[Swift-commit] r2943 - trunk/docs
Sun May 24 15:48:12 CDT 2009
Author: hategan
Date: 2009-05-24 15:48:12 -0500 (Sun, 24 May 2009)
New Revision: 2943
Modified:
   trunk/docs/userguide.xml
Log:
updated userguide
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-05-24 20:39:48 UTC (rev 2942)
+++ trunk/docs/userguide.xml	2009-05-24 20:48:12 UTC (rev 2943)
@@ -3242,6 +3242,10 @@
 			<para id="profile.maxtime">
 Indicates the maximum walltime that a coaster block can have. Default: unlimited.
 			</para>
+			<para id="profile.remoteMonitorEnabled">
+If set to "true", the client side will get a Swing window showing, graphically, the state of the
+coaster scheduler (blocks, jobs, etc.). Default: false
+			</para>
 			Reminds me this functionality should be added to the new coaster stuff
 			<para id="profile.globus.coasterInternalIP"><literal>coasterInternalIP</literal>
