[Swift-commit] r3536 - in usertools/swift/swiftconfig: bin lib/perl
Sun Aug 15 13:25:14 CDT 2010
Author: davidk
Date: 2010-08-15 13:25:13 -0500 (Sun, 15 Aug 2010)
New Revision: 3536
Added:
   usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm
Modified:
   usertools/swift/swiftconfig/bin/swiftconfig
   usertools/swift/swiftconfig/bin/swiftrun
Log:
Many updates to clarify code. Most shared functions now stored in SwiftConfig.pm module.
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig	2010-08-14 22:45:00 UTC (rev 3535)
+++ usertools/swift/swiftconfig/bin/swiftconfig	2010-08-15 18:25:13 UTC (rev 3536)
@@ -1,42 +1,18 @@
 #!/usr/bin/perl -w
 use strict;
-use Cwd;
-use Cwd qw(abs_path);
 use File::Copy;
 use File::Path;
 use Pod::Usage;
-my $swift_home = q{};
-if ( $ENV{'SWIFT_HOME'} && -e "$ENV{'SWIFT_HOME'}/bin/swift" ) {
-    $swift_home = $ENV{'SWIFT_HOME'};
-my @execution_path = split( '/', abs_path($0) );
- at execution_path = splice( @execution_path, 0, $#execution_path - 1 );
-my $parent_directory = join( '/', @execution_path );
-if ( !$swift_home ) {
-    if ( -e "$parent_directory/bin/swift" ) {
-        $swift_home = $parent_directory;
-    else {
-        @execution_path = split( '/', which("swift") );
-        @execution_path = splice( @execution_path, 0, $#execution_path - 1 );
-        my $tmp = join( '/', @execution_path );
-        if ( -e "$tmp/bin/swift" ) {
-            $swift_home = $tmp;
+use Cwd;
+use Cwd qw(abs_path);
 use FindBin qw($Bin);
-use lib "$FindBin::Bin/../lib/perl";   # Use libraries in $swift_home/lib/perl
+use lib "$FindBin::Bin/../lib/perl";   # Use libs in swiftconfig_home/lib/perl
+use SwiftConfig;
 use Getopt::Long;
-use File::Which qw(which where);
 use XML::Simple;
-use Data::Dumper;
+use File::Which qw(which where);
 # Variables used for sites.xml
 my $option_templates = q{};            # List all templates
@@ -55,7 +31,6 @@
 GetOptions(
     'remove=s'              => \$option_remove,
     'templates'             => \$option_templates,
-    'swift_home=s'          => \$swift_home,
     'sites'                 => \$option_sites,
     'describe=s'            => \$option_describe,
     'default|defaults'      => \$option_default,
@@ -63,77 +38,9 @@
     'template=s'            => \$option_template,
     'edit=s'                => \$option_edit,
     'copy=s'                => \$option_copy,
-    'help'                  => sub { pod2usage(-verbose => 2); },
+    'help|man'                  => sub { pod2usage(-verbose => 2); },
-# Create a new directory if it does not exist
-sub create_directory {
-    my $directory = $_[0];
-    if ( !-d "$directory" ) {
-        mkdir "$directory", 0700
-            or die "Unable to create directory $directory\n";
-# Process keyboard input
-sub get_entry {
-    my ( $entry_description, $entry_value, $use_default, @allowable_values, ) = @_;
-    # If use_default is specified, automatically plug in the default value
-    if($use_default) {
-        return $entry_value;
-   if(!@allowable_values) {
-        print "$entry_description [$entry_value]: ";
-    else {
-        print "$entry_description [";
-        my $counter=0;
-        foreach my $allowable(@allowable_values) {
-            if($counter != 0) {
-                print " ";
-            if($allowable eq $entry_value) {
-                print "*$allowable";
-            else {
-                print "$allowable";
-           $counter++;
-        print "]: ";
-    my $new_value = <STDIN>;
-    chomp($new_value);
-    if ($new_value) {
-        $entry_value = $new_value;
-    # Check if value entered is valid (if valid values were passed)
