.Arg;
 import org.globus.cog.karajan.stack.VariableStack;
-import org.globus.cog.karajan.util.TypeUtil;
 import org.globus.cog.karajan.workflow.ExecutionException;
 import org.globus.cog.karajan.workflow.nodes.functions.FunctionsCollection;
Modified: trunk/src/org/globus/swift/data/policy/Broadcast.java
--- trunk/src/org/globus/swift/data/policy/Broadcast.java	2010-10-07 20:40:01 UTC (rev 3666)
+++ trunk/src/org/globus/swift/data/policy/Broadcast.java	2010-10-07 21:25:29 UTC (rev 3667)
@@ -4,9 +4,6 @@
-import java.util.Map;
 import org.globus.swift.data.Director;
 public class Broadcast extends Policy {
Modified: trunk/src/org/globus/swift/data/util/LineReader.java
--- trunk/src/org/globus/swift/data/util/LineReader.java	2010-10-07 20:40:01 UTC (rev 3666)
+++ trunk/src/org/globus/swift/data/util/LineReader.java	2010-10-07 21:25:29 UTC (rev 3667)
@@ -10,27 +10,26 @@
 import java.util.ArrayList;
-import org.globus.cog.karajan.arguments.Arg;
 public class LineReader {
     public LineReader()
-    public static List read(File file) throws FileNotFoundException {
+    public static List<String> read(File file)
+    throws FileNotFoundException {
         BufferedReader reader =
             new BufferedReader(new FileReader(file));
         return read(reader);
-    public static List read(String s) {
+    public static List<String> read(String s) {
             new BufferedReader(new StringReader(s));
-    public static List read(BufferedReader reader) {
-        List result = new ArrayList();
+    public static List<String> read(BufferedReader reader) {
+        List<String> result = new ArrayList<String>();
         try
             String prevline = "";
@@ -65,7 +64,7 @@
     public static String[] tokenize(String line) {
         if (line == null)
             return null;
-        List words = new ArrayList();
+        List<String> words = new ArrayList<String>();
         String[] ws = line.split("\\s");
         for (int i = 0; i < ws.length; i++)
             if (ws[i].length() > 0)
