[Swift-commit] r2751 - usertools/cio/falkon
Sat Mar 28 10:56:19 CDT 2009
Author: aespinosa
Date: 2009-03-28 10:56:19 -0500 (Sat, 28 Mar 2009)
New Revision: 2751
Added:
   usertools/cio/falkon/ciologic-bgp.sh
Removed:
   usertools/cio/falkon/cio-logic.sh
Log:
Rename to separate BGP specific script
Deleted: usertools/cio/falkon/cio-logic.sh
--- usertools/cio/falkon/cio-logic.sh	2009-03-28 15:56:07 UTC (rev 2750)
+++ usertools/cio/falkon/cio-logic.sh	2009-03-28 15:56:19 UTC (rev 2751)
@@ -1,137 +0,0 @@
-#!/fuse/bin/bash
-CIOROOT=/home/espinosa/cio
-ERROR_LOG=/dev/null
-if [ $# -lt 7 ]; then
-  cat << EOF
-Usage: $0 <FALKON_IP> <TCPCORE_PORT1> <TCPCORE_PORT2> <NUM_WORKERS> <USER_ID> <FALKON_JOB_ID> <FALKON_ROOT_PATH> \
-    <PART_SIZE> <DATA_NUM> <STRIPE_SIZE>
-Example: $0 192.168.1.254 55000 55001 4 iraicu 0001 [FALKON_ROOT] \
-    1024 1 1"
-EOF
-  exit 2
-fi
-# Initiate the IP stack of the Torus network
-# -aespinosa
-/home/iskra/ZeptoOS/packages/cnip/prebuilt/cn-ipfwd.2409 &
-while [ ! -f /tmp/ifconfig.cmd ]; do
-    sleep 1
-done
-. /tmp/ifconfig.cmd
-RANK=`/home/espinosa/bin/rank`
-# size of the allocated partition.  also known as the total number of CNs
-PART_SIZE=$8
-# number of data CNs in partition
-DATA_NUM=$9
-STR=${10}
-ROLE=`/home/espinosa/bin/isdata $PART_SIZE $DATA_NUM $STR`
-ISDATA=$ROLE
-tmp=`/home/espinosa/bin/getdata $PART_SIZE $DATA_NUM $STR`
-DATACN=`/fuse/gpfs/home/espinosa/bin/ipcal 10.128.0.0 $tmp`
-if [ $RANK -eq 0 ]; then
-  # Run Central Hash Service
-  $CIOROOT/hashserver.rb
-elif [ "$ISDATA" != 'app' ]; then
-  if [ "$ROLE" = 'head' ]; then
-    echo "[ $BG_RANK@$IO_RANK-$PSET ] Starting Mosa Benefactor managed by $DATACN" >&2
-    echo "[ $BG_RANK@$IO_RANK-$PSET ] Starting Mosa Manager across $STR CNs" >&2
-    /home/espinosa/experiments/util/startchirp-wmosa.sh $DATACN $STR >&2
-  else
-    /home/espinosa/experiments/util/benefactor.sh $DATACN >&2
-  fi
-else
-  echo "[ $BG_RANK@$IO_RANK-$PSET ] Mounting Mosa data CN filesystem from $DATACN" >&2
-  /bin/mkdir /dataifs
-  export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/lib:/fuse/lib:/usr/lib
-  sleep 30
-  /home/espinosa/experiments/util/mosamount.sh $DATACN >&2
-  echo "worker started..." >> ${ERROR_LOG}
-  # Regular Falon worker startup script
-  FALKON_SERVICE_IP=$1
-  TCPCORE_PORT1=$2
-  TCPCORE_PORT2=$3
-  NUM_WORKERS=$4
-  USER_ID=$5
-  FALKON_JOB_ID=$6
-  FALKON_ROOT_PATH=$7
-  FALKON_HOME=${FALKON_ROOT_PATH}/users/${USER_ID}/${FALKON_JOB_ID}
-  echo "FALKON_HOME = ${FALKON_HOME}" >> ${ERROR_LOG}
-  #FALKON_HOME=/home/falkon/falkon
-  HOME=${FALKON_ROOT_PATH}
-  echo "HOME = ${HOME}" >> ${ERROR_LOG}
-  #HOME=${FALKON_HOME}
-  if [ -z "${FALKON_HOME}" ]; then