-    my $is_valid = 0;
-    if (@allowable_values) {
-        foreach my $allowable (@allowable_values) {
-            if ( $allowable eq $entry_value ) {
-                $is_valid = 1;
-        if ( !$is_valid ) {
-            my $error_message = q{};
-                $error_message = $error_message . $allowable . ' ';
-            print 'Invalid value selected. Please select from: '
-                . "$error_message\n";
-            $entry_value = get_entry( $entry_description, $entry_value,
-                @allowable_values, );
 # Prepare data
 my $xml = new XML::Simple();
@@ -144,279 +51,10 @@
 create_directory("$dotswift_directory/sites");
 # Determine the template directory
- at execution_path = split( '/', abs_path($0) );
+my @execution_path = split( '/', abs_path($0) );
 my $template_directory = join( '/', @execution_path ) . '/etc/sites';
-# Add new entry to auths.default
-sub add_ssh {
-    my ( $ssh_site, $ssh_url) = @_;
-    # Open authfile
-    my $auth_file = "$ENV{'HOME'}/.ssh/auth.defaults";
-    if( -e "$auth_file") {
-        open( AUTH_FILE, "<$auth_file")
-            || die "Unable to open $auth_file for reading\n";
-    else {
-        open( AUTH_FILE, "+>$auth_file" )
-            || die "Unable to open $auth_file for read/write!\n";
-    my @auth_data = <AUTH_FILE>;
-    close(AUTH_FILE);
-    # Get existing values and modify if found
-    my $ssh_username;
-    my $ssh_password;
-    my $found = 0;
-    foreach (@auth_data) {
-        if (/username/i && /^$ssh_url/i) {
-            ( my $setting, $ssh_username, ) = split( '=', $_ );
-            chomp($ssh_username);
-            $ssh_username = get_entry( 'Username',   $ssh_username, 0);
-            $_ = "$ssh_url.username=$ssh_username\n";
-            $found = 1;
-        if (/\.password/i && /^$ssh_url/i) {
-            ( my $setting, $ssh_password, ) = split( '=', $_ );
-            chomp($ssh_password);
-            $ssh_password = get_entry( 'Password', $ssh_password, 0);
-            $_ = "$ssh_url.password=$ssh_password\n";
-            $found = 1;
-    # Add new entry if needed
-    if(!$found) {
-        $ssh_username = getlogin();
-        $ssh_username = get_entry( 'Username',   $ssh_username, 0 );
-        $ssh_password = get_entry( 'Password', '', 0);
-        # Password based authentication
-        push( @auth_data, "$ssh_url.type=password\n" );
-        push( @auth_data, "$ssh_url.username=$ssh_username\n" );
-        push( @auth_data, "$ssh_url.password=$ssh_password\n" );
-    # Write data
-    write_file( $auth_file, @auth_data );
-# Remove an entry from auth.defaults
-sub remove_ssh {
-    my ( $ssh_url, ) = @_;
-    # Open auth.defaults
-    else {
-        return;
-    close(AUTH_FILE);
-    # Remove
-        if (/^$ssh_url/i) {
-            $_ = '';
-    # Write data
-# Update TC with correct hostname
-sub update_tc_hostname {
-    my ( $tc_filename, $tc_host ) = @_;
-    # Store TC data
-    open( TC_FILESTREAM, "$tc_filename" )
-        or die("Unable to open tc file $tc_filename!");
-    my @tc_data = <TC_FILESTREAM>;
-    close(TC_FILESTREAM);
-    foreach my $line (@tc_data) {
-        # Ignore comments
-        my $first_character = substr( $line, 0, 1 );
-        if ( $first_character eq '#' ) {
-            next;
-        # Replace old entry with new entry
-        my ($line_tc_host,   $line_tc_name,     $line_tc_path,
-            $line_tc_status, $line_tc_platform, $line_tc_profile,
-        ) = split( /\s+/, $line );
-        $line =
-              "$tc_host\t"
-            . "$line_tc_name\t"
-            . "$line_tc_path\t"
-            . "$line_tc_status\t"
