[Swift-commit] r3134 - trunk/src/org/griphyn/vdl/mapping
Sat Oct 10 20:54:15 CDT 2009
Author: hategan
Date: 2009-10-10 20:54:15 -0500 (Sat, 10 Oct 2009)
New Revision: 3134
Modified:
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
Log:
check for info being enabled before doing expensive string concatenations - for those who want to reduce data logging verbosity
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2009-10-11 01:50:20 UTC (rev 3133)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2009-10-11 01:54:15 UTC (rev 3134)
@@ -394,7 +394,9 @@
 		this.closed = true;
 		notifyListeners();
-		logger.info("closed " + this.getIdentifyingString());
+		if (logger.isInfoEnabled()) {
+			logger.info("closed " + this.getIdentifyingString());
 		// so because its closed, we can dump the contents
 		try {
@@ -425,11 +427,13 @@
 		String identifier = this.getIdentifier();
 		Path pathFromRoot = this.getPathFromRoot();
 		if (this.getPathFromRoot() != null) {
-			logger.info("ROOTPATH dataset=" + identifier + " path="
-					+ pathFromRoot);
-			if (this.getType().isPrimitive()) {
-				logger.info("VALUE dataset=" + identifier + " VALUE="
-						+ this.toString());
+				logger.info("ROOTPATH dataset=" + identifier + " path="
+						+ pathFromRoot);
+				if (this.getType().isPrimitive()) {
+					logger.info("VALUE dataset=" + identifier + " VALUE="
+							+ this.toString());
 			Mapper m;
@@ -468,12 +472,16 @@
 				try {
 					if(filemapped) {
 						Object path = m.map(pathFromRoot);
-						logger.info("FILENAME dataset=" + identifier + " filename="
-							+ path);
+							logger.info("FILENAME dataset=" + identifier + " filename="
+								+ path);
 				catch (Exception e) {
-					logger.info("NOFILENAME dataset=" + identifier);
+						logger.info("NOFILENAME dataset=" + identifier);
@@ -483,8 +491,10 @@
 			while (i.hasNext()) {
 				Map.Entry e = (Map.Entry) i.next();
 				AbstractDataNode node = (AbstractDataNode) e.getValue();
-				logger.info("CONTAINMENT parent=" + identifier + " child="
-						+ node.getIdentifier());
+					logger.info("CONTAINMENT parent=" + identifier + " child="
+							+ node.getIdentifier());
 				node.logContent();
