[Swift-commit] r3320 - in SwiftApps/adem-osg/lib: . adem
Mon May 3 14:57:01 CDT 2010
Author: aespinosa
Date: 2010-05-03 14:57:01 -0500 (Mon, 03 May 2010)
New Revision: 3320
Added:
   SwiftApps/adem-osg/lib/adem/
   SwiftApps/adem-osg/lib/adem/app.rb
   SwiftApps/adem-osg/lib/adem/config.rb
   SwiftApps/adem-osg/lib/adem/sites.rb
Modified:
   SwiftApps/adem-osg/lib/adem.rb
Log:
Grouped behavior by file
Added: SwiftApps/adem-osg/lib/adem/app.rb
--- SwiftApps/adem-osg/lib/adem/app.rb	                        (rev 0)
+++ SwiftApps/adem-osg/lib/adem/app.rb	2010-05-03 19:57:01 UTC (rev 3320)
@@ -0,0 +1,52 @@
+def app(args, conf)
+  "app"
+end
+def app_avail(pacman_cache)
+  `pacman -trust-all-caches -lc #{pacman_cache}`
+end
+def app_deploy(app, conf)
+  conf[:sites].each do |site|
+    path = "#{site[:app_directory]}/#{conf[:virtual_organization]}"
+    contact = site_fork site[:compute_element]
+    site[:pacman] = pacman_find(contact, path) if not site[:pacman]
+    target = {
+      :contact => contact,
+      :pacman => site[:pacman],
+      :path => path
+    package = "#{conf[:pacman_cache]}:#{app}"
+    pacman_install package, target
+  end
+end
+def site_fork(compute_element)
+  compute_element.gsub /jobmanager-.*$/, "jobmanager-fork"
+end
+def pacman_find(contact, rootdir)
+  File.open("find_pacman.sh", "w") do |dump|
+    dump.puts "#!/bin/bash"
+    dump.puts "which pacman"
+  end
+  File.chmod 0755, "find_pacman.sh"
+  resp = `globus-job-run #{contact} -d #{rootdir} -stage find_pacman.sh`
+  File.delete "find_pacman.sh"
+  File.dirname(File.dirname(resp))
+end
+def pacman_install(package, target)
+  File.open("pacman_install.sh", "w") do |dump|
+    dump.puts "source #{target[:pacman]}/setup.sh"
+    dump.puts "pacman -trust-all-caches -install #{package}"
+  end
+  File.chmod 0755, "pacman_install.sh"
+  `globus-job-run #{target[:contact]} /bin/mkdir -p #{target[:path]}`
+  resp = `globus-job-run #{target[:contact]} -d #{target[:path]} -stage pacman_install.sh`
+  File.delete "pacman_install.sh"
+  resp
+end
Added: SwiftApps/adem-osg/lib/adem/config.rb
--- SwiftApps/adem-osg/lib/adem/config.rb	                        (rev 0)
+++ SwiftApps/adem-osg/lib/adem/config.rb	2010-05-03 19:57:01 UTC (rev 3320)
@@ -0,0 +1,15 @@
+class ConfigError < RuntimeError
+end
+def load_config(yaml_config)
+  conf = YAML.load yaml_config
+  conf.each do |key, val|
+    conf.delete(key)
+    conf[key.to_sym] = val
+  end
+  conf
+end
+def config(args, config_file)
+  load_config File.open(config_file)
+end
Added: SwiftApps/adem-osg/lib/adem/sites.rb
--- SwiftApps/adem-osg/lib/adem/sites.rb	                        (rev 0)
+++ SwiftApps/adem-osg/lib/adem/sites.rb	2010-05-03 19:57:01 UTC (rev 3320)
@@ -0,0 +1,81 @@
+class SiteError < Exception
+  attr_reader :output
+  def initialize(output)
+    @output = output
+  end
+end
+def sites(args, conf, sites_file)
+  begin
+    YAML.load File.open sites_file
+  rescue Errno::ENOENT
+    result = ress_parse ress_query(conf).split("\n\n")
+    raise SiteError.new(result)
+  end
+end
+def ress_query(conf)
+  `condor_status -pool #{conf[:ress_server]} -const \
+    'stringListIMember(\"VO:#{conf[:virtual_organization]}\", \
+    GlueCEAccessControlBaseRule)' -long`
+end
+def ress_parse(ress)
+  class_ads = [
+    "GlueSiteUniqueID", "GlueCEInfoHostName", "GlueCEInfoJobManager",
+    "GlueCEInfoGatekeeperPort", "GlueSEAccessProtocolEndpoint",
+    "GlueSEAccessProtocolType", "GlueCEInfoApplicationDir", "GlueCEInfoDataDir"
+  site = {}
+  ress.each do |entry|
+    tmp = {}
+    entry.each do |attr|
+      attr.chomp!
