[Swift-commit] r3531 - usertools/swift/swiftconfig/bin
Fri Aug 13 13:46:32 CDT 2010
Author: davidk
Date: 2010-08-13 13:46:31 -0500 (Fri, 13 Aug 2010)
New Revision: 3531
Modified:
   usertools/swift/swiftconfig/bin/swiftrun
Log:
run.####
Modified: usertools/swift/swiftconfig/bin/swiftrun
--- usertools/swift/swiftconfig/bin/swiftrun	2010-08-13 15:43:27 UTC (rev 3530)
+++ usertools/swift/swiftconfig/bin/swiftrun	2010-08-13 18:46:31 UTC (rev 3531)
@@ -88,21 +88,19 @@
-# Verify user-created profile info exists
-my ( $seconds, $minutes, $hours, $days, $months, $years, @junk ) =
-    localtime(time);
-my $date_string = sprintf "%04s-%02s-%02s-%02s%02s%02s-%s", $years + 1900,
-    $months + 1, $days, $hours, $minutes, $seconds, getpgrp(0);
+# Create run directory
+my $script_filename = strip_directory($option_script);
 my $dotswift_directory = "$ENV{'HOME'}/.swift";
+my @run_directories = <run.????>;
+if(!@run_directories) {
+    $run_directories[0] = "run.0000";
+my ($run_number) = $run_directories[-1] =~ m{(\d+)};
+$run_number++;
+my $run_directory = getcwd() . "/" . sprintf "run.%04s", $run_number;
+create_directory($run_directory);
+copy_file( "$option_script", "$run_directory" );
-# Run job
-my $script_filename = strip_directory($option_script);
-create_directory("$dotswift_directory/jobs");
-create_directory("$dotswift_directory/jobs/$script_filename");
-create_directory("$dotswift_directory/jobs/$script_filename/$date_string");
-copy_file( "$option_script",
-    "$dotswift_directory/jobs/$script_filename/$date_string" );
 # Create configuration files for run
 foreach my $site (@option_sites) {
     # Handle 'all' to use all available configurations at once
@@ -117,10 +115,8 @@
             if ( !-e "$all_site/tc.data" ) {
                 die "Unable to find tc.data for $all_site\n";
-            cat_file( "$all_site/sites.xml",
-                "$dotswift_directory/jobs/$script_filename/$date_string/sites.xml" );
-            cat_file( "$all_site/tc.data",
-                "$dotswift_directory/jobs/$script_filename/$date_string/tc.data" );
+            cat_file( "$all_site/sites.xml", "$run_directory/sites.xml" );
+            cat_file( "$all_site/tc.data", "$run_directory/tc.data" );
@@ -136,15 +132,14 @@
             die "Unable to find tc.data for $site\n";
         cat_file( "$dotswift_directory/sites/$site/sites.xml",
+                  "$run_directory/sites.xml" );
         cat_file( "$dotswift_directory/sites/$site/tc.data",
+                  "$run_directory/tc.data" );
 # Link input data
 foreach my $input_file (@option_inputs) {
     # Check for relative path
     my $first_char = substr $input_file, 0, 1;
     if( $first_char ne '/') {
@@ -154,27 +149,27 @@
     if ( !-e $input_file ) {
         die "Unable to find requested input file: $input_file\n";
-    my $new_path = "$dotswift_directory/jobs/$script_filename/$date_string/"
-        . strip_directory($input_file);
+    my $new_path = "$run_directory/" . strip_directory($input_file);
     symlink $input_file, $new_path
         || die "Unable to create symlink to $new_path\n";
 # Complete XML tags
-my $site_filename =
-    "$dotswift_directory/jobs/$script_filename/$date_string/sites.xml";
-open( SITEFILE, "$site_filename" ) || die "Unable to open $site_filename\n";
+open( SITEFILE, "$run_directory/sites.xml" )
+    || die "Unable to open $run_directory/sites.xml\n";
 my @sitedata = <SITEFILE>;
 close(SITEFILE);
-open( SITEFILE, ">$site_filename" ) || die "Unable to open $site_filename\n";
+open( SITEFILE, ">$run_directory/sites.xml" )
+    || die "Unable to open $run_directory/sites.xml for writing\n";
 print SITEFILE "<config>\n at sitedata</config>\n";
 close(SITEFILE);
 # Run swift
-my $run_directory = "$dotswift_directory/jobs/$script_filename/$date_string";
 chdir("$run_directory") || die "Unable to chdir to $run_directory\n";
 print "Submitting job. Check $run_directory for details\n";
-my $system_command = "swift -sites.file $site_filename "
+my $system_command =
+      'swift '
+    . "-sites.file $run_directory/sites.xml "
     . "-tc.file $run_directory/tc.data "
     . "$option_script ";
