[Swift-commit] r2747 - in trunk: . libexec src/org/griphyn/vdl/karajan
Fri Mar 27 15:24:18 CDT 2009
Author: benc
Date: 2009-03-27 15:24:17 -0500 (Fri, 27 Mar 2009)
New Revision: 2747
Added:
   trunk/libexec/_swiftseq
   trunk/libexec/_swiftwrap
Removed:
   trunk/libexec/seq.sh
   trunk/libexec/wrapper.sh
Modified:
   trunk/CHANGES.txt
   trunk/libexec/vdl-int.k
   trunk/src/org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java
   trunk/src/org/griphyn/vdl/karajan/VDSTaskTransformer.java
Log:
fix bug 165: wrapper.sh and seq.sh are given more obscure names to reduce
conflicts when users want to make their own files called wrapper.sh or seq.sh
Modified: trunk/CHANGES.txt
--- trunk/CHANGES.txt	2009-03-27 08:47:39 UTC (rev 2746)
+++ trunk/CHANGES.txt	2009-03-27 20:24:17 UTC (rev 2747)
@@ -1,3 +1,9 @@
+(03/27/09)
+*** The wrapper.sh and seq.sh scripts that are deployed to remote sites to
+    help with execution have been renamed to more Swift specific names, to
+    avoid collision with user-supplied files of the same name. The new names
+    are _swiftwrap and _swiftseq
 (03/15/09)
 *** The log-processing code, primarily exposed as the swift-plot-log command,
     has been merged into the main Swift release, rather than being a separate
Copied: trunk/libexec/_swiftseq (from rev 2746, trunk/libexec/seq.sh)
--- trunk/libexec/_swiftseq	                        (rev 0)
+++ trunk/libexec/_swiftseq	2009-03-27 20:24:17 UTC (rev 2747)
@@ -0,0 +1,64 @@
+#!/bin/bash
+# get the parent directory of the directory containing wrapper.sh, to use
+# as the run directory
+# this assumes that seq.sh is being executed from the top level of
+# the shared directory, and that shared directory is in the top level
+# of the workflow run directory
+WFDIR=$(dirname $(dirname $0))
+cd $WFDIR
+SEQID="$1"
+shift
+LOGPATH="$1"
+shift
+mkdir -p $PWD/$LOGPATH
+WRAPPERLOG=$PWD/$LOGPATH/$SEQID.clusterlog
+echo `date +%s` START > $WRAPPERLOG
+echo `date +%s` WORKING DIRECTORY IS $PWD >> $WRAPPERLOG
+ls >>$WRAPPERLOG
+echo `date +%s` POST-LS >> $WRAPPERLOG
+EXEC="$1"
+shift
+# we go round this loop once for each clustered job
+while [ "$EXEC" != "" ]; do
+	echo `date +%s` LOOP-START >> $WRAPPERLOG
+	declare -a ARGS
+	INDEX=0
+	ARG="$1"
+	shift
+	while [ "$ARG" != "|" ]; do
+		if [ "$ARG" == "||" ]; then
+			ARG="|"
+		fi
+		echo `date +%s` ARG $ARG >> $WRAPPERLOG
+		ARGS[$INDEX]=$ARG
+		let INDEX=$INDEX+1
+		ARG="$1"
+		shift
+	done
+	echo `date +%s` EXECUTING $EXEC ${ARGS[@]} >> $WRAPPERLOG
+	"$EXEC" "${ARGS[@]}"
+	EXITCODE=$?