-            . "$line_tc_platform\t"
-            . "$line_tc_profile\n";
-    write_file( $tc_filename, @tc_data );
-# Update XML hash with values from command line
-sub update_xml {
-    # Set up data
-    my ($xml_filename, $edit_mode) = @_;
-    # Values for edit mode
-    # 0 - Edit all
-    # 1 - All but name
-    # 2 - Customized.. to do
-    if ( !-e $xml_filename ) {
-        die "Unable to update xml file $xml_filename\n";
-    my $xml_ref = $xml->XMLin(
-        $xml_filename,
-        ForceArray => [qw(workdirectory profile)],
-        KeyAttr    => [],
-    # Handle
-    if($edit_mode == 0) {
-        $xml_ref->{handle} = get_entry( 'Site Entry Name', $xml_ref->{handle}, $option_default);
-    # Execution
-    my $initial_exprovider = $xml_ref->{execution}{provider};
-    $xml_ref->{execution}{provider} = get_entry(
-        'Execution Provider',
-        $xml_ref->{execution}{provider},
-        $option_default,
-        @execution_providers,
-    my $current_exprovider = $xml_ref->{execution}{provider};
-    # Handle changes in execution provider
-    if( $initial_exprovider ne $current_exprovider ) {
-        # Add SSH fields
-        if( $current_exprovider eq 'ssh' ) {
-            if( !$xml_ref->{execution}{url} ) {
-                $xml_ref->{execution}{url} = 'unknown';
-        # Add coaster fields
-        if( $current_exprovider eq 'coaster' ) {
-            if( !$xml_ref->{execution}{jobmanager} ) {
-                $xml_ref->{execution}{jobmanager} = 'unknown';
-            if( !$xml_ref->{execution}{url} ){
-    # Job manager
-    if ( $xml_ref->{execution}{jobmanager}) {
-                get_entry( 'Execution Job Manager',
-                $xml_ref->{execution}{jobmanager},
-                $option_default
-    # Execution URL
-    if ( $xml_ref->{execution}{url} ) {
-                get_entry( 'Execution URL',
-                            $xml_ref->{execution}{url},
-                            $option_default
-    # Grid FTP
-    if ( $xml_ref->{gridftp} ) {
-        $xml_ref->{gridftp}{url} =
-            get_entry( 'GridFTP URL', $xml_ref->{gridftp}{url}, $option_default);
-    # Work directory
-    if ( $xml_ref->{workdirectory} ) {
-        $xml_ref->{workdirectory}[0] =~ s/\$HOME/$ENV{'HOME'}/;
-        $xml_ref->{workdirectory} =
-            [ get_entry( 'Work Directory', $xml_ref->{workdirectory}[0], $option_default) ];
-    # Job manager
-    if ( $xml_ref->{jobmanager} ) {
-        if ( $xml_ref->{jobmanager}{universe} ) {
-            $xml_ref->{jobmanager}{universe} =
-                get_entry( 'Job Universe', $xml_ref->{jobmanager}{universe}, $option_default);
-        if ( $xml_ref->{jobmanager}{url} ) {
-            $xml_ref->{jobmanager}{url} =
-                get_entry( 'Job Manager URL', $xml_ref->{jobmanager}{url}, $option_default);
-        if ( $xml_ref->{jobmanager}{major} ) {
-            $xml_ref->{jobmanager}{major} =
-                get_entry( 'Job Major Number',
-                $xml_ref->{jobmanager}{major}, $option_default);
-        if ( $xml_ref->{jobmanager}{minor} ) {
-            $xml_ref->{jobmanager}{minor} =
-                get_entry( 'Job Minor Number',
-                $xml_ref->{jobmanager}{minor}, $option_default);
-    # Filesystem
-    if ( $xml_ref->{filesystem} ) {
-        if ( $xml_ref->{filesystem}{provider} ) {
-            $xml_ref->{filesystem}{provider} = get_entry(
-                'Filesystem Provider',
-                $xml_ref->{filesystem}{provider},
-                $option_default,
-        if ( $xml_ref->{filesystem}{url} ) {
-            $xml_ref->{filesystem}{url} =
