[Swift-commit] r2940 - in trunk: . docs etc libexec src/org/griphyn/vdl/util tests/misc tests/sites
Sun May 17 07:03:40 CDT 2009
Author: benc
Date: 2009-05-17 07:03:39 -0500 (Sun, 17 May 2009)
New Revision: 2940
Added:
   trunk/tests/misc/arg-mode.sh
   trunk/tests/sites/local-wrapper-args-file.xml
Modified:
   trunk/CHANGES.txt
   trunk/docs/userguide.xml
   trunk/etc/swift.properties
   trunk/libexec/_swiftwrap
   trunk/libexec/vdl-int.k
   trunk/src/org/griphyn/vdl/util/VDL2Config.java
   trunk/tests/misc/run
Log:
Allow wrapper parameters to be specific in a file rather than on the
commandline. This trades commandline length for an extra file to stage-in
per job.
A new parameter, wrapper.parameter.mode, is introduced to control this.
Modified: trunk/CHANGES.txt
--- trunk/CHANGES.txt	2009-05-17 12:00:03 UTC (rev 2939)
+++ trunk/CHANGES.txt	2009-05-17 12:03:39 UTC (rev 2940)
@@ -1,3 +1,10 @@
+(05/17/09)
+*** Allow wrapper parameters to be specific in a file rather than on the
+    commandline. This trades commandline length for an extra file to stage-in
+    per job.
+    A new parameter, wrapper.parameter.mode, is introduced to control this.
+    This was feature request bug 201.
 (05/07/09)
 *** swift-log-to-cedps is removed. The functionality of generating
     .cedps format files is available by specifying the desired .cedps files
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-05-17 12:00:03 UTC (rev 2939)
+++ trunk/docs/userguide.xml	2009-05-17 12:03:39 UTC (rev 2940)
@@ -3039,6 +3039,25 @@
 					<varlistentry>
 						<term>
+							<property>wrapper.parameter.mode</property>
+						</term>
+						<listitem>
+							<para>
+Controls how Swift will supply parameters to the remote wrapper script.
+<literal>args</literal> mode will pass parameters on the command line. Some
+execution systems do not pass commandline parameters sufficiently cleanly
+for Swift to operate correctly.
+<literal>files</literal> mode will pass parameters through an additional
+input file (since Swift 0.95). This provides a cleaner communication channel
+for parameters, at the expense of transferring an additional file for each
+job invocation.
+							</para>
+						</listitem>
+					</varlistentry>
+					<varlistentry>
+						<term>
 							<property>wrapperlog.always.transfer</property>
 						</term>
 						<listitem>
Modified: trunk/etc/swift.properties
--- trunk/etc/swift.properties	2009-05-17 12:00:03 UTC (rev 2939)
+++ trunk/etc/swift.properties	2009-05-17 12:03:39 UTC (rev 2940)
@@ -295,6 +295,14 @@
 # status.mode=files
+# Controls how swift will supply parameters to the remote wrapper script.
+# 'args' mode will pass parameters on the command line
+# 'files' mode will pass parameters through an additional input file
+# valid values: args, files
+# Default: files
+# wrapper.parameter.mode=args
 # Determines if Swift remote wrappers will be executed by specifying an
 # absolute path, or a path relative to the job initial working directory
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap	2009-05-17 12:00:03 UTC (rev 2939)
+++ trunk/libexec/_swiftwrap	2009-05-17 12:03:39 UTC (rev 2940)
@@ -74,12 +74,21 @@
 	fi
+checkparamfile() {
+	log "checking for paramfile"
+	if [ "$1" == "-p" ]; then
+		JOBDIR=$2
+		PARAMFILE=${WFDIR}/parameters/${JOBDIR}/param-${ID}
+	fi
+	log "paramfile is: $PARAMFILE"
 getarg() {
 	NAME=$1
 	shift
 	VALUE=""
 	SHIFTCOUNT=0
-	if [ "$1" == "$NAME" ]; then
+	if [ "$PARAMFILE" == "" ] && [ "$1" == "$NAME" ]; then
 		shift
 		let "SHIFTCOUNT=$SHIFTCOUNT+1"
 		while [ "${1:0:1}" != "-" ] && [ "$#" != "0" ]; do
@@ -87,10 +96,12 @@
 			shift
 		done
+		VALUE="${VALUE:1}"
+	elif [ "$PARAMFILE" != "" ] && grep -E "^$NAME " $PARAMFILE ; then
+			VALUE=$(grep -E "^$NAME " $PARAMFILE | cut -d ' ' -f 2-)
 	else
