[Swift-commit] r2688 - provenancedb
Mon Mar 16 08:17:13 CDT 2009
Author: benc
Date: 2009-03-16 08:17:12 -0500 (Mon, 16 Mar 2009)
New Revision: 2688
Modified:
   provenancedb/drive-opm
   provenancedb/import-all
   provenancedb/paths.source.ci
   provenancedb/paths.source.soju
Log:
Remove expectation that log-processing lives in its own directory, as since
Swift r2683 that has been in the main Swift codebase.
Modified: provenancedb/drive-opm
--- provenancedb/drive-opm	2009-03-16 13:16:17 UTC (rev 2687)
+++ provenancedb/drive-opm	2009-03-16 13:17:12 UTC (rev 2688)
@@ -4,7 +4,7 @@
 filename=$1
-export PATH=$LOGPATH:$PATH
+export PATH=$PATH
 echo log to OPM conversion for $filename
Modified: provenancedb/import-all
--- provenancedb/import-all	2009-03-16 13:16:17 UTC (rev 2687)
+++ provenancedb/import-all	2009-03-16 13:17:12 UTC (rev 2688)
@@ -6,7 +6,7 @@
 # of individual runs will clean other files.
 source paths.source
-export PATH=$LOGDIR:$PROVDIR:$PATH
+export PATH=$PROVDIR:$PATH
 swift-plot-log $LOGREPO everylog-vs-versions.data
Modified: provenancedb/paths.source.ci
--- provenancedb/paths.source.ci	2009-03-16 13:16:17 UTC (rev 2687)
+++ provenancedb/paths.source.ci	2009-03-16 13:17:12 UTC (rev 2688)
@@ -1,10 +1,6 @@
 # file to source that sets variables for the various paths that are
 # presently hardcoded
-# this assumes that log-procesisng module is checked out in same place in
-# relation to provenancedb as in the SVN.
-export LOGDIR=`pwd`/../log-processing/
 # this is the path to log repo on benc's laptop
 export LOGREPO=~/swift-logs/
Modified: provenancedb/paths.source.soju
--- provenancedb/paths.source.soju	2009-03-16 13:16:17 UTC (rev 2687)
+++ provenancedb/paths.source.soju	2009-03-16 13:17:12 UTC (rev 2688)
@@ -1,10 +1,6 @@
 export LOGREPO=/Users/benc/work/everylog/
 export IDIR=/Users/benc/work/everylog/
