[Swift-commit] r3529 - usertools/swift/swiftconfig/bin
Fri Aug 13 00:12:44 CDT 2010
Author: davidk
Date: 2010-08-13 00:12:44 -0500 (Fri, 13 Aug 2010)
New Revision: 3529
Modified:
   usertools/swift/swiftconfig/bin/swiftconfig
Log:
-default and -full modes for adding in swiftconfig
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig	2010-08-13 04:13:38 UTC (rev 3528)
+++ usertools/swift/swiftconfig/bin/swiftconfig	2010-08-13 05:12:44 UTC (rev 3529)
@@ -52,18 +52,22 @@
 my $option_add       = q{};            # Add entry
 my $option_sites     = q{};            # List all usable sites
 my $option_describe  = q{};            # Print raw XML configuration
+my $option_default   = q{};            # When adding a site, use all defaults
 my @execution_providers =
     ( "gt4", "local", "pbs", "condor", "ssh", "coaster", );
 # Assign variables from command line options
 GetOptions(
-    'add=s'        => \$option_add,
-    'remove=s'     => \$option_remove,
-    'templates'    => \$option_templates,
-    'modify=s'     => \$option_modify,
-    'swift_home=s' => \$swift_home,
-    'sites'        => \$option_sites,
-    'describe=s'   => \$option_describe,
+    'add=s'                 => \$option_add,
+    'remove=s'              => \$option_remove,
+    'templates'             => \$option_templates,
+    'modify=s'              => \$option_modify,
+    'swift_home=s'          => \$swift_home,
+    'sites'                 => \$option_sites,
+    'describe=s'            => \$option_describe,
+    'default|defaults'      => \$option_default,
+    'full'                  => sub { $option_default = 0; },
 # Create a new directory if it does not exist
@@ -77,8 +81,12 @@
 # Process keyboard input
 sub get_entry {
-    my ( $entry_description, $entry_value, @allowable_values, ) = @_;
+    my ( $entry_description, $entry_value, $use_default, @allowable_values, ) = @_;
+    if($use_default) {
+        return $entry_value;
     print "$entry_description [$entry_value]: ";
     my $new_value = <STDIN>;
     chomp($new_value);
@@ -148,14 +156,14 @@
         if (/username/i && /^$ssh_url/i) {
             ( my $setting, $ssh_username, ) = split( '=', $_ );
             chomp($ssh_username);
-            $ssh_username = get_entry( 'Username',   $ssh_username );
+            $ssh_username = get_entry( 'Username',   $ssh_username, 0);
             $_ = "$ssh_url.username=$ssh_username\n";
             $found = 1;
         if (/\.password/i && /^$ssh_url/i) {
             ( my $setting, $ssh_password, ) = split( '=', $_ );
             chomp($ssh_password);
-            $ssh_password = get_entry( 'Password', $ssh_password );
+            $ssh_password = get_entry( 'Password', $ssh_password, 0);
             $_ = "$ssh_url.password=$ssh_password\n";
             $found = 1;
@@ -164,8 +172,8 @@
     # Add new entry if needed
     if(!$found) {
         $ssh_username = getlogin();
-        $ssh_password = get_entry( 'Password', '');
+        $ssh_username = get_entry( 'Username',   $ssh_username, 0 );
+        $ssh_password = get_entry( 'Password', '', 0);
         # Password based authentication
         push( @auth_data, "$ssh_url.type=password\n" );
@@ -254,40 +262,40 @@
     # Handle
-    $xml_ref->{handle} = get_entry( 'Site Entry Name', $xml_ref->{handle} );
+    $xml_ref->{handle} = get_entry( 'Site Entry Name', $xml_ref->{handle}, $option_default);
     # Grid FTP
     if ( $xml_ref->{gridftp} ) {
         $xml_ref->{gridftp}{url} =
-            get_entry( 'GridFTP URL', $xml_ref->{gridftp}{url} );
+            get_entry( 'GridFTP URL', $xml_ref->{gridftp}{url}, $option_default);
     # Work directory
     if ( $xml_ref->{workdirectory} ) {
         $xml_ref->{workdirectory}[0] =~ s/\$HOME/$ENV{'HOME'}/;
         $xml_ref->{workdirectory} =
-            [ get_entry( 'Work Directory', $xml_ref->{workdirectory}[0] ) ];
+            [ get_entry( 'Work Directory', $xml_ref->{workdirectory}[0], $option_default) ];
     # Job manager
     if ( $xml_ref->{jobmanager} ) {
         if ( $xml_ref->{jobmanager}{universe} ) {
             $xml_ref->{jobmanager}{universe} =
-                get_entry( 'Job Universe', $xml_ref->{jobmanager}{universe} );
+                get_entry( 'Job Universe', $xml_ref->{jobmanager}{universe}, $option_default);
         if ( $xml_ref->{jobmanager}{url} ) {
             $xml_ref->{jobmanager}{url} =
-                get_entry( 'Job Manager URL', $xml_ref->{jobmanager}{url} );
+                get_entry( 'Job Manager URL', $xml_ref->{jobmanager}{url}, $option_default);
         if ( $xml_ref->{jobmanager}{major} ) {
             $xml_ref->{jobmanager}{major} =
                 get_entry( 'Job Major Number',
-                $xml_ref->{jobmanager}{major} );
+                $xml_ref->{jobmanager}{major}, $option_default);
         if ( $xml_ref->{jobmanager}{minor} ) {
             $xml_ref->{jobmanager}{minor} =
                 get_entry( 'Job Minor Number',
-                $xml_ref->{jobmanager}{minor} );
+                $xml_ref->{jobmanager}{minor}, $option_default);
@@ -297,19 +305,20 @@
             $xml_ref->{execution}{provider} = get_entry(
                 'Execution Provider',
                 $xml_ref->{execution}{provider},
+                $option_default,
                 @execution_providers,
         if ( $xml_ref->{execution}{jobmanager} ) {
             $xml_ref->{execution}{jobmanager} =
                 get_entry( 'Execution Job Manager',
-                $xml_ref->{execution}{jobmanager} );
+                $xml_ref->{execution}{jobmanager},
+                $option_default);
         if ( $xml_ref->{execution}{url} ) {
             $xml_ref->{execution}{url} =
-                get_entry( 'Execution URL', $xml_ref->{execution}{url} );
+                get_entry( 'Execution URL', $xml_ref->{execution}{url}, $option_default);
     # Filesystem
@@ -318,19 +327,20 @@
             $xml_ref->{filesystem}{provider} = get_entry(
                 'Filesystem Provider',
                 $xml_ref->{filesystem}{provider},
+                $option_default,
         if ( $xml_ref->{filesystem}{url} ) {
             $xml_ref->{filesystem}{url} =
-                get_entry( 'Filesystem URL', $xml_ref->{filesystem}{url} );
+                get_entry( 'Filesystem URL', $xml_ref->{filesystem}{url}, $option_default);
     # Profiles
     foreach my $profile ( @{ $xml_ref->{profile} } ) {
         $profile->{content} =
-            get_entry( $profile->{key}, $profile->{content} );
+            get_entry( $profile->{key}, $profile->{content}, $option_default);
     return $xml_ref;
