[Swift-commit] r3151 - in trunk: . .settings
Sun Oct 11 23:02:04 CDT 2009
Author: hategan
Date: 2009-10-11 23:02:04 -0500 (Sun, 11 Oct 2009)
New Revision: 3151
Added:
   trunk/.classpath
   trunk/.project
   trunk/.settings/
   trunk/.settings/org.eclipse.jdt.core.prefs
   trunk/.settings/org.eclipse.jdt.ui.prefs
Log:
eclipse files
Added: trunk/.classpath
--- trunk/.classpath	                        (rev 0)
+++ trunk/.classpath	2009-10-12 04:02:04 UTC (rev 3151)
@@ -0,0 +1,25 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<classpath>
+	<classpathentry excluding="**/.svn/" kind="src" path="src"/>
+	<classpathentry excluding="**/.svn/**" kind="src" path="libexec"/>
+	<classpathentry excluding="**/.svn/**" kind="src" path="resources"/>
+	<classpathentry excluding="**/.svn/**" kind="src" path="etc"/>
+	<classpathentry combineaccessrules="false" kind="src" path="/karajan"/>
+	<classpathentry combineaccessrules="false" kind="src" path="/abstraction"/>
+	<classpathentry combineaccessrules="false" kind="src" path="/jglobus"/>
+	<classpathentry kind="lib" path="lib/antlr-2.7.5.jar"/>
+	<classpathentry kind="lib" path="lib/jsr173_1.0_api.jar"/>
+	<classpathentry kind="lib" path="lib/resolver.jar"/>
+	<classpathentry kind="lib" path="lib/stringtemplate.jar" sourcepath="/home/mike/work/sources/stringtemplate-2.2/src"/>
+	<classpathentry kind="lib" path="lib/vdldefinitions.jar"/>
+	<classpathentry kind="lib" path="lib/xbean_xpath.jar"/>
+	<classpathentry kind="lib" path="lib/xbean.jar"/>
+	<classpathentry kind="lib" path="lib/jug-lgpl-2.0.0.jar"/>
+	<classpathentry combineaccessrules="false" kind="src" path="/util"/>
+	<classpathentry combineaccessrules="false" kind="src" path="/grapheditor"/>
+	<classpathentry combineaccessrules="false" kind="src" path="/abstraction-provider-coaster"/>
+	<classpathentry combineaccessrules="false" kind="src" path="/provider-wonky"/>
+	<classpathentry kind="lib" path="lib/jline-0.9.94.jar"/>
+	<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
+	<classpathentry kind="output" path=".build"/>
+</classpath>
Added: trunk/.project
--- trunk/.project	                        (rev 0)
+++ trunk/.project	2009-10-12 04:02:04 UTC (rev 3151)
@@ -0,0 +1,17 @@
+<projectDescription>
+	<name>swift</name>
+	<comment></comment>
+	<projects>
+	</projects>
+	<buildSpec>
+		<buildCommand>
+			<name>org.eclipse.jdt.core.javabuilder</name>
+			<arguments>
+			</arguments>
+		</buildCommand>
+	</buildSpec>
+	<natures>
+		<nature>org.eclipse.jdt.core.javanature</nature>
+	</natures>
+</projectDescription>
Added: trunk/.settings/org.eclipse.jdt.core.prefs
--- trunk/.settings/org.eclipse.jdt.core.prefs	                        (rev 0)
+++ trunk/.settings/org.eclipse.jdt.core.prefs	2009-10-12 04:02:04 UTC (rev 3151)
@@ -0,0 +1,276 @@
+#Thu Sep 03 17:04:31 CDT 2009
+eclipse.preferences.version=1
+org.eclipse.jdt.core.codeComplete.argumentPrefixes=
+org.eclipse.jdt.core.codeComplete.argumentSuffixes=
+org.eclipse.jdt.core.codeComplete.fieldPrefixes=
+org.eclipse.jdt.core.codeComplete.fieldSuffixes=
+org.eclipse.jdt.core.codeComplete.localPrefixes=
+org.eclipse.jdt.core.codeComplete.localSuffixes=
+org.eclipse.jdt.core.codeComplete.staticFieldPrefixes=
+org.eclipse.jdt.core.codeComplete.staticFieldSuffixes=
+org.eclipse.jdt.core.codeComplete.staticFinalFieldPrefixes=
+org.eclipse.jdt.core.codeComplete.staticFinalFieldSuffixes=
+org.eclipse.jdt.core.compiler.codegen.inlineJsrBytecode=enabled
+org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.5
+org.eclipse.jdt.core.compiler.codegen.unusedLocal=preserve
+org.eclipse.jdt.core.compiler.compliance=1.5
+org.eclipse.jdt.core.compiler.debug.lineNumber=generate
+org.eclipse.jdt.core.compiler.debug.localVariable=generate
+org.eclipse.jdt.core.compiler.debug.sourceFile=generate
+org.eclipse.jdt.core.compiler.problem.assertIdentifier=error
+org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
+org.eclipse.jdt.core.compiler.source=1.5
+org.eclipse.jdt.core.formatter.align_type_members_on_columns=false
+org.eclipse.jdt.core.formatter.alignment_for_arguments_in_allocation_expression=20
+org.eclipse.jdt.core.formatter.alignment_for_arguments_in_enum_constant=16
+org.eclipse.jdt.core.formatter.alignment_for_arguments_in_explicit_constructor_call=20
+org.eclipse.jdt.core.formatter.alignment_for_arguments_in_method_invocation=20
