[Swift-commit] r3130 - trunk/src/org/griphyn/common/util
Sat Oct 10 20:47:00 CDT 2009
Author: hategan
Date: 2009-10-10 20:47:00 -0500 (Sat, 10 Oct 2009)
New Revision: 3130
Removed:
   trunk/src/org/griphyn/common/util/Currently.java
Log:
not used
Deleted: trunk/src/org/griphyn/common/util/Currently.java
--- trunk/src/org/griphyn/common/util/Currently.java	2009-10-11 01:46:26 UTC (rev 3129)
+++ trunk/src/org/griphyn/common/util/Currently.java	2009-10-11 01:47:00 UTC (rev 3130)
@@ -1,313 +0,0 @@
- * This file or a portion of this file is licensed under the terms of
- * the Globus Toolkit Public License, found in file GTPL, or at
- * http://www.globus.org/toolkit/download/license.html. This notice must
- * appear in redistributions of this file, with or without modification.
- * Redistributions of this Software, with or without modification, must
- * reproduce the GTPL in: (1) the Software, or (2) the Documentation or
- * some other similar material which is provided with the Software (if
- * any).
- * Copyright 1999-2004 University of Chicago and The University of
- * Southern California. All rights reserved.
-package org.griphyn.common.util;
-import java.util.*;
-import java.util.regex.*;
-import java.text.*;
- * Create a common interface to handle obtaining string timestamps.
- * The difficult part is to allow for an ISO 8601 date formatting.
- * @author Jens-S. Vöckler
- * @author Yong Zhao
- * @version $Revision: 1.4 $
- * @see java.util.Date
- * @see java.text.SimpleDateFormat
-public class Currently {
-   * This is used to format the time stamp.
-  private SimpleDateFormat m_formatter = null;
-   * Default time format, which is compact and has a timezone
-  public static final String DEFAULT_FORMAT = "yyyy.MM.dd HH:mm:ss zzz";
-   * Default ctor: Create a new instance with a default formatting
-   * string for timestamps.
-  public Currently()
-    m_formatter = new SimpleDateFormat(DEFAULT_FORMAT);
-   * Ctor: Create a new instance with a formatting string for time stamps.
-   * @param formatString complies to {@link java.text.SimpleDateFormat}.
-  public Currently( String formatString )
-    m_formatter = new SimpleDateFormat(formatString);
-   * @param format is a description of the simple date format to use.
-  public Currently( SimpleDateFormat format )
-    m_formatter = (SimpleDateFormat) format.clone();
-   * Accessor: Obtains the default timestamp format for all queues.
-   * @return the currently active timestamp prefix format.
-   * @see #setDateFormat( String )
-   * @see #setDateFormat( SimpleDateFormat )
-  public SimpleDateFormat getDateFormat()
-    return m_formatter;
-   * Accessor: Sets the default timestamp format for all queues.
-   * @param format is the new timestamp prefix format.
-   * @see #getDateFormat()
-  public void setDateFormat( SimpleDateFormat format )
-    if ( format != null )
-      m_formatter = format;
-   * @param format is the new timestamp prefix format as a string.
-  public void setDateFormat( String format )
-      m_formatter = new SimpleDateFormat(format);
-   * Obtains the current time as formatted string according to
-   * the format option.
-   * @return the current time as formatted string.
-   * @see #now( Date )
-  public String now()
-    return this.now( new Date() );
-   * @param then is a timestamp expressed as Date.
-   * @see #now()
-  public String now( Date then )
-    return this.m_formatter.format( then );
-   * Store the regular expressions necessary to parse ISO timestamps.
-  private static final String c_expression[] = {
-    "([12][0-9]{3})-([01][0-9])-([0123][0-9])(T([012][0-9]):([0-6][0-9]):([0-6][0-9])?(\\.[0-9]+)?)?(Z|[-+][01][0-9]:?[0-6][0-9])?",
-    "([12][0-9]{3})([01][0-9])([0123][0-9])(T?([012][0-9])([0-6][0-9])([0-6][0-9])?(\\.[0-9]+)?)?(Z|[-+][01][0-9]:?[0-6][0-9])?"
