[Swift-commit] r3338 - trunk/examples
Mon May 31 05:57:08 CDT 2010
Author: davidk
Date: 2010-05-31 05:57:08 -0500 (Mon, 31 May 2010)
New Revision: 3338
Added:
   trunk/examples/if.swift
   trunk/examples/iterate.swift
   trunk/examples/one.txt
   trunk/examples/q21.swift
   trunk/examples/q3.swift
   trunk/examples/q5.swift
   trunk/examples/q6.swift
   trunk/examples/q7.swift
   trunk/examples/q8.swift
   trunk/examples/restart.swift
   trunk/examples/second_procedure.swift
   trunk/examples/three.txt
   trunk/examples/two.txt
   trunk/examples/wcl
Removed:
   trunk/examples/tutorial/
Log:
Further modifications, updates and changes to tutorial scripts
Added: trunk/examples/if.swift
--- trunk/examples/if.swift	                        (rev 0)
+++ trunk/examples/if.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,18 @@
+type messagefile {}
+(messagefile t) greeting (string s) {
+    app {
+        echo s stdout=@filename(t);
+messagefile outfile <"hello20.txt">;
+boolean morning = true;
+if(morning) {
+  outfile = greeting("good morning");
+} else {
+  outfile = greeting("good afternoon");
Added: trunk/examples/iterate.swift
--- trunk/examples/iterate.swift	                        (rev 0)
+++ trunk/examples/iterate.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,22 @@
+type counterfile;
+(counterfile t) echo(string m) {
+  app {
+    echo m stdout=@filename(t);
+(counterfile t) countstep(counterfile i) {
+  app {
+    wcl @filename(i) @filename(t);
+counterfile a[]  <simple_mapper;prefix="foldout">;
+a[0] = echo("793578934574893");
+iterate v {
+  a[v+1] = countstep(a[v]);
+ trace("extract int value ", at extractint(a[v+1]));
+} until (@extractint(a[v+1]) <= 1);
Added: trunk/examples/one.txt
--- trunk/examples/one.txt	                        (rev 0)
+++ trunk/examples/one.txt	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1 @@
+this is one.txt
Added: trunk/examples/q21.swift
--- trunk/examples/q21.swift	                        (rev 0)
+++ trunk/examples/q21.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,14 @@
+(messagefile t) greeting (string s="hello") {
+    app {
+messagefile english <"english2.txt">;
+messagefile french <"francais2.txt">;
+english = greeting();
+french = greeting(s="bonjour");
Added: trunk/examples/q3.swift
--- trunk/examples/q3.swift	                        (rev 0)
+++ trunk/examples/q3.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,10 @@
+type file {}
+(file t) echo (string s = "default greeting") {
+    app {
+file hw = echo();
Added: trunk/examples/q5.swift
--- trunk/examples/q5.swift	                        (rev 0)
+++ trunk/examples/q5.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,14 @@
+type messagefile;
+(messagefile t) greeting (string s[]) {
+    app {
+        echo s[0] s[1] s[2] stdout=@filename(t);
+messagefile outfile <"q5out.txt">;
+string words[] = ["how","are","you"];
+outfile = greeting(words);
Added: trunk/examples/q6.swift
--- trunk/examples/q6.swift	                        (rev 0)
+++ trunk/examples/q6.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,14 @@
+type file {}
+(file t) echo (string s) {
+    app {
+string greetings[] = ["how","are","you"];
+foreach g in greetings {
+  file hw = echo(g);
Added: trunk/examples/q7.swift
--- trunk/examples/q7.swift	                        (rev 0)
+++ trunk/examples/q7.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,16 @@
+type file {}
+    app {
+string outputNames = "one two three";
+file outputFiles[] <fixed_array_mapper;files=outputNames>;
+foreach f in outputFiles {
+    f = echo("hello");
Added: trunk/examples/q8.swift
--- trunk/examples/q8.swift	                        (rev 0)
+++ trunk/examples/q8.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,14 @@
+type file {}
+    app {
+file inputFiles[] <filesys_mapper;pattern="*">;
+file o <"foo.out">;
+o = echo(@filenames(inputFiles));
Added: trunk/examples/restart.swift
--- trunk/examples/restart.swift	                        (rev 0)
+++ trunk/examples/restart.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,32 @@
+type file;
+(file f) touch() {
+  app {
+    touch @f;
+(file f) processL(file inp) {
+  app {
+    echo "processL" stdout=@f;
+(file f) processR(file inp) {
+  app {
+    broken "process" stdout=@f;
+(file f) join(file left, file right) {
+  app {
+    echo "join" @left @right stdout=@f;
+file f = touch();
+file g = processL(f);
+file h = processR(f);
+file i = join(g,h);
Added: trunk/examples/second_procedure.swift
--- trunk/examples/second_procedure.swift	                        (rev 0)
+++ trunk/examples/second_procedure.swift	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,20 @@
+    app {
+(messagefile o) capitalise(messagefile i) {
+    app {
+        tr "[a-z]" "[A-Z]" stdin=@filename(i) stdout=@filename(o);
+messagefile hellofile <"hello.txt">;
+messagefile final <"capitals.txt">;
+hellofile = greeting("hello from Swift");
+final = capitalise(hellofile);
Added: trunk/examples/three.txt
--- trunk/examples/three.txt	                        (rev 0)
+++ trunk/examples/three.txt	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1 @@
+three
Added: trunk/examples/two.txt
--- trunk/examples/two.txt	                        (rev 0)
+++ trunk/examples/two.txt	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1 @@
+a second file
Added: trunk/examples/wcl
--- trunk/examples/wcl	                        (rev 0)
+++ trunk/examples/wcl	2010-05-31 10:57:08 UTC (rev 3338)
@@ -0,0 +1,3 @@
+#!/bin/bash
+echo -n $(wc -c < $1) > $2
Property changes on: trunk/examples/wcl
___________________________________________________________________