-                get_entry( 'Filesystem URL', $xml_ref->{filesystem}{url}, $option_default);
-    # Profiles
-    foreach my $profile ( @{ $xml_ref->{profile} } ) {
-        $profile->{content} =
-            get_entry( $profile->{key}, $profile->{content}, $option_default);
-    return $xml_ref;
-# Write a file given variable and filename
-sub write_file {
-    my ( $filename, @data ) = @_;
-    open( TEMPFILESTREAM, ">$filename" )
-        or die("Unable to open $filename!\n");
-    print TEMPFILESTREAM @data;
-    close(TEMPFILESTREAM);
-# Print all files in a directory
-sub print_directory {
-    my ($directory) = @_;
-    chdir($directory)
-        || die "Unable to change directories to $directory\n";
-    my @files = <*>;
-    foreach my $file (@files) {
-        ( my $basename, my $ext ) = split( /\./, $file );
-        my @path = split( '/', $basename );
-        print "$basename\n";
 # Add configuration from a template
 if ($option_template) {
@@ -426,7 +64,7 @@
     if ( !-e "$sites_input_file" ) {
         die "Unable to find configuration for $sites_input_file\n";
-    my $xml_ref          = update_xml("$sites_input_file", 0);
+    my $xml_ref          = update_xml("$sites_input_file", 0, $option_default, @execution_providers);
     my $new_sitename     = $xml_ref->{handle};
     my $output_directory = "$dotswift_directory/sites/$new_sitename";
     if ( -d "$output_directory" ) {
@@ -437,8 +75,7 @@
     my @files_to_copy = <$from_directory/*>;
     create_directory("$output_directory");
     foreach my $file_to_copy (@files_to_copy) {
-        copy( $file_to_copy, "$output_directory" )
-            || die "Unable to copy to $file_to_copy to $output_directory\n";
+        copy_file($file_to_copy, $output_directory);
     my $xml_out_ref = $xml->XMLout(
         $xml_ref,
@@ -474,14 +111,13 @@
         die "Unable to find configuration named $option_remove\n";
-    my $xml_filename = "$dotswift_directory/sites/$option_remove/sites.xml";
-        $xml_filename,
-        KeyAttr    => [],
     # Remove SSH entry if needed
+    #my $xml_filename = "$dotswift_directory/sites/$option_remove/sites.xml";
+    #my $xml_ref = $xml->XMLin(
+    #    $xml_filename,
+    #    ForceArray => [qw(workdirectory profile)],
+    #    KeyAttr    => [],
     #if($xml_ref->{execution}{provider} eq "ssh") {
     #    remove_ssh($xml_ref->{execution}{url});
@@ -518,7 +154,7 @@
         KeyAttr    => [],
-    $xml_ref = update_xml("$sites_file", 1);
+    $xml_ref = update_xml("$sites_file", 1, $option_default, @execution_providers);
    # Save
@@ -551,8 +187,7 @@
     my @files_to_copy = <$input_directory/*>;
-            || die "Unable to copy $file_to_copy to $output_directory\n";
     # Rename and save
@@ -572,7 +207,10 @@
     # Edit sites
     my $initial_exurl = $xml_ref->{execution}{url};
-    $xml_ref = update_xml( "$output_directory/sites.xml", 1);
+    $xml_ref = update_xml( "$output_directory/sites.xml",
+                           1,
+                           $option_default,
+                           @execution_providers);
     my $new_exurl = $xml_ref->{execution}{url};
@@ -605,10 +243,9 @@
 =head1 OVERVIEW
-The swiftconfig program allows users to configure Swift. It allows for the
-adding, removing, and modification of remote sites by utilizing a set of
-standard templates. It also provides a way to quickly add, remove and modify
-translation catalog entries without having to manually edit files.
+The swiftconfig program allows users to configure Swift. It enables users to
+add configurations based on templates, copy configurations, remove configurations,
+and edit configurations.