+org.eclipse.jdt.core.formatter.alignment_for_arguments_in_qualified_allocation_expression=20
+org.eclipse.jdt.core.formatter.alignment_for_assignment=0
+org.eclipse.jdt.core.formatter.alignment_for_binary_expression=16
+org.eclipse.jdt.core.formatter.alignment_for_compact_if=16
+org.eclipse.jdt.core.formatter.alignment_for_conditional_expression=80
+org.eclipse.jdt.core.formatter.alignment_for_enum_constants=0
+org.eclipse.jdt.core.formatter.alignment_for_expressions_in_array_initializer=16
+org.eclipse.jdt.core.formatter.alignment_for_multiple_fields=16
+org.eclipse.jdt.core.formatter.alignment_for_parameters_in_constructor_declaration=16
+org.eclipse.jdt.core.formatter.alignment_for_parameters_in_method_declaration=16
+org.eclipse.jdt.core.formatter.alignment_for_selector_in_method_invocation=20
+org.eclipse.jdt.core.formatter.alignment_for_superclass_in_type_declaration=16
+org.eclipse.jdt.core.formatter.alignment_for_superinterfaces_in_enum_declaration=16
+org.eclipse.jdt.core.formatter.alignment_for_superinterfaces_in_type_declaration=16
+org.eclipse.jdt.core.formatter.alignment_for_throws_clause_in_constructor_declaration=16
+org.eclipse.jdt.core.formatter.alignment_for_throws_clause_in_method_declaration=16
+org.eclipse.jdt.core.formatter.blank_lines_after_imports=1
+org.eclipse.jdt.core.formatter.blank_lines_after_package=1
+org.eclipse.jdt.core.formatter.blank_lines_before_field=0
+org.eclipse.jdt.core.formatter.blank_lines_before_first_class_body_declaration=0
+org.eclipse.jdt.core.formatter.blank_lines_before_imports=1
+org.eclipse.jdt.core.formatter.blank_lines_before_member_type=1
+org.eclipse.jdt.core.formatter.blank_lines_before_method=1
+org.eclipse.jdt.core.formatter.blank_lines_before_new_chunk=0
+org.eclipse.jdt.core.formatter.blank_lines_before_package=0
+org.eclipse.jdt.core.formatter.blank_lines_between_import_groups=1
+org.eclipse.jdt.core.formatter.blank_lines_between_type_declarations=1
+org.eclipse.jdt.core.formatter.brace_position_for_annotation_type_declaration=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_anonymous_type_declaration=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_array_initializer=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_block=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_block_in_case=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_constructor_declaration=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_enum_constant=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_enum_declaration=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_method_declaration=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_switch=end_of_line
+org.eclipse.jdt.core.formatter.brace_position_for_type_declaration=end_of_line
+org.eclipse.jdt.core.formatter.comment.clear_blank_lines_in_block_comment=false
+org.eclipse.jdt.core.formatter.comment.clear_blank_lines_in_javadoc_comment=false
+org.eclipse.jdt.core.formatter.comment.format_block_comments=true
+org.eclipse.jdt.core.formatter.comment.format_header=false
+org.eclipse.jdt.core.formatter.comment.format_html=true
+org.eclipse.jdt.core.formatter.comment.format_javadoc_comments=true
+org.eclipse.jdt.core.formatter.comment.format_line_comments=true
+org.eclipse.jdt.core.formatter.comment.format_source_code=true
+org.eclipse.jdt.core.formatter.comment.indent_parameter_description=true
+org.eclipse.jdt.core.formatter.comment.indent_root_tags=true
+org.eclipse.jdt.core.formatter.comment.insert_new_line_before_root_tags=insert
+org.eclipse.jdt.core.formatter.comment.insert_new_line_for_parameter=insert
+org.eclipse.jdt.core.formatter.comment.line_length=80
+org.eclipse.jdt.core.formatter.compact_else_if=true
+org.eclipse.jdt.core.formatter.continuation_indentation=2
+org.eclipse.jdt.core.formatter.continuation_indentation_for_array_initializer=2
+org.eclipse.jdt.core.formatter.format_guardian_clause_on_one_line=false
+org.eclipse.jdt.core.formatter.indent_body_declarations_compare_to_annotation_declaration_header=true
+org.eclipse.jdt.core.formatter.indent_body_declarations_compare_to_enum_constant_header=true
+org.eclipse.jdt.core.formatter.indent_body_declarations_compare_to_enum_declaration_header=true
+org.eclipse.jdt.core.formatter.indent_body_declarations_compare_to_type_header=true
+org.eclipse.jdt.core.formatter.indent_breaks_compare_to_cases=true