-   * Stores compiled patterns at first use, quasi-Singleton.
-  private static Pattern c_pattern[] = null;
-   * Parses one of the ISO 8601 that it produces. Note, it will not
-   * parse the full range of ISO timestamps.
-   * @param stamp is the textual timestamp representation.
-   * @return a time or <code>null</code>, if unparsable.
-  public static Date parse( String stamp )
-    // initialize the compiled expressions once
-    if ( c_pattern == null ) {
-      c_pattern = new Pattern[ c_expression.length ];
-      for ( int i=0; i<c_expression.length; ++i )
-	c_pattern[i] = Pattern.compile( c_expression[i] );
-    // match against pattern
-    for ( int i=0; i<c_expression.length; ++i ) {
-      Matcher m = c_pattern[i].matcher(stamp);
-      if ( m.matches() ) {
-	Calendar c = Calendar.getInstance();
-	c.set( Calendar.YEAR, Integer.parseInt(m.group(1)) );
-	c.set( Calendar.MONTH, Integer.parseInt(m.group(2)) );
-	c.set( Calendar.DAY_OF_MONTH, Integer.parseInt(m.group(3)) );
-	if ( m.group(4).length() > 0 ) {
-	  c.set( Calendar.HOUR, Integer.parseInt(m.group(5)) );
-	  c.set( Calendar.MINUTE, Integer.parseInt(m.group(6)) );
-	  if ( m.group(7) != null && m.group(7).length() > 0 )
-	    c.set( Calendar.SECOND, Integer.parseInt(m.group(7)) );
-	  if ( m.group(8) != null && m.group(8).length() > 1 ) {
-	    String millis = m.group(8).substring(1);
-	    while ( millis.length() < 3 ) millis += "0";
-	    millis = millis.substring(0,3);
-	    c.set( Calendar.MILLISECOND, Integer.parseInt(millis) );
-	TimeZone z = TimeZone.getDefault();
-	if ( m.group(9) != null && m.group(9).length() > 0 ) {
-	  boolean utc = ( Character.toUpperCase( m.group(9).charAt(0) ) == 'Z' );
-	  if ( ! utc ) z = TimeZone.getTimeZone( "GMT+0" );
-	  else z = TimeZone.getTimeZone( "GMT" + m.group(9) );
-	c.setTimeZone(z);
-	return c.getTime();
-    // not found
-    return null;
-   * Ignores any internal date format, and tries to show a complete
-   * date/timp stamp of the current time in extended ISO 8601 format.
-   * UTC time (Zulu time) or a local timezone will be used. A sample for
-   * UTC output is 2002-04-23T02:49:58Z   A sample for local zone
-   * (CDT) is 2002-04-22T21:49:58-05:00
-   * @param zuluTime returns a UTC formatted stamp, if true. Otherwise
-   * the time will be formatted according to the local zone.
-   * @return an ISO 8601 formatted date and time representation for the
-   * current time in extended format without millisecond resolution
-   * @see #iso8601( boolean, boolean, boolean, Date )
-  public static String iso8601( boolean zuluTime )
-    return Currently.iso8601( zuluTime, true, false, new Date() );
-   * date/timp stamp in extended ISO 8601 format. UTC time (Zulu time)
-   * or a local timezone will be used.<p>
-   * <table border=1>
-   * <tr><th>zone</th><th>format</th><th>fraction</td><th>example</th></tr>
-   * <tr><td>local</td><td>basic</td><td>integral</td><td>20020523T140427-0500</td></tr>
-   * <tr><td>UTC</td><td>basic</td><td>integral</td><td>20020523190427Z</td></tr>
-   * <tr><td>local</td><td>extd.</td><td>integral</td><td>2002-05-23T14:04:27-05:00</td></tr>
-   * <tr><td>UTC</td><td>extd.</td><td>integral</td><td>2002-05-23T19:04:27Z</td></tr>
-   * <tr><td>local</td><td>basic</td><td>millis</td><td>20020523T140427.166-0500</td></tr>
-   * <tr><td>UTC</td><td>basic</td><td>millis</td><td>20020523190427.166Z</td></tr>
-   * <tr><td>local</td><td>extd.</td><td>millis</td><td>2002-05-23T14:04:27.166-05:00</td></tr>
-   * <tr><td>UTC</td><td>extd.</td><td>millis</td><td>2002-05-23T19:04:27.166Z</td></tr>
-   * </table><p>
-   * the time will be formatted according to the local zone. Local time
-   * should be prefixed with the 'T'.