+	echo `date +%s` EXECUTED $EXITCODE >> $WRAPPERLOG
+	if [ "$EXITCODE" != "0" ]; then
+		echo `date +%s` FAILED >> $WRAPPERLOG
+		exit $EXITCODE
+	fi
+        unset ARGS
+	EXEC="$1"
+	shift
+done
+echo `date +%s` DONE >> $WRAPPERLOG
Copied: trunk/libexec/_swiftwrap (from rev 2746, trunk/libexec/wrapper.sh)
--- trunk/libexec/_swiftwrap	                        (rev 0)
+++ trunk/libexec/_swiftwrap	2009-03-27 20:24:17 UTC (rev 2747)
@@ -0,0 +1,327 @@
+# this script must be invoked inside of bash, not plain sh
+infosection() {
+	echo >& "$INFO"
+	echo "_____________________________________________________________________________" >& "$INFO"
+	echo >& "$INFO"
+	echo "        $1" >& "$INFO"
+	echo >& "$INFO"
+info() {
+	infosection "uname -a"
+	uname -a 2>&1 >& "$INFO"
+	infosection "id"
+	id 2>&1 >& "$INFO"
+	infosection "env"
+	env 2>&1 >& "$INFO"
+	infosection "df"
+	df 2>&1 >& "$INFO"
+	infosection "/proc/cpuinfo"
+	cat /proc/cpuinfo 2>&1 >& "$INFO"
+	infosection "/proc/meminfo"
+	cat /proc/meminfo 2>&1 >& "$INFO"
+	infosection "command line"
+	echo $COMMANDLINE 2>&1 >& "$INFO"
+	if [ -f "$STDOUT" ] ; then
+		infosection "stdout"
+		cat $STDOUT >& "$INFO"
+	fi
+	if [ -f "$STDERR" ] ; then
+		infosection "stderr"
+		cat $STDERR >& "$INFO"
+	fi
+logstate() {
+	echo "Progress " `date +"%Y-%m-%d %H:%M:%S.%N%z"` " $@" >& "$INFO"
+log() {
+	echo "$@" >& "$INFO"
+fail() {
+	EC=$1
+	shift
+	if [ "$STATUSMODE" = "files" ]; then
+		echo $@ >"$WFDIR/status/$JOBDIR/${ID}-error"
+	fi
+	log $@
+	info
+		exit 0
+	else
+		exit $EC
+	fi
+checkError() {
+	if [ "$?" != "0" ]; then
+		fail $@
+	fi
+checkEmpty() {
+	if [ "$1" == "" ]; then
+		shift
+		fail 254 $@
+	fi
+getarg() {
+	NAME=$1
+	shift
+	VALUE=""
+	SHIFTCOUNT=0
+	if [ "$1" == "$NAME" ]; then
+		shift
+		let "SHIFTCOUNT=$SHIFTCOUNT+1"
+		while [ "${1:0:1}" != "-" ] && [ "$#" != "0" ]; do
+			VALUE="$VALUE $1"
+			shift
+		done
+	else
+		fail 254 "Missing $NAME argument"
+	fi
+	VALUE="${VALUE:1}"
+openinfo() {
+	exec 3<> $1
+	INFO=3
+closeinfo() {
+	exec 3>&-
+COMMANDLINE=$@
+# get the parent directory of the directory containing _swiftwrap, to use
+# this assumes that _swiftwrap is being executed from the top level of
+cd $WFDIR
+# make the WFDIR absolute
+WFDIR=$(pwd)
+openinfo "wrapper.log"
+ID=$1
+checkEmpty "$ID" "Missing job ID"
+shift
+getarg "-jobdir" "$@"
+JOBDIR=$VALUE
+shift $SHIFTCOUNT
+checkEmpty "$JOBDIR" "Missing job directory prefix"
+mkdir -p $WFDIR/info/$JOBDIR
+closeinfo
+rm -f "$WFDIR/info/$JOBDIR/${ID}-info"
+openinfo "$WFDIR/info/$JOBDIR/${ID}-info"
+logstate "LOG_START"
+infosection "Wrapper"
+getarg "-e" "$@"
+EXEC=$VALUE
+shift $SHIFTCOUNT
+getarg "-out" "$@"
+STDOUT=$VALUE
+shift $SHIFTCOUNT
+getarg "-err" "$@"
+STDERR=$VALUE
+shift $SHIFTCOUNT
+getarg "-i" "$@"
+STDIN=$VALUE
+shift $SHIFTCOUNT
+getarg "-d" "$@"
+DIRS=$VALUE
+shift $SHIFTCOUNT
+getarg "-if" "$@"
+INF=$VALUE