-      echo "ERROR: environment variable FALKON_HOME not defined"
-      echo "ERROR: environment variable FALKON_HOME not defined" >> ${ERROR_LOG}
-      exit 1
-  fi
-  if [ ! -d "${FALKON_HOME}" ]; then
-      echo "ERROR: invalid FALKON_HOME set: $FALKON_HOME"
-      echo "ERROR: invalid FALKON_HOME set: $FALKON_HOME" >> ${ERROR_LOG}
-      exit 1
-  fi
-  cd ${FALKON_HOME}
-  source falkon.env.bgp-cn
-  HOME_PATH=`pwd`
-  export MACH_ID=`uname -i`
-  RAND_ID2=`/home/espinosa/bin/rank`
-  a0=${RAND_ID2%%=*}; rest=${RAND_ID2#*=}
-  RAND_ID=${rest%%=*};
-  #PLATFORM=`uname -m`
-  EXP_START=`date +%Y.%m.%d_%H.%M.%S`
-  for ((b=1; b < ${NUM_WORKERS} ; b++))
-  do
-    #LOG_FILE=${FALKON_LOGS}/worker/${RAND_ID}.${b}.${EXP_START}.txt
-    LOG_FILE=/dev/null
-    #${FALKON_WORKER_HOME}/src-c/BGexec_${PLATFORM} ${FALKON_SERVICE_IP} ${TCPCORE_PORT1} ${TCPCORE_PORT2} -perf >> "${LOG_FILE}" 2>&1 &
-    #echo "starting .... ${FALKON_WORKER_HOME}/src-c/BGexec ${FALKON_SERVICE_IP} ${TCPCORE_PORT1} ${TCPCORE_PORT2} -perf"
-    echo "starting worker ${RAND_ID} CPU ${b}..." >> ${ERROR_LOG}
-    ${FALKON_WORKER_HOME}/src-c/BGexec ${FALKON_SERVICE_IP} ${TCPCORE_PORT1} ${TCPCORE_PORT2} -perf >> ${LOG_FILE} 2>&1 &
-    #${HOME_PATH}/src-c/BGexec_${PLATFORM} ${FALKON_SERVICE_IP} 55000 55001 -debug
-    /bin/sleep 1
-  done
-  #LOG_FILE=${FALKON_LOGS}/worker/${RAND_ID}.${NUM_WORKERS}.${EXP_START}.txt
-  echo "starting worker ${RAND_ID} CPU ${NUM_WORKERS}..." >> ${ERROR_LOG}
-  echo "finished!" >> ${ERROR_LOG}
-fi
Copied: usertools/cio/falkon/ciologic-bgp.sh (from rev 2750, usertools/cio/falkon/cio-logic.sh)
--- usertools/cio/falkon/ciologic-bgp.sh	                        (rev 0)
+++ usertools/cio/falkon/ciologic-bgp.sh	2009-03-28 15:56:19 UTC (rev 2751)
@@ -0,0 +1,137 @@
+#!/fuse/bin/bash
+CIOROOT=/home/espinosa/cio
+ERROR_LOG=/dev/null
+if [ $# -lt 7 ]; then
+  cat << EOF
+Usage: $0 <FALKON_IP> <TCPCORE_PORT1> <TCPCORE_PORT2> <NUM_WORKERS> <USER_ID> <FALKON_JOB_ID> <FALKON_ROOT_PATH> \
+    <PART_SIZE> <DATA_NUM> <STRIPE_SIZE>
+Example: $0 192.168.1.254 55000 55001 4 iraicu 0001 [FALKON_ROOT] \
+    1024 1 1"
+EOF
+  exit 2
+fi
+# Initiate the IP stack of the Torus network
+# -aespinosa
+/home/iskra/ZeptoOS/packages/cnip/prebuilt/cn-ipfwd.2409 &
+while [ ! -f /tmp/ifconfig.cmd ]; do
+    sleep 1
+done
+. /tmp/ifconfig.cmd
+RANK=`/home/espinosa/bin/rank`
+# size of the allocated partition.  also known as the total number of CNs
+PART_SIZE=$8
+# number of data CNs in partition
+DATA_NUM=$9
+STR=${10}
+ROLE=`/home/espinosa/bin/isdata $PART_SIZE $DATA_NUM $STR`
+ISDATA=$ROLE
+tmp=`/home/espinosa/bin/getdata $PART_SIZE $DATA_NUM $STR`
+DATACN=`/fuse/gpfs/home/espinosa/bin/ipcal 10.128.0.0 $tmp`
+if [ $RANK -eq 0 ]; then
+  # Run Central Hash Service