 =head1 DESCRIPTION
Modified: usertools/swift/swiftconfig/bin/swiftrun
--- usertools/swift/swiftconfig/bin/swiftrun	2010-08-14 22:45:00 UTC (rev 3535)
+++ usertools/swift/swiftconfig/bin/swiftrun	2010-08-15 18:25:13 UTC (rev 3536)
@@ -11,70 +11,8 @@
 use XML::Simple;
 use Pod::Usage;
+use SwiftConfig;
-# Figure out the path to Swift
-    else {
-            || die "Unable to create directory $directory\n";
-# Append one file to another
-sub cat_file {
-    my ( $src, $dst ) = @_;
-    if ( -e $dst ) {
-        open( DSTFILE, ">>$dst" ) || die "Unable to open $dst for append\n";
-    else {
-        open( DSTFILE, ">$dst" )
-            or die "Unable to open $dst for writing\n";
-    open( SRCFILE, $src ) || die "Unable to open $src for reading\n";
-    foreach my $line (<SRCFILE>) {
-        print DSTFILE $line;
-# Copy a file to a new location
-sub copy_file {
-    if ( !-e $src ) { die "Unable to access $src\n"; }
-    if ( !-e $dst ) { die "Unable to access $dst\n"; }
-    copy( $src, $dst ) or die "Unable to copy $src to $dst\n";
-# Strip directory name out of script
-sub strip_directory {
-    my ($fullpath) = @_;
-    my @path = split( '/', $fullpath );
-    my $filename = $path[$#path];
-    return $filename;
 # Command line processing
 my @option_sites;     # Site name to execute upon
 my $option_script;    # Script name to run
@@ -84,10 +22,9 @@
     'site|sites=s{,}'   => \@option_sites,
     'script=s'          => \$option_script,
     'input|inputs=s{,}' => \@option_inputs,
 # Create run directory
 my $script_filename = strip_directory($option_script);
 my $dotswift_directory = "$ENV{'HOME'}/.swift";
Added: usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm
--- usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm	                        (rev 0)
+++ usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm	2010-08-15 18:25:13 UTC (rev 3536)
@@ -0,0 +1,467 @@
+package SwiftConfig;
+use 5.010001;
+use strict;
+use warnings;
+use File::Copy;
+use File::Path;
+use Pod::Usage;
+use FindBin qw($Bin);
+use lib "$FindBin::Bin/../lib/perl";   # Use libraries in $swift_home/lib/perl
+use SwiftConfig;
+use Getopt::Long;
+use XML::Simple;
+require Exporter;
+our @ISA = qw(Exporter);
+# Items to export into callers namespace by default. Note: do not export
+# names by default without a very good reason. Use EXPORT_OK instead.
+# Do not simply export all your public functions/methods/constants.
+# This allows declaration use SwiftConfig ':all';
+# If you do not need this, moving things directly into @EXPORT or @EXPORT_OK
+# will save memory.