+shift $SHIFTCOUNT
+getarg "-of" "$@"
+OUTF=$VALUE
+shift $SHIFTCOUNT
+getarg "-k" "$@"
+KICKSTART=$VALUE
+shift $SHIFTCOUNT
+getarg "-status" "$@"
+STATUSMODE=$VALUE
+shift $SHIFTCOUNT
+if [ "$1" == "-a" ]; then
+	shift
+else
+	fail 254 "Missing arguments (-a option)"
+fi
+if [ "$STATUSMODE" = "files" ]; then
+	mkdir -p $WFDIR/status/$JOBDIR
+fi
+if [ "X$SWIFT_JOBDIR_PATH" != "X" ]; then
+  log "Job directory mode is: local copy"
+  DIR=${SWIFT_JOBDIR_PATH}/$JOBDIR/$ID
+  COPYNOTLINK=1
+else
+  log "Job directory mode is: link on shared filesystem"
+  DIR=jobs/$JOBDIR/$ID
+  COPYNOTLINK=0
+fi
+PATH=$PATH:/bin:/usr/bin
+if [ "$PATHPREFIX" != "" ]; then
+export PATH=$PATHPREFIX:$PATH
+fi
+if [ "X${EXEC:0:1}" != "X/" ] ; then
+export ORIGEXEC=$EXEC
+export EXEC=$(which $EXEC)
+if [ "X$EXEC" = "X" ] ; then
+fail 254 "Cannot find executable $ORIGEXEC on site system path"
+fi
+fi
+log "DIR=$DIR"
+log "EXEC=$EXEC"
+log "STDIN=$STDIN"
+log "STDOUT=$STDOUT"
+log "STDERR=$STDERR"
+log "DIRS=$DIRS"
+log "INF=$INF"
+log "OUTF=$OUTF"
+log "KICKSTART=$KICKSTART"
+log "ARGS=$@"
+log "ARGC=$#"
+IFS="|"
+logstate "CREATE_JOBDIR"
+mkdir -p $DIR
+checkError 254 "Failed to create job directory $DIR"
+log "Created job directory: $DIR"
+logstate "CREATE_INPUTDIR"
+for D in $DIRS ; do
+	mkdir -p "$DIR/$D" 2>&1 >>"$INFO"
+	checkError 254 "Failed to create input directory $D"
+	log "Created output directory: $DIR/$D"
+done
+logstate "LINK_INPUTS"
+for L in $INF ; do
+	if [ $COPYNOTLINK = 1 ]; then
+		cp "$PWD/shared/$L" "$DIR/$L" 2>&1 >& $INFO
+		checkError 254 "Failed to copy input file $L"
+		log "Copied input: $PWD/shared/$L to $DIR/$L"
+	else
+		ln -s "$PWD/shared/$L" "$DIR/$L" 2>&1 >& $INFO
+		checkError 254 "Failed to link input file $L"
+		log "Linked input: $PWD/shared/$L to $DIR/$L"
+	fi
+done
+logstate "EXECUTE"
+cd $DIR
+#ls >>$WRAPPERLOG
+if [ ! -f "$EXEC" ]; then
+	fail 254 "The executable $EXEC does not exist"
+fi
+if [ ! -x "$EXEC" ]; then
+	fail 254 "The executable $EXEC does not have the executable bit set"
+fi
+if [ "$KICKSTART" == "" ]; then
+	if [ "$STDIN" == "" ]; then
+		"$EXEC" "$@" 1>"$STDOUT" 2>"$STDERR"
+	else
+		"$EXEC" "$@" 1>"$STDOUT" 2>"$STDERR" <"$STDIN"
+	fi
+	checkError $? "Exit code $?"
+else
+	if [ ! -f "$KICKSTART" ]; then
+		log "Kickstart executable ($KICKSTART) not found"
+		fail 254 "The Kickstart executable ($KICKSTART) was not found"
+	elif [ ! -x "$KICKSTART" ]; then
+		log "Kickstart executable ($KICKSTART) is not executable"
+		fail 254 "The Kickstart executable ($KICKSTART) does not have the executable bit set"
+	else
+		mkdir -p $WFDIR/kickstart/$JOBDIR
+		log "Using Kickstart ($KICKSTART)"
+			"$KICKSTART" -H -o "$STDOUT" -e "$STDERR" "$EXEC" "$@" 1>kickstart.xml 2>"$STDERR"
+		else
+			"$KICKSTART" -H -o "$STDOUT" -i "$STDIN" -e "$STDERR" "$EXEC" "$@" 1>kickstart.xml 2>"$STDERR"
+		fi
+		export APPEXIT=$?
