[Swift-commit] r3550 - in usertools/swift/swiftconfig: bin lib/perl
Mon Aug 16 20:51:45 CDT 2010
Author: davidk
Date: 2010-08-16 20:51:45 -0500 (Mon, 16 Aug 2010)
New Revision: 3550
Modified:
   usertools/swift/swiftconfig/bin/swiftrun
   usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm
Log:
Print run times and a few updates to application editing
Modified: usertools/swift/swiftconfig/bin/swiftrun
--- usertools/swift/swiftconfig/bin/swiftrun	2010-08-16 21:39:27 UTC (rev 3549)
+++ usertools/swift/swiftconfig/bin/swiftrun	2010-08-17 01:51:45 UTC (rev 3550)
@@ -160,7 +160,8 @@
 # Run swift
 chdir("$run_directory") || die "Unable to chdir to $run_directory\n";
-print "Submitting job. Check $run_directory for details\n";
+print "Executing script $option_script\n";
+print "Check $run_directory for output and debugging information\n";
 my $system_command =
       'swift '
     . "-sites.file $run_directory/sites.xml "
@@ -175,6 +176,13 @@
 # Execute
 system($system_command);
+my $sec = (time - $^T);
+my $hours = ($sec/(60*60))%24;
+my $mins = ($sec/60)%60;
+my $secs = $sec%60;
+my $datestring = sprintf("%dh:%dm:%ds", $hours, $mins, $secs);
+print "Script $option_script finished in $datestring\n";
 __END__
 =head1 NAME
Modified: usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm
--- usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm	2010-08-16 21:39:27 UTC (rev 3549)
+++ usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm	2010-08-17 01:51:45 UTC (rev 3550)
@@ -561,6 +561,7 @@
         my @apps_file_data = <APPLIST>;
         close(APPLIST);
         foreach my $current_app (@apps_file_data) {
+            chomp($current_app);
             if($apps) {
                 $apps = "$apps $current_app";
@@ -571,7 +572,7 @@
     my @all_available_appsets = glob("$ENV{'HOME'}/.swift/apps/*.apps");
-    print "Available application sets are: ";
+    print "Available application sets: ";
     foreach(@all_available_appsets) {
         $_ = strip_directory($_);
         ($_, my $junk) = split('\.');
@@ -579,10 +580,7 @@
     print "\n";
-    print "Application sets for $site: ";
-    $apps = <STDIN>;
-    chomp($apps);
+    $apps = get_entry("Select application sets for $site", $apps, 0);
     my @all_list = split(/ /, $apps);
     open(APPFILE, ">$ENV{'HOME'}/.swift/sites/$site/apps")
         || die "Unable to open $ENV{'HOME'}/.swift/sites/$site/apps for writing!\n";
@@ -648,6 +646,15 @@
    print "Enter name to call this application set: ";
    my $set_name = <STDIN>;
    chomp($set_name);
+   if(-e "$ENV{'HOME'}/.swift/apps/$set_name.apps") {
+       print "Set named $set_name already exists\n";
+       my $yesno = get_entry("Overwrite $set_name?", "No", 0, ("yes", "no"));
+       if($yesno eq "no") {
+           return;
    write_file("$ENV{'HOME'}/.swift/apps/$set_name.apps", @tc_data);
    print "Successfully imported application set named $set_name\n";