+our %EXPORT_TAGS = ( 'all' => [ qw(
+our @EXPORT_OK = ( @{ $EXPORT_TAGS{'all'} } );
+our @EXPORT = qw(create_directory get_entry add_ssh remove_ssh
+update_tc_hostname update_xml write_file print_directory strip_directory
+copy_file cat_file
+our $VERSION = '0.01';
+# Prepare data
+my $xml = new XML::Simple();
+# Create a new directory if it does not exist
+sub create_directory {
+    my $directory = $_[0];
+    if ( !-d "$directory" ) {
+        mkdir "$directory", 0700
+            or die "Unable to create directory $directory\n";
+# Process keyboard input
+sub get_entry {
+    my ( $entry_description, $entry_value, $use_default, @allowable_values, ) = @_;
+    # If use_default is specified, automatically plug in the default value
+    if($use_default) {
+        return $entry_value;
+   if(!@allowable_values) {
+        print "$entry_description [$entry_value]: ";
+    else {
+        print "$entry_description [";
+        my $counter=0;
+        foreach my $allowable(@allowable_values) {
+            if($counter != 0) {
+                print " ";
+            if($allowable eq $entry_value) {
+                print "*$allowable";
+            else {
+                print "$allowable";
+           $counter++;
+        print "]: ";
+    my $new_value = <STDIN>;
+    chomp($new_value);
+    if ($new_value) {
+        $entry_value = $new_value;
+    # Check if value entered is valid (if valid values were passed)
+    my $is_valid = 0;
+    if (@allowable_values) {
+        foreach my $allowable (@allowable_values) {
+            if ( $allowable eq $entry_value ) {
+                $is_valid = 1;
+        if ( !$is_valid ) {
+            my $error_message = q{};
+                $error_message = $error_message . $allowable . ' ';
+            print 'Invalid value selected. Please select from: '
+                . "$error_message\n";
+            $entry_value = get_entry( $entry_description, $entry_value,
+                @allowable_values, );
+# Add new entry to auths.default
+sub add_ssh {
+    my ( $ssh_site, $ssh_url) = @_;
+    # Open authfile
+    my $auth_file = "$ENV{'HOME'}/.ssh/auth.defaults";
+    if( -e "$auth_file") {
+        open( AUTH_FILE, "<$auth_file")
+            || die "Unable to open $auth_file for reading\n";
+    else {
+        open( AUTH_FILE, "+>$auth_file" )
+            || die "Unable to open $auth_file for read/write!\n";
+    my @auth_data = <AUTH_FILE>;
+    close(AUTH_FILE);
+    # Get existing values and modify if found
+    my $ssh_username;
+    my $ssh_password;
+    my $found = 0;
+    foreach (@auth_data) {
+        if (/username/i && /^$ssh_url/i) {
+            ( my $setting, $ssh_username, ) = split( '=', $_ );
+            chomp($ssh_username);
+            $ssh_username = get_entry( 'Username',   $ssh_username, 0);
+            $_ = "$ssh_url.username=$ssh_username\n";
+            $found = 1;
+        if (/\.password/i && /^$ssh_url/i) {
+            ( my $setting, $ssh_password, ) = split( '=', $_ );
+            chomp($ssh_password);
+            $ssh_password = get_entry( 'Password', $ssh_password, 0);
+            $_ = "$ssh_url.password=$ssh_password\n";
+            $found = 1;
+    # Add new entry if needed
+    if(!$found) {
+        $ssh_username = getlogin();
+        $ssh_username = get_entry( 'Username',   $ssh_username, 0 );
+        $ssh_password = get_entry( 'Password', '', 0);
+        # Password based authentication
+        push( @auth_data, "$ssh_url.type=password\n" );
+        push( @auth_data, "$ssh_url.username=$ssh_username\n" );
+        push( @auth_data, "$ssh_url.password=$ssh_password\n" );
+    # Write data
+    write_file( $auth_file, @auth_data );
+# Remove an entry from auth.defaults
+sub remove_ssh {
+    my ( $ssh_url, ) = @_;
+    # Open auth.defaults
+    else {
+        return;
+    close(AUTH_FILE);
+    # Remove
+        if (/^$ssh_url/i) {
+            $_ = '';
+    # Write data
+# Update TC with correct hostname
+sub update_tc_hostname {
+    my ( $tc_filename, $tc_host ) = @_;
+    # Store TC data