-   * @param extendedFormat will use the extended ISO 8601 format which
-   * separates the different timestamp items. If false, the basic
-   * format will be used. In UTC and basic format, the 'T' separator
-   * will be omitted.
-   * @param withMillis will put the millisecond extension into the timestamp.
-   * If false, the time will be without millisecond fraction. The separator
-   * is taken from {@link java.text.DecimalFormatSymbols#getMinusSign()},
-   * which usually is a period or a comma.
-   * @param now is a time stamp as Date.
-   * the given point in time.
-  public static String iso8601( boolean zuluTime, boolean extendedFormat,
-				boolean withMillis, Date now )
-    Calendar c =
-      Calendar.getInstance( zuluTime ?
-			    TimeZone.getTimeZone("UTC") :
-			    TimeZone.getDefault() );
-    c.setTime( now );
-    // set up formattting options
-    DecimalFormat nf2 = new DecimalFormat("##00");
-    DecimalFormat nf3 = new DecimalFormat("###000");
-    DecimalFormat nf4 = new DecimalFormat("####0000");
-    DecimalFormatSymbols dfs = nf2.getDecimalFormatSymbols();
-    // allocate result string buffer
-    int size = extendedFormat ? (zuluTime ? 25 : 30) : (zuluTime ? 21 : 25);
-    if ( ! withMillis ) size -= 4;
-    StringBuffer result = new StringBuffer(size);
-    result.append( nf4.format(c.get(Calendar.YEAR)) );
-    if ( extendedFormat ) result.append('-'); // position 5
-    result.append( nf2.format(c.get(Calendar.MONTH)+1) );
-    if ( extendedFormat ) result.append('-'); // position 8
-    result.append( nf2.format(c.get(Calendar.DAY_OF_MONTH)) );
-    // generating UTC in basic format may leave out the 'T' separator
-    if ( extendedFormat || ! zuluTime ) result.append('T'); // position 11
-    result.append( nf2.format(c.get(Calendar.HOUR_OF_DAY)) );
-    if ( extendedFormat ) result.append(':'); // position 14
-    result.append( nf2.format(c.get(Calendar.MINUTE)) );
-    if ( extendedFormat ) result.append(':'); // position 17
-    result.append( nf2.format(c.get(Calendar.SECOND)) );
-    if ( withMillis ) {
-      // Though there is no explicit spec which allows a complete
-      // timestamp with milliseconds, it is implied through two
-      // levels, sigh. 5.3.4.2 allows decimal fractions with
-      // time-only stamps that have a timezone. The intro of 5.4.2
-      // allows 5.3.1.3.
-      result.append( dfs.getDecimalSeparator() ); // position 20
-      result.append( nf3.format(c.get(Calendar.MILLISECOND)) );
-    if ( zuluTime ) {
-      // this is easy
-      result.append('Z');
-    } else {
-      // time zone calculations
-      int zone_offset = c.get(Calendar.ZONE_OFFSET)/1000;
-      int save_offset = c.get(Calendar.DST_OFFSET)/1000;
-      int diff = (zone_offset + save_offset) / 60;
-      result.append( diff < 0 ? dfs.getMinusSign() : '+' ); // position 24
-      if ( diff < 0 ) diff = Math.abs(diff);
-      result.append( nf2.format( diff / 60 ) );
-      if ( extendedFormat ) result.append( ':' );
-      result.append( nf2.format( diff % 60 ) );
-    return result.toString();
