[Swift-commit] r2899 - in trunk: . docs etc libexec src/org/griphyn/vdl/mapping src/org/griphyn/vdl/util
Tue May 5 11:19:12 CDT 2009
Author: benc
Date: 2009-05-05 11:19:12 -0500 (Tue, 05 May 2009)
New Revision: 2899
Modified:
   trunk/CHANGES.txt
   trunk/docs/userguide.xml
   trunk/etc/swift.properties
   trunk/libexec/vdl.k
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/util/VDL2Config.java
   trunk/src/org/griphyn/vdl/util/VDL2ConfigProperties.java
Log:
New configuration property provenance.log which controls whether verbose
provenance-related log information is recorded in the run log file or
not. By default, this is false, which means that less information is
output by default now than previously.
Modified: trunk/CHANGES.txt
--- trunk/CHANGES.txt	2009-05-05 15:31:26 UTC (rev 2898)
+++ trunk/CHANGES.txt	2009-05-05 16:19:12 UTC (rev 2899)
@@ -1,3 +1,9 @@
+(05/05/09)
+*** New configuration property provenance.log which controls whether verbose
+    provenance-related log information is recorded in the run log file or
+    not. By default, this is false, which means that less information is
+    output by default now than previously.
 (04/27/09)
 *** Swift 0.9 built from Swift SVN r2860 and cog SVN r2388
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-05-05 15:31:26 UTC (rev 2898)
+++ trunk/docs/userguide.xml	2009-05-05 16:19:12 UTC (rev 2899)
@@ -2968,6 +2968,23 @@
 							</para>
 						</listitem>
 					</varlistentry>
+					<varlistentry>
+						<term>
+							<property>provenance.log</property>
+						</term>
+						<listitem>
+							<para>
+								Valid values: <literal>true</literal>, <literal>false</literal>
+							</para>
+							<para>
+								Default value: <literal>false</literal>
+							</para>
+							<para>
+								This property controls whether the log file will contain provenance information enabling this will increase the size of log files, sometimes significantly.
+							</para>
+						</listitem>
+					</varlistentry>
 				</variablelist>
Modified: trunk/etc/swift.properties
--- trunk/etc/swift.properties	2009-05-05 15:31:26 UTC (rev 2898)
+++ trunk/etc/swift.properties	2009-05-05 16:19:12 UTC (rev 2899)
@@ -312,3 +312,10 @@
 foreach.max.threads=1024
+# controls whether the log file will contain provenance information
+# enabling this will increase the size of log files, sometimes
+# significantly.
+provenance.log=false
Modified: trunk/libexec/vdl.k
--- trunk/libexec/vdl.k	2009-05-05 15:31:26 UTC (rev 2898)
+++ trunk/libexec/vdl.k	2009-05-05 16:19:12 UTC (rev 2899)
@@ -24,7 +24,11 @@
 	export(
 		element(parameterlog, [direction, variable, id],
-			log("info","PARAM thread={#thread} direction={direction} variable={variable} provenanceid={id}")
+			if(
+				vdl:configProperty("provenance.log") == "true"
+				log("info","PARAM thread={#thread} direction={direction} variable={variable} provenanceid={id}")
 		element(split, [var], each(str:split(vdl:getFieldValue(var), " ")))
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2009-05-05 15:31:26 UTC (rev 2898)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2009-05-05 16:19:12 UTC (rev 2899)
@@ -20,6 +20,9 @@
 import org.griphyn.vdl.karajan.VDL2FutureException;
+import org.griphyn.vdl.util.VDL2Config;
 public abstract class AbstractDataNode implements DSHandle {
 	static final String DATASET_URI_PREFIX = "tag:benc at ci.uchicago.edu,2008:swift:dataset:";
@@ -392,12 +395,15 @@
 		notifyListeners();
 		logger.info("closed " + this.getIdentifyingString());
 		// so because its closed, we can dump the contents
 		try {
-			logContent();
+			if(VDL2Config.getConfig().getProvenanceLog()) {
+				logContent();
 		catch (Exception e) {
 			logger.warn("Exception whilst logging dataset content for " + this,
-					e);
+				e);
 		// TODO record retrospective provenance information for this dataset
 		// here
Modified: trunk/src/org/griphyn/vdl/util/VDL2Config.java
--- trunk/src/org/griphyn/vdl/util/VDL2Config.java	2009-05-05 15:31:26 UTC (rev 2898)
+++ trunk/src/org/griphyn/vdl/util/VDL2Config.java	2009-05-05 16:19:12 UTC (rev 2899)
@@ -83,6 +83,7 @@
 		put("throttle.file.operations", "8");
 		put("throttle.score.job.factor", "4");
 		put(VDL2ConfigProperties.SITEDIR_KEEP, "false");
+		put(VDL2ConfigProperties.PROVENANCE_LOG, "false");
 		put("replication.enabled", "false");
 		put("replication.min.queue.time", "60");
@@ -202,6 +203,10 @@
 		return Boolean.valueOf(getProperty(VDL2ConfigProperties.SITEDIR_KEEP, "true")).booleanValue();
+	public boolean getProvenanceLog() {
+		return Boolean.valueOf(getProperty(VDL2ConfigProperties.PROVENANCE_LOG, "false")).booleanValue();
 	public String toString() {
 		return "Swift configuration " + files;
Modified: trunk/src/org/griphyn/vdl/util/VDL2ConfigProperties.java
--- trunk/src/org/griphyn/vdl/util/VDL2ConfigProperties.java	2009-05-05 15:31:26 UTC (rev 2898)
+++ trunk/src/org/griphyn/vdl/util/VDL2ConfigProperties.java	2009-05-05 16:19:12 UTC (rev 2899)
@@ -24,6 +24,7 @@
 	public static final String KICKSTART_ALWAYS_TRANSFER = "kickstart.always.transfer";
 	public static final String WRAPPERLOG_ALWAYS_TRANSFER = "wrapperlog.always.transfer";
 	public static final String SITEDIR_KEEP = "sitedir.keep";
+	public static final String PROVENANCE_LOG = "provenance.log";
 	public static final Map PROPERTIES;
 	static {
@@ -109,6 +110,12 @@
 					"If set to true, keeps remote site run directory after execution has completed."));
+		PROPERTIES.put(
+				PROVENANCE_LOG,
+				new PropInfo(
+					"<true|false>",
+					"If set to true, will record provenance information in the log file"));
 	public static Map getPropertyDescriptions() {
