[Swift-commit] r3829 - trunk/src/org/globus/swift/catalog
Thu Dec 23 16:48:53 CST 2010
Author: wozniak
Date: 2010-12-23 16:48:52 -0600 (Thu, 23 Dec 2010)
New Revision: 3829
Added:
   trunk/src/org/globus/swift/catalog/TCEntry.java
Log:
Rename of TransformationCatalogEntry
Added: trunk/src/org/globus/swift/catalog/TCEntry.java
--- trunk/src/org/globus/swift/catalog/TCEntry.java	                        (rev 0)
+++ trunk/src/org/globus/swift/catalog/TCEntry.java	2010-12-23 22:48:52 UTC (rev 3829)
@@ -0,0 +1,513 @@
+ * This file or a portion of this file is licensed under the terms of
+ * the Globus Toolkit Public License, found in file GTPL, or at
+ * http://www.globus.org/toolkit/download/license.html. This notice must
+ * appear in redistributions of this file, with or without modification.
+ * Redistributions of this Software, with or without modification, must
+ * reproduce the GTPL in: (1) the Software, or (2) the Documentation or
+ * some other similar material which is provided with the Software (if
+ * any).
+ * Copyright 1999-2004 University of Chicago and The University of
+ * Southern California. All rights reserved.
+package org.globus.swift.catalog;
+ * An object of this class corresponds to a
+ * tuple in the Transformation Catalog.
+ * @author Gaurang Mehta
+ * @$Revision: 1.9 $
+ * @see org.griphyn.common.classes.SysInfo
+ * @see org.griphyn.common.classes.TCType
+import org.globus.swift.catalog.types.SysInfo;
+import org.globus.swift.catalog.types.TCType;
+import org.globus.swift.catalog.util.Profile;
+import org.globus.swift.catalog.util.ProfileParser;
+import org.globus.swift.catalog.util.Separator;
+import java.util.ArrayList;
+import java.util.List;
+public class TCEntry
+    implements CatalogEntry {
+     * The logical namespace of the transformation
+    private String namespace;
+     * The version of the transformation.
+    private String version;
+     *  The logical name of the transformation.
+    private String name;
+     *  The Id of the resource on which the transformation
+     *  is installed.
+    private String resourceid;
+     * The physical path on the resource for a particual arch, os and type.
+    private String physicalname;
+     * The profiles associated with the transformation;
+    private List<Profile> profiles;
+     * The System Info for the transformation.
+    private SysInfo sysinfo;
+     * The type of transformation. Takes one of the predefined enumerated type TCType.
+    private TCType type = TCType.INSTALLED;
+     * The basic constructor
+    public TCEntry() {
+        namespace = null;
+        name = null;
+        version = null;
+        resourceid = null;
+        physicalname = null;
+        profiles = null;
+        sysinfo = null;
+     * Optimized Constructor
+     * @param namespace String
+     * @param name String
+     * @param version String
+    public TCEntry( String namespace,
+                                       String name,
+                                       String version){
+        this.namespace = namespace;
+        this.version = version;
+        this.name = name;
+     * @param resourceid String
+     * @param physicalname String
+     * @param type TCType
+     * @param profiles List
+     * @param sysinfo SysInfo
+    public TCEntry( String namespace, String name,
+        String version,
+        String resourceid, String physicalname, TCType type,
+        List<Profile> profiles,
+        SysInfo sysinfo ) {
+        this.name = name;
+        this.resourceid = resourceid;
+        this.physicalname = physicalname;
+        this.profiles = profiles;
+        this.sysinfo = sysinfo;
+        this.type = type;
+     * creates a new instance of this object and returns
+     * you it. A shallow clone.
+     * TO DO : Gaurang correct the clone method.
+     * @return Object
+    public Object clone() {
+        return new TCEntry( namespace, name, version,
+            resourceid, physicalname,
+            type, profiles, sysinfo );
+     * gets the String version of the
+     * data class
+     * @return String
+    public String toString() {
+        String st = "\n " +
+            "\n Logical Namespace : " + this.namespace +
+            "\n Logical Name      : " + this.name +
+            "\n Version           : " + this.version +
+            "\n Resource Id       : " + this.resourceid +
+            "\n Physical Name     : " + this.physicalname +
+            "\n SysInfo           : " + ((this.sysinfo == null) ? "" : this.sysinfo.toString()) +
+            "\n TYPE              : " + ((this.type == null) ? "" : type.toString());
+        if(profiles != null){
+            for (Profile p : profiles)
+                st = st + "\n Profile           : " + p.toString();
+        return st;
+     * Prints out a TC file format String.