 		fail 254 "Missing $NAME argument"
 	fi
-	VALUE="${VALUE:1}"
 openinfo() {
@@ -115,6 +126,7 @@
 # make the WFDIR absolute
 WFDIR=$(pwd)
+PARAMFILE=
 openinfo "wrapper.log"
 ID=$1
@@ -122,10 +134,16 @@
 shift
-getarg "-jobdir" "$@"
-JOBDIR=$VALUE
-shift $SHIFTCOUNT
+checkparamfile "$@"
+# JOBDIR might have been assigned through the -p option, or might
+# be a parameter here
+if [ "$JOBDIR" == "" ] ; then
+	getarg "-jobdir" "$@"
+	JOBDIR=$VALUE
+	shift $SHIFTCOUNT
+fi
 checkEmpty "$JOBDIR" "Missing job directory prefix"
 mkdir -p $WFDIR/info/$JOBDIR
 closeinfo
@@ -172,15 +190,25 @@
 STATUSMODE=$VALUE
 shift $SHIFTCOUNT
-if [ "$1" == "-a" ]; then
+declare -a CMDARGS
+if [ "$PARAMFILE" == "" ] && [ "$1" == "-a" ] ; then
 	shift
+	CMDARGS=("$@")
+elif [ "$PARAMFILE" != "" ] ; then
+	CMDARGS=()
+	FIRST=1
+	while read line ; do
+		if [ "$FIRST" == "1" ] ; then
+			CMDARGS=("$line")
+			FIRST=0
+		else
+			CMDARGS=("${CMDARGS[*]}" "$line")
+		fi
+	done < <(grep -E "^-a " $PARAMFILE | cut -d " " -f 2-)
 else
 	fail 254 "Missing arguments (-a option)"
 fi
-declare -a CMDARGS
-CMDARGS=("$@")
 if [ "$STATUSMODE" = "files" ]; then
 	mkdir -p $WFDIR/status/$JOBDIR
 fi
Modified: trunk/libexec/vdl-int.k
--- trunk/libexec/vdl-int.k	2009-05-17 12:00:03 UTC (rev 2939)
+++ trunk/libexec/vdl-int.k	2009-05-17 12:03:39 UTC (rev 2940)
@@ -113,6 +113,11 @@
 					dir:make(dircat(wfdir, "status"), host=rhost)
+				wrapperMode := configProperty("wrapper.parameter.mode",host=rhost)
+				if(wrapperMode == "files"
+					dir:make(dircat(wfdir, "parameters"), host=rhost)
 				dir:make(dircat(wfdir, "info"), host=rhost)
 				wfdir, sharedDir
 				//we send the cleanup data to vdl:main()
@@ -204,6 +209,24 @@
+		element(stageWrapperParams, [jobid, jobdir, wrapfile, dir, host]
+			log(LOG:INFO, "START jobid={jobid} - staging in wrapper params")
+			provider := provider(wrapfile)
+			srchost := hostname(wrapfile)
+			srcdir := dirname(wrapfile)
+			destdir := dircat(dir, "/parameters/{jobdir}/")
+			filename := basename(wrapfile)
+			cacheOn(list(destdir, host)
+				dir:make(destdir, host=host, provider=provider)
+			task:transfer(srcprovider=provider, srchost=srchost, srcfile=filename, srcdir=srcdir, desthost=host, destdir=destdir)
+			log(LOG:INFO, "END jobid={jobid}")
 		element(doStagein, [jobid, files, dir, host]
 			log(LOG:INFO, "START jobid={jobid} - Staging in files")
 			uParallelFor(file, files
@@ -381,27 +404,71 @@
 				log(LOG:DEBUG, "THREAD_ASSOCIATION jobid={jobid} thread={#thread} host={rhost} replicationGroup={replicationGroup}")
 				statusMode := configProperty("status.mode",host=rhost)
+				ddir := "{VDL:SCRIPTNAME}-{VDL:RUNID}.d"
+				if(sys:not(file:exists(ddir))
+					task:dir:make(ddir)
+				wrapfile := "{ddir}/param-{jobid}"
+				stdout := try(stdout, "stdout.txt")
+				stderr := try(stderr, "stderr.txt")
+				kickstart := vdl:kickstart(rhost)
+				fileDirs := fileDirs(stagein, stageout)
+					sequential(
+						sys:file:write(wrapfile,
+							"-e ",vdl:executable(tr, rhost), nl(),
+							"-out ",stdout,nl(),
+							"-err ",stderr,nl(),
+							"-i ",maybe(stdin),nl(),
+							"-d ",flatten(each(fileDirs)),nl(),
+							"-if ",flatten(infiles(stagein)),nl(),
+							"-of ",flatten(outfiles(stageout)),nl(),
+							"-k ",kickstart,nl(),
+							"-status ",statusMode,nl())
+						for(argiterator, arguments
+							sys:file:write(wrapfile,append=true,"-a ",argiterator,nl())
 				vdl:setprogress("Stage in")
 				tmpdir := dircat(concat(wfdir, "/jobs/", jobdir), jobid)
-				stdout := try(stdout, "stdout.txt")
-				stderr := try(stderr, "stderr.txt")
-				kickstart := vdl:kickstart(rhost)
 				try(
 					sequential(
-						fileDirs := fileDirs(stagein, stageout)
 						createDirSet(jobid, sharedDir, rhost, fileDirs)