+      class_ads.each do |class_ad|
+        if attr.include? class_ad
+          tmp[class_ad] = attr.gsub!(/.*\=\ (.*)$/, '\1').gsub /"/, ''
+        end
+      end
+    end
+    next if tmp["GlueSiteUniqueID"] == nil
+    site_name = tmp["GlueSiteUniqueID"]
+    site[site_name] = {} if site[site_name] == nil
+    compute_element = "#{tmp['GlueCEInfoHostName']}:#{tmp['GlueCEInfoGatekeeperPort']}/jobmanager-#{tmp['GlueCEInfoJobManager']}"
+    if site[site_name]["compute_element"] == nil
+      site[site_name]["compute_element"] = compute_element
+    elsif site[site_name]["compute_element"] != compute_element
+      old = site[site_name]["compute_element"].to_a
+      old << compute_element
+      site[site_name]["compute_element"] = old.uniq
+    end
+    storage_element = "gsiftp://#{tmp['GlueCEInfoHostName']}:2811"
+    if site[site_name]["storage_element"] == nil
+      site[site_name]["storage_element"] = storage_element
+    elsif site[site_name]["storage_element"] != storage_element
+      old = site[site_name]["storage_element"].to_a
+      old << storage_element
+      site[site_name]["storage_element"] = old.flatten.uniq
+    end
+    site[site_name]["data_directory"] = tmp['GlueCEInfoDataDir']
+    site[site_name]["app_directory"] = tmp['GlueCEInfoApplicationDir']
+    # Disabled because some storage endpoints are broken
+    #storage_element = tmp['GlueSEAccessProtocolEndpoint'] if tmp['GlueSEAccessProtocolType'] == 'gsiftp'
+    #next if storage_element == nil
+    #if storage_element.include? ','
+      #storage_element = storage_element.split(',').grep /gsiftp/
+    #end
+    #if site[site_name]["storage_element"] == nil
+      #site[site_name]["storage_element"] = storage_element
+    #elsif site[site_name]["storage_element"] != storage_element
+      #old = site[site_name]["storage_element"].to_a
+      #old << storage_element
+      #site[site_name]["storage_element"] = old.flatten.uniq
+    #end
+  end
+  site
+end
Modified: SwiftApps/adem-osg/lib/adem.rb
--- SwiftApps/adem-osg/lib/adem.rb	2010-05-03 19:56:55 UTC (rev 3319)
+++ SwiftApps/adem-osg/lib/adem.rb	2010-05-03 19:57:01 UTC (rev 3320)
@@ -1,157 +1,14 @@
 require 'yaml'
 require 'ftools'
+require 'adem/config'
+require 'adem/sites'
+require 'adem/app'
 CONFIGURATION_FILE = "#{ENV['HOME']}/.adem/config"
 SITES_FILE         = "#{ENV['HOME']}/.adem/sites"
 APPS_FILE          = "#{ENV['HOME']}/.adem/apps"
-class SiteError < Exception
-  attr_reader :output
-  def initialize(output)
-    @output = output
-  end
-end
-class ConfigError < RuntimeError
-end
-def load_config(yaml_config)
-  conf = YAML.load yaml_config
-  conf.each do |key, val|
-    conf.delete(key)
-    conf[key.to_sym] = val
-  end
-  conf
-end
-def sites(args, conf, sites_file)
-  begin
-    YAML.load File.open sites_file
-  rescue Errno::ENOENT
-    result = ress_parse ress_query(conf).split("\n\n")
-    raise SiteError.new(result)
-  end
-end
-def ress_query(conf)
-  `condor_status -pool #{conf[:ress_server]} -const \
-    'stringListIMember(\"VO:#{conf[:virtual_organization]}\", \
-    GlueCEAccessControlBaseRule)' -long`
-end
-def ress_parse(ress)
-  class_ads = [
-    "GlueSiteUniqueID", "GlueCEInfoHostName", "GlueCEInfoJobManager",
-    "GlueCEInfoGatekeeperPort", "GlueSEAccessProtocolEndpoint",
-    "GlueSEAccessProtocolType", "GlueCEInfoApplicationDir", "GlueCEInfoDataDir"
-  site = {}
-  ress.each do |entry|
-    tmp = {}
-    entry.each do |attr|
-      attr.chomp!