+org.eclipse.jdt.core.formatter.indent_empty_lines=false
+org.eclipse.jdt.core.formatter.indent_statements_compare_to_block=true
+org.eclipse.jdt.core.formatter.indent_statements_compare_to_body=true
+org.eclipse.jdt.core.formatter.indent_switchstatements_compare_to_cases=true
+org.eclipse.jdt.core.formatter.indent_switchstatements_compare_to_switch=true
+org.eclipse.jdt.core.formatter.indentation.size=4
+org.eclipse.jdt.core.formatter.insert_new_line_after_annotation=insert
+org.eclipse.jdt.core.formatter.insert_new_line_after_opening_brace_in_array_initializer=do not insert
+org.eclipse.jdt.core.formatter.insert_new_line_at_end_of_file_if_missing=do not insert
+org.eclipse.jdt.core.formatter.insert_new_line_before_catch_in_try_statement=insert
+org.eclipse.jdt.core.formatter.insert_new_line_before_closing_brace_in_array_initializer=do not insert
+org.eclipse.jdt.core.formatter.insert_new_line_before_else_in_if_statement=insert
+org.eclipse.jdt.core.formatter.insert_new_line_before_finally_in_try_statement=insert
+org.eclipse.jdt.core.formatter.insert_new_line_before_while_in_do_statement=do not insert
+org.eclipse.jdt.core.formatter.insert_new_line_in_empty_annotation_declaration=insert
+org.eclipse.jdt.core.formatter.insert_new_line_in_empty_anonymous_type_declaration=insert
+org.eclipse.jdt.core.formatter.insert_new_line_in_empty_block=insert
+org.eclipse.jdt.core.formatter.insert_new_line_in_empty_enum_constant=insert
+org.eclipse.jdt.core.formatter.insert_new_line_in_empty_enum_declaration=insert
+org.eclipse.jdt.core.formatter.insert_new_line_in_empty_method_body=insert
+org.eclipse.jdt.core.formatter.insert_new_line_in_empty_type_declaration=insert
+org.eclipse.jdt.core.formatter.insert_space_after_and_in_type_parameter=insert
+org.eclipse.jdt.core.formatter.insert_space_after_assignment_operator=insert
+org.eclipse.jdt.core.formatter.insert_space_after_at_in_annotation=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_at_in_annotation_type_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_binary_operator=insert
+org.eclipse.jdt.core.formatter.insert_space_after_closing_angle_bracket_in_type_arguments=insert
+org.eclipse.jdt.core.formatter.insert_space_after_closing_angle_bracket_in_type_parameters=insert
+org.eclipse.jdt.core.formatter.insert_space_after_closing_brace_in_block=insert
+org.eclipse.jdt.core.formatter.insert_space_after_closing_paren_in_cast=insert
+org.eclipse.jdt.core.formatter.insert_space_after_colon_in_assert=insert
+org.eclipse.jdt.core.formatter.insert_space_after_colon_in_case=insert
+org.eclipse.jdt.core.formatter.insert_space_after_colon_in_conditional=insert
+org.eclipse.jdt.core.formatter.insert_space_after_colon_in_for=insert
+org.eclipse.jdt.core.formatter.insert_space_after_colon_in_labeled_statement=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_allocation_expression=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_annotation=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_array_initializer=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_constructor_declaration_parameters=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_constructor_declaration_throws=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_enum_constant_arguments=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_enum_declarations=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_explicitconstructorcall_arguments=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_for_increments=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_for_inits=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_method_declaration_parameters=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_method_declaration_throws=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_method_invocation_arguments=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_multiple_field_declarations=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_multiple_local_declarations=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_parameterized_type_reference=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_superinterfaces=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_type_arguments=insert
+org.eclipse.jdt.core.formatter.insert_space_after_comma_in_type_parameters=insert