+    open( TC_FILESTREAM, "$tc_filename" )
+        or die("Unable to open tc file $tc_filename!");
+    my @tc_data = <TC_FILESTREAM>;
+    close(TC_FILESTREAM);
+    foreach my $line (@tc_data) {
+        # Ignore comments
+        my $first_character = substr( $line, 0, 1 );
+        if ( $first_character eq '#' ) {
+            next;
+        # Replace old entry with new entry
+        my ($line_tc_host,   $line_tc_name,     $line_tc_path,
+            $line_tc_status, $line_tc_platform, $line_tc_profile,
+        ) = split( /\s+/, $line );
+        $line =
+              "$tc_host\t"
+            . "$line_tc_name\t"
+            . "$line_tc_path\t"
+            . "$line_tc_status\t"
+            . "$line_tc_platform\t"
+            . "$line_tc_profile\n";
+    write_file( $tc_filename, @tc_data );
+# Update XML hash with values from command line
+sub update_xml {
+    # Set up data
+    my ($xml_filename, $edit_mode, $option_default, @execution_providers) = @_;
+    # Values for edit mode
+    # 0 - Edit all
+    # 1 - All but name
+    # 2 - Customized.. to do
+    if ( !-e $xml_filename ) {
+        die "Unable to update xml file $xml_filename\n";
+    my $xml_ref = $xml->XMLin(
+        $xml_filename,
+        ForceArray => [qw(workdirectory profile)],
+        KeyAttr    => [],
+    # Handle
+    if($edit_mode == 0) {
+        $xml_ref->{handle} = get_entry( 'Site Entry Name', $xml_ref->{handle}, $option_default);
+    # Execution
+    my $initial_exprovider = $xml_ref->{execution}{provider};
+    $xml_ref->{execution}{provider} = get_entry(
+        'Execution Provider',
+        $xml_ref->{execution}{provider},
+        $option_default,
+        @execution_providers,
+    my $current_exprovider = $xml_ref->{execution}{provider};
+    # Handle changes in execution provider
+    if( $initial_exprovider ne $current_exprovider ) {
+        # Add SSH fields
+        if( $current_exprovider eq 'ssh' ) {
+            if( !$xml_ref->{execution}{url} ) {
+                $xml_ref->{execution}{url} = 'unknown';
+        # Add coaster fields
+        if( $current_exprovider eq 'coaster' ) {
+            if( !$xml_ref->{execution}{jobmanager} ) {
+                $xml_ref->{execution}{jobmanager} = 'unknown';
+            if( !$xml_ref->{execution}{url} ){
+    # Job manager
+    if ( $xml_ref->{execution}{jobmanager}) {
+                get_entry( 'Execution Job Manager',
+                $xml_ref->{execution}{jobmanager},
+                $option_default
+    # Execution URL
+    if ( $xml_ref->{execution}{url} ) {
+                get_entry( 'Execution URL',
+                            $xml_ref->{execution}{url},
+                            $option_default
+    # Grid FTP
+    if ( $xml_ref->{gridftp} ) {
+        $xml_ref->{gridftp}{url} =
+            get_entry( 'GridFTP URL', $xml_ref->{gridftp}{url}, $option_default);
+    # Work directory
+    if ( $xml_ref->{workdirectory} ) {
+        $xml_ref->{workdirectory}[0] =~ s/\$HOME/$ENV{'HOME'}/;
+        $xml_ref->{workdirectory} =
+            [ get_entry( 'Work Directory', $xml_ref->{workdirectory}[0], $option_default) ];
+    # Job manager
+    if ( $xml_ref->{jobmanager} ) {
+        if ( $xml_ref->{jobmanager}{universe} ) {
+            $xml_ref->{jobmanager}{universe} =
+                get_entry( 'Job Universe', $xml_ref->{jobmanager}{universe}, $option_default);
+        if ( $xml_ref->{jobmanager}{url} ) {
+            $xml_ref->{jobmanager}{url} =
+                get_entry( 'Job Manager URL', $xml_ref->{jobmanager}{url}, $option_default);
+        if ( $xml_ref->{jobmanager}{major} ) {
+            $xml_ref->{jobmanager}{major} =
+                get_entry( 'Job Major Number',
+                $xml_ref->{jobmanager}{major}, $option_default);
+        if ( $xml_ref->{jobmanager}{minor} ) {
+            $xml_ref->{jobmanager}{minor} =
+                get_entry( 'Job Minor Number',
+                $xml_ref->{jobmanager}{minor}, $option_default);
+    # Filesystem
+    if ( $xml_ref->{filesystem} ) {