+		mv -f kickstart.xml "$WFDIR/kickstart/$JOBDIR/$ID-kickstart.xml" 2>&1 >& "$INFO"
+		checkError 254 "Failed to copy Kickstart record to shared directory"
+		if [ "$APPEXIT" != "0" ]; then
+			fail $APPEXIT "Exit code $APPEXIT"
+		fi
+	fi
+fi
+cd $WFDIR
+log "Moving back to workflow directory $WFDIR"
+logstate "EXECUTE_DONE"
+log "Job ran successfully"
+MISSING=
+for O in $OUTF ; do
+	if [ ! -f "$DIR/$O" ]; then
+		if [ "$MISSING" == "" ]; then
+			MISSING=$O
+		else
+			MISSING="$MISSING, $O"
+		fi
+	fi
+done
+if [ "$MISSING" != "" ]; then
+	fail 254 "The following output files were not created by the application: $MISSING"
+fi
+logstate "COPYING_OUTPUTS"
+	cp "$DIR/$O" "shared/$O" 2>&1 >& "$INFO"
+	checkError 254 "Failed to copy output file $O to shared directory"
+done
+logstate "RM_JOBDIR"
+rm -rf "$DIR" 2>&1 >& "$INFO"
+checkError 254 "Failed to remove job directory $DIR"
+	logstate "TOUCH_SUCCESS"
+	touch status/${JOBDIR}/${ID}-success
+fi
+logstate "END"
+closeinfo
+# ensure we exit with a 0 after a successful exection
+exit 0
Deleted: trunk/libexec/seq.sh
--- trunk/libexec/seq.sh	2009-03-27 08:47:39 UTC (rev 2746)
+++ trunk/libexec/seq.sh	2009-03-27 20:24:17 UTC (rev 2747)
@@ -1,64 +0,0 @@
-#!/bin/bash
-# get the parent directory of the directory containing wrapper.sh, to use
-# as the run directory
-# this assumes that seq.sh is being executed from the top level of
-# the shared directory, and that shared directory is in the top level
-# of the workflow run directory
-WFDIR=$(dirname $(dirname $0))
-cd $WFDIR
-SEQID="$1"
-shift
-LOGPATH="$1"
-shift
-mkdir -p $PWD/$LOGPATH
-WRAPPERLOG=$PWD/$LOGPATH/$SEQID.clusterlog
-echo `date +%s` START > $WRAPPERLOG
-echo `date +%s` WORKING DIRECTORY IS $PWD >> $WRAPPERLOG
-ls >>$WRAPPERLOG
-echo `date +%s` POST-LS >> $WRAPPERLOG
-EXEC="$1"
-shift
-# we go round this loop once for each clustered job
-while [ "$EXEC" != "" ]; do
-	echo `date +%s` LOOP-START >> $WRAPPERLOG
-	declare -a ARGS
-	INDEX=0
-	ARG="$1"
-	shift
-	while [ "$ARG" != "|" ]; do
-		if [ "$ARG" == "||" ]; then
-			ARG="|"
-		fi
-		echo `date +%s` ARG $ARG >> $WRAPPERLOG
-		ARGS[$INDEX]=$ARG
-		let INDEX=$INDEX+1
-		ARG="$1"
-		shift
-	done
-	echo `date +%s` EXECUTING $EXEC ${ARGS[@]} >> $WRAPPERLOG
-	"$EXEC" "${ARGS[@]}"
-	EXITCODE=$?