+org.eclipse.jdt.core.formatter.insert_space_after_ellipsis=insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_angle_bracket_in_parameterized_type_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_angle_bracket_in_type_arguments=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_angle_bracket_in_type_parameters=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_brace_in_array_initializer=insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_bracket_in_array_allocation_expression=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_bracket_in_array_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_annotation=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_cast=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_catch=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_constructor_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_enum_constant=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_for=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_if=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_method_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_method_invocation=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_parenthesized_expression=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_switch=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_synchronized=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_while=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_postfix_operator=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_prefix_operator=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_question_in_conditional=insert
+org.eclipse.jdt.core.formatter.insert_space_after_question_in_wildcard=do not insert
+org.eclipse.jdt.core.formatter.insert_space_after_semicolon_in_for=insert
+org.eclipse.jdt.core.formatter.insert_space_after_unary_operator=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_and_in_type_parameter=insert
+org.eclipse.jdt.core.formatter.insert_space_before_assignment_operator=insert
+org.eclipse.jdt.core.formatter.insert_space_before_at_in_annotation_type_declaration=insert
+org.eclipse.jdt.core.formatter.insert_space_before_binary_operator=insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_angle_bracket_in_parameterized_type_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_angle_bracket_in_type_arguments=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_angle_bracket_in_type_parameters=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_brace_in_array_initializer=insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_bracket_in_array_allocation_expression=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_bracket_in_array_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_annotation=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_cast=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_catch=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_constructor_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_enum_constant=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_for=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_if=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_method_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_method_invocation=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_parenthesized_expression=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_switch=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_synchronized=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_while=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_colon_in_assert=insert
+org.eclipse.jdt.core.formatter.insert_space_before_colon_in_case=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_colon_in_conditional=insert
+org.eclipse.jdt.core.formatter.insert_space_before_colon_in_default=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_colon_in_for=insert
