[Swift-commit] r2710 - nmi-build-test/submit-machine/daily
Fri Mar 20 04:42:00 CDT 2009
Author: benc
Date: 2009-03-20 04:41:59 -0500 (Fri, 20 Mar 2009)
New Revision: 2710
Modified:
   nmi-build-test/submit-machine/daily/kickstart-HEAD.submit
   nmi-build-test/submit-machine/daily/kickstart-many.submit
   nmi-build-test/submit-machine/daily/swift-java-1.4.2_05-coaster.submit
   nmi-build-test/submit-machine/daily/swift-java-1.4.2_05-deef.submit
   nmi-build-test/submit-machine/daily/swift-java-1.4.2_05.submit
   nmi-build-test/submit-machine/daily/swift-java-1.5.0_08.submit
Log:
remove some platforms that apparently no longer exist
Modified: nmi-build-test/submit-machine/daily/kickstart-HEAD.submit
--- nmi-build-test/submit-machine/daily/kickstart-HEAD.submit	2009-03-20 04:53:43 UTC (rev 2709)
+++ nmi-build-test/submit-machine/daily/kickstart-HEAD.submit	2009-03-20 09:41:59 UTC (rev 2710)
@@ -9,7 +9,7 @@
 remote_task = nmi-build-test/kickstart-build
-platforms = x86_fc_3, x86_fc_4, x86_fc_5, x86_cent_4.2, x86_64_fc_4, x86_64_fc_5, x86_macos_10.4, ppc_macos_10.4, x86_deb_3.1
+platforms = x86_fc_5, x86_cent_4.2, x86_64_fc_4, x86_64_fc_5, x86_macos_10.4, ppc_macos_10.4, x86_deb_3.1
 # these two don't build kickstart: x86_64_deb_4.0 x86_deb_4.0
Modified: nmi-build-test/submit-machine/daily/kickstart-many.submit
--- nmi-build-test/submit-machine/daily/kickstart-many.submit	2009-03-20 04:53:43 UTC (rev 2709)
+++ nmi-build-test/submit-machine/daily/kickstart-many.submit	2009-03-20 09:41:59 UTC (rev 2710)
@@ -9,7 +9,7 @@
-platforms = x86_suse_10.2, x86_rhas_3, x86_cent_4.2, x86_rhas_4, x86_suse_10.0, x86_64_sles_9, x86_sl_4.4, ppc_ydl_3.0, ia64_sles_9, ia64_rhas_4, x86_sles_8, x86_64_fc_4, x86_fc_2, x86_fc_3, ia64_sles_8, ps3_ydl_5.0, x86_rh_8.0, ia64_rhas_3, x86_fc_5, x86_deb_3.1, x86_rh_9, ppc_macos_10.4, x86_64_rhas_3, x86_slf_3, x86_deb_4.0, x86_64_rhas_4, x86_64_fc_5, ppc64_sles_9, x86_64_deb_4.0, x86_fc_4, x86_macos_10.4, x86_rh_7.2, x86_ubuntu_5.10, x86_sles_9, x86_64_sles_8
+platforms = x86_suse_10.2, x86_rhas_3, x86_cent_4.2, x86_rhas_4, x86_suse_10.0, x86_64_sles_9, x86_sl_4.4, ia64_sles_9, ia64_rhas_4, x86_sles_8, x86_64_fc_4, ia64_sles_8, ps3_ydl_5.0, ia64_rhas_3, x86_fc_5, x86_deb_3.1, ppc_macos_10.4, x86_64_rhas_3, x86_slf_3, x86_deb_4.0, x86_64_rhas_4, x86_64_fc_5, ppc64_sles_9, x86_64_deb_4.0, x86_macos_10.4, x86_ubuntu_5.10, x86_sles_9, x86_64_sles_8
