[Swift-commit] r2666 - trunk/src/org/griphyn/vdl/engine
Mon Mar 9 11:03:35 CDT 2009
Author: hategan
Date: 2009-03-09 11:03:35 -0500 (Mon, 09 Mar 2009)
New Revision: 2666
Modified:
   trunk/src/org/griphyn/vdl/engine/Karajan.java
   trunk/src/org/griphyn/vdl/engine/VariableScope.java
Log:
fixed nested procedure calls causing variable redefinition error
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2009-03-09 15:23:13 UTC (rev 2665)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2009-03-09 16:03:35 UTC (rev 2666)
@@ -1131,7 +1131,7 @@
 		    StringTemplate call = template("callexpr");
 		    String type = funcSignature.getOutputArray(0).getType();
-		    subscope.addVariable("swift#callintermediate", type);
+		    subscope.addInternalVariable("swift#callintermediate", type);
 		    call.setAttribute("datatype", type);
 		    call.setAttribute("call", call(c, subscope, true));
Modified: trunk/src/org/griphyn/vdl/engine/VariableScope.java
--- trunk/src/org/griphyn/vdl/engine/VariableScope.java	2009-03-09 15:23:13 UTC (rev 2665)
+++ trunk/src/org/griphyn/vdl/engine/VariableScope.java	2009-03-09 16:03:35 UTC (rev 2666)
@@ -91,8 +91,24 @@
 		varTypes.put(name, type);
 		if(!added) throw new CompilationException("Could not add variable "+name+" to scope.");
+	 * Does pretty much the same as addVariable() except it doesn't throw
+	 * an exception if the variable is defined in a parent scope
+	public void addInternalVariable(String name, String type) throws CompilationException {
+		logger.info("Adding internal variable " + name + " of type " + type + " to scope " + hashCode());
+		if(isVariableLocallyDefined(name)) {
+			throw new CompilationException("Variable " + name + " is already defined.");
+		boolean added = variables.add(name);
+		varTypes.put(name, type);
+		if(!added) throw new CompilationException("Could not add variable "+name+" to scope.");
 	public boolean isVariableDefined(String name) {
 		if(isVariableLocallyDefined(name)) return true;
 		if(parentScope != null && parentScope.isVariableDefined(name)) return true;