+org.eclipse.jdt.core.formatter.insert_space_before_colon_in_labeled_statement=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_allocation_expression=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_annotation=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_array_initializer=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_constructor_declaration_parameters=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_constructor_declaration_throws=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_enum_constant_arguments=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_enum_declarations=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_explicitconstructorcall_arguments=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_for_increments=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_for_inits=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_method_declaration_parameters=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_method_declaration_throws=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_method_invocation_arguments=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_multiple_field_declarations=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_multiple_local_declarations=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_parameterized_type_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_superinterfaces=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_type_arguments=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_comma_in_type_parameters=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_ellipsis=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_angle_bracket_in_parameterized_type_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_angle_bracket_in_type_arguments=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_angle_bracket_in_type_parameters=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_annotation_type_declaration=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_anonymous_type_declaration=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_array_initializer=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_block=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_constructor_declaration=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_enum_constant=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_enum_declaration=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_method_declaration=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_switch=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_type_declaration=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_bracket_in_array_allocation_expression=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_bracket_in_array_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_bracket_in_array_type_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_annotation=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_annotation_type_member_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_catch=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_constructor_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_enum_constant=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_for=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_if=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_method_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_method_invocation=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_parenthesized_expression=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_switch=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_synchronized=insert
+org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_while=insert
+org.eclipse.jdt.core.formatter.insert_space_before_parenthesized_expression_in_return=insert
+org.eclipse.jdt.core.formatter.insert_space_before_parenthesized_expression_in_throw=insert
+org.eclipse.jdt.core.formatter.insert_space_before_postfix_operator=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_prefix_operator=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_question_in_conditional=insert
+org.eclipse.jdt.core.formatter.insert_space_before_question_in_wildcard=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_semicolon=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_semicolon_in_for=do not insert
+org.eclipse.jdt.core.formatter.insert_space_before_unary_operator=do not insert
+org.eclipse.jdt.core.formatter.insert_space_between_brackets_in_array_type_reference=do not insert
+org.eclipse.jdt.core.formatter.insert_space_between_empty_braces_in_array_initializer=do not insert
+org.eclipse.jdt.core.formatter.insert_space_between_empty_brackets_in_array_allocation_expression=do not insert
+org.eclipse.jdt.core.formatter.insert_space_between_empty_parens_in_annotation_type_member_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_between_empty_parens_in_constructor_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_between_empty_parens_in_enum_constant=do not insert