-	echo `date +%s` EXECUTED $EXITCODE >> $WRAPPERLOG
-	if [ "$EXITCODE" != "0" ]; then
-		echo `date +%s` FAILED >> $WRAPPERLOG
-		exit $EXITCODE
-	fi
-        unset ARGS
-	EXEC="$1"
-	shift
-done
-echo `date +%s` DONE >> $WRAPPERLOG
Modified: trunk/libexec/vdl-int.k
--- trunk/libexec/vdl-int.k	2009-03-27 08:47:39 UTC (rev 2746)
+++ trunk/libexec/vdl-int.k	2009-03-27 20:24:17 UTC (rev 2747)
@@ -104,8 +104,8 @@
 				wfdir := "{VDL:SCRIPTNAME}-{VDL:RUNID}"
 				sharedDir := dircat(wfdir, "shared")
 				dir:make(sharedDir, host=rhost)
-				transfer(srcdir="{vds.home}/libexec/", srcfile="wrapper.sh", destdir=sharedDir, desthost=rhost)
-				transfer(srcdir="{vds.home}/libexec/", srcfile="seq.sh", destdir=sharedDir, desthost=rhost)
+				transfer(srcdir="{vds.home}/libexec/", srcfile="_swiftwrap", destdir=sharedDir, desthost=rhost)
+				transfer(srcdir="{vds.home}/libexec/", srcfile="_swiftseq", destdir=sharedDir, desthost=rhost)
 				dir:make(dircat(wfdir, "kickstart"), host=rhost)
 				statusMode := configProperty("status.mode",host=rhost)
@@ -401,7 +401,7 @@
 						vdl:setprogress("Submitting")
 						vdl:execute("/bin/bash",
-							list("shared/wrapper.sh", jobid,
+							list("shared/_swiftwrap", jobid,
 								"-jobdir", jobdir,
 								"-e", vdl:executable(tr, rhost),
 								"-out", stdout,
Deleted: trunk/libexec/wrapper.sh
--- trunk/libexec/wrapper.sh	2009-03-27 08:47:39 UTC (rev 2746)
+++ trunk/libexec/wrapper.sh	2009-03-27 20:24:17 UTC (rev 2747)
@@ -1,327 +0,0 @@
-# this script must be invoked inside of bash, not plain sh
-infosection() {
-	echo >& "$INFO"
-	echo "_____________________________________________________________________________" >& "$INFO"
-	echo >& "$INFO"
-	echo "        $1" >& "$INFO"
-	echo >& "$INFO"
-info() {
-	infosection "uname -a"
-	uname -a 2>&1 >& "$INFO"
-	infosection "id"
-	id 2>&1 >& "$INFO"
-	infosection "env"
-	env 2>&1 >& "$INFO"
-	infosection "df"
-	df 2>&1 >& "$INFO"
-	infosection "/proc/cpuinfo"
-	cat /proc/cpuinfo 2>&1 >& "$INFO"
-	infosection "/proc/meminfo"
-	cat /proc/meminfo 2>&1 >& "$INFO"
-	infosection "command line"
-	echo $COMMANDLINE 2>&1 >& "$INFO"
-	if [ -f "$STDOUT" ] ; then
-		infosection "stdout"
-		cat $STDOUT >& "$INFO"
-	fi
-	if [ -f "$STDERR" ] ; then
-		infosection "stderr"
-		cat $STDERR >& "$INFO"
-	fi
-logstate() {
-	echo "Progress " `date +"%Y-%m-%d %H:%M:%S.%N%z"` " $@" >& "$INFO"
-log() {
-	echo "$@" >& "$INFO"
-fail() {
-	EC=$1
-	shift
-	if [ "$STATUSMODE" = "files" ]; then
-		echo $@ >"$WFDIR/status/$JOBDIR/${ID}-error"
-	fi
-	log $@
-	info
-		exit 0
-	else
-		exit $EC
-	fi
-checkError() {
-	if [ "$?" != "0" ]; then
-		fail $@
-	fi
-checkEmpty() {
-	if [ "$1" == "" ]; then
-		shift
-		fail 254 $@
-	fi
-getarg() {
-	NAME=$1
-	shift
-	VALUE=""
-	SHIFTCOUNT=0
-	if [ "$1" == "$NAME" ]; then
-		shift
-		let "SHIFTCOUNT=$SHIFTCOUNT+1"
-		while [ "${1:0:1}" != "-" ] && [ "$#" != "0" ]; do
-			VALUE="$VALUE $1"
-			shift
-		done
-	else
-		fail 254 "Missing $NAME argument"
-	fi
-	VALUE="${VALUE:1}"
-openinfo() {
-	exec 3<> $1
-	INFO=3