+     * @return String
+    public String toTCString() {
+        String st = this.getResourceId() + "\t" +
+            this.getLogicalTransformation() + "\t" +
+            this.getPhysicalTransformation() + "\t" +
+            this.getType() + "\t" +
+            this.getSysInfo() + "\t";
+        if ( profiles != null ) {
+            st += ProfileParser.combine( profiles );
+        } else {
+            st += "NULL";
+        return st;
+     * Returns an xml output of the contents of the data class.
+     * @return String
+    public String toXML() {
+        String xml = "\t\t<pfn physicalName=\"" +
+            this.getPhysicalTransformation() + "\""
+            + " siteid=\"" + this.getResourceId() + "\""
+            + " type=\"" + this.getType() + "\""
+            + " sysinfo=\"" + this.getSysInfo() + "\"";
+        if ( this.profiles != null ) {
+            xml += " >\n";
+                xml += "\t\t\t" + p.toXML() + "\n";
+            xml += "\t\t</pfn>\n";
+        } else {
+            xml += " />\n";
+        return xml;
+     * Set the logical transformation with a fully qualified tranformation String of the format NS::NAME:Ver
+     * @param logicaltransformation String
+    public void setLogicalTransformation( String logicaltransformation ) {
+        String[] ltr;
+        ltr = splitLFN( logicaltransformation );
+        this.namespace = ltr[ 0 ];
+        this.name = ltr[ 1 ];
+        this.version = ltr[ 2 ];
+     * Set the logical transformation by providing the namespace, name and version as seperate strings.
+    public void setLogicalTransformation( String namespace, String name,
+        String version ) {
+        this.name = name;
+     * Set the logical namespace of the transformation.
+    public void setLogicalNamespace( String namespace ) {
+     * Set the logical name of the transformation.
+    public void setLogicalName( String name ) {
+        this.name = name;
+     * Set the logical version of the transformation.
+    public void setLogicalVersion( String version ) {
+     *  Set the resourceid where the transformation is available.
+    public void setResourceId( String resourceid ) {
+     * Set the type of the transformation.
+    public void setType( TCType type ) {
+        this.type = ( type == null ) ? TCType.INSTALLED : type;
+     * Set the physical location of the transformation.
+    public void setPhysicalTransformation( String physicalname ) {
+     * Set the System Information associated with the transformation.
+    public void setSysInfo( SysInfo sysinfo ) {
+        this.sysinfo = ( sysinfo == null ) ? new SysInfo() : sysinfo;
+     * Allows you to add one profile at a time to the transformation.
+     * @param profile Profile  A single profile consisting of namespace, key and value
+    public void setProfile( Profile profile ) {
+        if ( profile != null ) {
+            if ( this.profiles == null ) {
+                this.profiles = new ArrayList<Profile>( 5 );
+            this.profiles.add( profile );
+     * Allows you to add multiple profiles to the transformation.
+     * @param profiles List of Profile objects containing the profile information.
+    public void setProfiles( List<Profile> profiles ) {
+                this.profiles =
+                    new ArrayList<Profile>( profiles.size() );
+            this.profiles.addAll( profiles );
+     * Gets the Fully Qualified Transformation name in the format NS::Name:Ver.
+     * @return String
+    public String getLogicalTransformation() {
+        return joinLFN( namespace, name, version );
+     * Returns the Namespace associated with the logical transformation.
+     * @return String Returns null if no namespace associated with the transformation.
+    public String getLogicalNamespace() {
+        return this.namespace;
+     * Returns the Name of the logical transformation.
+     * @return String
+    public String getLogicalName() {
+        return this.name;
+     * Returns the version of the logical transformation.
+     * @return String Returns null if no version assocaited with the transformation.
+    public String getLogicalVersion() {
+        return this.version;
+     * Returns the resource where the transformation is located.
