[Swift-commit] r2776 - trunk/docs
Mon Mar 30 00:26:56 CDT 2009
Author: benc
Date: 2009-03-30 00:26:56 -0500 (Mon, 30 Mar 2009)
New Revision: 2776
Modified:
   trunk/docs/userguide.xml
Log:
split a very long doc line
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-03-30 05:26:23 UTC (rev 2775)
+++ trunk/docs/userguide.xml	2009-03-30 05:26:56 UTC (rev 2776)
@@ -1423,9 +1423,13 @@
   <varlistentry><term>-runid <literal>identifier</literal></term>
     <listitem><para>
-Specifies the run identifier. This must be unique for every invocation and is used in several places to keep files from different executions cleanly separated. By default, a datestamp and random number are used to generate a run identifier. When using this parameter, care should be taken to ensure
-that the run ID remains unique with respect to all other run IDs that might
-be used, irrespective of (at least) expected execution sites, program or user.
+      Specifies the run identifier. This must be unique for every invocation
+      and is used in several places to keep files from different executions
+      cleanly separated. By default, a datestamp and random number are used
+      to generate a run identifier. When using this parameter, care should be
+      taken to ensure that the run ID remains unique with respect to all
+      other run IDs that might be used, irrespective of (at least) expected
+      execution sites, program or user.
     </para></listitem>
   </varlistentry>