+org.eclipse.jdt.core.formatter.insert_space_between_empty_parens_in_method_declaration=do not insert
+org.eclipse.jdt.core.formatter.insert_space_between_empty_parens_in_method_invocation=do not insert
+org.eclipse.jdt.core.formatter.keep_else_statement_on_same_line=false
+org.eclipse.jdt.core.formatter.keep_empty_array_initializer_on_one_line=false
+org.eclipse.jdt.core.formatter.keep_imple_if_on_one_line=false
+org.eclipse.jdt.core.formatter.keep_then_statement_on_same_line=false
+org.eclipse.jdt.core.formatter.lineSplit=80
+org.eclipse.jdt.core.formatter.never_indent_block_comments_on_first_column=false
+org.eclipse.jdt.core.formatter.never_indent_line_comments_on_first_column=false
+org.eclipse.jdt.core.formatter.number_of_blank_lines_at_beginning_of_method_body=0
+org.eclipse.jdt.core.formatter.number_of_empty_lines_to_preserve=1
+org.eclipse.jdt.core.formatter.put_empty_statement_on_new_line=true
+org.eclipse.jdt.core.formatter.tabulation.char=space
+org.eclipse.jdt.core.formatter.tabulation.size=4
+org.eclipse.jdt.core.formatter.use_tabs_only_for_leading_indentations=false
+org.eclipse.jdt.core.formatter.wrap_before_binary_operator=true
Added: trunk/.settings/org.eclipse.jdt.ui.prefs
--- trunk/.settings/org.eclipse.jdt.ui.prefs	                        (rev 0)
+++ trunk/.settings/org.eclipse.jdt.ui.prefs	2009-10-12 04:02:04 UTC (rev 3151)
@@ -0,0 +1,58 @@
+#Sat Feb 07 18:44:35 CST 2009
+editor_save_participant_org.eclipse.jdt.ui.postsavelistener.cleanup=false
+formatter_profile=_spaces
+formatter_settings_version=11
+org.eclipse.jdt.ui.exception.name=e
+org.eclipse.jdt.ui.gettersetter.use.is=false
+org.eclipse.jdt.ui.javadoc=false
+org.eclipse.jdt.ui.keywordthis=false
+org.eclipse.jdt.ui.overrideannotation=true
+org.eclipse.jdt.ui.text.custom_code_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
+sp_cleanup.add_default_serial_version_id=true
+sp_cleanup.add_generated_serial_version_id=false
+sp_cleanup.add_missing_annotations=true
+sp_cleanup.add_missing_deprecated_annotations=true
+sp_cleanup.add_missing_nls_tags=false
+sp_cleanup.add_missing_override_annotations=true
+sp_cleanup.add_serial_version_id=false
+sp_cleanup.always_use_blocks=true
+sp_cleanup.always_use_parentheses_in_expressions=false
+sp_cleanup.always_use_this_for_non_static_field_access=false
+sp_cleanup.always_use_this_for_non_static_method_access=false
+sp_cleanup.convert_to_enhanced_for_loop=false
+sp_cleanup.format_source_code=false
+sp_cleanup.make_local_variable_final=false
+sp_cleanup.make_parameters_final=false
+sp_cleanup.make_private_fields_final=true
+sp_cleanup.make_variable_declarations_final=true
+sp_cleanup.never_use_blocks=false
+sp_cleanup.never_use_parentheses_in_expressions=true
+sp_cleanup.on_save_use_additional_actions=false
+sp_cleanup.organize_imports=true
+sp_cleanup.qualify_static_field_accesses_with_declaring_class=false
+sp_cleanup.qualify_static_member_accesses_through_instances_with_declaring_class=true
+sp_cleanup.qualify_static_member_accesses_through_subtypes_with_declaring_class=true
+sp_cleanup.qualify_static_member_accesses_with_declaring_class=false
+sp_cleanup.qualify_static_method_accesses_with_declaring_class=false
+sp_cleanup.remove_private_constructors=true
+sp_cleanup.remove_trailing_whitespaces=false
+sp_cleanup.remove_trailing_whitespaces_all=true
+sp_cleanup.remove_trailing_whitespaces_ignore_empty=false
+sp_cleanup.remove_unnecessary_casts=true
+sp_cleanup.remove_unnecessary_nls_tags=false
+sp_cleanup.remove_unused_imports=false
+sp_cleanup.remove_unused_local_variables=false
+sp_cleanup.remove_unused_private_fields=true
+sp_cleanup.remove_unused_private_members=false
+sp_cleanup.remove_unused_private_methods=true
+sp_cleanup.remove_unused_private_types=true
+sp_cleanup.sort_members=false
+sp_cleanup.sort_members_all=false
+sp_cleanup.use_blocks=false
+sp_cleanup.use_blocks_only_for_return_and_throw=false
+sp_cleanup.use_parentheses_in_expressions=false
+sp_cleanup.use_this_for_non_static_field_access=false
+sp_cleanup.use_this_for_non_static_field_access_only_if_necessary=true
+sp_cleanup.use_this_for_non_static_method_access=false
+sp_cleanup.use_this_for_non_static_method_access_only_if_necessary=true