+  $CIOROOT/hashserver.rb
+elif [ "$ISDATA" != 'app' ]; then
+  if [ "$ROLE" = 'head' ]; then
+    echo "[ $BG_RANK@$IO_RANK-$PSET ] Starting Mosa Benefactor managed by $DATACN" >&2
+    echo "[ $BG_RANK@$IO_RANK-$PSET ] Starting Mosa Manager across $STR CNs" >&2
+    /home/espinosa/experiments/util/startchirp-wmosa.sh $DATACN $STR >&2
+  else
+    /home/espinosa/experiments/util/benefactor.sh $DATACN >&2
+  fi
+else
+  echo "[ $BG_RANK@$IO_RANK-$PSET ] Mounting Mosa data CN filesystem from $DATACN" >&2
+  /bin/mkdir /dataifs
+  export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/lib:/fuse/lib:/usr/lib
+  sleep 30
+  /home/espinosa/experiments/util/mosamount.sh $DATACN >&2
+  echo "worker started..." >> ${ERROR_LOG}
+  # Regular Falon worker startup script
+  FALKON_SERVICE_IP=$1
+  TCPCORE_PORT1=$2
+  TCPCORE_PORT2=$3
+  NUM_WORKERS=$4
+  USER_ID=$5
+  FALKON_JOB_ID=$6
+  FALKON_ROOT_PATH=$7
+  FALKON_HOME=${FALKON_ROOT_PATH}/users/${USER_ID}/${FALKON_JOB_ID}
+  echo "FALKON_HOME = ${FALKON_HOME}" >> ${ERROR_LOG}
+  #FALKON_HOME=/home/falkon/falkon
+  HOME=${FALKON_ROOT_PATH}
+  echo "HOME = ${HOME}" >> ${ERROR_LOG}
+  #HOME=${FALKON_HOME}
+  if [ -z "${FALKON_HOME}" ]; then
+      echo "ERROR: environment variable FALKON_HOME not defined"
+      echo "ERROR: environment variable FALKON_HOME not defined" >> ${ERROR_LOG}
+      exit 1
+  fi
+  if [ ! -d "${FALKON_HOME}" ]; then
+      echo "ERROR: invalid FALKON_HOME set: $FALKON_HOME"
+      echo "ERROR: invalid FALKON_HOME set: $FALKON_HOME" >> ${ERROR_LOG}
+      exit 1
+  fi
+  cd ${FALKON_HOME}
+  source falkon.env.bgp-cn
+  HOME_PATH=`pwd`
+  export MACH_ID=`uname -i`
+  RAND_ID2=`/home/espinosa/bin/rank`
+  a0=${RAND_ID2%%=*}; rest=${RAND_ID2#*=}
+  RAND_ID=${rest%%=*};
+  #PLATFORM=`uname -m`
+  EXP_START=`date +%Y.%m.%d_%H.%M.%S`
+  for ((b=1; b < ${NUM_WORKERS} ; b++))
+  do
+    #LOG_FILE=${FALKON_LOGS}/worker/${RAND_ID}.${b}.${EXP_START}.txt
+    LOG_FILE=/dev/null
+    #${FALKON_WORKER_HOME}/src-c/BGexec_${PLATFORM} ${FALKON_SERVICE_IP} ${TCPCORE_PORT1} ${TCPCORE_PORT2} -perf >> "${LOG_FILE}" 2>&1 &
+    #echo "starting .... ${FALKON_WORKER_HOME}/src-c/BGexec ${FALKON_SERVICE_IP} ${TCPCORE_PORT1} ${TCPCORE_PORT2} -perf"
+    echo "starting worker ${RAND_ID} CPU ${b}..." >> ${ERROR_LOG}
+    ${FALKON_WORKER_HOME}/src-c/BGexec ${FALKON_SERVICE_IP} ${TCPCORE_PORT1} ${TCPCORE_PORT2} -perf >> ${LOG_FILE} 2>&1 &
+    #${HOME_PATH}/src-c/BGexec_${PLATFORM} ${FALKON_SERVICE_IP} 55000 55001 -debug
+    /bin/sleep 1
+  done
+  #LOG_FILE=${FALKON_LOGS}/worker/${RAND_ID}.${NUM_WORKERS}.${EXP_START}.txt
+  echo "starting worker ${RAND_ID} CPU ${NUM_WORKERS}..." >> ${ERROR_LOG}
+  echo "finished!" >> ${ERROR_LOG}
+fi