-      class_ads.each do |class_ad|
-        if attr.include? class_ad
-          tmp[class_ad] = attr.gsub!(/.*\=\ (.*)$/, '\1').gsub /"/, ''
-        end
-      end
-    end
-    next if tmp["GlueSiteUniqueID"] == nil
-    site_name = tmp["GlueSiteUniqueID"]
-    site[site_name] = {} if site[site_name] == nil
-    compute_element = "#{tmp['GlueCEInfoHostName']}:#{tmp['GlueCEInfoGatekeeperPort']}/jobmanager-#{tmp['GlueCEInfoJobManager']}"
-    if site[site_name]["compute_element"] == nil
-      site[site_name]["compute_element"] = compute_element
-    elsif site[site_name]["compute_element"] != compute_element
-      old = site[site_name]["compute_element"].to_a
-      old << compute_element
-      site[site_name]["compute_element"] = old.uniq
-    end
-    storage_element = "gsiftp://#{tmp['GlueCEInfoHostName']}:2811"
-    if site[site_name]["storage_element"] == nil
-      site[site_name]["storage_element"] = storage_element
-    elsif site[site_name]["storage_element"] != storage_element
-      old = site[site_name]["storage_element"].to_a
-      old << storage_element
-      site[site_name]["storage_element"] = old.flatten.uniq
-    end
-    site[site_name]["data_directory"] = tmp['GlueCEInfoDataDir']
-    site[site_name]["app_directory"] = tmp['GlueCEInfoApplicationDir']
-    # Disabled because some storage endpoints are broken
-    #storage_element = tmp['GlueSEAccessProtocolEndpoint'] if tmp['GlueSEAccessProtocolType'] == 'gsiftp'
-    #next if storage_element == nil
-    #if storage_element.include? ','
-      #storage_element = storage_element.split(',').grep /gsiftp/
-    #end
-    #if site[site_name]["storage_element"] == nil
-      #site[site_name]["storage_element"] = storage_element
-    #elsif site[site_name]["storage_element"] != storage_element
-      #old = site[site_name]["storage_element"].to_a
-      #old << storage_element
-      #site[site_name]["storage_element"] = old.flatten.uniq
-    #end
-  end
-  site
-end
-def app(args, conf)
-  "app"
-end
-def app_avail(pacman_cache)
-  `pacman -trust-all-caches -lc #{pacman_cache}`
-end
-def app_deploy(app, conf)
-  conf[:sites].each do |site|
-    path = "#{site[:app_directory]}/#{conf[:virtual_organization]}"
-    contact = site_fork site[:compute_element]
-    site[:pacman] = pacman_find(contact, path) if not site[:pacman]
-    target = {
-      :contact => contact,
-      :pacman => site[:pacman],
-      :path => path
-    package = "#{conf[:pacman_cache]}:#{app}"
-    pacman_install package, target
-  end
-end
-def site_fork(compute_element)
-  compute_element.gsub /jobmanager-.*$/, "jobmanager-fork"
-end
-def pacman_find(contact, rootdir)
-  File.open("find_pacman.sh", "w") do |dump|
-    dump.puts "#!/bin/bash"
-    dump.puts "which pacman"
-  end
-  File.chmod 0755, "find_pacman.sh"
-  resp = `globus-job-run #{contact} -d #{rootdir} -stage find_pacman.sh`
-  File.delete "find_pacman.sh"
-  File.dirname(File.dirname(resp))
-end
-def pacman_install(package, target)
-  File.open("pacman_install.sh", "w") do |dump|
-    dump.puts "source #{target[:pacman]}/setup.sh"
-    dump.puts "pacman -trust-all-caches -install #{package}"
-  end
-  File.chmod 0755, "pacman_install.sh"
-  `globus-job-run #{target[:contact]} /bin/mkdir -p #{target[:path]}`
-  resp = `globus-job-run #{target[:contact]} -d #{target[:path]} -stage pacman_install.sh`
-  File.delete "pacman_install.sh"
-  resp
-end
-def config(args, config_file)
-  load_config File.open(config_file)
-end
 def run_command(args, config_file, sites_file)
   command = args.shift
   output = nil