 						doStagein(jobid, stagein, sharedDir, rhost)
+							stageWrapperParams(jobid, jobdir, wrapfile, wfdir, rhost)
 						log(LOG:DEBUG, "JOB_START jobid={jobid} tr={tr}", maybe(" arguments=", arguments), " tmpdir={tmpdir} host={rhost}")
 						vdl:setprogress("Submitting")
-						vdl:execute("/bin/bash",
-							list("shared/_swiftwrap", jobid,
+							vdl:execute("/bin/bash",
+								list("shared/_swiftwrap", jobid, "-p", jobdir)
+							directory=wfdir
+							redirect=false
+							host=rhost
+							vdl:tcprofile(tr, rhost) //this gets various app params from the tc, such as environment, walltime, etc
+							replicationGroup=replicationGroup
+							replicationChannel=replicationChannel
+							jobid=jobid
+						if(wrapperMode == "args"
 								"-jobdir", jobdir,
 								"-e", vdl:executable(tr, rhost),
 								"-out", stdout,
@@ -412,7 +479,8 @@
 								"-of", flatten(outfiles(stageout)),
 								"-k", kickstart,
 								"-status", statusMode
-								"-a", maybe(each(arguments)))
+								"-a", maybe(each(arguments))
 							directory=wfdir
 							redirect=false
 							host=rhost
@@ -420,13 +488,18 @@
 							jobid=jobid
 						vdl:setprogress("Checking status")
 						if(statusMode == "files"
 							checkJobStatus(rhost, wfdir, jobid, tr, jobdir)
+							file:remove(wrapfile)
 						log(LOG:DEBUG, "STAGING_OUT jobid={jobid}")
@@ -497,7 +570,7 @@
 		element(generateProvenanceGraph, [gdata]
 			pgraph := vdl:configProperty("pgraph")
 			gname := if(pgraph == "true" "{VDL:SCRIPTNAME}-{VDL:RUNID}.dot" pgraph)
Modified: trunk/src/org/griphyn/vdl/util/VDL2Config.java
--- trunk/src/org/griphyn/vdl/util/VDL2Config.java	2009-05-17 12:00:03 UTC (rev 2939)
+++ trunk/src/org/griphyn/vdl/util/VDL2Config.java	2009-05-17 12:03:39 UTC (rev 2940)
@@ -89,6 +89,7 @@
 		put("replication.min.queue.time", "60");
 		put("replication.limit", "3");
 		put("status.mode", "files");
+		put("wrapper.parameter.mode", "args");
 		put("wrapper.invocation.mode", "absolute");
Added: trunk/tests/misc/arg-mode.sh
--- trunk/tests/misc/arg-mode.sh	                        (rev 0)
+++ trunk/tests/misc/arg-mode.sh	2009-05-17 12:03:39 UTC (rev 2940)
@@ -0,0 +1,19 @@
+#!/bin/bash
+INITDIR=$(pwd)
+cd ../language-behaviour
+./generate-tc.data
+cat tc.data ../sites/tc.data > tmp.tc.data.sites
+SITE=local-wrapper-args-file.xml
+echo testing site configuration: $SITE
+export SWIFT_TEST_PARAMS="-sites.file ../sites/${SITE} -tc.file tmp.tc.data.sites"
+./run 001-echo 066-many 141-space-in-filename 142-space-and-quotes 1421-space-and-quotes
Property changes on: trunk/tests/misc/arg-mode.sh
___________________________________________________________________
Modified: trunk/tests/misc/run
--- trunk/tests/misc/run	2009-05-17 12:00:03 UTC (rev 2939)
+++ trunk/tests/misc/run	2009-05-17 12:03:39 UTC (rev 2940)
@@ -2,7 +2,7 @@
 for a in clusters no-retries dryrun typecheck path-prefix restart restart2 restart3 restart4 restart5 restart-iterate workernode-local \
 ordering-extern-notlazy restart-extern ordering-extern \
 external-mapper-args extract-int-delayed asserts \
-relative-wrapper arg \
+relative-wrapper arg arg-mode \
 ; do
  ./${a}.sh
  R=$?
Added: trunk/tests/sites/local-wrapper-args-file.xml
--- trunk/tests/sites/local-wrapper-args-file.xml	                        (rev 0)
+++ trunk/tests/sites/local-wrapper-args-file.xml	2009-05-17 12:03:39 UTC (rev 2940)
@@ -0,0 +1,12 @@
+<config>
+  <pool handle="localhost">
+    <execution provider="local" />
+    <gridftp  url="local://localhost" />
+    <workdirectory >/var/tmp</workdirectory>
+    <profile namespace="karajan" key="jobThrottle">0</profile>
+    <profile namespace="karajan" key="delayBase">0</profile>
+    <profile namespace="karajan" key="wrapper.parameter.mode">files</profile>
+  </pool>
+</config>