+     * @return String
+    public String getResourceId() {
+        return this.resourceid;
+     * Returns the type of the transformation.
+     * @return TCType
+    public TCType getType() {
+        return this.type;
+     * Returns the physical location of the transformation.
+     * @return String
+    public String getPhysicalTransformation() {
+        return this.physicalname;
+     * Returns the system information associated with the transformation in the formation ARCH::OS:OSver:GlibVer
+     * @return SysInfo
+    public SysInfo getSysInfo() {
+        return this.sysinfo;
+     * Returns the list of profiles associated with the transformation.
+     * @return List Returns null if no profiles associated.
+    public List<Profile> getProfiles() {
+        return this.profiles;
+     * Returns the profiles for a particular Namespace.
+     * @param namespace String The namespace of the profile
+     * @return List   List of Profile objects. returns null if none are found.
+    @SuppressWarnings("hiding")
+    public List<Profile> getProfiles( String namespace ) {
+        List<Profile> results = null;
+            for ( Profile p : profiles ) {
+                if ( p.getProfileNamespace().equalsIgnoreCase( namespace ) ) {
+                    if ( results == null ) {
+                        results = new ArrayList<Profile>();
+                    results.add( p );
+            return results;
+        } else {
+            return results;
+     * Joins the 3 components into a fully qualified logical name of the format NS::NAME:VER
+     * @return String
+    private static String joinLFN( String namespace, String name,
+        return Separator.combine( namespace, name, version );
+     * Splits the full qualified logical transformation into its components.
+     * @return String[]
+    private static String[] splitLFN( String logicaltransformation ) {
+        return Separator.split( logicaltransformation );
+     * Converts the file profile string to a list of Profiles.
+     * @param profiles String The profile string.
+     * @return List Returns a list of profile objects
+    /* public List stringToProfiles( String profiles ) {
+         if ( profiles == null ) {
+             return null;
+         List resultprofiles = new ArrayList();
+         String[] namespaces = profiles.split( ";" );
+         for ( int i = 0; i < namespaces.length; i++ ) {
+             String[] nsprofiles = namespaces[ i ].split( "::", 2 );
+             if ( nsprofiles.length == 2 ) {
+                 String ns = nsprofiles[ 0 ].trim();
+                 String[] keyvalues = nsprofiles[ 1 ].trim().split( "," );
+                 for ( int j = 0; j < keyvalues.length; j++ ) {
+                     String[] keyvalue = keyvalues[ j ].trim().split( "=", 2 );
+                     String key = null;
+                     String value = null;
+                     if ( keyvalue.length == 2 ) {
+                         key = keyvalue[ 0 ].trim();
+                         value = keyvalue[ 1 ].trim();
+                     if ( key != null && !key.equals( "" ) && value != null ) {
+                         Profile p = new Profile( ns, key, value );
+                         resultprofiles.add( p );
+         return resultprofiles;
+     * Generates a file type profiles String.
+     * @param listprofiles List
+     * @return String
+    /*    public String profilesToString( List listprofiles ) {
+            String lprofiles = null;
+//        String temp = null;
+            if ( listprofiles != null ) {
+                lprofiles=ProfileParser.combine( listprofiles );
+                String currentns = "";
+                for ( Iterator i = listprofiles.iterator(); i.hasNext(); ) {
+                    Profile p = ( Profile ) i.next();
+     if ( !currentns.equalsIgnoreCase( p.getProfileNamespace() ) ) {
+                        currentns = p.getProfileNamespace();
+                        if ( lprofiles != null ) {
+     lprofiles = lprofiles + temp + ";" + currentns + "::";
+                            temp = null;
+                        } else {
+                            lprofiles = currentns + "::";
+                    if ( temp != null ) {
+                        temp = temp + "," + p.getProfileKey() + "=" +
+                            p.getProfileValue();
+                    } else {
+                        temp = p.getProfileKey() + "=" + p.getProfileValue();
+                lprofiles += temp;
+            return lprofiles;
+     * Compares two catalog entries for equality.
+     * @param entry is the entry to compare with
+     * @return true if the entries match, false otherwise
+    public boolean equals( TCEntry entry ) {
+        return this.toTCString().equalsIgnoreCase( entry.toTCString() );