-closeinfo() {
-	exec 3>&-
-COMMANDLINE=$@
-# this assumes that wrapper.sh is being executed from the top level of
-cd $WFDIR
-# make the WFDIR absolute
-WFDIR=$(pwd)
-openinfo "wrapper.log"
-ID=$1
-checkEmpty "$ID" "Missing job ID"
-shift
-getarg "-jobdir" "$@"
-JOBDIR=$VALUE
-shift $SHIFTCOUNT
-checkEmpty "$JOBDIR" "Missing job directory prefix"
-mkdir -p $WFDIR/info/$JOBDIR
-closeinfo
-rm -f "$WFDIR/info/$JOBDIR/${ID}-info"
-openinfo "$WFDIR/info/$JOBDIR/${ID}-info"
-logstate "LOG_START"
-infosection "Wrapper"
-getarg "-e" "$@"
-EXEC=$VALUE
-shift $SHIFTCOUNT
-getarg "-out" "$@"
-STDOUT=$VALUE
-shift $SHIFTCOUNT
-getarg "-err" "$@"
-STDERR=$VALUE
-shift $SHIFTCOUNT
-getarg "-i" "$@"
-STDIN=$VALUE
-shift $SHIFTCOUNT
-getarg "-d" "$@"
-DIRS=$VALUE
-shift $SHIFTCOUNT
-getarg "-if" "$@"
-INF=$VALUE
-shift $SHIFTCOUNT
-getarg "-of" "$@"
-OUTF=$VALUE
-shift $SHIFTCOUNT
-getarg "-k" "$@"
-KICKSTART=$VALUE
-shift $SHIFTCOUNT
-getarg "-status" "$@"
-STATUSMODE=$VALUE
-shift $SHIFTCOUNT
-if [ "$1" == "-a" ]; then
-	shift
-else
-	fail 254 "Missing arguments (-a option)"
-fi
-if [ "$STATUSMODE" = "files" ]; then
-	mkdir -p $WFDIR/status/$JOBDIR
-fi
-if [ "X$SWIFT_JOBDIR_PATH" != "X" ]; then
-  log "Job directory mode is: local copy"
-  DIR=${SWIFT_JOBDIR_PATH}/$JOBDIR/$ID
-  COPYNOTLINK=1
-else
-  log "Job directory mode is: link on shared filesystem"
-  DIR=jobs/$JOBDIR/$ID
-  COPYNOTLINK=0
-fi
-PATH=$PATH:/bin:/usr/bin
-if [ "$PATHPREFIX" != "" ]; then
-export PATH=$PATHPREFIX:$PATH
-fi
-if [ "X${EXEC:0:1}" != "X/" ] ; then
-export ORIGEXEC=$EXEC
-export EXEC=$(which $EXEC)
-if [ "X$EXEC" = "X" ] ; then
-fail 254 "Cannot find executable $ORIGEXEC on site system path"
-fi
-fi
-log "DIR=$DIR"
-log "EXEC=$EXEC"
-log "STDIN=$STDIN"
-log "STDOUT=$STDOUT"
-log "STDERR=$STDERR"
-log "DIRS=$DIRS"
-log "INF=$INF"
-log "OUTF=$OUTF"
-log "KICKSTART=$KICKSTART"
-log "ARGS=$@"
-log "ARGC=$#"
-IFS="|"
-logstate "CREATE_JOBDIR"
-mkdir -p $DIR
-checkError 254 "Failed to create job directory $DIR"
-log "Created job directory: $DIR"
-logstate "CREATE_INPUTDIR"
-for D in $DIRS ; do
-	mkdir -p "$DIR/$D" 2>&1 >>"$INFO"
-	checkError 254 "Failed to create input directory $D"
-	log "Created output directory: $DIR/$D"
-done
-logstate "LINK_INPUTS"
-for L in $INF ; do
-	if [ $COPYNOTLINK = 1 ]; then
-		cp "$PWD/shared/$L" "$DIR/$L" 2>&1 >& $INFO
-		checkError 254 "Failed to copy input file $L"
-		log "Copied input: $PWD/shared/$L to $DIR/$L"
-	else
-		ln -s "$PWD/shared/$L" "$DIR/$L" 2>&1 >& $INFO
-		checkError 254 "Failed to link input file $L"
-		log "Linked input: $PWD/shared/$L to $DIR/$L"
-	fi
-done
-logstate "EXECUTE"
-cd $DIR
-#ls >>$WRAPPERLOG
-if [ ! -f "$EXEC" ]; then
-	fail 254 "The executable $EXEC does not exist"
-fi
-if [ ! -x "$EXEC" ]; then
-	fail 254 "The executable $EXEC does not have the executable bit set"
-fi
-if [ "$KICKSTART" == "" ]; then
-	if [ "$STDIN" == "" ]; then
-		"$EXEC" "$@" 1>"$STDOUT" 2>"$STDERR"
-	else
-		"$EXEC" "$@" 1>"$STDOUT" 2>"$STDERR" <"$STDIN"
-	fi
-	checkError $? "Exit code $?"
