[Swift-commit] r3332 - text/internals/trunk
Thu May 13 14:51:28 CDT 2010
Author: aespinosa
Date: 2010-05-13 14:51:27 -0500 (Thu, 13 May 2010)
New Revision: 3332
Modified:
   text/internals/trunk/internals.tex
Log:
Raw notes last last week
Modified: text/internals/trunk/internals.tex
--- text/internals/trunk/internals.tex	2010-05-05 16:06:08 UTC (rev 3331)
+++ text/internals/trunk/internals.tex	2010-05-13 19:51:27 UTC (rev 3332)
@@ -182,5 +182,183 @@
 \end{verbatim}
+\subsection{Elements}
+Example: recursive list
+\begin{verbatim}
+element(f, [n]
+  if(n == 0, 0,
+    n,
+    f(n-1) )
+l := list(f(10))
+\end{verbatim}
+equivalent to
+\begin{verbatim}
+l := list(10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0)
+\end{verbatim}
+Expansion :
+f(10) -> 10, f(9) -> 10, 9, f(8) -> ...
+At some point there will be 10 stackframes active.
+Positional arguments are always required, Optional arguments cannot be specified
+positionally.
+\section{Unreturned arguments}
+... = vargs. should always be last in an element definition.  Stuck in the
+default channel
+element(f, [...]
+  each(...)
+f(1,2,3) -> 1,2,3
+element(f, [...]
+  for(i, ...
+    i
+Optional arguments cannot be expressed in positional form
+\section{Named channels}
+Multiple varargs
+channel(a) - an implicit channel
+to(a, 1,2,3)
+example
+element(fc, [b, channel(a)]
+  for(i, a,
+    echo(b, '-', i)
+Used in generating a graphviz DAG
+parallelElement(con, [channel(c)]
+  for(i, c
+    echo(i)
+element(gen, []
+  for(i, range(0,10),
+    wait(delay=1000), i
+con(gen())
+Print as a channel:
+print("a") -> to(stdout, "a")
+You can intercept a channel.  Other purely functional languages like Haskell
+messes up this side effect.
+element(x, [channel(stdout)]
+  a := first(stdout)
+  echo(reverse(a))
+x(print("abc"))
+dumps "cba"
+\sectio{Swift compilation}
+swift source -> parser -> vdlx -> dump parser / compiled /translated -> .kml
+down tree. static type checking, limited data flow analysis
+.kml uses some libraries vdl-int.k, vdl.k, vdl-sc.k, vdl-lib.xml - java defined
+elements
+vdl-sc.k -> site catalog parsing
+execute-*.k
+vdl.k, vdl-lib.k -> publicly accessible by the kml file.  encapsulation issues
+vdl-lib.xml -> mapping functions (extractint, etc, @java),
+            -> data manipulation
+            -> two namespaces vdl and swiftscript
+"swiftscript" : actual mapping functions @name
+  @name = filename(foo) equivalent to C's '&'
+originally @no data flow with mapping functions.  limited processing on a string
+.  supposed to assist in the mapping functions
+vdl : - dataset functions
+    - directory manipulation (basename, dirname).  used internally
+cdm: - cdm functions
+\section{first.swift}
+In normal karajan (not compiled xml)
+element(greeting, [t]
+  vdl:execute(
+    vdl:tr("echo")
+    vdl:stageout(t)
+    vdl:arguments("Hello world")
+    vdl:stdout(swifscript:filename(t))
+  vdl:closedataset(t)
+With input parameter
+type file;
+app (file m) greeting(string msg) {
+  echo msg stdout=@filename(t);
+file outf<"a.txt">;
+outf = greeting("Hello world");
+compiled
+element(greeting, [t, msg]
+  vdl:execute(
+    vdl:tr("echo")
+    vdl:stageout(t)
+    vdl:arguments(vdl:getfieldvalue(msg))
+\section{DSHandle}
+Most primitive representation of a swift piece of data.  A pointer.  The hash
+table is filled with DSHandle values.  Pointer descriptor of a swift object
+A tree
+Scalar = just a struct
+Implements -> scalar, array, structs, etc.
+More or relation to nodes than the names of the nodes in itself
+All data variables in swift (dshandles) are futures.
+string s = "x"; ->
+s=vdl:new(...)
+vdl:setfieldvalue(s, "x")
 \end{document}
