[Swift-commit] r3176 - trunk/libexec
Sun Oct 25 15:51:37 CDT 2009
Author: hategan
Date: 2009-10-25 15:51:37 -0500 (Sun, 25 Oct 2009)
New Revision: 3176
Modified:
   trunk/libexec/_swiftwrap
   trunk/libexec/_swiftwrap.vbs
   trunk/libexec/vdl-int.k
Log:
scratch directory
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap	2009-10-25 20:50:06 UTC (rev 3175)
+++ trunk/libexec/_swiftwrap	2009-10-25 20:51:37 UTC (rev 3176)
@@ -144,11 +144,20 @@
 	shift $SHIFTCOUNT
 fi
+getarg "-scratch" "$@"
+SCRATCH=$VALUE
+shift $SHIFTCOUNT
+if [ "X$PROGRESSIVE_INFO" == "X" ]; then
+	INFODIR=$SCRATCH/info/$JOBDIR
+else
+	INFODIR=$WFDIR/info/$JOBDIR
+fi
 checkEmpty "$JOBDIR" "Missing job directory prefix"
-mkdir -p $WFDIR/info/$JOBDIR
+mkdir -p $INFODIR
 closeinfo
-rm -f "$WFDIR/info/$JOBDIR/${ID}-info"
-openinfo "$WFDIR/info/$JOBDIR/${ID}-info"
+rm -f "$INFODIR/${ID}-info"
+openinfo "$INFODIR/${ID}-info"
 logstate "LOG_START"
 infosection "Wrapper"
@@ -213,9 +222,9 @@
 	mkdir -p $WFDIR/status/$JOBDIR
 fi
-if [ "X$SWIFT_JOBDIR_PATH" != "X" ]; then
+if [ "$WFDIR" != "$SCRATCH" ]; then
   log "Job directory mode is: local copy"
-  DIR=${SWIFT_JOBDIR_PATH}/$JOBDIR/$ID
+  DIR=$SCRATCH/$JOBDIR/$ID
   COPYNOTLINK=1
 else
   log "Job directory mode is: link on shared filesystem"
@@ -293,8 +302,18 @@
 fi
 if [ "$KICKSTART" == "" ]; then
 	if [ "$STDIN" == "" ]; then
+		if [ "$SWIFT_GEN_SCRIPTS" != "" ]; then
+			echo "#!/bin/bash" > run.sh
+			echo "\"$EXEC\" \"${CMDARGS[@]}\" 1>\"$STDOUT\" 2>\"$STDERR\"" >> run.sh
+			chmod +x run.sh
+		fi
 		"$EXEC" "${CMDARGS[@]}" 1>"$STDOUT" 2>"$STDERR"
 	else
+			echo "\"$EXEC\" \"${CMDARGS[@]}\" 1>\"$STDOUT\" 2>\"$STDERR\" <\"$STDIN\"" >> run.sh
+			chmod +x run.sh
+		fi
 		"$EXEC" "${CMDARGS[@]}" 1>"$STDOUT" 2>"$STDERR" <"$STDIN"
 	fi
 	checkError $? "Exit code $?"
@@ -361,6 +380,10 @@
 closeinfo
-# ensure we exit with a 0 after a successful exection
+	mv "$INFODIR/${ID}-info" "$WFDIR/info/$JOBDIR/${ID}-info"
+fi
+# ensure we exit with a 0 after a successful execution
 exit 0
Modified: trunk/libexec/_swiftwrap.vbs
--- trunk/libexec/_swiftwrap.vbs	2009-10-25 20:50:06 UTC (rev 3175)
+++ trunk/libexec/_swiftwrap.vbs	2009-10-25 20:51:37 UTC (rev 3176)
@@ -159,6 +159,10 @@
+expectArg("scratch")
+SCRATCH = getArgVal(MandatoryArg, "job dir")
+'though we'll ignore SCRATCH here
 expectArg("e")
 EXEC = getArgVal(MandatoryArg, "executable")
Modified: trunk/libexec/vdl-int.k
--- trunk/libexec/vdl-int.k	2009-10-25 20:50:06 UTC (rev 3175)
+++ trunk/libexec/vdl-int.k	2009-10-25 20:51:37 UTC (rev 3176)
@@ -427,6 +427,10 @@
 				if(wrapperMode == "files"
 					sequential(
 						sys:file:write(wrapfile,
+							"-scratch", try(
+								vdl:siteprofile(rhost, "scratch")
+								vdl:siteprofile(rhost, "workdir")
 							"-e ",vdl:executable(tr, rhost), nl(),
 							"-out ",stdout,nl(),
 							"-err ",stderr,nl(),
@@ -486,6 +490,10 @@
 								dircat("shared", vdl:siteprofile(rhost, "swift:wrapperScript"), os=os),
 								jobid,
 								"-jobdir", jobdir,
+								"-scratch", try(
 								"-e", vdl:executable(tr, rhost),
 								"-out", stdout,
 								"-err", stderr,