 # remove x86_slc_3 because it seems to hang too long...
Modified: nmi-build-test/submit-machine/daily/swift-java-1.4.2_05-coaster.submit
--- nmi-build-test/submit-machine/daily/swift-java-1.4.2_05-coaster.submit	2009-03-20 04:53:43 UTC (rev 2709)
+++ nmi-build-test/submit-machine/daily/swift-java-1.4.2_05-coaster.submit	2009-03-20 09:41:59 UTC (rev 2710)
@@ -9,7 +9,7 @@
 remote_task = nmi-build-test/coaster
-platforms = x86_cent_4.2, x86_rhas_4, x86_suse_10.0, x86_64_sles_9, ia64_sles_9, ia64_rhas_4, ppc_macos_10.3, x86_sles_8, x86_64_fc_4, x86_fc_2, x86_fc_3, ia64_sles_8, x86_rh_8.0, ia64_rhas_3, x86_deb_3.1, x86_rh_9, x86_64_rhas_3, x86_slf_3, x86_deb_4.0, x86_64_rhas_4, x86_64_deb_4.0, x86_fc_4, x86_rh_7.2, x86_ubuntu_5.10, x86_sles_9
+platforms = x86_cent_4.2, x86_rhas_4, x86_suse_10.0, x86_64_sles_9, ia64_sles_9, ia64_rhas_4, x86_sles_8, x86_64_fc_4, ia64_sles_8, ia64_rhas_3, x86_deb_3.1, x86_64_rhas_3, x86_slf_3, x86_deb_4.0, x86_64_rhas_4, x86_64_deb_4.0, x86_ubuntu_5.10, x86_sles_9
 # these machines don't match requirements at 2008-05-25:
 # x86_sl_4.4 x86_slc_3
Modified: nmi-build-test/submit-machine/daily/swift-java-1.4.2_05-deef.submit
--- nmi-build-test/submit-machine/daily/swift-java-1.4.2_05-deef.submit	2009-03-20 04:53:43 UTC (rev 2709)
+++ nmi-build-test/submit-machine/daily/swift-java-1.4.2_05-deef.submit	2009-03-20 09:41:59 UTC (rev 2710)
@@ -9,7 +9,7 @@
 remote_task = nmi-build-test/with-deef
-platforms = x86_cent_4.2, x86_rhas_4, x86_suse_10.0, x86_64_sles_9, ia64_sles_9, ia64_rhas_4, x86_sles_8, x86_64_fc_4, x86_fc_2, x86_fc_3, ia64_sles_8, x86_rh_8.0, ia64_rhas_3, x86_deb_3.1, x86_rh_9, x86_64_rhas_3, x86_slf_3, x86_deb_4.0, x86_64_rhas_4, x86_64_deb_4.0, x86_fc_4, x86_rh_7.2, x86_ubuntu_5.10, x86_sles_9
 notify = benc at hawaga.org.uk
Modified: nmi-build-test/submit-machine/daily/swift-java-1.4.2_05.submit
--- nmi-build-test/submit-machine/daily/swift-java-1.4.2_05.submit	2009-03-20 04:53:43 UTC (rev 2709)
+++ nmi-build-test/submit-machine/daily/swift-java-1.4.2_05.submit	2009-03-20 09:41:59 UTC (rev 2710)
@@ -9,7 +9,7 @@
 remote_task = nmi-build-test/main
 # removed ppc_macos_10.3 - swift doesn't build on that and it can be an
 # unsupported platform
Modified: nmi-build-test/submit-machine/daily/swift-java-1.5.0_08.submit
--- nmi-build-test/submit-machine/daily/swift-java-1.5.0_08.submit	2009-03-20 04:53:43 UTC (rev 2709)
+++ nmi-build-test/submit-machine/daily/swift-java-1.5.0_08.submit	2009-03-20 09:41:59 UTC (rev 2710)
@@ -14,7 +14,7 @@
 #platforms = x86_fc_3, x86_fc_4, x86_fc_5, x86_cent_4.2, x86_64_fc_4, x86_64_fc_5, x86_macos_10.4, ppc_macos_10.4, x86_deb_3.1
 #platforms = x86_fc_3, x86_fc_4, x86_fc_5, x86_cent_4.2, x86_64_fc_4, x86_64_fc_5, x86_deb_3.1, ps3_ydl_5.0
-platforms = x86_fc_3, x86_fc_4, x86_fc_5, x86_cent_4.2, x86_64_fc_4, x86_64_fc_5, x86_deb_3.1
+platforms = x86_fc_5, x86_cent_4.2, x86_64_fc_4, x86_64_fc_5, x86_deb_3.1
 remote_task_timeout = 240m
