[Swift-commit] r2707 - in trunk: resources src/org/griphyn/vdl/engine tests/language-behaviour
Wed Mar 18 07:30:54 CDT 2009
Author: benc
Date: 2009-03-18 07:30:51 -0500 (Wed, 18 Mar 2009)
New Revision: 2707
Added:
   trunk/tests/language-behaviour/00261-function-param-file.in
   trunk/tests/language-behaviour/00261-function-param-file.swift
   trunk/tests/language-behaviour/00262-function-param-file-many.in
   trunk/tests/language-behaviour/00262-function-param-file-many.swift
Modified:
   trunk/resources/Karajan.stg
   trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
Intermediate datasets were not mapped, so worked for procedures
that returned in-memory values but not files. This commit maps them
using the concurrent mapper, like file variables.
Modified: trunk/resources/Karajan.stg
--- trunk/resources/Karajan.stg	2009-03-17 19:11:54 UTC (rev 2706)
+++ trunk/resources/Karajan.stg	2009-03-18 12:30:51 UTC (rev 2707)
@@ -294,10 +294,14 @@
    </vdl:setfieldvalue>
-callexpr(call, datatype, callID) ::= <<
+callexpr(call, datatype, callID, prefix) ::= <<
 <sequential>
 	<set name="swift#callintermediate">
-		<vdl:new type="$datatype$" dbgname="tmp"/>
+		<vdl:new type="$datatype$" dbgname="swift#callintermediate">
+			<vdl:mapping descriptor="concurrent_mapper">
+				<vdl:parameter name="prefix">_callintermediate-$prefix$</vdl:parameter>
+			</vdl:mapping>
+		</vdl:new>
 	</set>
 	$call$
 	<variable>swift#callintermediate</variable>
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2009-03-17 19:11:54 UTC (rev 2706)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2009-03-18 12:30:51 UTC (rev 2707)
@@ -1138,6 +1138,7 @@
 		    call.setAttribute("datatype", type);
 		    call.setAttribute("call", call(c, subscope, true));
 		    call.setAttribute("callID", new Integer(callID++));
+		    call.setAttribute("prefix", UUIDGenerator.getInstance().generateRandomBasedUUID().toString());
 		    return call;
 		} else {
 			throw new CompilationException("unknown expression implemented by class "+expression.getClass()+" with node name "+expressionQName +" and with content "+expression);
Added: trunk/tests/language-behaviour/00261-function-param-file.in
--- trunk/tests/language-behaviour/00261-function-param-file.in	                        (rev 0)
+++ trunk/tests/language-behaviour/00261-function-param-file.in	2009-03-18 12:30:51 UTC (rev 2707)
@@ -0,0 +1,4 @@
+a
+b
+c
+d
Added: trunk/tests/language-behaviour/00261-function-param-file.swift
--- trunk/tests/language-behaviour/00261-function-param-file.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/00261-function-param-file.swift	2009-03-18 12:30:51 UTC (rev 2707)
@@ -0,0 +1,14 @@
+type file;
+app (file editedParams) setTemps ( file inParams )
+cat stdin=@inParams stdout=@editedParams;
+file inParams<single_file_mapper; file="00261-function-param-file.in" >;
+string config [] = readData( setTemps(inParams ) );
+trace(0,config[0]);
+trace(1,config[1]);
Added: trunk/tests/language-behaviour/00262-function-param-file-many.in
--- trunk/tests/language-behaviour/00262-function-param-file-many.in	                        (rev 0)
+++ trunk/tests/language-behaviour/00262-function-param-file-many.in	2009-03-18 12:30:51 UTC (rev 2707)
@@ -0,0 +1,4 @@
+a
+b
+c
+d
Added: trunk/tests/language-behaviour/00262-function-param-file-many.swift
--- trunk/tests/language-behaviour/00262-function-param-file-many.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/00262-function-param-file-many.swift	2009-03-18 12:30:51 UTC (rev 2707)
@@ -0,0 +1,14 @@
+type file;
+app (file editedParams) cat ( file inParams )
+file inParams<single_file_mapper; file="00262-function-param-file-many.in" >;
+string config [] = readData( cat(cat(cat(inParams ) )));
