[Swift-commit] r3576 - trunk/tests/cdm
Fri Aug 27 16:44:47 CDT 2010
Author: wozniak
Date: 2010-08-27 16:44:47 -0500 (Fri, 27 Aug 2010)
New Revision: 3576
Added:
   trunk/tests/cdm/201-direct-output.check.sh
   trunk/tests/cdm/201-direct-output.clean.sh
   trunk/tests/cdm/201-direct-output.setup.sh
   trunk/tests/cdm/201-direct-output.swift
   trunk/tests/cdm/README.txt
   trunk/tests/cdm/fs.template.data
   trunk/tests/cdm/title.txt
Log:
Add test cdm/201-direct-output
Added: trunk/tests/cdm/201-direct-output.check.sh
--- trunk/tests/cdm/201-direct-output.check.sh	                        (rev 0)
+++ trunk/tests/cdm/201-direct-output.check.sh	2010-08-27 21:44:47 UTC (rev 3576)
@@ -0,0 +1,8 @@
+#!/bin/sh
+set -x
+grep $( uname -m ) 201-input.txt  || exit 1
+grep $( uname -m ) 201/output.txt || exit 1
+exit 0
Property changes on: trunk/tests/cdm/201-direct-output.check.sh
___________________________________________________________________
Added: trunk/tests/cdm/201-direct-output.clean.sh
--- trunk/tests/cdm/201-direct-output.clean.sh	                        (rev 0)
+++ trunk/tests/cdm/201-direct-output.clean.sh	2010-08-27 21:44:47 UTC (rev 3576)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 201-input.txt 201
+exit 0
Property changes on: trunk/tests/cdm/201-direct-output.clean.sh
Added: trunk/tests/cdm/201-direct-output.setup.sh
--- trunk/tests/cdm/201-direct-output.setup.sh	                        (rev 0)
+++ trunk/tests/cdm/201-direct-output.setup.sh	2010-08-27 21:44:47 UTC (rev 3576)
@@ -0,0 +1,10 @@
+#!/bin/sh
+set -x
+  uname -a
+  date
+} > 201-input.txt
+exit 0
Property changes on: trunk/tests/cdm/201-direct-output.setup.sh
Added: trunk/tests/cdm/201-direct-output.swift
--- trunk/tests/cdm/201-direct-output.swift	                        (rev 0)
+++ trunk/tests/cdm/201-direct-output.swift	2010-08-27 21:44:47 UTC (rev 3576)
@@ -0,0 +1,14 @@
+type file;
+app (file o) copy (file i)
+  cp @i @o;
+file f1<"201-input.txt">;
+// Will be transformed by CDM to 201/output.txt:
+file f2<"output.txt">;
+f2 = copy(f1);
Added: trunk/tests/cdm/README.txt
--- trunk/tests/cdm/README.txt	                        (rev 0)
+++ trunk/tests/cdm/README.txt	2010-08-27 21:44:47 UTC (rev 3576)
@@ -0,0 +1,5 @@
+000 series : noop tests
+200 series : DIRECT tests
+300 series : BROADCAST test
Added: trunk/tests/cdm/fs.template.data
--- trunk/tests/cdm/fs.template.data	                        (rev 0)
+++ trunk/tests/cdm/fs.template.data	2010-08-27 21:44:47 UTC (rev 3576)
@@ -0,0 +1 @@
+rule .*output.txt DIRECT _PWD_/201
Added: trunk/tests/cdm/title.txt
--- trunk/tests/cdm/title.txt	                        (rev 0)
+++ trunk/tests/cdm/title.txt	2010-08-27 21:44:47 UTC (rev 3576)
@@ -0,0 +1 @@
+CDM tests