-else
-	if [ ! -f "$KICKSTART" ]; then
-		log "Kickstart executable ($KICKSTART) not found"
-		fail 254 "The Kickstart executable ($KICKSTART) was not found"
-	elif [ ! -x "$KICKSTART" ]; then
-		log "Kickstart executable ($KICKSTART) is not executable"
-		fail 254 "The Kickstart executable ($KICKSTART) does not have the executable bit set"
-	else
-		mkdir -p $WFDIR/kickstart/$JOBDIR
-		log "Using Kickstart ($KICKSTART)"
-			"$KICKSTART" -H -o "$STDOUT" -e "$STDERR" "$EXEC" "$@" 1>kickstart.xml 2>"$STDERR"
-		else
-			"$KICKSTART" -H -o "$STDOUT" -i "$STDIN" -e "$STDERR" "$EXEC" "$@" 1>kickstart.xml 2>"$STDERR"
-		fi
-		export APPEXIT=$?
-		mv -f kickstart.xml "$WFDIR/kickstart/$JOBDIR/$ID-kickstart.xml" 2>&1 >& "$INFO"
-		checkError 254 "Failed to copy Kickstart record to shared directory"
-		if [ "$APPEXIT" != "0" ]; then
-			fail $APPEXIT "Exit code $APPEXIT"
-		fi
-	fi
-fi
-cd $WFDIR
-log "Moving back to workflow directory $WFDIR"
-logstate "EXECUTE_DONE"
-log "Job ran successfully"
-MISSING=
-for O in $OUTF ; do
-	if [ ! -f "$DIR/$O" ]; then
-		if [ "$MISSING" == "" ]; then
-			MISSING=$O
-		else
-			MISSING="$MISSING, $O"
-		fi
-	fi
-done
-if [ "$MISSING" != "" ]; then
-	fail 254 "The following output files were not created by the application: $MISSING"
-fi
-logstate "COPYING_OUTPUTS"
-	cp "$DIR/$O" "shared/$O" 2>&1 >& "$INFO"
-	checkError 254 "Failed to copy output file $O to shared directory"
-done
-logstate "RM_JOBDIR"
-rm -rf "$DIR" 2>&1 >& "$INFO"
-checkError 254 "Failed to remove job directory $DIR"
-	logstate "TOUCH_SUCCESS"
-	touch status/${JOBDIR}/${ID}-success
-fi
-logstate "END"
-closeinfo
-# ensure we exit with a 0 after a successful exection
-exit 0
Modified: trunk/src/org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java
--- trunk/src/org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java	2009-03-27 08:47:39 UTC (rev 2746)
+++ trunk/src/org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java	2009-03-27 20:24:17 UTC (rev 2747)
@@ -225,7 +225,7 @@
 					JobSpecification js = new JobSpecificationImpl();
 					t.setSpecification(js);
 					js.setExecutable("/bin/sh");
-					js.addArgument("shared/seq.sh");
+					js.addArgument("shared/_swiftseq");
 					js.addArgument("cluster-"+thisClusterId);
 					js.addArgument("/clusters/"); // slice path more here TODO
 					js.setDirectory(dir);
Modified: trunk/src/org/griphyn/vdl/karajan/VDSTaskTransformer.java
--- trunk/src/org/griphyn/vdl/karajan/VDSTaskTransformer.java	2009-03-27 08:47:39 UTC (rev 2746)
+++ trunk/src/org/griphyn/vdl/karajan/VDSTaskTransformer.java	2009-03-27 20:24:17 UTC (rev 2747)
@@ -126,8 +126,8 @@
 				VDL2Config config = VDL2Config.getConfig();
 				if(config.getProperty("wrapper.invocation.mode", bc).equals("absolute")
-			 	 &&(executable.endsWith("shared/wrapper.sh")
-			   	  || executable.endsWith("shared/seq.sh"))) {
+			 	 &&(executable.endsWith("shared/_swiftwrap")
+			   	  || executable.endsWith("shared/_swiftseq"))) {
 				String s  = spec.getDirectory()+"/"+executable;
 				l.set(0,s);
