[Swift-commit] r3302 - SwiftApps/adem-osg
Mon May 3 14:56:10 CDT 2010
Author: aespinosa
Date: 2010-05-03 14:56:10 -0500 (Mon, 03 May 2010)
New Revision: 3302
Modified:
   SwiftApps/adem-osg/adem-test.rb
   SwiftApps/adem-osg/adem.rb
Log:
Refactored configurations as method parameters
Modified: SwiftApps/adem-osg/adem-test.rb
--- SwiftApps/adem-osg/adem-test.rb	2010-05-03 19:56:07 UTC (rev 3301)
+++ SwiftApps/adem-osg/adem-test.rb	2010-05-03 19:56:10 UTC (rev 3302)
@@ -87,4 +87,14 @@
 class RunTest < Test::Unit::TestCase
   include Adem::TestSetup
+  def test_config
+    assert_equal(@conf, run_command(["config"], "config", nil))
+  end
+  def test_sites_from_file
+    conf = @conf
+    site_list = YAML.load @site_list
+    assert_equal(site_list, run_command(["sites"], "config", "sites"))
+  end
 end
Modified: SwiftApps/adem-osg/adem.rb
--- SwiftApps/adem-osg/adem.rb	2010-05-03 19:56:07 UTC (rev 3301)
+++ SwiftApps/adem-osg/adem.rb	2010-05-03 19:56:10 UTC (rev 3302)
@@ -111,16 +111,27 @@
   load_config File.open(config_file)
 end
-def run_command(args)
+def run_command(args, config_file, sites_file)
   command = args.shift
-  if command != "config"
-    conf = load_config File.open(CONFIGURATION_FILE)
-    puts sites(args, conf, SITES_FILE).to_yaml if command == "sites"
+  output = nil
+  if command == "sites"
+    conf = load_config File.open(config_file)
+    begin
+      output = sites(args, conf, sites_file) if command == "sites"
+    rescue SiteError => exception
+      output = exception.output
+      File.open(sites_file, "w") do |sites_file|
+        sites_file << output.to_yaml
+      end
+    end
+  elsif command == "app"
+    conf[:sites] = sites(nil, conf, sites_file)
+    app(args, conf)
   else
-    config args, CONFIGURATION_FILE
+    output = config args, config_file
   end
 end
 if $0 == __FILE__
-  run_command ARGV
+  run_command ARGV, CONFIGURATION_FILE, SITES_FILE
 end