+        if ( $xml_ref->{filesystem}{provider} ) {
+            $xml_ref->{filesystem}{provider} = get_entry(
+                'Filesystem Provider',
+                $xml_ref->{filesystem}{provider},
+                $option_default,
+        if ( $xml_ref->{filesystem}{url} ) {
+            $xml_ref->{filesystem}{url} =
+                get_entry( 'Filesystem URL', $xml_ref->{filesystem}{url}, $option_default);
+    # Profiles
+    foreach my $profile ( @{ $xml_ref->{profile} } ) {
+        $profile->{content} =
+            get_entry( $profile->{key}, $profile->{content}, $option_default);
+    return $xml_ref;
+# Write a file given variable and filename
+sub write_file {
+    my ( $filename, @data ) = @_;
+    open( TEMPFILESTREAM, ">$filename" )
+        or die("Unable to open $filename!\n");
+    print TEMPFILESTREAM @data;
+    close(TEMPFILESTREAM);
+# Print all files in a directory
+sub print_directory {
+    my ($directory) = @_;
+    chdir($directory)
+        || die "Unable to change directories to $directory\n";
+    my @files = <*>;
+    foreach my $file (@files) {
+        ( my $basename, my $ext ) = split( /\./, $file );
+        my @path = split( '/', $basename );
+        print "$basename\n";
+# Append one file to another
+sub cat_file {
+    my ( $src, $dst ) = @_;
+    if ( -e $dst ) {
+        open( DSTFILE, ">>$dst" ) || die "Unable to open $dst for append\n";
+    else {
+        open( DSTFILE, ">$dst" )
+            or die "Unable to open $dst for writing\n";
+    open( SRCFILE, $src ) || die "Unable to open $src for reading\n";
+    foreach my $line (<SRCFILE>) {
+        print DSTFILE $line;
+# Copy a file to a new location
+sub copy_file {
+    if ( !-e $src ) { die "Unable to access $src\n"; }
+    if ( !-e $dst ) { die "Unable to access $dst\n"; }
+    copy( $src, $dst ) or die "Unable to copy $src to $dst\n";
+# Strip directory name out of a string
+sub strip_directory {
+    my ($fullpath) = @_;
+    my @path = split( '/', $fullpath );
+    my $filename = $path[$#path];
+    return $filename;
+1;
+__END__
+=head1 SwiftConfig
+SwiftConfig - Perl module for swiftconfig and swiftrun applications
+=head1 SYNOPSIS
+  use SwiftConfig;
+=head1 DESCRIPTION
+The SwiftConfig module provides a set of standard routines needed to handle
+Swift Configuration.
+create_directory(directory_name)
+    Creates a directory, handles errors
+get_entry($entry_description, $entry_value, $use_default, @allowable_values)
+    get_entry is used to get input from the user
+    $entry_description is used to describe the data to the user
+    $entry_value is the default value. If the user hits enter, it will be used
+    $use_default, if true, will set input to $entry_value without prompting
+    @allowable_values is a list of all available options for that input
+add_ssh($ssh_site, $ssh_url)
+    Add an entry to ~/.ssh/auth.defaults
+    $ssh_site is the swift configuration name
+    $ssh_url is the network name/address to connect to
+remove_ssh($ssh_url)
+    Remove an entry from ~/.ssh/auth.defaults
+    $ssh_url is the network name/address to remove
+update_tc_hostname($filename, $tc_hostname)
+    Change the site name in a tc.data file
+    $filename is the filename of the tc.data
+    $tc_hostname is the value of the new hostname
+update_xml($xml_filename, $edit_mode, $option_default, @execution_providers)
+    Edit and update a sites.xml file
+    $xml_filename filename to edit
+    There are currently two edit modes: 0=edit everything, 1=everything but name
+    $option_default, if true, will automatically use defaults
+    @execution_providers is the list of all valid execution providers
+write_file($filename, @data)
+    Write to $filename with @data. Handle errors
+print_directory($directory)
+    List all files within a directory without paths
+cat_file($src, $dst)
+    Concatenate $src to $dst, handle errors
+copy_file($src, $dst)
+    Copy file $src to $dst, handle errors
+strip_directory($fullpath)
+    Given a string like "/foo/blah/file.txt", return "file.txt"
+=cut
